VWVortex.com - FS: Misc parts #2 SoCal. Will ship international * <---
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 45
    Thread: FS: Misc parts #2 SoCal. Will ship international * <---
    1. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      1943 Flugkreisel, 1945 VRIL-7
      05-06-2010 02:43 PM #1
      All parts used unless otherwise stated and sold as-is with no warranty.
      Shipping TBD, ask for quote.
      * Will ship international for additional fees.
      Paypal + fees.
      VR6 grille badges $18 ea. (1 left).
      VR6 rear badges $14 ea.
      Golf badge $14.
      GTI badge SOLD.
      Turbo badge $14.
      Mk1 Jetta aux gauge brown plate $45 all pins intact.
      Jetta badges $14 ea.
      Jetta GLI badge SOLD.
      Carat fender and rear badges $14 ea.
      Wolfsburg badges $14 ea.
      Rectangular badge is mint.
      Porsche/Recaro seat knobs. $15 ea. or 2 for $25.
      May fit some VW seats.
      Golde chrome sunroof without button SOLD!
      Golde chrome sunroof crank $22.
      Black stock crank $12.
      NLA Rare NEW Hettel hand brake combination lock $105. SOLD!
      Leather OEM black hand brake handle $20.
      NLA Window crank or Golde sunroof handle 10 mm spacers. $15 ea. or 2 for $25.
      Aero grill pins 2 for $10.
      Aktiv or VW branded speaker covers.
      With pins to mount speaker to grill. $30 ea or 2 for $55.
      Without pins, for vehicles with current metal speaker box in door. $25 ea or 2 for 45.
      Please inquire about current availability.
      Thanks for viewing!
      The original Dub and Dubber.
      Manche VWs sind einfach schneller als andere.
    2. Member rallydub's Avatar
      Nov 5th, 2001
      Riverside ,California
      Widebody Gti,Vr6 Vento,Rabbit
      05-13-2010 02:42 PM #2
      still have the black oval wolfburg badge
    3. Member rabbit1984's Avatar
      Mar 26th, 2010
      Tacoma Wa
      85 GTI
      05-17-2010 10:37 PM #3
      what does the isv do?
    4. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      05-17-2010 10:44 PM #4
      Quote Originally Posted by rabbit1984 View Post
      Hello,
      The electronic idle air stabilizer valve adjusts the amount of air bypassing the throttle valve to control engine idle speed. Whenever the throttle valve idle switch is closed, the valve receives signals from the control unit based on engine rpm and other inputs. This voltage signal cycles on and off. The ratio of on-time to off-time (duty cycle) determines the position of the valve and how far it is open.
      When the idle air stabilizer valve is functioning correctly, it should vibrate and hum slightly whenever the engine is running at idle.
    5. 05-29-2010 04:27 AM #5
      Interested in the Golde sunroof cranks, probably a stupid question that i think i know the answer to but....
      Will the 1.8l 16v fit in a 8v without any problems?
      When i start my 86 gti it doesn't turn on, so i give it gas, hold the gas in for about 10 seconds than it idles, but even when it idles the car shakes pretty bad and it also dips but than it revs up again, till it warms up. After it warms up a bit it idles fine. Do you think i just need to clean the isv? Thanks in advance.
    6. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      05-29-2010 07:25 AM #6
      This for sale ad is not the place to ask me technical questions, please post them in the appropriate forum. If I browse that particular forum, I usually will reply.
      But I will answer you here this time.
      Sure you can swap in a 1.8L 16v to replace your 8v.
      The down pipe on your 86 GTI should be a dual pipe, so your good there.
      The trans can be kept, but you'll want the 16v trans.
      I'm not an electronic novice, so wiring is not a big deal for me.
      Some people are not familiar with schematics, but the Bentley manual does a good job of explaining it.
      Though I prefer Mitchell on Demand schematics over the Bentley since they are usually all on a single page, the Bentley spreads it out and it take time to trace a circuit.
      If you've never done a swap, make sure you have a single donor vehicle. This way you can get everything you need from one source. It is very important to label the wiring connectors with a description of its function and location. Doing this will make the swap much faster as you don't have to guess or take the time to search in the schematics.
