VWVortex.com - 16v crank pulley
    Results 1 to 20 of 20
    Thread: 16v crank pulley
    1. Junior Member
      Apr 1st, 2010
      Trenton, Ohio
      1991 Jetta GLI
      05-04-2010 07:32 PM #1
      I'm trying to replace my timing belt and can't figure how to remove the crank pulley. Is it right or left thread? The Bentley doesn't cover this, it just says to remove it. Any advice?
    2. Member rocconut's Avatar
      Feb 20th, 2004
      Montpelier VA
      16v Scirocco x 5 MKI GTI, MKII GTI 55 CHEVY
      05-06-2010 09:38 AM #2
      Turn your wrench to the left to loosen. you may have to squirt so PB Blast on it first.
    3. Member weejunGL's Avatar
      Feb 2nd, 2005
      Norwegen
      MKII 16vT Syncro
      05-06-2010 01:19 PM #3
      well, its probably rusted stuck, so use a rubber mallet, and knock the **** out of it and it will come loose
      there are speciality tools for this tho
    4. Member Sinner44's Avatar
      Oct 11th, 2006
      Reno, NV
      2003 1.8T GTI, 1.8 16VT GTI Project
      05-06-2010 08:53 PM #4
      Yeah use a ton of PB ....also make sure you throw that bolt away and buy a replacement..if youre worried about it shearing get the APR bolt for a Mit. Galant... if need be i can find the number for you...i used to have it saved, but since the original vortex went down i lost all my reference material lol
    5. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      05-07-2010 03:29 AM #5
      You don't have to remove the 19mm bolt to get the pullies off, just the four 6mm socket head bolts. The big one is for the crank sprocket and does not need to be removed to change the t-belt.
    6. Member
      Apr 2nd, 2003
      Richmond IN
      87 scirocco, 92 cabriolet
      05-07-2010 07:32 AM #6
      x2
      whack the v-belt pullies with a mallet and they will pop off omce you have the 4 allen bolts out.
      the crank pully is tight tight tight. youll need to drop the oil pan and block the crank to be able to put enough torque on that bolt to remove it.
    7. Junior Member
      Apr 1st, 2010
      Trenton, Ohio
      1991 Jetta GLI
      05-07-2010 08:22 AM #7
      My impact won't break it. Thanks for the advice.
    8. Member Sinner44's Avatar
      Oct 11th, 2006
      Reno, NV
      05-07-2010 11:38 AM #8
      Yeah you don't have to remove that bolt to take the vbelt pulley off and if you don't need to take that timing cog off I wouldn't lol
      Apr 2nd, 2003
      Richmond IN
      05-07-2010 04:35 PM #9
      an impact won't touch the crank bolt, it's @ something like 165 FTlbs. you need to block the crank and use a breaker bar and a couple foot extension.
      plus supposedly using an impact wrench on the crank and flywheel can damage your connecting rod bearings. which makes sense enough to me not to do that.
    10. Junior Member
      Apr 1st, 2010
      Trenton, Ohio
      1991 Jetta GLI
      05-07-2010 04:41 PM #10
      thanks, guys.:bow
    11. Member Sinner44's Avatar
      Oct 11th, 2006
      Reno, NV
      05-07-2010 04:45 PM #11
      I'm not sure why you're removing that bolt...it doesn't hold the pulley on only the toothed timing cog...but if you do end up removing it for some reason...REPLACE IT!!! And I think the torque Is 145 for the 12pt w/o a washer
    12. Member 16ValveInside's Avatar
      Nov 20th, 2004
      South Carolina
      91 GTI 16V Current Project. 91 GTI 8V. 91 GTI 16V (totaled). 91 Jetta GL. 1967 & 1955 Cal-Look/48IDA
      05-08-2010 05:56 PM #12
      Quote Originally Posted by Sinner44 View Post
      Now I just torqued mine down last week and the torque for a 12 sided bolt w/collar w/o a washer is 66 ft. lb. + 1/2 turn. Hex head bolt with washer is 111 ft. lb., and 6 sided bolt with washer is 137 ft lb.
    13. Member Sinner44's Avatar
      Oct 11th, 2006
      Reno, NV
      05-08-2010 11:15 PM #13
      AH! Thank you for the correction sir!!! I definitely should have checked my bentley before posting! That could have been very very bad! Good Catch 16v!!!
    14. Junior Member
      Apr 1st, 2010
      Trenton, Ohio
      1991 Jetta GLI
      05-12-2010 07:38 PM #14
      Ok, I got the pulleys off. Where is the timing mark on the crank pulley? Is it the nipple? Also, what size is the bolt on the cover above the crank? Mine looks to be stripped. Thanks
    15. Member Sinner44's Avatar
      Oct 11th, 2006
      Reno, NV
      05-13-2010 06:11 PM #15
      I may be too late and you may have already figured it out...but the timing mark is on the pulley you removed it's a notch on the outside of the pulley on the side closest to the block...there isn't one on the timing crank cog the nipple is more or less on there for the crank pulley...
    16. Junior Member
      Apr 1st, 2010
      Trenton, Ohio
      1991 Jetta GLI
      05-13-2010 08:26 PM #16
      I don't see the notch, I'll take the pulley to work and clean it tonight. Do you happen to have a picture?
    17. Member Sinner44's Avatar
      Oct 11th, 2006
      Reno, NV
      05-13-2010 09:57 PM #17
    18. Member shortwave360's Avatar
      Jul 6th, 2008
      Seattle, WA
      MKV 08' GTi FSI 6MT, 92' cabby 8v
      03-22-2011 10:05 PM #18
      Does any one know the part number for (PL) the allen head bolts for the crank pulley? I have N90339605 but cannot find a pic.
    19. Member
      Apr 16th, 2006
      Brokelyn, NY
      90 fox, 85 gli
      03-23-2011 04:10 AM #19
      if you ever do want to remove the crank sprocket bolt, say to refresh the seal, you could carefully crank the starter for a split second. does it everytime.
      I really suck at smog.
    20. Member
      Sep 18th, 2004
      Marion, Iowa
      2001 Jetta 1.8t, 90 Jetta GLI (E85), 04 Jetta GLI
      03-24-2011 11:57 PM #20
      I just go to Ace hardware and get bolts. Get the hardened black bolts, they work fine.
