Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 71 to 105 of 159
Thread: Come along way for one year and the lowest budget EVER!
  1. Member danderso's Avatar
    Oct 14th, 2008
    Colorado, The States
    Mk1 Cabby 16v
    10-30-2010 04:18 PM #71
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
  2. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    10-30-2010 04:19 PM #72
    Photobucket
    Photobucket
    Photobucket
  3. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    10-30-2010 04:21 PM #73
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
  4. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    10-30-2010 04:22 PM #74
    Photobucket
    Photobucket
    Photobucket
  5. Member nich.j.anderson's Avatar
    May 18th, 2008
    Westminster Colorado
    1997 Jetta GLX; 1988 Jetta; 1986 Jetta; 1981 Rabbit Cabby
    11-01-2010 11:21 PM #75
    Photobucket
    Photobucket
    Photobucket
    Photobucket
  6. Member nich.j.anderson's Avatar
    May 18th, 2008
    11-01-2010 11:24 PM #76
    Time to install a clutch and flywheel.
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
  7. Member nich.j.anderson's Avatar
    May 18th, 2008
    11-01-2010 11:26 PM #77
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Photobucket
    Jun 27th, 2008
    Olympia, WA
    11-02-2010 01:52 AM #78
    Mmmmmmmm
  9. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    11-04-2010 03:39 PM #79
    The starter gear from the flywheel came off while we were taking off the clutch, so after getting the entertainment of watching my brother trying to push it back on, I let him know that you need to heat the starter gear up then it will drop on the flywheel no problem. So we just dropped it in the barbeque for an hour or so. Then it just dropped on!
    You know you're low when:
    Quote Originally Posted by Bnana View Post
    you lol because piratehooker texted you saying she's stuck at the car wash
  10. 11-04-2010 04:30 PM #80
    Why did you cut off the flex points? There's a reason they were there. Your downpipe is probably going to break right at the flange.
  11. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    11-04-2010 04:58 PM #81
    Hopefully not! We didn't have enough room for the flex pipe. But the motor mounts are poly so there 'shouldn't' be much play
  12. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    84 VW Rabbit GTI, 84 VW Jetta Coupe
    12-30-2010 02:41 AM #82
    Any updates???
  13. Member nich.j.anderson's Avatar
    May 18th, 2008
    03-30-2011 02:11 PM #83
    Ahh updates...
    Well we put a clutch in and put the engine back in,
    we then struggled for weeks trying to get the correct pulley/alternator/belt set up
    then winter rolled in and we've just fiddled every now and again with it
    We'll get some pictures up soon.
  14. Member nich.j.anderson's Avatar
    May 18th, 2008
    03-30-2011 02:17 PM #84
    if you make a wiring harness from scratch that doesn't fallow the stock set up (plugging into relays vs the fuse panel) draw a wiring diagram
    Even if you use the correct color wires, you're going to forget what you did
    I don't care how clever you think you are
    It's easier drawing it as you're making it vs. going back and trying to trace wires to see what's going where.
    Especially when it's a mkII engine in a mkI with mkIII & mkIV wire and Saab relays(although relays are relays) I think that the contact with swedenism has an effect on them
  15. 03-30-2011 02:28 PM #85
    that exhaust is gonna snap
    I'm a giant.. My name is Matias
    Quote Originally Posted by WackyWabbitRacer View Post
    Yes...but let's pretend there is no internet and you have to fix the problem by thinking through a solution.
    Tell me your solution, and then I will give you my idea to fix the problem.
    Cheers, WWR.
  16. Member
    Nov 20th, 2010
    New Orleans LA
    1983 VW Rabbit GTI
    03-30-2011 03:09 PM #86
    Tons of good work!!! Keep it up!
    Is the a second gen gauge cluster??
  17. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    05-25-2011 10:49 AM #87
    Yes the gauge cluster is a second gen cluster!
    If the exhaust snaps then it will be replaced with a mk1 16v header, Techtonics cat, and a techtonics 2.25 cat-back.
