VWVortex.com - AWP 1.8T ECU Pinout/Wiring Diagram
    Results 1 to 8 of 8
    Thread: AWP 1.8T ECU Pinout/Wiring Diagram
    1. Member pueblorrado v3.0's Avatar
      Nov 22nd, 2006
      SLC, UT
      2008 VW .:R 32, 2014 Ford Fusion SE
      05-11-2010 07:58 PM #1
      I have searched and searched, and the new forum search just isn't cooperating with me (who knew it could get worse!?)
      Does anyone have the pinout diagram for the AWP/1.8t (if they are all the same)?
      Really, all I need to know: which pins act as signal and signal return for the MAP sensor. Your help is much appreciated.
      p4c:
    2. Member DBVeeDB's Avatar
      Aug 2nd, 2007
      Des Plaines, IL
      His: '06 LS: Hers: '14 MKZ : '03 GTI 1.8T/5MT
      05-11-2010 08:39 PM #2
      would also be interested. i found one the other day on the "old" tex haha
    3. Member pueblorrado v3.0's Avatar
      Nov 22nd, 2006
      SLC, UT
      05-12-2010 11:59 AM #3
      despair bump
    4. 05-12-2010 03:02 PM #4
      Both of you, check your PM's...
    5. Member PernellGTI's Avatar
      Jan 1st, 2010
      Phoenix
      B8.5 A4 Stage 2+, 2011 Q5, E30, B7 A4 S-line, B5S4 Stage 3
      08-02-2010 01:52 PM #5
      Hey guys I'm trying to install a Knocklite (knock alert device) on my 1.8T gti AWP but I need a ECU pinout diagram, anyone knows where to find it? I did the search but nothing came close to what Im looking for, anyone can help?
    6. Member supb15's Avatar
      Apr 10th, 2007
      Maine
      1980 Rabbit 20vt
      01-03-2011 03:53 AM #6
      can you send me one too. im about to go on the adventure of awp in a rabbit and im trying to plan out the wiring a little bit before i get started. it would be much appreciated
    7. n00b
      May 8th, 2010
      SW Florida
      1997 Audi A4 Quattro !.8T 5spd BT+N20+Meth
      08-04-2011 05:03 AM #8
      not too sure about the above mentioned knock detection device, but with AEM EMS's I have had excellent results with the knock control / knock feedback features. AEB running 42psi boost on pump gas + 50/50 h20 meth via 750cc nozzle (also AEM) -can run more boost, but the knock feedback loop retards timing> adds fuel and would ultimately cut ignition in order to curb knock.
      the fact the frequency can be dialed in with absolute precision is what makes this system shine. please let us know how the Knocklite wirks, because this device might just save the day for my AEM managed 4.2L 40v V8. -the new series 2 AEM's have sufficient ignition and injector outputs, but only ONE knock input! my series 1 Race EMS has 2 as do most Series 1 EMS's, but this will soon be a moot point as the 40v V8 has FOUR knock sensors! perhaps a couple knocklite's could be used to compensate for the Series 2's lack of additional knock channels
      Bored + stroked=2008cc, TiAL-Garrett GT3076R AEM Race EMS AEM TwinFIre CDI AEM progressive H20/Meth 496.1AWHP / 436.4FtLbs 3.04 0-60(dry)/4.657 0-60 (rain)
      ENGINEERED, MADE, BUILT -not bought, hired + a bunch of damned "kits"
