VWVortex.com - evap purge valve
    Results 1 to 7 of 7
    Thread: evap purge valve
    1. Member BigJ389's Avatar
      Dec 21st, 2008
      Brownsville Tx
      1987 Golf///2006 jetta
      05-13-2010 01:47 PM #1
      anyone know where my evap purge valve is? My problem is that I got my car scanned and it showed a large evap leak, i already replaced my gas cap and some vacuum hoses, i was told to check my evap purge valve or the pcv valve, is this correct? Also the purge valve, can i just clean that out or it has to be replaced? I know the older vr6 had the egr valve and you could clean out the gunk, is the purge valve like that? TY in advance
    2. Member Das Borgen's Avatar
      Sep 10th, 2008
      Columbus, OH
      1995 M3, 1999 740i "Short" Sport, 2000 Ducati 748
      05-13-2010 01:52 PM #2
      should be right on your passenger shock tower in the engine bay. right underneath the airbox. Its line goes to the PCV intake boot
      Quote Originally Posted by Das Borgen
      VR6s should sound like Chewbacca getting raped
      Dazzle Surprise - Team My Little Pony
      Jul 13th, 2001
      Oakland, CA
      05-13-2010 02:40 PM #3
      Quote Originally Posted by BigJ389 View Post
      If you truly have a leak, the EVAP purge valve is probably not the source. It's more likely to be a leak in one of the hoses leading to the charcoal canister (one of which goes to the purge valve). And you can't clean the purge valve; if it's faulty (like mine was), you must replace it.
      Kenji
    4. Member BigJ389's Avatar
      Dec 21st, 2008
      Brownsville Tx
      05-13-2010 03:11 PM #4
      ok well i found the evap purge valve and inspected the hoses going to the canister, didnt see any hoses that might have any tear, but one of them i did notice slight cuts but nothing major to where its cut all the way down, its only the top layer but thats about it
    5. Member Das Borgen's Avatar
      Sep 10th, 2008
      Columbus, OH
      05-13-2010 03:29 PM #5
      you're welcome?
    6. Member BigJ389's Avatar
      Dec 21st, 2008
      Brownsville Tx
      05-13-2010 05:07 PM #6
      ha sorry thank you
    7. Member BigJ389's Avatar
      Dec 21st, 2008
      Brownsville Tx
      05-13-2010 11:48 PM #7
      hey also tomorrow ill be taking out the charcoal canister, how do i go about cleaning that out if it does have too much buildup in it?
