VWVortex.com - 1.8T Problem - Crank, no spark. - Fun Challenge
    Results 1 to 24 of 24
    Thread: 1.8T Problem - Crank, no spark. - Fun Challenge
    1. 05-20-2010 08:20 AM #1
      Guys, I am in a bind right now. I need this car to run, you guys know when your wife's car needs to work!!
      Audi A4 1.8TQ 1998 - AEB Engine.
      The car started to stall by itself when coming back from work. Would start again for a few minutes. This went on, the car was getting harder and harder to start. Now, no start at all.
      I have the car in my driveway at the moment, got codes from my new VAG Hex-Can...will post them later.
      1- Coil pack gets voltage, but no spark, or no trigger.
      2- I measured the resistance between the center pin of the left bank of the ICM with the 4 pin of the right bank and got different resistance.
      1- 7.5 Mohms
      2- 0.013 Mohms
      3- 7.5 Mohms
      4- 7.5 Mohms
      This indicates that the ICM was bad, or on its way. I got a used one, (I need it fast) resistance all measured at 8.5 Mohms. I think this one is good.
      3- I get throttle body codes,
      4- Throttle body: The cable to the throttle is loose, is that normal? I hear the car trying to adjust the TB every time I try to start it.
      Also, I hear a clicking noise from under my steering wheel, very often when I put the can to "ON"...like a clicking relay.
      Help me out guys,
      Thanks
      Dayz
    2. 05-20-2010 12:20 PM #2
      Quote Originally Posted by Dayz View Post
      1- 7.5 Mohms
      2- 0.013 Mohms
      3- 7.5 Mohms
      4- 7.5 Mohms
      Help me out guys,
      Thanks
      Dayz
      Check the obvious, fuses, then relays, then crank sensor(s) then cam sensor...
    3. 05-20-2010 04:32 PM #3
      Chassis Type: 8D - Audi A4 B5
      Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
      Mileage: 218510km/135775miles
      Address 01: Engine Labels: 058-907-55x-AEBN.lbl
      Part No: 8D0 907 557 P
      Component: 1.8L R4/5VT MOTR AT D07
      Coding: 06251
      Shop #: WSC 06335
      5 Faults Found:
      18010 - Power Supply Terminal 30: Voltage too Low
      P1602 - 35-10 - - - Intermittent
      16521 - Oxygen (Lambda) Sensor B1 S2: Signal too Low
      P0137 - 35-00 - -
      17967 - Throttle Body (J338): Fault in basic settings
      P1559 - 35-00 - -
      18048 - Internal Control Module: EEPROM Error
      P1640 - 35-00 - -
      17953 - Throttle Valve Controller: Malfunction
      P1545 - 35-00 - -
      Readiness: 0110 0101
      Address 02: Auto Trans Labels: 01V-927-156.lbl
      Part No: 8D0 927 156 BN
      Component: AG5 01V 1.8l5VT USA 8508
      Coding: 00000
      Shop #: WSC 00000
      2 Faults Found:
      00529 - Engine Speed Signal Missing
      31-10 - Open or Short to Ground - Intermittent 00526 - Brake Light Switch-F
      27-00 - Implausible Signal
      Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
      Part No: 8L0 820 043 D
      Component: A4 KLIMAVOLLAUTOMAT_D75
      Coding: 04140
      Shop #: WSC 06335
      1 Fault Found:
      01206 - Signal for Duration of Ignition Off Time
      27-10 - Implausible Signal - Intermittent
      Address 15: Airbags Labels: None
      Part No: 8D0 959 655 D
      Component: Airbag 7 Audi 0302
      Coding: 00104
      Shop #: WSC 06335
      1 Fault Found:
      00532 - Supply Voltage B+
      07-10 - Signal too Low - Intermittent
      Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
      Part No: 8D0 919 880 QX
      Component: B5-KOMBIINSTR. VDO D10
      Coding: 06342
      Shop #: WSC 03023
      No fault code found.
