VWVortex.com - DIY Timing belt change Passat B5.5 - Great pics and advice
    Results 1 to 3 of 3
    Thread: DIY Timing belt change Passat B5.5 - Great pics and advice
    1. Semi-n00b deutscher_b5's Avatar
      Apr 7th, 2010
      Colorado
      2003 B5.5 1.8T
      05-17-2010 02:49 PM #1
      I am currently in the process of doing a timing belt change as well as replacing the water pump and associated items that are recommended for this type of maintenance. I've read several different write-ups, which have all been very helpful. I decided to take, an almost step-by-step, picture log while doing this. Putting the radiator in service position was a real time saver for one. I'm more than willing to pass on the pictures and whatever info you need at your request. I'm actually very surprised how straight forward this procedure was. As long as you are very patient and meticulous when taking on this, you should have no problem. I'm currently held up on one issue, which I have posted a separate thread to. Although I'm sure that I'm correct, I want to make sure - there is no issue of pride here, I rather ask than to make a mistake and pay several hundred dollars for this. Thanks everyone for your informative and detailed write-ups. I hope I can return the favor in the future!
      Deutsche automobile setzen den standard beim ingenieurwesen und entwurf. Treiben sie einen Ford, wenn sie diese mangeln.
    2. n00b Paul Jensen's Avatar
      May 17th, 2009
      Fargo, North Dakota
      2010 Passat TSI Wagon, 2005 Passat TDI Sedan, 1999 VW Passat V6 GLS
      04-16-2011 10:27 AM #2
      Hello Deutscher,
      I am in the process of having to change the timing belt on my 2005 TDI. I would be happy to receive a copy of the photos you took when you did the exchange. Could you e-mail me a link please?
      Thanaks in advance,
      Paul Jensen
      paul.n.jensen@gmail.com
      Quote Originally Posted by deutscher_b5 View Post
    3. Junior Member
      Nov 21st, 2009
      Rensselaer County, NY
      2003 Passat 1.8T FWD
      08-20-2011 11:31 AM #3
      I know this is an old post... but any chance you still have the pictures and/or a writeup? It's proving hard to find something reliable for the b5.5...
      I've got an 03 1.8T, and Id appreciate anything you can provide!
