VWVortex.com - What are the signs/symptoms of bad control arm bushings?
    Results 1 to 9 of 9
    Thread: What are the signs/symptoms of bad control arm bushings?
    1. Awaiting Email Confirmation Dubluva's Avatar
      Sep 15th, 2002
      04-27-2010 12:20 PM #1
      I've noticed that all of my wheels seem to be wearing excessively only on the inside edge. I know this could be an alignment problem, but before I do that I wanted to see if this was a sign of bad control arms. I have no knocking or suspension creaking when driving, however some of the rubber bushings in the front lower control arms is cracking. The car has 194K so it may just be time to replace them, but money is tight and if an alignment will prolong having to replace them, I may have to do that for now, and then tackle the control arms later.
      Thanks
    2. Member jamespav's Avatar
      Dec 31st, 2007
      Flemington NJ
      B5 A4 c5 a6
      04-27-2010 02:12 PM #2
      Is your car lowered?
      FS: Hinson racing clutch basket for 2003 kx250 will fit other stuff...pm if interested
      Jan 30th, 2007
      98 A4 + 83 GTI
      04-27-2010 03:35 PM #3
      If you're going to change the control arms, do the alignment afterwards
      clean 99 mk3 jetta for sale. 130k James_Le_Mans instagram.
    4. Awaiting Email Confirmation Dubluva's Avatar
      Sep 15th, 2002
      04-28-2010 04:57 PM #4
      no its not lowered. OEM sport suspension and factory wheels. I was planning to align it after the control arms if they need to be done. This is one of the tires that I think came from the right rear. Not all of them are this bad, but they all have excessive wear on that inside edge similar to the way this one is worn.
      sucks
      Modified by Dubluva at 4:16 PM 4-28-2010
    5. Member thepirate's Avatar
      Jun 5th, 2008
      Houston, TX
      Chopped up B5
      04-28-2010 10:55 PM #5
      Looks like it needs an alignment. Usually bad control arms make squeaking noises when you go over bumps or turn.
    6. 04-28-2010 11:00 PM #6
      Did my control arms about 10k miles ago.
      What my control arms did was every time you go over say a speed bump, or a small bump, you get a clunking sound. As if nothing big but just some clunk from the front end. It would also feel a little loose when jacked up in the air.
      The picture looks like your victim to a bad alignment
    7. 04-28-2010 11:47 PM #7
      definitely alignment. I havent heard of control arms causing -2 degree camber. Maybe it happens but so far i havent seen it. And camber is adjusted by shifting the cradle, the arms just follow in the motion.
    8. 04-29-2010 11:23 AM #8
      alignment
    9. Awaiting Email Confirmation Dubluva's Avatar
      Sep 15th, 2002
      05-01-2010 12:30 AM #9
      thanks....i'll take it in and git'r done!!