      As for your vehicle taking time to start, have you measured fuel pressure?
      CIS and CIS-E fuel pumps have a replaceable check valve. This check valve is located at the outlet of the main fuel pump, it just threads on.
      The fuel accumulator also has a check valve, but it can only be replaced with a new fuel accumulator, it is not a separate device.
      Cold start issues, can be tested following the Bentley manual.
      You'll want to verify your thermo time switch is working and operating the cold start valve (use a noid light). Also verify your coolant temp sensor works and that your differential pressure regulator does too. The two are used during cold starts to maintain a smooth idle. Also check your O2 sensor and throttle body switches work.
      Again the Bentley manual will have all the information and test equipment needed to verify the various sensors. The Bentley even shows you how to make your own test equipment.
    7. 05-29-2010 08:35 PM #7
      Wow i am so sorry i should have asked
      Will the 1.8l 16v ISV fit in a 8v without any problems?
      Sorry i was not asking for the engine swap, 3 little not typed letters made you type all that and for that i am sorry man!
      Thats why i asked this question
      "When i start my 86 gti it doesn't turn on, so i give it gas, hold the gas in for about 10 seconds than it idles, but even when it idles the car shakes pretty bad and it also dips but than it revs up again, till it warms up. After it warms up a bit it idles fine. Do you think i just need to clean the isv? Thanks in advance."
      Because i though it was related to the isv. I thought it was a relevant question to your post. Sorry about that.
    8. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      05-30-2010 02:25 AM #8
      The 1.8L 16v and your 86 Golf have the same exact ISV, same part #.
      Cleaning the ISV would be ideal. Make sure it moves freely and vibrates.
      If that doesn't solve your issue, consult the Bentley manual and perform tests on the various sensors that I mentioned earlier.
      Best of luck!
    9. 05-30-2010 02:44 AM #9
      Alright thanks. I.m. Sent.
    10. Member gtimotorsport46's Avatar
      Apr 19th, 2007
      Chicago
      09-21-2010 12:22 AM #10
      how many of the round white back ground wolfsburg emblems do you have?
    11. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      09-21-2010 10:44 AM #11
      2 of them, but one is more faded than the other.
      None are perfect, they have seen a lot of sun.
    12. Junior Member alevw's Avatar
      Jul 27th, 2010
      Puerto Rico and Virginia
      1989 gli helios , 1988 gli, 1989 cabrio
      09-25-2010 11:50 PM #12
      I'm interested in two emblems black or white wolfburg and have them send it to Virginia
    13. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      09-26-2010 12:05 AM #13
      I'll check my parts inventory and get back to you about the badges and colors. I've sold several items and haven't updated this ad.
    14. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      09-26-2010 12:49 AM #14
      I have 2 white and 1 black round wolfsburg badges.
    15. Member MKhamiII's Avatar
      Apr 15th, 2008
      90 GLI
      09-30-2010 05:36 PM #15
      The used ISV is in working order? Or is the history unknown?
    16. Junior Member alevw's Avatar
      Jul 27th, 2010
      10-11-2010 10:30 PM #16
      prices 2 white emblen shipped to 22079
    17. Member infeliciter's Avatar
      Sep 12th, 2010
      Tacoma, WA
      97 Jetta
      02-23-2011 03:24 PM #17
      Still got the 1.8 ISV?
    18. Member infeliciter's Avatar
      Sep 12th, 2010
      Tacoma, WA
      97 Jetta
      03-01-2011 09:52 AM #18
      Received part! ISV looks good.
    19. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      03-31-2011 01:11 PM #19
    20. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      04-01-2011 12:39 PM #20
    21. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      04-02-2011 02:04 PM #21
    22. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      04-03-2011 10:57 AM #22
    23. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      04-04-2011 12:52 PM #23
    24. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      04-05-2011 12:46 PM #24
    25. Senior Member Eric D's Avatar
      Feb 16th, 1999
      Tragic Kingdom, CA
      04-06-2011 01:37 PM #25