  18. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    07-27-2011 04:41 PM #88
    little update:
    The car runs fine now. Needs a little bit of work! Projects are never finished! Passed emissions with our fake cat! I just had to mix a little E85 to lean it out a little, but just for the testing period.
    I took it to a tire shop to get new tires put on the front. Some kid went crazy with the torque wrench and stripped my hub. He also put the wrong wheel weights on, so on my way back to the shop they flew off!
    Anyway once I get it back its new tie rods and boots as well as a wheel bearing!
    I replaced the ghetto-fab fog with a HELIA (Hella knock-off)
    Compressed the Rear Bumper
    Eventually some 13x8's
    pictures will be uploaded soon
  19. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    12-29-2011 07:06 PM #89
    Just a couple of videos, taken in a remote area with no bystanders
    http://youtu.be/ECkrQyISRVw
    http://youtu.be/PeErW1kfgbE
    comments?
  20. Member Road Boss's Avatar
    Jul 15th, 2004
    Woodbridge, VA
    12-29-2011 07:47 PM #90
    Good job!
  21. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    12-29-2011 08:56 PM #91
    Thanks!
    Looking to get a deep duckbill now and some wheels!
  22. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    12-29-2011 10:22 PM #92
    holy special olympics welding batman!
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  23. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    12-29-2011 10:33 PM #93
    thank you!
    haha that's a $80 welder for you! Gets the job done but defiantly not pretty!
    But I still think this guy has me beat!
    http://forums.vwvortex.com/showthrea...-manifold-fail
  24. Banned vento86's Avatar
    Oct 13th, 2008
    12-29-2011 10:47 PM #94
    that.... exhaust...
  25. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    12-30-2011 12:08 AM #95
    Quote Originally Posted by vento86 View Post
    that.... exhaust...
    yay or nay?
  26. Member ducatipaso's Avatar
    Apr 13th, 2003
    norcal
    82 aaz pickup
    12-30-2011 12:50 AM #96
    wanted: early MK2 Golf or Jetta GTD rear badge -- any reasonable condition
    click
  27. Member tt_silver's Avatar
    Jul 14th, 2008
    DesMoines, WA
    01 Audi TT, 93 Corrado SLC, 83 Rabbit GTI
    12-30-2011 01:03 AM #97
    I dig it..
  28. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    12-30-2011 01:22 AM #98
    thanks guys!
  29. Member Pigsdofly's Avatar
    Mar 31st, 2004
    08 Husky 610sm, 01 Boxster, 23 Tbucket, 54 Corvette
    12-30-2011 01:53 AM #99
    I used to wipe my boogers in the armpit of my shirt but I found a new place to put them.
  30. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    12-31-2011 02:43 AM #100
    Quote Originally Posted by Pigsdofly View Post
    Holy ****!!!! You are alive!!!!
  31. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    12-31-2011 02:54 AM #101
    Quote Originally Posted by danderso View Post
    thank you!
    You just don't know how to weld...
  32. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    01-01-2012 04:35 AM #102
    Lets just say you get good at grinding before you get good at welding...
  33. Member T-Giv's Avatar
    Mar 13th, 2011
    Crawlorado
    1984 Rabbit 16V SOLD, 1982 Caddy 20V 1.8t, 2011 Jeep Wrangler JK
    01-01-2012 10:17 AM #103
    Good to see some Westminster boys getting hard at work! I'm down in Wheat Ridge but my 16v is not progressing very quickly. Keep up the good work!
  34. Member danderso's Avatar
    Oct 14th, 2008
    Mk1 Cabby 16v
    01-01-2012 04:52 PM #104
    Quote Originally Posted by T-Giv View Post
    Thanks! It's yours the mars red euro plastic bumper round headlights mk1?
  35. Member T-Giv's Avatar
    Mar 13th, 2011
    Crawlorado
    01-01-2012 10:42 PM #105
    That's the one. You'll have to come down and check it out. Once I get some things done on it we can go for a cruise of the upper west side.
