Page 4 of 19 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 635
Thread: DIY: Ultimate SAI/N249/PCV/EVAP Delete
  1. Banned erevlydeux's Avatar
    Jul 29th, 2006
    road island
    2004 hunk' o metal
    12-07-2010 07:29 PM #106
    Quote Originally Posted by HardHittaz00 View Post
    This may be a stupid question, but if the ecu no longer controls your boost levels then what does? I've got the stage 3 APR kit and am about to do this full delete, but I have no manual boost controller or anything.
    Then you need a manual boost controller.
    Jan 30th, 2010
    Jacksonville, NC
    2002 GTI 1.8T
    12-07-2010 09:07 PM #107
    Well, your N249 just interrupts your DV/BOV so it will still work just fine connected directly to manifold pressure, better in fact. During self troubleshooting or limp, the ECU will induce vacuum to your DV/BOV, using the N249, in an attempt to pull boost from the system. The N75, EBC or MBC will still control your boost levels.....
    Understand?
  3. 12-08-2010 02:39 AM #108
    Thanks chaveezy! I kind of understand But you're saying I'll be fine without a mbc? I will still boost and cut off at the proper levels?
  4. Member
    Jan 30th, 2010
    Jacksonville, NC
    2002 GTI 1.8T
    12-08-2010 06:45 AM #109
    Yes of course it will, your chip controls your N75 valve, which bleeds boost away from the wastegate, which in turn raises boost levels. (without the N75 you would only boost until wastegate pressure is reached ~14psi, depending on your installed spring).
    Your N249 valve is another way to interrupt the DV, which is just another way to bleed boost levels away during self troubleshooting (limp), and other part throttle conditions. I'm not sure of the exact N249 logic, but in a nutshell that's what it does/is able to do.
    Hope this helps.
  5. 12-08-2010 07:58 PM #110
    Yezzir! Much appreciated! Just was a little confused.
  6. Member l88m22vette's Avatar
    Mar 1st, 2006
    Chicagoland, IL
    12-08-2010 08:51 PM #111
    Quote Originally Posted by chaveezy View Post
    With a Forge actuator or straight spring on a 3071, yes, but the k03/k04 run at 5psi on the spring, which is also why limp mode is at 5psi (you can't get around the mechanical boost controller)
    Jan 30th, 2010
    Jacksonville, NC
    2002 GTI 1.8T
    12-09-2010 05:57 PM #112
    I'm on a GT2871R and I'm at standard wastegate pressure (~14psi), however, it was more to make a point.. That's why the note, "depending on your installed spring".
    Good catch though
  8. 12-09-2010 07:34 PM #113
    dont know if i missed it in there but what are the benifits of this delete. Thanks in advance
  9. Member hootyburra's Avatar
    Feb 19th, 2007
    Bloomsburg PA
    337.sold 2.slow
    12-09-2010 10:50 PM #114
    Quote Originally Posted by kdawg24 View Post
    to help you become less of a noob and more familiar with your car.
    CTS 3076 kit, CTS 750hp FMIC, CM FX400, 2L, AEB, RMR IM, Raxles, Eurodyne, 870's...
    Vag Scans, pm me
  10. 12-09-2010 11:00 PM #115
    thanks dunbsh*t any one else that is not an a**
  11. Member nstevic01's Avatar
    Nov 9th, 2007
    Land O Lakes, Fl
    2003 VW GTi 1.8t
    12-09-2010 11:35 PM #116
    Well he is correct in a way, you do get more familiar with your car. If you are new to cars or your dub in general, I would not recommend this as a first mod.
    Some benefits include, cleaning up the engine bay making things like oil changes and identifying leaks easier, simplifying the vac lines, the addition of an oil catch can to trap the "crap" that goes through the old PCV setup.
    Also is beneficial in saving money on costly part replacement in non-emission states. So if your SAI, EVAP regulator, or Combi go bad, you can just delete them.
    Most everyone will agree that the car runs ALOT better with this delete done. Keep in mind if your state has emissions related inspections, you will most likely fail if you perform this delete. So keep that in mind.
  12. 12-09-2010 11:41 PM #117
    thank you nstevic that wasnt so hard, i'm not new did timing belt by myself just not advanced enough to start removing designed in parts of the car with out asking what the benifits vs risk are and i am in cali so this would not be prudent due to emission standards
  13. 12-10-2010 12:13 PM #118
    Just to be sure...I can leave the evap, n249, & n112 plugged and tucked away?
    Also, can anyone tell me what to do with this on my TT (awp)? It is in the location of the blue balls on the normal AWP. It has 3 wire so resistoring doesn't seem the option. The lines go to the same location you remove and cap. Right now I plan on leaving it in placed connected.
    Thanks.
  14. Banned erevlydeux's Avatar
    Jul 29th, 2006
    road island
    2004 hunk' o metal
    12-10-2010 01:59 PM #119
    Quote Originally Posted by sprockeTT71 View Post
    check my sig. I can help you with getting some nice resistors for evap/n112/n249 so you can shed that extra weight/clutter.
  15. 12-10-2010 03:17 PM #120
    Can I delete the pcv system and not bother with a catch can?
  16. 12-10-2010 03:19 PM #121
    Quote Originally Posted by finesse View Post
    You cannot plug up the holes. You can use a filter on each location, some have done it. Or you can run a hose down to the floor so it leaks on the ground.
  17. 12-10-2010 04:19 PM #122
    thank you dub,
    I have to do this on a budget
  18. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    12-10-2010 04:38 PM #123
    ^^^ get rid of all that ish and run a hose to the floor from the crankcase and a filter off the valvecover and be done with it
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  19. Member J@H Dub 1.8t's Avatar
    Apr 11th, 2007
    Coconut Creek, FL
    03 JTI 1.8T
    12-28-2010 12:46 AM #124
    This is a GREAT diy but my question is have there been any boost leaks?
