Page 2 of 24 FirstFirst 1 2 3 4 5 6 12 ... LastLast
Results 36 to 70 of 837
Thread: Holset user thread
  1. Member turboit's Avatar
    Oct 4th, 2001
    Delaware
    '04.5 Jetta Gli, '93 Corrado SLC
    06-09-2010 02:03 PM #36
    kinda wish I didn't sell my hx35 and put that on my jetta
  2. Member euro4-DoOr's Avatar
    Apr 8th, 2004
    Florida (941)
    97 golf 08 jetta 99 golf
    06-10-2010 12:42 PM #37
    here's mine......hy35....not done yet....but soon
  3. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    06-10-2010 02:50 PM #38
    Awesome!!!!! Please post more info on your setup, such as manifold, engine work, dp, software etc. Anything you can think of post it up. The more info the better
  4. Member Boost112's Avatar
    May 7th, 2002
    Miami/ Orlando
    1995 VW : 2010 VW : 2013 VW
    06-10-2010 03:15 PM #39
    Quote Originally Posted by Dave926 View Post
    x2
    --- SPACE FOR RENT---
    Quote Originally Posted by schwartzmagic View Post
    Those VRTs are so full of win :-D
    www.dubcartel.net
  5. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    A founding Member of the 8v 350+whp Club, Now rocking a B7 S4 mmmmm V8!
    06-13-2010 07:06 PM #40
    done friday...
  6. Member Sparknock's Avatar
    Feb 24th, 2004
    Laddy's Island SC
    98 golf gl and 97 GTI 16vT
    06-13-2010 10:01 PM #41
    why is every using a hx35? you can get an HE351cw that come with a 9cm2 exhaust and a muck better compressor disign then the hx35
    with great power comes great responsibility......so push the gas pedal to the floor
    (Oo====oO)
  7. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-13-2010 10:26 PM #42
    Quote Originally Posted by Sparknock View Post
    design (90* bend of compressor can bring problems), price, and availability. The only real thing the HE351 has over the HX35 is faster spool which is attributed to the 9cm hotside not compressor wheel design... the HE351 has a large compressor wheel but flows the same and has the same efficiency (roughly) to that of the HX35
    HE351:
    HX35
  8. Member acee_dub's Avatar
    Jun 12th, 2008
    Outside, looking in.
    Cut Springs Vento 2l 8v
    06-14-2010 01:51 AM #43
    Quote Originally Posted by Quintin@USRT View Post
    done friday...
    Going to do some dyno runs?
  9. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-14-2010 09:03 AM #44
    Quote Originally Posted by acee_dub View Post
    eventually.
  10. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    06-14-2010 08:41 PM #45
    I believe the he351 does flow a bit more. But q is right, that 90* is a bitch. The only way it will fit on any vw would be with a sri, or a 1.8t of some sort. Except most of 1.8t guys only talk about garretts and pte turbos that the dsm guys have proven how ****ty the chra's are at med to high boost.
    There is a dsm named aero who ran the he351ve (the vgt one) using a 14b actuator. Before his rod bearing went he was seeing positive manifold pressure around 2400 rpm. I'm not into fast spool but a turbo that spools before 3k and pump out 500+ whp is better than any turbo imho. Plus being able to have it act like a big hotside on the top end makes the turbine more efficient.
    Quint if you could post up at what point you see positive manifold pressure and at what point you see full spool that would be great
  11. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    mk2 coupe,mk4 golf both 2.0hhhhhhhhh
    06-14-2010 08:44 PM #46
    t
    yea i found this out
    12.2@116mph-293whp305wtq 22psi stock aba-AC-DD My Jetta
    Current Want list-sunroof delete,paint
    Fifteen52 - Urotuning
  12. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-14-2010 09:37 PM #47
    5psi by like 2800...11~12psi by like 3800 (3rd gear...but its a tall 3rd )
  13. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    06-14-2010 10:13 PM #48
    That's a lot better than most garretts....sounds like something a 50 trim would spool at. That's really good when you consider your car is an 8v
  14. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-14-2010 10:21 PM #49
    yea its not bad...i found a small boost leak today will go drive it tomorrow.
  15. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    06-15-2010 12:57 AM #50
    Now just imagine if you actually made a divided mani. Dsm people talk about picking up a few hundred rpm of spool, along with 'tuning' their oil pressure.
