Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 92
Thread: Anyone need P/N's while I have ETKA up?
  1. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    05-13-2010 03:19 PM #1
    Post what you are looking for and I will try to find the P/N for you.
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  2. Member dogger's Avatar
    Jul 29th, 2005
    Pasadena, CA
    1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
    05-13-2010 05:10 PM #2
    Being nice today?
  3. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    05-13-2010 05:22 PM #3
    Being nice today?
    HAHA yeah... BTW found the P/N for those clips on the water deflector.
  4. Member iAco's Avatar
    Aug 2nd, 2004
    New York
    VSR, TDI
    05-13-2010 05:47 PM #4
    Tie rods for manual steering with VR plus suspension?
  5. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    05-13-2010 05:57 PM #5
    pretty sure it is the following:
    right:
    b 1H0 419 804
    left:
    b 1H0 419 803
  6. Member iAco's Avatar
    Aug 2nd, 2004
    New York
    VSR, TDI
    05-13-2010 06:05 PM #6
    Sweet. For the life of me I couldn't find them by searching even before the new Vortex.
  7. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    05-13-2010 06:13 PM #7
    Worst case call fourseasontuning. James should be able to get them.
  8. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    05-29-2010 04:36 PM #8
    Bump
  9. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    07-24-2010 07:14 AM #9
    Bump...from the dead
    ^^ Fixed
    Curious what these numbers find:
    535 919 035 AK
    535 919 042 AD
    Thanks
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  10. 07-24-2010 11:53 AM #10
    Not that I don't have ETKA myself, but I challenge you to find the part number for a vr6 power steering pump fitting o-ring... because I can't . (The fittings that goes inside the pump, on the male threaded steel insert).
  11. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-26-2010 02:26 AM #11
    Quote Originally Posted by leebro61 View Post
    That one?
  12. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    07-26-2010 02:44 AM #12
    Quote Originally Posted by RedYellowWhite View Post
    ^^ Fixed
    535 919 035 AK
    535 919 042 AD
    Thanks
    Bump 4 me...
    My MK1 build thread
    SpoonFedTuning
  13. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-26-2010 03:25 AM #13
    Bump 4 me...
    Showing up as instrument cluster for the first number, the second number is a sub-item on the first one. It is a printed circuit board w/ housing and labeled "GB" which I assume is Great Britain.
    Looks like UK 16v Cluster to me
  14. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    07-26-2010 03:35 AM #14
    Thanks Kyle
    So, I know I have the correct part now...but curious what the "sub-item" actually means in this case
    My MK1 build thread
    SpoonFedTuning
  15. 07-26-2010 08:21 AM #15
    That one?
    I found that same drawing and ordered that part and it's tiny. I think the one I need is considered integral to the pump so it's not shown separately.
  16. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-26-2010 11:38 AM #16
    Thanks Kyle
    Sub items are individual cluster components. You can just buy the tach, the speedometer, etc instead of a whole cluster.
    The first part number is an entire cluster the second one you had me look up the the circuit board to the cluster and the housing.
    I looked through two different sections that I thought it could be in. (ETKA likes to hide things sometimes). The pump itself shows no seals etc when I pull it up. When I looked at the oil system for the PS that is what I came up with. I will check mk3 and passat to see if they are different by chance.
  17. Member Rento_VW's Avatar
    Jul 1st, 2007
    Temecula, CA
    '97 Lexus LS400 Coach, '93 Corrado SLC Turbo (Storaged/Mothballed)
    07-26-2010 04:29 PM #17
    Hmmm if the offer is still up. Do throttle body bolts come up in ETKA? I looked lastnight on the bolt itself, nothing stamped on them other than some name.
  18. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-26-2010 05:23 PM #18
    Quote Originally Posted by Rento_VW View Post
    N 090 315 1
    The bolt size BTW is M8x25. Not sure on thread pitch. Etka lacks in that department.
  19. Member Rento_VW's Avatar
    Jul 1st, 2007
    Temecula, CA
    07-26-2010 05:28 PM #19
    Sweet, all I know is I need a couple of those bolts ... I just needa figure out how i'ma remove the damaged one since it's in the hardest spot to reach.
