VWVortex.com - Marvel Mystery Oil - Anyone Ever Used It?
    The Car Lounge
    Page 1 of 3 123 LastLast
    Results 1 to 25 of 64
    Thread: Marvel Mystery Oil - Anyone Ever Used It?
    1. Member tincanman99's Avatar
      Oct 19th, 2000
      1990 Golf GL, 2007 Audi A3
      04-30-2010 10:46 AM #1
      Contemplating putting it in my 90 Golf. Have heard it makes the engine happy and removes deposits and such.
    2. Member LA7VJetta's Avatar
      Jul 21st, 2009
      1985 Mercedes 190D
      04-30-2010 10:47 AM #2
      i have used it in mowers and ****, not sure if it worked or not. seems to help in 2 strokes for lubrication, though.
    3. Member tincanman99's Avatar
      Oct 19th, 2000
      04-30-2010 10:50 AM #3
      My dad says its the deal. He said they used it back in the day and it will make the engine last forever.
    4. Member CodeMan's Avatar
      May 12th, 2006
      Westminster, CO
      Scirocco 16v, E34 540i, V50 T5 AWD
      04-30-2010 10:51 AM #4
      My Scirocco had been sitting for a year and the CIS-e was completely gummed up and would only run for 45-60 seconds. At the suggestion of vwdaun I dumped half a bottle of MMO in my tank. 3 starts later and my fuel distributer was de-gummified. Been running like a top since.
      MMO [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    5. Member TheTimob's Avatar
      Sep 13th, 2003
      Divide, CO
      84 Scirocco, 13 Prius C, 00 Celica, 2x 94 Camrys
      04-30-2010 10:53 AM #5
      I think of Marvel Mystery oil as something good to put a few ounces into the spark plug holes of an engine right before an extended storage period, such as parking a car, or winterizing lawn equipment. It keeps the rings from sticking to the cylinder walls, and it keeps moisture from rusting ridges around the pistons.
      But nowadays, there are many competing "Upper Cylinder Lubricant" type of products. These are not to be confused with fuel injector cleaner type products. Lucas (the oil company) makes one of the top selling ones.
    6. 04-30-2010 11:31 AM #6
      I run this in all 3 of my 4 wheelers (all 2 strokers) and I have yet see an issue. I also run this in my El Camino - both gas and oil. Keeps the sludgification from starting.
    7. 04-30-2010 11:34 AM #7
      the sheet works!
      i've used it to codition engines that have been i storage.
      it quieted the weak valve in my type 4.
      it helped my beat to snot gto live longer than it should have.
      it certainly won't hurt anything.
    8. Geriatric Member BRealistic's Avatar
      Dec 16th, 2005
      East-10EC
      88 F150, 04 RX8, 96 T&C LXi
      04-30-2010 11:35 AM #8
      yes.
      In everything from cars, trucks to lawnmowers.
      removed because realized just as annoying as the people that refuse to turn off their phone app's auto-spam with every post.
    9. 04-30-2010 12:24 PM #9
      yeah, figured it can't hurt. I'd have to do a teardown to see if it really helped.
    10. 04-30-2010 12:33 PM #10
      I have used it on several older cars with decent results. Many a vintage Ferrari owner has turned to Marvel's to fend off a dreaded $25k motor rebuild.
      I remember reading an article where Keith Martin (www.sportscarmarket.com) used it in a 330 GT he had bought that had been sitting for quite awhile with great results.
    11. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      '66 Beetle (X2) '08 Fit
      04-30-2010 12:35 PM #11
      my standard answer is that I don't put anything in my oil except oil... and BG products, ZDDP additive and Marvel Mystery Oil. I can't think of another additive that I'd use. MMO is good stuff! [IMG]http://*****************.com/smile/emthup.gif[/IMG]
      MMO is also the lubricant for the old Judson Supercharger. These were little vane type superchargers for imported cars in the '60s. Naturally, I'm most familiar with the VW version. Notice in the photo that the container on the left has it right in there. The nice thing is that it not only lubes the supercharger, it keeps the valves clean, too!
    12. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      04-30-2010 12:37 PM #12
      Quote, originally posted by tgodbout »
      I could believe it. If I were tinkering with an old engine that had been sitting for quite a while, I'd pull the plugs and put it in there and let it sit for a day or two before trying to move it. If I were in a pinch, I'd use ATF, but I'd rather use MMO.
    13. 04-30-2010 12:41 PM #13
      Quote, originally posted by Air and water do mix »
      a friend of mine told me to use atf over mmo, but i didn't like the sound of that. only problem was that the engine was a 1915cc aircooled, so i poored it in the plug holes, then it ran out the exhaust ports! doh! lol
      it's still in the garage, that mofo is gonna smoke like a mutha when i start it up.
    14. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      05-04-2010 01:26 PM #14
      Quote, originally posted by water&air »
      Horizontally opposed engines ftw! When I build them, I always make sure that the oil ring has it's gap at the top!
