Results 1 to 12 of 12
Thread: Vag-com scan code question
  1. Member hammergears's Avatar
    Jan 8th, 2009
    Sacramento,California
    GLS GTi
    04-28-2010 02:12 AM #1
    17069 - ECM Power Relay Control Circuit (J271): Open Circuit
    P0685 - 35-00 - -
    Readiness: 0110 1101
    Getting this engine code, Anyone know causes??
    Garrett T3/T4 50trim .63 ar dual ball bearing, TiAL 38mm, eurojet FMIC, walbro 255, siemens 630cc, Eurodyne/Maestro to name a few...
    hammergears@gmail.com
  2. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    04-28-2010 09:34 AM #2
    That's typically a problem with the ECM Power Relay or a power supply problem, such as a fuse for the ECM Power Relay. Does the car run?
    Dana Marie
    P.S. No Scan = No Soup
  3. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    04-28-2010 10:00 AM #3
    No it doesn't, i have a few wiring harness plugs unplugged like the o2 after the cat, and the ECM was unplugged and unplugged from the battery, does this mean I have to get it coded from the dealer? What other possibilities does this code mean?
  4. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    04-28-2010 07:25 PM #4
  5. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    04-28-2010 09:35 PM #5
    Please post the complete Auto-Scan so we can see all of the details. Have you checked fuses and the power supply relay?
    Modified by Dana @ Ross-Tech at 9:37 PM 4-28-2010
    Dana Marie
  6. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    04-29-2010 07:41 PM #6
    No fuses appear to be bad, any specifics fuses to check?? this ecm is new so will it need to be coded to my car by dealer or can i do it with vag-com? I heard that the throttle body and or ecm must be coded, true?false? here is the scan
    Thursday,29,April,2010,16:41:18:48776
    VCDS Version: Release 908.2
    Data version: 20100326
    Chassis Type: 1J - VW Golf/Bora IV
    Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
    76
    Mileage: 195390km/121409miles
    Address 01: Engine Labels: 06A-906-032-AWP.lbl
    Part No: 06A 906 032 HS
    Component: 1.8L R4/5VT G 0008
    Coding: 07500
    Shop #: WSC 00066
    3VWSE69M52M154493 VWZ7Z0A4703431
    1 Fault Found:
    P0685 - 35-00 - -
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 P
    Component: ABS 20 IE CAN 0001
    Coding: 03504
    Shop #: WSC 00066
    No fault code found.
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 A
    Component: 09 AIRBAG VW5 0003
    Coding: 12345
    Shop #: WSC 01317
    Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
    Part No: 1J0 920 900 J
    Component: A4-KOMBIINSTR. VDO V18
    Coding: 07242
    Shop #: WSC 26111
    Part No: IMMO
    Component: IDENTNR: VWZ7Z0X1832281
    IMMO-IDENTNR: VWZ7Z0X1832281
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01317
    Address 46: Central Conv. Labels: 1J0-959-799.lbl
    Part No: 1J0 959 799 AJ
    Component: 61 Zentral-SG Komf. 0001
    Coding: 04096
    Shop #: WSC 00066
    Part No: 1J1959801C
    Component: 60 Tõrsteuerger. FS0002r
    Part No: 1J1959802D
    Component: 60 Tõrsteuerger. BF0002r
    Part No: 1J4959811C
    Component: 60 Tõrsteuerger. HL0002r
    Part No: 1J4959812C
    Component: 60 Tõrsteuerger. HR0002r
    End ---------------------------------------------------------------------
  7. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    04-29-2010 11:08 PM #7
  8. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    04-30-2010 12:12 AM #8
    Quote, originally posted by hammergears »
    Please quit bumping your thread.
    That looks like an Immo III ECM out of a '02 AWP in an Immo. II vehicle. I doubt your dealer will be able to program that.
    http://www.ross-tech.com/vag-c....html
    I would recommend checking your repair manual and comparing wiring diagrams to see if the power supply problem is due to incorrect wiring. Based on the scan it looks like that car had an AWD engine.
    I wouldn't be concerned with the TBA at this time. It should be done after all faults are cleared. http://wiki.ross-tech.com/wiki...BA%29
    Dana Marie
  9. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    04-30-2010 11:03 PM #9
    Yes this motor is a 2002 AWP that went into a 2000 golf gls chassis, would you know where this fault could be happening in a situation like this?? if not any specific areas to check? thanks
  10. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    05-12-2010 07:35 PM #10
    Okay needed a 428 relay for ECM power ** installed code cleared and hasn't returned, could that have been the epc issue?
  11. Member hammergears's Avatar
    Jan 8th, 2009
    GLS GTi
    05-12-2010 07:38 PM #11
    EPC light is still illuminated but relay replaced. That code hasn't returned but the car hasn't started either. There is an immobilser defeat on my ECM so the immobiliser is no longer an issue, any ideas? All wiring within the engine bay is for the specific year, from what I have checked the spark plugs are not sparking and the fuel injectors are not spraying although the fuel pump does prime.
    Friday,14,May,2010,17:16:55:48776
    76
    Component: 1.8L R4/5VT G01*0008
    Coding: 11510
    Shop #: WSC 10002
    XXXXXXXXXXXXXXXXX XXXXXXXXXXXXXX
    1 Fault Found:
    16955 - Brake Switch (F): Implausible Signal
    P0571 - 35-00 - -
    Coding: 03504
    Shop #: WSC 00066
    Coding: 12345
    Shop #: WSC 01317
    Coding: 07242
    Shop #: WSC 26111
    Part No: IMMO
    Coding: 00006
    Shop #: WSC 01317
    Coding: 04096
    Shop #: WSC 00066
    Part No: 1J1959801C
    Part No: 1J1959802D
    Part No: 1J4959811C
    Part No: 1J4959812C
  12. Member mazen...'s Avatar
    Sep 30th, 2008
    jeddah,saudia arabia
    golf MK4
    01-20-2012 03:40 AM #12
    is that after you swapped your ecu?
