VWVortex.com - 98 GTI VR6 Fuse box diagram
    Results 1 to 16 of 16
    Thread: 98 GTI VR6 Fuse box diagram
    1. 05-08-2010 04:38 PM #1
      Can't seem to find my cruise control fuse. Looking for a diagram of the fuse box for my 98 gti vr6. I know this has been posted before, but my link to it is no longer valid. I'd appreciate if someone could post this again or direct me to a link.
      Thanks
    2. Member AtomixMK3's Avatar
      Apr 6th, 2010
      Palm Springs/Redlands, CA
      1989 VW GTI 16v (W.I.P), 1998 VW Jetta 2.0 (Totalled), 2001 VW GTI 1.8t
      05-08-2010 04:45 PM #2
      Ok hold up give me like 15 minutes and I'll get it for you
    3. Member AtomixMK3's Avatar
      Apr 6th, 2010
      05-08-2010 05:17 PM #3
      Below Relays
      1 - Headlight, Low Beam Left (56b) 10A
      2 - Headlight, Low Beam Right (56b) 10A
      3 - License Plate Lights (58) 10A
      4 - Rear Window Wiper And Washer System 15A
      5 - Windshield Wiper/Washer 15A
      6 - Fresh Air Blower, AC (X) 20A
      7 - Tail Lights, Right (58R) 10A
      8 - Tail Lights, Left (58L) 10A
      9 - Rear Window Defogger 20A
      10 - Fog Lights 15A
      11 - Headlight, High Beam, Left (56a) 10A
      12 - Headlight, High Beam, Right (56a) 10A
      13 - Horn (15) 10A
      14 - Back-Up Lights 10A
      15 - Engine Electronics (15) 10A
      16 - Power Sunroof, Front Map/Reading Light 15A
      17 - Emergency Flashers (15) 10A
      18 - Fuel Pump (FP), Heated Oxygen Sensors (HO2S) Control Module 20A
      19 - Coolant Fan, A/C Relay (30) 30A
      20 - Brake Lights (30) 10A
      21 - Interior Lights, Clock, Luggage Compartment Light (30) 15A
      22 - Cigarette Lighter, Radio, Luggage Compartment Release 10A
      "Hidden" Above Relays
      ABS Hydraulic Pump Relay 30A
      ABS Main Relay 30A
      A/C 30A
      Power Windows 20A
      Cruise Control 5A
      Cigarette Lighter 15A
      So if you pull the block down above the relays there are a few fuses. Obviously according to my list your cruise control should be the only 5A fuse up there.
    4. Member ShavedRabbit's Avatar
      Sep 6th, 2002
      Scranton Pa
      All Of Them
      05-08-2010 06:00 PM #4
      good info
    5. 05-08-2010 06:40 PM #5
      Thanks for the speedy reply Atomix.
      I wish there was also a diagram for the fuses above the relays (and maybe for the relays themselves), because there didn't seem to be a 5A up there. Had 2 30s, a 15, and a 10 - none of which were out.
      I'd had luck previously removing and reinstalling fuses that weren't blown to apparently improve an electrical contact and was hoping this might bring my cruise control back.
      Btw, in case anyone is wondering how to get the fuse box to drop down, there are two white plastic clips located at the base of the fuse box on either side that lift up from the bottom. After you pop these, you should be able to spread the hooks that the round knobs at the base of the box rest on, and then lift the box up and forward.
    6. Member AtomixMK3's Avatar
      Apr 6th, 2010
      05-08-2010 06:45 PM #6
      Well the cruise control on MK3's are known for going to hell. Mine worked once in a while on the long trips to Arizona. I'll pull mine and take a look to see what I've got.
    7. Member Sallad's Avatar
      Aug 29th, 2004
      Kelowna, BC
      '94 Jetta 2.0 16v
      05-08-2010 07:21 PM #7
      Have you checked for vacuum leaks for the reason it not working?
      Pro Patria
      Making power, 4 valves at a time.
      MkIII 16v Club.
    8. Member marauder228vw's Avatar
      Jul 2nd, 2009
      Made in Dade, Fl
      15 Lxus is350 fsport , 2005 vw gli 6 speed
      10-21-2010 04:53 PM #8
      Quote Originally Posted by AtomixMK3 View Post
      Below Relays
      10 - Fog Lights 15A
      13 - Horn (15) 10A
      ABS Main Relay 30A
      A/C 30A
      Power Windows 20A
      Cruise Control 5A
      Would this work also for a 95 vr6?
      Parked!!1
    9. Member builtvw's Avatar
      Sep 19th, 2009
      coopersburg
      windsor 2.0, ginster 1.8t
      01-15-2013 04:38 AM #9
      bump for myself
      Quote Originally Posted by ZACHER3tuning View Post
      only on vortex, could this turn into a argument.
      http://forums.vwvortex.com/showthrea...Project-molest
    10. Member VrFiend's Avatar
      Sep 18th, 2008
      Iowa
      95 Passat GLX, 95 Jetta GLX
      01-15-2013 06:07 AM #10
      Quote Originally Posted by DalVR6 View Post
    11. 07-15-2015 02:21 PM #11
      Would the fuse diagram be the same for my 96 GTI? Having trouble with the windows not going down or up unless I lock/unlock the car. Anyone know of an alarm fuse I can take out so I can at least hop in from the passenger side until I figure out what's wrong or get a new driver door
      Sent from my XT1064 using Tapatalk
    12. 07-15-2015 02:22 PM #12
      Thanks in advance!
    13. Member AtomixMK3's Avatar
      Apr 6th, 2010
      07-15-2015 04:10 PM #13
      Yes the fuses would be the same. I'm not familiar with the power windows on a MK3 but do you mean your windows only actuate if you put the key in the door and unlock/lock and hold they key like that of MK4 and up?
      Sent from my SM-N910V using Tapatalk
      Vagcom available in Palm Springs area PM me
    14. 07-15-2015 04:55 PM #14
      Thanks! All good I found out its because the spring inside the handle that would somewhat rebound the keyhole back to the horizontal position was shot, so it was basically like I was constantly holding the window down/up, got a replacement handle withba good spring just need to swap the tumblers now!
    15. Member AtomixMK3's Avatar
      Apr 6th, 2010
      07-15-2015 04:56 PM #15
      Swapping them is really easy the blade portion has a hook that slips out only takes a minute to swap but be careful not to break the hook
    16. n00b
      Feb 10th, 2015
      Palm Bay, Fl.
      '01 Cabrio
      11-30-2016 01:54 PM #16
      Hi,
      My 01 Cabrio's windshield washer stopped working the other day and I'm trying to trouble shoot. If anyone can help please do! The Wipers work fine, so am i correct in assuming it can't be the fuse (#5?). Also, I don't hear a pumping sound when I pull on the wiper stalk. Does this mean that the pump motor is to blame? If anyone can give me ste-by-step instructions on how to troubleshoot, I'd really appreciate it...pics or a video link would be awesome if anyone has access to these! Thx!
      Rob
