VWVortex.com - My 2.9L BVH parts collection...
    Page 1 of 8 12345 ... LastLast
    Results 1 to 25 of 183
    Thread: My 2.9L BVH parts collection...
    1. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
      05-07-2010 06:22 PM #1
      Well it's taken close to a year of hunting, ordering and collecting, but it's all here now! I know, I know, there's been lots of 2.9 build threads, but whatever....
      Next step, machine shop
    2. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-08-2010 09:31 AM #2
      Top End:
      TT 268 cams
      Ferrea 41mm intake valves
      Ferrea 36mm exhaust valves
      Ferrea HD valve springs
      Ferrea Ti retainers
      Ferrea single groove keepers
      TT oversized valve seats.
      Autotech SS exhaust studs
      APR UC head studs
      Bottom End:
      Wiseco 82.5mm forged pistons (10.5:1 comp)
      ARP main stud kit
      ARP rod bolt kit
      Extra goodies:
      BFI stage 0.5 poly mounts
      Verdict Motorsports coilpack spacer
      Verdict Motorsports shifter bushings
      Mason Tech billet crack pipe
      TT 2" downpipe
      Gruvenparts alum tensioner pulley
      Neuspeed UD pulleys
      ACT 8.3lb 1pc flywheel
      ACT 6pad spring disc
      ACT HD pressure plate
      42DD SAI plug
      Low temp T-stat (70*)
      Low temp fan switch
      OEM/Maint things:
      Mk4 AFP metal HG
      Valve guides
      OEM oil pump
      OEM oil pan
      OEM timing chains/guides
      Crank/Rod bearings
      Int shaft bearing
      OEM release bearing
      OEM release bearing sleeve
      ALL gaskets/o-rings
      ALL coolant pipes/flanges
      Nearly all new bolts for block and head
    3. Banned vortexpert.'s Avatar
      Sep 27th, 2009
      Surprise, AZ
      68 chevelle, 98 GTI VR6 S/C, 00 hombre, 02 1.8t jetta wagon, Haro Mirra 540 Air
      05-08-2010 10:37 AM #3
      i am the vortexpert and i approve this thread
    4. Member vr604's Avatar
      Feb 19th, 2003
      Vancouver B.C
      1972 BMW 2002, 2008 VW Rabbit, 2008 Nissan Xterra,
      05-08-2010 11:10 AM #4
      Thats a big parts collection. Good luck with the build, what software or tuning do you plan on running?
      Also, when you fit the transmission make sure that the pressure plates outer rivets dont hit the bellhousing. When I did mine I didn't find out until I started the motor
    5. Member daloztprophet's Avatar
      Apr 14th, 2009
      NY,NY
      Euro Vr6
      05-08-2010 11:11 AM #5
      feels good dont it ?so youll pretty much be running n/a? with 11: comp/ratio? or.....? ever since i started my 2.9 build i realized alot of people have been going in and have been boring out their blocks nice! good luck with your build scotty let me know how it goes youll be hearing from my build soon i have to update the thread n get it up here
    6. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-08-2010 02:42 PM #6
      feels good dont it?
      Yes it does... the only I'm uncertain of at this point is what software to run. I sent off an email to TT yesterday with all the datails, but I hear alot of good things about C2's products also. Any input is welcome, thanks. And btw this will all be packed into my mk2 golf (OBDI electronics - 95 corrado stuff).
    7. Member adamea1635's Avatar
      Apr 11th, 2006
      Albany, NY
      96 GTI(Wrecked), 94 B3 Passat VR6, 2000 Jetta VR6, 2010 Jetta, 2015 GTI S
      05-08-2010 06:19 PM #7
      awesome... GL and please make many pic enriched updates
    8. Member GinsterMan98's Avatar
      May 19th, 2008
      Panama City FL
      96 GTI VR6 08 Hyundai Santa Fe SE
      05-08-2010 09:06 PM #8
      should be a good build up, good luck man.
    9. Member DUBZAK's Avatar
      Oct 26th, 2009
      Doin' W3rk at the Shop or my House
      Corrado SLC, Audi A8 QUATTRO, B6 ULTRASPORT MT6
      05-09-2010 03:26 AM #9
      that is an impressive pile of WIN sir.
      Nice piston choice as well :thumb
      |Corrado SLC 2.9LVR6|Corrado Keyless Entry | A8 "Grape Ape" | SPOONFEDTUNING |FOURSEASONTUNING|DUBNUTZ|
      Quote Originally Posted by pileofredparts View Post
      Do you guys remember the time that Ryan kid started mixing and matching rods and end caps and then his motor wouldnt turn over? I do
    10. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-09-2010 01:54 PM #10
      Quote Originally Posted by adamea1635 View Post
      Thought some info/pics as to the reason for the rebuild may be appreciated. Piston rings were worn to the point of burning lots of oil and top compression ring on cylinder 5 was actually broken in half! The cam lobes wer also worn and a couple were pitted. And lastly, I found small pit marks as if something had hit the top of cylinder 3's piston.
