I just did it earlier this week and I have an AWW engine. It is very close minus a few vac. ports.
I am sure that these engines will be very similar. I would cap off the extra ports that still hold vac. and run everything straight to the manifold.
I like the difference that I am seeing in my car now. I didn't realize that I had some lines that were busted underneath my intake manifold causing vac. leaks and it a bit messy underneath from some oil coming out.
Thanks for an amazing write up!! It really helped.![]()
. He showed me the "part" that I would have to buy and its $180! Its that whole system of piping including hard pipe and their connectors. They were very friendly but said it doesn't look like they sell just the T fitting anymore. I have an AWD engine code and the more I thought about it the more I think that the OEM equipment for my vehicle is different then what they now sell in their parts... the two hoses that intersect the same T fitting that are NOT broken off both have hose clamps on them. Can anyone else confirm that not all engine codes have the 'all-in-one' hose mess as a single part?
