Member
ESP Error Code
05-17-2010 05:24 PM
#1
So......
I had my ESP light come on solid and the display read ESP Error.
This happened the first day I got the car, and the next morning it went away and never came back.
Now 5 months later the eroor is coming and going at random for the last week or so.
It is a 2010 MkVI GTI 4 Door.
Here is a full autoscan as well as the individual module. Any help is appreciated.
Hopefully it will be something easy and relatively cheap I can fix on my own rather than having to go to the dealer.
Thanks in advance to Dana and who ever else helps!
========AUTO SCAN===========
Monday,17,May,2010,16:12:49:17431
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 62 65
72 77
VIN: WVWGV9AJ9AW213166
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AM HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH11--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 114B600C492300FD880C06EA921F0041300800
1 Fault Found:
16352 - Control Module - Electrical Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 7
Reset counter: 61
Mileage: 9050 km
Time Indication: 0
Date: 2005.14.23
Time: 12:35:20
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 233
Count: 51259
Count: 255
Count: 0
Count: 0
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AJ HW: 3C8 907 336 AJ
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000001002
ASAM Dataset: EV_Climatic A01005
ROD: EV_Climatic_VW36.rod
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0572
Revision: 00103 AE
Coding: 6D180A1E90252AC48088008174000D0441050086534D8D6064 8020200000
Part No: 1K1 955 119 F
Component: Wischer 31100 21 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 019 0706
Serial number: 003C4D07NDK9
Coding: 00003032
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_VW36.rod
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
Component: J0527 056 0111
Coding: 0000532
Part No: 5K0 959 542
Component: E221__MFL-TAS H05 0010
Coding: 00000130
Shop #: WSC 00000
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 970 H HW: 5K6 920 970 H
Component: KOMBI H03 0305
Serial number: 00000000000000
Coding: 270F00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 AD HW: 1K0 907 951
Component: J533 Gateway H07 0111
Revision: H07 01 Serial number: 041109F1000816
Coding: E9817F07101612000002
Address 1C: Position Sensing Labels: None
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223T6P0904
Coding: 0000002
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0305
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
Component: SG EXT.PLAYER H13 0090
Revision: A1001003 Serial number: 7667650699
Coding: 010000
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2113
Coding: 0001204
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 74 3001
Revision: 00H17000
Address 47: Sound System (R12) Labels: 5K0-035-456.clb
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06
Revision: -------- Serial number: BP218198623154
ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
ROD: EV_AudioVerst8KanalBNO1.rod
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
Address 55: Xenon Range Labels: 5M0-907-357-A.lbl
Part No SW: 5M0 907 357 C HW: 5M0 907 357 C
Component: AFS-Steuergeraet 0142
Revision: 00H04000 Serial number:
Coding: 1446940
Part No: 7L6 941 329 B
Component: AFS-Lst.-Modul l 0004
Coding: 00000022
Component: AFS-Lst.-Modul r 0004
Coding: 00000022
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H10 0035
Revision: -----20S Serial number: VWZ4Z7J1126659
Coding: 0101000001
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
Address 65: Tire Pressure (J502) Labels: None
Component: RDK 103 0521
Coding: 018705
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0001168
Address 77: Telephone (J738) Labels: None
Part No SW: 1K8 035 730 C HW: 1K8 035 730 C
Component: Telefon H08 6600
Revision: 00008000 Serial number: 20389520283918
Coding: 412100
End ---------------------------------------------------------------------
=========CONTROL MODULE 3==========
Monday,17,May,2010,16:15:06:17431
Address 03: ABS Brakes Labels: None
Control Module Part Number: 1K0 907 379 AH HW: 1K0 907 379 AH
Component and/or Version: ESP MK60EC1 H30 0107
Software Coding: 114B600C492300FD880C06EA921F0041300800
Work Shop Code: WSC 01357 011 00200
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 7
Reset counter: 61
Mileage: 9050 km
Time Indication: 0
Date: 2005.14.23
Time: 12:35:20
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 233
Count: 51259
Count: 255
Count: 0
Count: 0
Forum Sponsor
05-17-2010 06:59 PM
#2
Looks to me like you've got a defective ABS control module.
-Uwe-
Member
05-18-2010 12:49 PM
#3
great, that sounds like a trip to the dreaded dealer then for some warranty work.
thanks
12-15-2010 02:17 PM
#4
I just got the ESP error code this morning. Going to take my car into the dealership this weekend. Just wondering what ended up being wrong and what they did to fix it.
Thanks.
Member
12-15-2010 05:36 PM
#5
Well, This was a fun experience.
I had my car in the shop for 25 days due to this ESP error light.
Anyway, to make a long story short,
ABS Module, ABS Pump, and two other small sensors all had to be replaced.
Once they fixed one thing another thing went wrong.
I dont know if it was all a coincidence or what.
VW of america was involved being my car was out of commission for so long (dealer issues.)
The actual working time was about 4 or 5 days with all other the things that went wrong, and a good chunk of it was waiting on parts to come in.
Hope you have better luck than I did.
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
Forum Rules