    11. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
      05-09-2010 05:37 PM #11
      holy $hit!!! arent thoses bags from sealership i bet it costed u soo much!!!!
    12. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-09-2010 07:38 PM #12
      Quote Originally Posted by dogyouare View Post
      Yes you are correct sir. I work at a BMW dealership but my company owns the VW down the street so it didn't cost me a ton, but yes not cheap. I do admit to getting a little anal when it came to what hardware needed replacement. Looking back I pretty much bought new bolts for anything that mounted to the longblock... ok, ok alot anal...
    13. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      05-10-2010 09:47 AM #13
      lol your lucky u work for them. and i do get stingy on what bolt/hardware i use also.
    14. 05-12-2010 05:11 AM #14
      Quote Originally Posted by vortexpert. View Post
      i am the vortexpet and i approve this thread
      You sure about that?
      I couldn't recover my password from the old forum and had to make a new profile. Lost all my IMs, notes in notepad, etc... 7 years worth down the drain.
    15. Member vegamotion's Avatar
      Aug 31st, 2009
      toledo ohio
      1990 jetta coupe 1.8t swap, 2008 G8 GT, 2014 jetta 1.8t
      05-12-2010 12:32 PM #15
      incredible i do envy u sir.
      just started my mk2 1.8t build thread, check it out :http://forums.vwvortex.com/showthrea...t-build-thread
    16. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-13-2010 06:53 PM #16
      Well it feels good, dropped off the head, block and necessary parts at the machine shop today. Said it should be ready for me in 2-3 weeks....
    17. Semi-n00b
      Nov 9th, 2009
      norwegen
      86 mk2 2.9 vr6
      05-13-2010 07:30 PM #17
      wow! you have allot of work ahead
    18. 05-13-2010 07:56 PM #18
      Now order Estyles Headers and a Copy of Leebro's Medium length Intake Manfild
    19. Member thecreeper's Avatar
      Oct 26th, 2001
      2012 GTI | 1996 Passat wagon RIP
      05-13-2010 09:30 PM #19
      Scotty_2.0
      Can you do me a huge favor?
      Can you tell me what side the O2 sensor bung is located on your TT downpipe? Mine is facing the driver's side and it makes for a pretty good stretch of the wiring harness...not really an issue but stock was facing the passenger's side.
      Thanks!
    20. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-13-2010 09:45 PM #20
      Quote Originally Posted by thecreeper View Post
      Thanks!
      Yeah it's pointing straight out towards the driver's side. Hope it's not an issue like you say it may be.... ohwell sure it'll work out.
    21. Member thecreeper's Avatar
      Oct 26th, 2001
      05-13-2010 11:37 PM #21
      Quote Originally Posted by Scotty_2.0 View Post
      You do need to reroute the wiring, it's a bit tight. It scared me a little because it needs to travel over the DP this way to plug in, and I kept thinking the heat would destroy the wiring. I ended up wrapping the exposed wires with thermal tape and tucked it up under that metal heat shield covering the brake line. So far so good...
    22. Banner Advertiser
      Nov 7th, 2001
      Millersville
      05-14-2010 01:03 AM #22
      Contact C2.
      They will get you squared away software wise.
      42 Draft Designs
    23. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      05-20-2010 02:54 PM #23
      Stopped by the machine shop today. Snapped a couple pics of the head in the early stages. Valve seats in. Quite suprised to find out that the valve seats actually touch each other in the middle... Was also suprised to find out that the mahcinist didn't like the TT ovesided valve seats I provided and instead used his own. Said he prefers the valve seat to be slightly bigger than the valve face, and the TT ones were almost exactly the same as the valve....
      Anyhow, here's the progress thus far...
    24. Member DUBZAK's Avatar
      Oct 26th, 2009
      05-20-2010 03:37 PM #24
      looking good. Ill be a few months behind you on the headwork, so I can take notes from you now!
    25. Member VWJETTY's Avatar
      Jun 29th, 2006
      Dumfries, VA
      97 VW Jetta VR6 OEM+ // 05 Mitshubishi Evolution 8
      05-20-2010 10:09 PM #25
      subscribed!
      https://reviewlinker.com/members?id=vwjetty
      Air&Water Specialists @ Bug Haus VW - 804.232.8989 || VRSociety #296 || GO LAKERS
      VCU RAMS