    Btw quintin what is your oil feed/drain setup? I currently have some russel -16an proflex hose on the way and I'm going to flare the stock cummins pipe and clamp it to that. The od of the cummins drain tube is .88 and the russell proflex line is .875 id
  16. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-15-2010 12:22 PM #51
    CORRECTION: positive pressure by 2400...5psi by 3200...10psi by 3800...20psi by 4400 (8v with ramhorn and 1.8t BT file)
  17. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    06-15-2010 04:50 PM #52
    That's a fast spool...like really fast. Makes me wonder about my hx30. Just by going your data I should spool a bit faster since mine is smaller and its on a 16v.
  18. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-15-2010 05:18 PM #53
  19. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    06-16-2010 12:03 PM #54
    That's just amazing. Can you elaborate some more on the speca of your motor, such as the bottom end, cam, headwork etc. Please let us know the oil feed and drain setup as well
  20. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-16-2010 12:12 PM #55
    2008cc 8v 8.5:1 compression, TT266 cam, ramhorn manifold (undivided) i gasket matched and knife-edged the divider of the turbine inlet as a result, 3" DP....
    here's a lil fun run to show...still at 11~12psi
    this trans REALLY hates high rpms
  21. Member acee_dub's Avatar
    Jun 12th, 2008
    06-16-2010 01:02 PM #56
    nice work
  22. Member bigtoy302's Avatar
    Apr 26th, 2006
    Veneta, OR
    06-16-2010 11:13 PM #57
    I ran a HY35 on my 1.8t in my Corrado. It put down 342HP at 21PSI. Full boost was at 4800RPM. I later changed to a HX35 later and lost about 100rpm spool but did not notice much on the top end. I never had a chance to re dyno it. I did somehow manage to loose 5MPG going from the HY to the HX.
    I have since parted out the car and used the HX35 on my 4runner
  23. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-16-2010 11:16 PM #58
    ok tried out 16psi...wow...substantial difference...i think i'm happy here for now
  24. Member acee_dub's Avatar
    Jun 12th, 2008
    06-17-2010 12:00 AM #59
    Quote Originally Posted by bigtoy302 View Post
    Did you run a scroll manifold or no scroll?
    Contemplating whether I should get scrolled or open scrolled for my VR6 as I've heard spooling at low rpm is rough on the o2a's which aren't the strongest of transmissions.
  25. Member bigtoy302's Avatar
    Apr 26th, 2006
    Veneta, OR
    06-17-2010 12:16 AM #60
    Open. On my 2JZ I did a twin scroll and get 15PSI at 2900RPM. On a VR6 I think you would benefit from a twin scroll on the HX. The HY is open.
  26. Member
    Oct 1st, 2007
    northern nj
    2005 blue lagoon gli
    06-20-2010 02:11 PM #61
    Anyone out there running a hx35 on a 1.8t? thinking a bored 2.0 twin scroll hx35 might be a nice kit to build
  27. Member bigtoy302's Avatar
    Apr 26th, 2006
    Veneta, OR
    06-21-2010 11:02 PM #62
    I ran both hy and hx on my 1.8t. I liked the hy better for street driving.
  28. Member Boost112's Avatar
    May 7th, 2002
    Miami/ Orlando
    06-22-2010 10:49 AM #63
    anybody with experience of a hx40 on a 12v?
    www.dubcartel.net
  29. Member ricky_vwt's Avatar
    Nov 29th, 2005
    Daytona
    `00 GTi& A6 avant
    06-22-2010 04:39 PM #64
    Which engine code was as that? Stock internals?
  30. Member bigtoy302's Avatar
    Apr 26th, 2006
    Veneta, OR
    06-23-2010 11:10 PM #65
    Quote Originally Posted by ricky_vwt View Post
    AEB. Ported and polished head, Supertech exhaust valves, Wiseco .5mm over pistons, Scat rods. Megasquirt 2 management.
  31. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    06-24-2010 12:36 PM #66
    That high of a spool seems weird. Quintin has a pretty fast spool with an 8v
  32. Forum Sponsor Quintin@USRT's Avatar
    Oct 6th, 2009
    DC
    06-29-2010 02:25 AM #67
    by 4500...
  33. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    07-08-2010 02:53 PM #68
    Bumping bc I know there are more people using holsets
  34. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    07-09-2010 12:11 AM #69
    I'll be a user by maybe tomorrow or the end of next week
    Garret blew tonight
  35. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    07-24-2010 01:01 PM #70
    keep this going...where is hyperformancevw? I know he was running 12 flat in a mk2 running a holset of some variety