    Thanks
  20. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    07-26-2010 05:43 PM #20
    Thanks
    Use an easy out.
  21. Member iAco's Avatar
    Aug 2nd, 2004
    New York
    VSR, TDI
    08-03-2010 01:31 PM #21
    Could you be kind enough to find these part numbers for me?
    On the upper radiator support there are "caps" that the hood pins go in to. I misplaced them and want to pick up two new ones.
    Also there are snap caps that hold some of the door moldings. They are found along the bottom of the doors, along the body when the door is closed and also on the underside of the hood at the very front. I managed to break most of them when I took them off.
    I wish I could get an ETKA for my Mac.
  22. Member skaterazn's Avatar
    Jan 9th, 2007
    Wa
    Toyota Poopra, OBD2 vrt gear eater, A3
    08-03-2010 01:50 PM #22
    Your mother? I need a new one. she's wearing out
  23. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    08-03-2010 02:13 PM #23
    Quote Originally Posted by iAco View Post
    Found it, in an odd place as usual.
    535 823 599
    clip:
    251 823 717
    Quote Originally Posted by skaterazn View Post
    Tong, we are talking about YOUR mom! I hear mcnair calls her miss easy out
  24. Member iAco's Avatar
    Aug 2nd, 2004
    New York
    VSR, TDI
    08-03-2010 03:24 PM #24
    Thanks.
  25. Member Rento_VW's Avatar
    Jul 1st, 2007
    Temecula, CA
    08-03-2010 04:07 PM #25
    If you will please, AAA/VR6:
    - front upper strut mount/bushing
    - front strut bearing
    - rear upper strut mount/bushing
    - rear lower strut mount/bushing
  26. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    08-03-2010 04:09 PM #26
    You need actual P/Ns for those?
    Are you actually going to the stealer ship for those parts?
  27. Member Rento_VW's Avatar
    Jul 1st, 2007
    Temecula, CA
    08-03-2010 05:53 PM #27
    I just wanted the PNs for my writeup, I left the wrappers at my friend's house, i'm not 100% sure if he trashed them or not.
    I should have seen how much I could have gotten them from the dealership though since I paid half the price for the top hats then all other sites and shops wanted to charge me.
  28. Member skaterazn's Avatar
    Jan 9th, 2007
    Wa
    08-03-2010 08:48 PM #28
    I call McNair that after I get your sloppy seconds
  29. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    08-16-2010 12:10 AM #29
    2.9 tb
    021 133 061 e
  30. Banned Sponge Bob's Avatar
    Jun 8th, 2009
    2 SLC's, M3, M5, Duramax 3500, STV Euro, 1198 Duc, Turbo Busa, R6 Track bike
    08-16-2010 01:23 PM #30
    Thank you
  31. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    10-30-2010 11:27 AM #31
    Up
    Part # on these plz (rear beam bushings):
    Or where can I find these besides the dealer?
    My MK1 build thread
    SpoonFedTuning
  32. Member needaveedub's Avatar
    Jan 22nd, 2001
    L.I.. N.Y.
    93 Corrado, 99 A4 Avant
    10-30-2010 11:44 AM #32
    191 501 541 for G60
    1H1 501 541 A for VR6
    but those dont look stock they look like black polyurethane
    - Ben
    93 Corrado VR6
    99 A4 Avant 1.8T Quattro
  33. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    10-30-2010 12:21 PM #33
    Quote Originally Posted by needaveedub View Post
    191 501 541 for G60
    Thanks
    any ideas on where I can source those "poly" ones shown in the above pic?
    My MK1 build thread
    SpoonFedTuning
  34. Member needaveedub's Avatar
    Jan 22nd, 2001
    L.I.. N.Y.
    10-30-2010 01:56 PM #34
    nope, no clue.
    but heres a thread suggesting why poly might not be such a good choice.
    http://forums.vwvortex.com/showthread.php?2118568
    - Ben
    93 Corrado VR6
  35. Member needaveedub's Avatar
    Jan 22nd, 2001
    L.I.. N.Y.
    10-30-2010 02:05 PM #35
    upon further google inspection i found this...but no pics to confirm if they are identical
    http://www.suspension.com/volks.htm
    - Ben
    93 Corrado VR6
