stud build![]()
#106
do you have any estimation of a completion date?
my car
FS:mk4 jetta fenders; mk4 jetta hood uniblack. pm for details
4th Annual Scooter's GTG European Car Show-Saturday June 9th 2012 Milwaukee, WI
http://forums.vwvortex.com/showthrea...ukee-Wisconsin
#108
2001.5 S4 VR6 Build Thread http://www.audizine.com/forum/showthread.php?364704-Big-Boost-s-VR6-BAT-Build!
www.o2induction.com
#109
so....breaking it in going to dubs in the valley if its done?
my car
#111
Simply amazing![]()
the fabrication in this thread is just nuts...keep it up![]()
I want to see this thing in action!
#112
The party is about to start again. The fuel system lines and fittings are in hand and ready for fab and installation.
www.o2induction.com
#113
What kind of fuel line did you go with? Only reason I ask is I just finished my fuel system and had an issue with hose I bought losing approval for fuel use after I purchased it.
#114
I bought the Goodridge lines from Pegasus Racing. It is the PTFE lines that can handle E85, methanol, etc along with the appropriate fittings. What lines did you purchase?
www.o2induction.com
#116
www.o2induction.com
#117
www.o2induction.com
#118
Congrats on the euro turner page ! Must be getting anxious to drive it now eh
#119
I need to see the final results of this build. This has been one of the most epic builds I have followed.
We bow down to you sir.
"I'm gonna fill a pillow case full of bars of soap, and beat the $#!t out of you..."
I want my S4....
#121
I'm hoping for 1000 crank, but realistically 800 crank may be more achievable. We'll see.
Here's an update on the progress....
Here are the parts that have just been wet sanded with a final 2000 grit. The next step is the final two step polish on those parts plus the intake manifold, turbo discharge plenum and the intercooler.
Below are the pix of the repaired bumper!
The bumper and the core support both have provisions for the mounting points, but it's not permanently installed yet. It has been test fitted and fits like OEM despite being severely modified. In its final resting position, it fits snug under the lights and the Bentley manual was used as a reference for all of the body panels in terms of fitment and spacing. The short story, yeah I know the bumper is hanging and it looks like it doesn't fit, but TRUST ME, it fits fine.
This is the first time the car has seen daylight!!
The OEM grilles still have to be reinstalled, but you can get the gist of how it will look.....stock. It should cover up the core support perfectly just enough so that the casual onlooker will have no idea what's behind it.
www.o2induction.com
#123
UPDATE!
Fuel lines attached to the bulk head fitting.
4" 304 stainless downpipe with bungs for O2 and wideband sensors.
Here are some pixs of the final polishing....
www.o2induction.com
#125
this build is absolutely amazing!i cant wait to see it run!!! what kind of money do you have into this?
#126
UPDATE! The following things are complete:
Overflow coolant tank
Overflow lines for A/W intercooler and radiator
Wastegate vacuum lines
Boost solenoid lines
Brake booster line
Vacuum check valve
Bleeder cylinder for cylinder head
Thermal covers for A/W intercooler return lines
Fuel pressure sender installed
Fuel lines ran underneath car
www.o2induction.com
#127
More to come.......
www.o2induction.com
#129
wait.. wtf youre located in Milwaukee, Wi?
#130
#134
#135
UPDATE! Here are a pack of three more things that require wiring! This should resolve any cooling issue I may have.
This is a thermal barrier to protect the paint on the strut tower housing.
[SIZE=2]This is the underside of the overflow coolant tank. Yes, it will be mirror polished too![/SIZE]
www.o2induction.com
#136
Wow wonderfully done
If your not Passing then stay Right --->
(860) NLC Dub's & Euro'sWas originally LGSVR6 back in the day but i forgot my password....
#137
this is beautiful.. you should just get a clear hood to show it off all the time
http://www.lowbuds.com/
I do custom trunk setups, false floor, powder coating, media blasting, polishing, custom carbon fiber parts, custom fiberglass subwoofer enclosures, wheels repair/assembly.
PM me with what you have in mind and we can make it happen!
#139
yeah, he made mention of that typo shortly after that post
Now, which one of you humps has got a cigarette for Dr. Rockso?
#140
I finally got around to working on the OEM harness to allow the factory cluster to work properly. I also began pre-wiring the car for the audio system. The audio system design will have cues from the engine bay. It should turn out pretty good. As far as equipment, that's still in the air. I'm also waiting on the final word for the one off set of wheels for the car. I want to start the car in about 2-3 weeks if everything goes as planned.
As far as HP numbers, I hope to lay down at least 800 to the wheels. I have more than enough fuel and turbo CFM to do more, but I hope to start there. Regarding how much money I have invested in the car, I gotta keep that one to myself. Let's just say if the wife found out she may want to buy another house.
What's really funny is when some friends saw the car in person, they all said "How could you race this car?" They all want me to use it as a show car.
My thoughts......F*CK that. Why?? Because Race Car.
www.o2induction.com