    15. Senior Member ClockworkChad's Avatar
      Mar 21st, 2003
      NY
      b6 a4 stg 3+
      05-04-2010 01:43 PM #15
      my old vr6 jetta had an oil pump that didnt like to work from hitting one to many road obstacles (many oils pans done on that thing) - but with a little MMO with the oil change it kept it working fine with the oil temp in the right range.
    16. Member Mr Wolf's Avatar
      Feb 18th, 1999
      calgary.ab.ca
      1969 Porsche 912R, 1969 MB 280 SE coupe, 2004 Volvo XC70, 2010 Ford F-150
      05-04-2010 01:57 PM #16
      MMO is the cat's ass for fixing collapsed hydraulic lifters in the Vanagon engines. Throw a few ounces in, drive it for a 100 km or so, then do an oil change and it seems to clean the crap out and get the lifters quiet again.
      -Keith
      The to-do list is over 726 lines long. One day my cars will run again.
    17. Member Das Borgen's Avatar
      Sep 10th, 2008
      Columbus, OH
      1995 M3, 1999 740i "Short" Sport, 2000 Ducati 748
      05-04-2010 02:01 PM #17
      Seafoam is my snake oil of choice
      Quote Originally Posted by Das Borgen
      VR6s should sound like Chewbacca getting raped
      Dazzle Surprise - Team My Little Pony
    18. Member mr_e1974's Avatar
      Jun 5th, 2002
      Central, FL...the sunshine state
      2k1/VW/GTI 12v, 99 'Vette FRC
      05-04-2010 02:13 PM #18
      Quote, originally posted by Mr Wolf »
      I've got just under 200k miles on my 12v VR6 and I use MMO at every oil change. I've been running 4 3/4 quarts of synthetic oil and 1/4 quart of MMO at EVERY oil change for almost 100k miles and the thing runs like a top. MMO says that you can replace up to 20% of your "normal" oil with MMO on the package but I'm not sure about if that would be safe to do for long term. I should tear into the head and see how clean it is/isn't inside. I'm still on the original timing chains too so I may have to do them sooner or later and do some inspecting while I'm in there.
      "An AUDI is nothing more than a Volkswagen in a pretty prom dress."
      Stance will make her dance...well, try that "line" at da strip club
      Stretch is for sissies...REAL MEN love sticky meaty tires.
    19. Member sbvwfanatic's Avatar
      Aug 24th, 2004
      Santa Barbara
      09CW VW Rabbit w/19"BBS CKs, FK springs/shocks/struts
      05-04-2010 03:09 PM #19
      Just used it on an 83 4runner I picked up through a tow-yard lien sale. There was a pretty loud lifter knock and now it's down to a slightly annoying whisper. (Yeah, I know, I know, get the lifter fixed but it's a budget beater till my wife gets through nursing school.)
    20. Senior Member Air and water do mix's Avatar
      Aug 5th, 2004
      Southern Indiana
      05-04-2010 05:27 PM #20
      Quote, originally posted by sbvwfanatic »
      Don't worry too much about it. That's what a beater is for. Keep adding a little and see if it gets any quieter. [IMG]http://*****************.com/smile/emthup.gif[/IMG]
    21. Member rabbitinfife's Avatar
      Dec 22nd, 2007
      Fife,Wa
      A bunch of rusty Kraut cans
      02-15-2013 01:07 AM #21
      My 89 cabby has over 400 k on it I use some of this stuff every couple of months, a bit in the tank, a bit in the crankcase. Works wonders on the lifter tick helps tired hydraulic lifters, nearly eliminates it.
      I had a diesel rabbit years ago that I used to put a quart of that stuff in every other month half the quart in the crankcase half the quart in the fuel never had a single fuel problem ever. I drove the hell out of that thing too. All I ever did on it was the timing belt at regular intervals.
    22. Member rabbitinfife's Avatar
      Dec 22nd, 2007
      Fife,Wa
      02-15-2013 01:12 AM #22
      Most of the old timers I know that have been working on stuff for years swear by this stuff.
      My dad ran a fleet of semi trucks when I was a kid he ran this in every truck he had.
    23. Member rabbitinfife's Avatar
      Dec 22nd, 2007
      Fife,Wa
      02-18-2013 10:48 AM #23
      I swapped a motor into my golf yesterday fired it this motor hasn't ran in like 4 years. Right away the valves were clack a lacking like crazy even after running for 15 minutes and pumping up there was still one or two of them were quite loud. Added a half quart of mmo amazing no more noise.
    24. Member 01tj's Avatar
      Nov 8th, 2005
      WV
      12 Ecoboosted Flex, 11 6-speed quad cab Frontier, recently sold02 330i, 09 Flex, 01 Wrangler
      02-18-2013 10:52 AM #24
      Quote Originally Posted by Das Borgen View Post
      I've used seafoam, I've never got the big cloud but it does seem to smooth things out a bit. How do the two compare.
    25. Member
      May 7th, 2010
      Toronto, Canada
      2017 Golf R
      02-18-2013 10:54 AM #25
      How does it compare to this snake oil?