      Address 35: Centr. Locks Labels: 8D0-862-257.lbl
      Part No: 8L0 862 257 N
      Component: CV-Pump D05
      Coding: 16200
      Shop #: WSC 06335
      10 Faults Found:
      01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
      35-00 - -
      01371 - Alarm triggered by Door Contact Switch; Driver's Side
      35-00 - -
      01374 - Alarm triggered by Terminal 15
      35-00 - -
      01370 - Alarm triggered by Interior Monitoring
      35-00 - -
      01369 - Alarm triggered by Hood Switch
      35-00 - -
      01368 - Alarm triggered by Luggage Compartment Switch
      35-00 - -
      01366 - Opened Due to Crash Signal
      35-00 - -
      01365 - Lock/Unlock Switch; Interior
      29-00 - Short to Ground
      00955 - Key 1
      09-00 - Adaptation Limit Surpassed
      00956 - Key 2
      Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
      Part No: 4B0 951 173
      Component: Innenraumueberw. D02
      Coding: 00101
      Shop #: WSC 06335
      2 Faults Found:
      01382 - Alarm triggered by Anti-Theft Sensor; Front Left
      35-00 - -
      01383 - Alarm triggered by Anti-Theft Sensor; Front Right
      35-00 - -
      Address 56: Radio Labels: 8D0-035-1xx-56.lbl
      Part No: 4B0 035 186
      Component: Radio D01
      Coding: 00117
      Shop #: WSC 06335
      End ---------------------------------------------------------------------
    4. 05-20-2010 06:04 PM #4
      You have a lot of codes there. OK, so clear the codes and try to start. I have a suspicion that it is the immobilizer but clearing the codes (all of them) might prove that it's just a low battery causing all that trouble. I still think it's crank sensor related but could also be something more...
      So, clear the codes, try to start, check again for codes... some codes might disappear where the ones that are truly at fault will come back...
    5. 05-20-2010 08:02 PM #5
      Codes are clear. The only ones that comes up intermittently are the Throttle body. Trans comes with 0 codes and the rest is not important at this point.
      How do I test a Crank sensor and a Cam sensor? I have Genuine Vag Com, can I test them with that? The car won't start.
      Thanks
      Dayz
    6. 05-21-2010 01:50 AM #6
      I'm friend of "DAYZ" in his driveway looking at the A4.. After some research, it does sound like the Crank Position Sensor could be the problem, but would it not show in the fault codes? Is there any way to test it other than replacing it?
      The current fault codes are as follows:
      Coding: 06251
      Shop #: WSC 06335
      4 Faults Found:
      P1559 - 35-00 - -
      P1640 - 35-00 - -
      P1545 - 35-00 - -
      Coding: 00000
      Shop #: WSC 00000
      1 Fault Found:
      Coding: 04140
      Shop #: WSC 06335
      1 Fault Found:
      Coding: 16200
      Shop #: WSC 06335
      1 Fault Found:
      35-00 - -
      Other notes:
      -All 4 coil packs were changed.
      -All 4 spark plugs were changed.
      -Fuel filter was changed.
      -2000 km was driven after that, then the car stopped on the road but could be started again. It has been stalling ever since and now it won't start at all.
      -As noted above, ICM was suspicious as per multimeter test and was changed for a used HUCO ICM from a 98 Passat.
      Any ideas would be appreciated!!
