VWVortex.com - manual throttle body adaption??
    Results 1 to 18 of 18
    Thread: manual throttle body adaption??
    1. Member twistedjet's Avatar
      Sep 15th, 2009
      mississauga, ontario
      01 gti vr6... 2002 jetta 1.8t sold... 98 glx vr6 sold
      05-09-2010 02:33 PM #1
      i disconnected my battery to install my stereo, and i've been reading that i need to adapt the throttle body once reconnecting the battery.
      I don't have vag-com so i was wondering if there's a manual solution. I've heard different things like open the hood and door, and leave the key in the "on" position.
      Not sure if this is correct so asking for your expertise. THANKS
    2. 05-09-2010 05:53 PM #2
      No, VAGcom is the only way to do a full adaptation.
      Just give it a test drive. It will most likely drive fine. It's more for good measure than anything (unless you are replacing/cleaning the TB).
      Road Farmin'
      Nov 21st, 2001
      Delta, BC, Canada
      2001 1.8t jetta, 1990 golf
      05-09-2010 06:40 PM #3
      there is a manual way to do it without vag-com...can't remeber how, links not working to old info, someone should let you know. Something like turn key to "on" position for 2 minutes and then start. Wait for another response though
    4. Member TheBossQ's Avatar
      Aug 15th, 2009
      2003 Jetta Wolfsburg; 2005 Jetta 2.5; 2006 Nissan Titan; 2011 EOS 2.0T
      05-09-2010 09:01 PM #4
      Quote Originally Posted by 86crapper View Post
      Disconnect the negative battery cable for at least 10 minutes. Reconnect cable. Key On Engine Off (KOEO), should send it into adaptation.
    5. Member TheBossQ's Avatar
      Aug 15th, 2009
      05-09-2010 09:25 PM #5
      I found this procedure that skips resetting the ECU. I am going to try it.
      Turn the key to the on position, the position just before the starter turns over.
      Press the gas pedal to the floor with the key in the "on" position.
      Hold the pedal to the floor for five seconds, then turn the key back to the "off" position(don't remove the key), then release the gas pedal.
      Wait 2 minutes for a full alignment. During this time you may hear very faint noises and clicks.
    6. Member twistedjet's Avatar
      Sep 15th, 2009
      05-10-2010 02:53 PM #6
      i will try that.
      issue seems to be that no one is completely sure.
    7. Former Advertiser Lavi@Unitronic.ca's Avatar
      Nov 20th, 2008
      NYC<----->Montreal
      05' GLI 10:1 - GT30r - W/M-N2O
      05-10-2010 03:10 PM #7
      there is NO WAY besides VAGCOM to force a TBA. check with Ross-Tech.. or search of the TBA aka chicken dance vag com in google
    8. Member nug548's Avatar
      Jan 28th, 2005
      green bay, wi
      03' gti 1.8t, 88' jetta GL
      05-10-2010 03:41 PM #8
      you have the battery disconnected. reconnect. the the key to on-dont start. wait about 30s to a minute. start the car. done.... btw if you pop the hood and go listen you'll hear the throttle body doing its thing.
      i and many other people have done it this way many times with no problems.
      03' GTI 1.8T-----
      X+, APR TIP, MBC, ECS race valve, 3" catless DP to 2.5" with magnaflow muffler, 14lb. FW and vr6 clutch, gutted air box w/ bottom cut, K&N filter, 4 bar FPR, BRK7E's, forge 007p DV, N249 deleted, forge boost hose kit
      88' jetta GL--- sold
    9. Former Advertiser Lavi@Unitronic.ca's Avatar
      Nov 20th, 2008
      NYC<----->Montreal
      05-10-2010 04:47 PM #9
      you and many other people are not aligning there throttle body! your just hearing the throttle body whine from testing that it does, its not aligning, big difference. no data is being calculated and or being effected.
    10. 05-10-2010 04:56 PM #10
      Quote Originally Posted by Lavi@Unitronic.ca View Post
      X100
      The idea that you could do it without VAGcom was dissolved a long time ago. VAGcom is truly the only way.
      Road Farmin'
    11. Member nug548's Avatar
      Jan 28th, 2005
      green bay, wi
      05-10-2010 08:02 PM #11
      well i guess i stand corrected...
      03' GTI 1.8T-----
    12. Member vwturbowolf's Avatar
      Nov 27th, 2003
      baltimore, maryland
      01 jetta 1.8t, 14 tiguan 4mo
      05-10-2010 08:58 PM #12
      there was actually a video that compared doing it with vagcom and trying to do it the chicken dance ways. it had the intercooler pipe removed and you could see the throttle plate moving with the noticable differences.
      btw. i drive the car probably once or twice month and disconnect the battery everytme, same with during winter i start it every few weeks, most likely it will be fine to start and drive.
    13. Member mpatterson's Avatar
      Jun 25th, 2009
      Hamilton Ontario Canada
      2005 Jetta GLI
      05-11-2010 09:16 AM #13
      i've got the apr software with the throttle body alignment function built in, are you saying this wont' actually do it either?
    14. n00b
      Feb 20th, 2007
      Morehead City NC
      97 Jetta VR6, 01 Jetta 1.8T
      05-22-2010 08:07 AM #14
      I have a VAG-COM and have done the TB alignment both ways. The Bentley for my 97 Jetta tells you to disconnect the neg battery terminal, turn on Key and reconnect to force the TB into an alignment. If you open the hood and listen you will hear the TB. When I have done it with the VAG-COM you hear the same sequence from the TB. I don't know if there is any additional things going on when you do it with a VAG-COM but it appeared to work both ways. Actually for my 97 jetta I was having rough idle issues and did the battery terminal thing and the issues went away.... so I am assuming it worked.
    15. Member groggory's Avatar
      Apr 21st, 2003
      Long Beach, CA
      2002 VW GTI 1.8 BT
      05-22-2010 01:34 PM #15
      Quote Originally Posted by mpatterson View Post
      The APR software will do it too. They wrote the procedure into the software.
      For people without the APR TBA feature...they need to use vag com.
    16. Member
      Apr 11th, 2010
      Gainesville, FL
      05-22-2010 05:28 PM #16
      I have a v-checker pro scanner which will do a TBA.
    17. Banned dubinsincuwereindiapers's Avatar
      Jan 16th, 2008
      InYourMom
      Bugatti Veyron
      05-22-2010 08:23 PM #17
      My Maestro 7 does TBA
    18. Banned Hawaii5-0's Avatar
      Apr 9th, 2007
      Kalaoa, HI
      '06 GTI
      05-22-2010 09:16 PM #18
      Quote Originally Posted by Guilianelli View Post
      uhh.....97 jetta's didn't have 1.8t's with ME7 ecu's so this is kind of irrelavent. i don't even think they had drive by wire throttle bodies. vag-com or APR and Eurodyne Maestro software are the only ways to align the throttle body. yes it will make noise with the key on but it is not doing an alignment.
