VWVortex.com - two faults....01521 and 02084
    Results 1 to 4 of 4
    Thread: two faults....01521 and 02084
    1. Member wolfsburg__gli's Avatar
      Feb 24th, 2009
      Orlando / Boca
      84' Mercedes 300SD - 87' BMW 535iS
      04-28-2010 01:18 PM #1
      i ran a scan on my 2009 Wolfsburg 2.0T DSG
      i got these two codes.....need help on how there are a problem...and how to fix it
      first
      Tuesday,27,April,2010,17:01:02:32041
      VCDS Version: Release 908.2
      Address 02: Auto Trans Labels: 02E-300-0xx.lbl
      Control Module Part Number: 02E 300 051 C HW: 02E 927 770 AJ
      Component and/or Version: GSG DSG AG6 431 1816
      Software Coding: 0000020
      Work Shop Code: WSC 02069 000 90108
      1 Fault Found:
      02084 - Component Protection
      000 - - - Intermittent
      Freeze Frame:
      Fault Status: 00100000
      Fault Priority: 0
      Reset counter: 35
      Mileage: 13574 km
      Time Indication: 0
      second
      Tuesday,27,April,2010,17:03:22:32041
      Address 65: Tire Pressure Labels: 3C0-959-433-65.lbl
      Control Module Part Number: 1K0 959 433 CT HW: 1K0 959 433 CT
      Component and/or Version: RDK 0450
      Software Coding: 0100101
      Work Shop Code: WSC 00066 000 00000
      1 Fault Found:
      01521 - Sensor for Tire Pressure
      004 - No Signal/Communication - Intermittent
      Freeze Frame:
      Fault Status: 00100100
      Fault Priority: 4
      Fault Frequency: 5
      Reset counter: 115
      Mileage: 27346 km
      Time Indication: 0
      Date: 2000.00.00
      Time: 16:41:13
      IG @tbmikeeee
      I VAG-COM IN SOUTH FLORIDA & ORLANDO PM ME
    2. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      02 Gti, 12 Tiggy SEL
      04-29-2010 10:30 AM #2
      Since both of the faults are Intermittent clear them and see if they come back. I don't have an explanation for the Trans. fault. Was any transmission work done to the car recently?
      If the TPMS sensor was still off line, the fault shouldn't be intermittent and the TPMS light would be on. You could look at the Measuring Blocks in 65 - Tire Pressure, but I would expect everything to be normal at this time.
      Dana Marie
      P.S. No Scan = No Soup
    3. Member pavlo1994's Avatar
      May 8th, 2009
      New Jersey
      08 Rabbit
      06-03-2011 11:08 PM #3
      How would i know which wheel is the code coming from?
      Both of the people in the Jetta had a large lunch that day. 2 omgwtfbbq sandwiches with lolslaw and 2 sides of roflfries = 7.3lbs-.05 for digestive breakdown=6.8lbs! Power to weight ratio bishes!!!
    4. Forum Sponsor Dana @ Ross-Tech's Avatar
      Sep 15th, 2009
      Apollo, PA
      06-04-2011 12:31 AM #4
      If you are asking about the 2008 Rabbit, that vehicle does not use wheel position recognition so this will help:
      http://wiki.ross-tech.com/wiki/index...on_Recognition
      Dana Marie