    7. 05-21-2010 11:09 AM #7
      Quote Originally Posted by SAphoto View Post
      Coding: 06251
      Shop #: WSC 06335
      4 Faults Found:
      P1559 - 35-00 - -
      P1640 - 35-00 - -
      P1545 - 35-00 - -
      Coding: 00000
      Shop #: WSC 00000
      1 Fault Found:
      Coding: 04140
      Shop #: WSC 06335
      1 Fault Found:
      Coding: 16200
      Shop #: WSC 06335
      1 Fault Found:
      35-00 - -
      Other notes:
      I am thinking this is actually related to code 18048... Here's what Ross-Teck Wiki says:
      18048/P1640/005696 - Internal Control Module: EEPROM Error
      Possible Causes
      Engine Control Module modified (e.g. Chip Tuning)
      Engine Control Module faulty
      Possible Solutions
      Contact your Tuner
      Replace Engine Control Module
      For more info on MIL codes go to:http://wiki.ross-tech.com/wiki/index...ry:Fault_Codes
      Good luck, I hope you find the problem. Make sure you report back what you find so as to help others who might have the same issues as you. Sorry for your misfortune...
    8. Member TheBossQ's Avatar
      Aug 15th, 2009
      2003 Jetta Wolfsburg; 2005 Jetta 2.5; 2006 Nissan Titan; 2011 EOS 2.0T
      05-21-2010 11:23 AM #8
      Thanks
      Dayz
      You need an oscilloscope to test the crank and cam sensors.
      Feb 8th, 2002
      MA
      2012 4dr GTI Autobahn, RIP: 2000 4dr Golf GLS 1.8T - 226384 miles.
      05-23-2010 03:06 PM #9
      P0321, P0322 would indicate unusual or missing crankshaft sensor signal. Test the crankshaft sensor - 730-1000ohms between pins 2 and 3. Infinity between the other pin pairings.
    10. 05-25-2010 06:43 PM #10
      UPDATES:
      Crankshaft position sensor was replaced with a brand new one, no change.
      Fuel pump relay is clicking. In fact when the car was still starting there was a lot of clicking going on but I didn't know what that was exactly. Now that I've opened the relay compartment and felt the clicking, I can say it was likely the FP relay going nuts.
      QUESTIONs
      Could this be the source of the problem? Would a bad fuel pump relay cause the car to crank and not spark??
      Another thing I could check is the camshaft sensor but how can this be done? I only have access to a multimeter.
      I'm starting to run out of things to check and replace!
    11. 05-25-2010 07:19 PM #11
      UPDATES:
      QUESTIONs
      You got a error code 18048 which according to the ross wiki says the ECU is bad. Take it out and bring it to the dealer, have them verify it's bad...
    12. 06-01-2010 08:51 PM #12
      This is not a fun challenge anymore
      Used ECU from a working car arrived today.. still no start.. but now I get a new codes (these codes can't be from the car it came from right?):
      4 Faults Found:
      16716 - Knock Sensor 2 (G66): Signal too Low
      P0332 - 35-10 - - - Intermittent
      18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
      P1606 - 35-10 - - - Intermittent
      16487 - Mass Air Flow Sensor (G70): Signal too High
      P0103 - 35-10 - - - Intermittent
      SHORT HISTORY OF RECENT WORK:
      -4 coil packs replaced by new
      -Spark plugs replaced, I believe gapped at 28 instead of 32 (to be verified and fixed)
      -Fuel filter replaced (new)
      -Stab link right and left (new)
      2000km driven, then problems above started (stall and now no start)
      -ICM replaced by used HUCO ICM from a Passat (pins tested)
      -Crank shaft Position sensor replaced with new one
      -ECU replaced with used one from working car
      What do I do now?
    13. Member guayne's Avatar
      Jan 6th, 2010
      Capital Region, NY
      337 GTI, E36 M3
      06-01-2010 10:31 PM #13
      have a beer, it should help the audi turn over
    14. 06-03-2010 03:35 PM #14
      With the help of ETHER, the engine started (hallelujah). Once started it runs fine (I did not drive it, just at idle). I turned it off and on again. It did start, but with difficulty, and the following code appeared: 17956 - Boost Pressure Regulation Valve N75
      Cleared the code, it did not reappear. Now the car doesn`t start again -although I`m sure it would with ether.
      Any reading I should check from the VAG measuring values? Any suggestions? (besides beer)
    15. 06-03-2010 04:08 PM #15
      It does sound more and more like the Fuel Pump Relay, since you can get it to start with a shot of starting fluid, and the fuel pump relay was making funny rapid clicking noises.