  20. 12-28-2010 02:55 AM #125
    I am about to do this delete but I am wanting to leave my Evap system alone. If i follow the first part of this guide do any of the lines intersect the EVAP system? or should I be fine. ? thanks for any help.
  21. Junior Member RobClubley's Avatar
    Jul 14th, 2006
    Wellington, New Zealand
    2004 Skoda Octavia vRS
    12-28-2010 03:24 AM #126
    You'll be fine. As you can see the evap system is separate:
    Shark Performance STS Stage 2 Corrida Red 2004 Octavia vRS Estate - It's the bestest Skoda in New Zealand!
    Car's Facebook Page
    Whaia te mātauranga, whaia te māramatanga - Pursue knowledge, pursue the wisdom of knowledge
  22. Member carsluTT's Avatar
    Dec 31st, 2004
    riVersIde, cA
    12-31-2010 12:52 PM #127
    great info
    CNC plasma/router services, tig welding, sheet metal work,boost tubes, cages made in house, paint/body VAG-COM. need parts made? PM me i can help, parts are shipping daily
    dCi-vW
  23. Junior Member
    Feb 16th, 2010
    2002 Jetta GLS 1.8T
    01-02-2011 02:39 PM #128
    What will happen if I only remove the sai, n249, and pcv systems and run a separate line for the evap?
  24. Junior Member RobClubley's Avatar
    Jul 14th, 2006
    01-02-2011 02:48 PM #129
    Quote Originally Posted by pryorjack View Post
    I've done that - and removed the evap line to the intake leaving just the one to the throttle body. No issues.
    Car's Facebook Page
  25. Junior Member
    Feb 16th, 2010
    2002 Jetta GLS 1.8T
    01-02-2011 05:32 PM #130
    Quote Originally Posted by RobClubley View Post
    awesome. i will be doing this soon
  26. Member pielout's Avatar
    Jul 12th, 2006
    Wichita KS
    BT JB 20th #0818
    01-05-2011 09:43 PM #131
    Since I just got chipped(Unitronics), I also got the CAT SAI and EVAP deletes in the program....my question is do I still have to run resistors since those got deleted already? I wouldn't think so but I'm not sure
  27. Member carsluTT's Avatar
    Dec 31st, 2004
    riVersIde, cA
    01-05-2011 11:25 PM #132
    Quote Originally Posted by pielout View Post
    well... search would tell u this, but ill make it a touch easyer for you....... yes u need resistors even if u had the deletes done in your software and removed the physical parts. with out resistors your car will not adapt the fuel trims and such properly. all that happens with out the resistors is ull have a car that runs ok and dosnt get a cell the way your setup now. if you use the search button or read this whole thread u should find plenty of info showing why its important to have both a software delete and resistors to get things running properly.
    dCi-vW
  28. Member pielout's Avatar
    Jul 12th, 2006
    Wichita KS
    BT JB 20th #0818
    01-05-2011 11:41 PM #133
    thank you for being kind and not blasting me to hard I DID read every post in this thread I just didnt recall anybody saying they had the deletes and resistors(maybe I did just didnt catch it) now I know, thank you sir
  29. Member MNShortBus's Avatar
    Mar 13th, 2008
    Maple Grove, MN
    2003 IY GTI
    01-05-2011 11:50 PM #134
    So far I have removed everything but the evap system. Are there any negative effects of removing the evap system, or risks? I don't have emissions testing in my area, so I'm not worried about that.
  30. Member mooreboy947's Avatar
    May 3rd, 2009
    Independence, KY
    04 GLi
    01-07-2011 12:04 AM #135
    Question here there is a picture of the evap lines being capped off after removal behind coolant ball.... Tell me if I'm wrong but wont that cause vapor lock since the vapors have no whre to go but through the gas lines or shooting your gas cap off at the pump.Please correct me if I' wrong on that one so I can correct it or not.
  31. Member 1.8Tbsl's Avatar
    Nov 11th, 2005
    Hawaii
    01-07-2011 01:37 AM #136
    Need Help...I did the full delete and now i have a very bad idle. Goes up to around 1000rpm and then down to 500rpm and eventually car dies out. I can drive, but once i come to a stop it almost dies unless giving some gas. No codes pop up.
  32. Junior Member RobClubley's Avatar
    Jul 14th, 2006
    01-07-2011 02:17 AM #137
    Sounds like you might have a vac leak somewhere
    Car's Facebook Page
  33. Member nstevic01's Avatar
    Nov 9th, 2007
    Land O Lakes, Fl
    2003 VW GTi 1.8t
    01-07-2011 10:18 AM #138
    Quote Originally Posted by mooreboy947 View Post
    13k miles with this method and 0 issues.
    PM me for SAI/N249/PCV/EVAP Delete parts and kits -->http://www.diydeleteparts.com/
  34. Member HereTryThis's Avatar
    Feb 2nd, 2008
    York Region
    MK4 tr wolf / MK6 cw GLI
    01-07-2011 12:07 PM #139
    I cut mine back to the pump and left them un-capped. no issues, slight gas smell on the odd day.
    AWE downpipe/ Neuspeed TOP & TBP/ TC button/ Euro switch/ B6 passat alum control arms and spindals.
    Scraped Crusaders
  35. Member mooreboy947's Avatar
    May 3rd, 2009
    Independence, KY
    04 GLi
    01-08-2011 12:46 AM #140
    I didn't want to seem like a smart ass or anything just trying to figure out the best way to do it. Is there any way to permantely delete codes with VAD mobile anyone???????
