Page 4 of 24 FirstFirst 1 2 3 4 5 6 7 8 14 ... LastLast
Results 106 to 140 of 839
Thread: Holset user thread
  1. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    1989 Helios GLI 1997 Mk3 ****box
    08-26-2010 12:44 PM #106
    Quote Originally Posted by frescoG60 View Post
    How well does the HX35 fit the VR6's characteristics?
    I would think similar to a 50 trim on a vr6, maybe a bit over 3 k for spool.
  2. 08-26-2010 03:21 PM #107
    Quote Originally Posted by Dave926 View Post
    2400rpm = 1psi 3300rpm = 20psi with 12cm hotside
  3. 08-26-2010 03:54 PM #108
    Dam that's quick spool
    Haters make me laugh
  4. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    08-30-2010 09:44 PM #109
    I found a user on here by the name of "G60 Scuzz." He ran a hx30 on his bone stock PG corrado and made 285whp @ 24 psi. I think 300 whp for me is no prob, considering that i'm running a 16v and I have the same holset actuator for some shenanigans
  5. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    08-30-2010 09:46 PM #110
    Thats faster than the .63 50 trim my friend had on his vr6. All it could do was 10 psi at 3300 or so.
    Watching the tach, boost and road in a vrt was never easy
  6. Member 1098lover's Avatar
    May 16th, 2009
    socal
    mk3 jetta VRT
    09-06-2010 03:55 AM #111
    I have a hx-35 on a 12v vr6 with a front mount and c2 42# software
    10psi at 3200ish
    http://www.youtube.com/watch?v=tENxPqzYzHo
  7. 09-09-2010 01:47 PM #112
    Quote Originally Posted by 1098lover View Post
    10psi at 3200ish
    what hx35 do you have 6/7/ or 8 blade compressor ?
    have you tried any other turbo on ur car to compare the differnces ?
    i read they dont come into there efficiency range till past 20psi ??
    Oct 1st, 2007
    northern nj
    2005 blue lagoon gli
    09-09-2010 06:42 PM #113
    Quote Originally Posted by magner View Post
    Ive read there are different 6/7/8 blade compressors depending on year of the turbo, any specific compressor better than the other?
  9. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    09-10-2010 08:56 AM #114
    All the information regarding compressor efficiency and what blade compressors are the best is all on the first page
  10. Member 1098lover's Avatar
    May 16th, 2009
    socal
    mk3 jetta VRT
    09-10-2010 08:07 PM #115
    I think it is a 8 blade wheel. Im told that that turbo is good for much more than 15psi but I am pretty sure that I will F#** something up if I run much more than that on a stock motor.
  11. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-11-2010 03:18 AM #116
    Holsets are efficient at over 30 psi above atm
  12. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    2001 MK4 2.0 Jetta....dont sleep ;)
    09-11-2010 03:48 PM #117
    My 8v dyno'd today...
    373whp
    367wtq
    25psi HX35 (54mm 7blade compressor)
    Mustang dyno...
    vids/pics up soon...
  13. Member Dave926's Avatar
    Mar 30th, 2005
    Rhode Island
    09-11-2010 03:58 PM #118
    what happened to usrt quintin.
    Holy **** btw. There is still 10 psi left in that turbo, but i think at 35 psi the head will lift
  14. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-11-2010 04:38 PM #119
    i was only with USRT as a side gig helping out...Full time i was Asst Manager at Advance Auto then came to work here at RAI and can't do both.
  15. Member obdONE's Avatar
    Jan 28th, 2002
    Houston
    95 VRT
    09-22-2010 10:48 AM #120
    Hey all, I hope to be a member of the Holset bandwagon soon. Looking to buy the hx35 that's in the classifieds right now. hx35 with an 18cm compressor housing. going on a 12v.
    any advice for starting out?
    This is a fantastic thread, btw. Thanks so much for all the info posted up.
  16. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 03:12 PM #121
    hx35 is roughly equal to a a GT30R, so go get 'em.
  17. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 03:23 PM #122
    Quote Originally Posted by Pat @ Pitt Soundworks View Post
    depending on which one outta the hundreds of models you get...mine came off a bus and is roughly equal to a t3/t4 50trim
  18. Member obdONE's Avatar
    Jan 28th, 2002
    Houston
    95 VRT
    09-22-2010 03:26 PM #123
    4" inlet
    2.5" v-band out
    3" v-band hot side
    if that helps at all...
  19. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 03:29 PM #124
    Quote Originally Posted by Quintin@R.A.I. View Post
    It's what, 6 lb/min difference between a 7blade and 8blade - ignoring all the vgt ones?
  20. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 03:44 PM #125
    that's what they say...but see my 8blade measured 56mm inducer 82mm exducer... the 7blade measured 54mm inducer and 76.2mm exducer...so i bet the flow is about equal.
    BTW are you coming to h2o???
  21. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 03:47 PM #126
    When is it?
  22. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 03:59 PM #127
    When is it?
    ummmm... THIS WEEKEND FOO!
  23. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 04:02 PM #128
    Meh, I thought I missed it. If it's this weekend, no. I already made plans to go out. I was hoping to take the scirocco to the event but I still can't get the oil to stop leaking so I've given up on that.
  24. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 04:25 PM #129
    get down there! so i can meet you and give you your ecu!
  25. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 05:11 PM #130
    send it with the 20v head flange. I have a compound turbo system to build.
    Now to decide. for the small charger do I want a 3071R or a small16g LOL
  26. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 05:16 PM #131
    send it with the 28v head flange. I have a compound turbo system to build.
    28v huh? sounds interesting... and you want the evo3 16g ya pansy.
  27. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 05:27 PM #132
    typo, my bad. My concern is the 16g compressor housing won't flow enough for compounding with the hx52. I know the .63ar 3071 housing will flow well enough. I know the small16g is a 300is hp turbo, the big 16g is a 350ish turbo (at the cost of much later spool), but what sizes are the turbine housings?
  28. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 05:33 PM #133
    it's a TD05H turbine...the evo3 compressor will flow enough.
  29. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 05:35 PM #134
    I don't know what that means.
  30. Former Advertiser Quintin@R.A.I.'s Avatar
    Aug 25th, 2010
    DC
    09-22-2010 05:40 PM #135
    gOoGlE is yo friend.
  31. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-22-2010 06:10 PM #136
    I like it better when you tell me.
    It actually would be nice if you weren't the only VW guy to run a 16G.
    I know I've swapped a small 16g for a 20g before and it's not too big.
  32. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    09-24-2010 08:57 PM #137
    Q.....
    got some partz donated for the rabbit.
    3.0L V6 Audi FULL LONG BLOCK MOTOR with complete harness and all.
    along with motor, a BIG Holset VGT turbo. the same turbo doing WELL on the I-5 2.2L Audi motor in the Audi car.....
    oh yeah, and a VEMS Ecu, too.
    so you think its worth pursuing a RWD mid engine build with this stuff? or should i still go ABF clone etc?
    we been doin some playin with the VGT stuff, and we have some sort of method to it. and its working....
    HOLLA!!!!!
  33. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    09-25-2010 10:13 AM #138
    You can donate some parts to me.....
    I got me the evo3 16g on the way. Time to start building.
  34. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    09-25-2010 10:38 AM #139
    this is one of my friends I-5 Audi setups.....
    he is the one providing me with parts for the other race car....
  35. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    09-25-2010 10:47 AM #140
    How are you controlling the vanes in the turbo or are they open all the time?
    Quote Originally Posted by ..Derek.. View Post
    Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    Tucson Forced Induction