    16. 06-14-2010 11:35 AM #16
      Finally the problem has been isolated. Voltage at the fusebox is 0.215 and same at the pump. Connecting the battery directly in fuse 28 (fuel pump) will start the car. So the problem is between the battery and the fusebox.
      The question is what to check now. I don't know how to follow the wire or where to look. I'm starting to lack time for all this and I think it would be cheap to get it fixed at a mechanic given the problem is identified, but if it's something I can do on my own quickly I'm all ears.
      Thanks again.
    17. 06-14-2010 01:15 PM #17
      I believe that fuse #28 (green wire) comes FROM the Fuel Pump Relay, so it's still quite possible that the relay is faulty.
    18. 08-26-2010 11:22 AM #18
      have the same problem on a TT 2002 roadster
      p1602 voltage supply
      p0321 engine speed sensor
      krank sensor was good but has still been replaced.
      the wiring is good from the krank to ecu and from ecu to the coils.
      I get no spark, the coils are good, but i still changed them to be sure, spark plugs are new.
      The coils are not getting any trigger.
      If i start the car and look in the measuring blocks, i will see the RPM go up to 200-240 rpm.
      i checked with a used ecu from a jetta 2002 180 hp it should at least start for 2 seconds before it stalls again because of the immobilizer. But it does the same exact thing and in addition a couple more dtcs (02 sensor)
      In case you ask me, fuses are OK, all grounds ave been cleaned and ecu relay is good.
      The problem is: no trigger from the ecu to the coil even if the ecu gets the rpm right
      Help !
    19. 08-26-2010 11:50 AM #19
      So with the new crank sensor, can you clear the P0321 error, and it will come right back? If so, I would double check that the signal from the crank sensor is indeed getting right to the pins on the ecu.
      I'm not sure if the ecu does this or not, but it could derive rpm from the cam sensor. If so, then you could still have a bad signal from the crank sensor, but still read an rpm from the ecu measuring blocks.
      98.5 A4 B5 1.8T ebay TO4E [:/]
    20. 08-26-2010 02:06 PM #20
      as i said, the krank sensor wiring has been checked and is fine.
      the cam sensor has been checked too, we even tried with another one from a spare 1.8t i have.
      i just checked the timing and it is perfectly on .
    21. 08-26-2010 02:34 PM #21
      Did you try to reset the error code to see if it comes right back? Just wondering if the ecu still thinks the Crank sensor is still a problem, or whether that has been resolved.
    22. 08-27-2010 07:23 AM #22
      I've reset it too many times allready...
      i've even touched the 2 battery poles together to empty all the condensers to reset it for real.
      i'm now thinkin about recoding the ecu, don't know if that could do something.
      one last interestingt point is the krank sensor, vw carry 2 different krank sensor, the difference would be the wire's lengt.
      My parts supplier carries 1 krank sensor, it is the one with the longer wire.
      That makes me think maybe there could be a possibility of problem there, but, i still get the fvcking signal in the measuring blocks.
      Oh and one last important point : I tried the AMU ecu into an AWP jetta and it started, if i try the AWP ecu in the TT, it won't start, in all case, the TT will never start (make a spark). there are no trigger coming out of the ecu to the coils.
      WHAT THE H3LL IS WRONG ???
    23. 08-27-2010 11:27 AM #23
      problem found
      Piston rod no1 and no4 bent
      the number 4 rod bent the sensor wheel for krank sensor.
      i didn't open further but it will need at least a set of piston rod @ 900 CAD + a sensor wheel @ 60 CAD
      or a new engine.
      thannks for help tho
      Max
    24. 08-27-2010 11:54 AM #24
      wow
      wonder how that happened? timing belt was okay. did those pistons hydraulic? usually predetonation breaks rods, not bends them. just curious. sorry about the news though.
