VWVortex.com - Holset user thread
    Page 5 of 45 FirstFirst 12345678915 ... LastLast
    Results 101 to 125 of 1103
    Thread: Holset user thread
    1. Member 16v lover's Avatar
      Feb 17th, 2007
      saint john, NB
      c5 A6 avant, b3 passat big turbo 16v
      08-17-2010 10:51 PM #101
      Quintin. the inducer of my he351cw compressor is 61.20mm wall to wall if that helps you any.
    2. 08-18-2010 03:45 PM #102
      How well does the HX35 fit the VR6's characteristics?
    3. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      08-18-2010 08:54 PM #103
      big boy toys
      going to need something bigger than 3"
    4. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      1989 Helios GLI 1997 Mk3 ****box
      08-26-2010 12:46 AM #104
      http://forums.vwvortex.com/showthrea...whp-madness...
      Pretty interesting thread on a g6o with an 8v head. 280whp on 24 psi. I still have the stock holset actuator as well so i will be there at some point, and I should see over 300 whp with my 16v head.
    5. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      08-26-2010 12:51 AM #105
      Quote Originally Posted by Nasty Vr6 View Post
      So what do you do if you wanna run 8-10 pounds?
      check my build thread, granted it hasnt been updated in a while. You can use another wastegate actuator from another car that has an adjustable rod and go from there. I got mine from a Saab 900 with a t25, and got a metric eyelet rod from ebay.
      I think its set for about 8si. If it doesnt work then tial and screamer pipe ftmfw
      On a second note I just got some extra v-band rings so i can have a nice open exhaust for H20
    6. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      08-26-2010 01:44 PM #106
      Quote Originally Posted by frescoG60 View Post
      I would think similar to a 50 trim on a vr6, maybe a bit over 3 k for spool.
    7. 08-26-2010 04:21 PM #107
      Quote Originally Posted by Dave926 View Post
      2400rpm = 1psi 3300rpm = 20psi with 12cm hotside
    8. 08-26-2010 04:54 PM #108
      Dam that's quick spool
      Haters make me laugh
    9. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      08-30-2010 10:44 PM #109
      I found a user on here by the name of "G60 Scuzz." He ran a hx30 on his bone stock PG corrado and made 285whp @ 24 psi. I think 300 whp for me is no prob, considering that i'm running a 16v and I have the same holset actuator for some shenanigans
    10. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      08-30-2010 10:46 PM #110
      Thats faster than the .63 50 trim my friend had on his vr6. All it could do was 10 psi at 3300 or so.
      Watching the tach, boost and road in a vrt was never easy
    11. Member 1098lover's Avatar
      May 16th, 2009
      socal
      mk3 jetta VRT
      09-06-2010 04:55 AM #111
      I have a hx-35 on a 12v vr6 with a front mount and c2 42# software
      10psi at 3200ish
      http://www.youtube.com/watch?v=tENxPqzYzHo
    12. 09-09-2010 02:47 PM #112
      Quote Originally Posted by 1098lover View Post
      10psi at 3200ish
      what hx35 do you have 6/7/ or 8 blade compressor ?
      have you tried any other turbo on ur car to compare the differnces ?
      i read they dont come into there efficiency range till past 20psi ??
    13. Member
      Oct 1st, 2007
      northern nj
      2005 blue lagoon gli
      09-09-2010 07:42 PM #113
      Quote Originally Posted by magner View Post
      Ive read there are different 6/7/8 blade compressors depending on year of the turbo, any specific compressor better than the other?
    14. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      09-10-2010 09:56 AM #114
      All the information regarding compressor efficiency and what blade compressors are the best is all on the first page
    15. Member 1098lover's Avatar
      May 16th, 2009
      socal
      mk3 jetta VRT
      09-10-2010 09:07 PM #115
      I think it is a 8 blade wheel. Im told that that turbo is good for much more than 15psi but I am pretty sure that I will F#** something up if I run much more than that on a stock motor.
    16. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      09-11-2010 04:18 AM #116
      Holsets are efficient at over 30 psi above atm
    17. Former Advertiser Quintin@R.A.I.'s Avatar
      Aug 25th, 2010
      DC
      2001 MK4 2.0 Jetta....dont sleep ;)
      09-11-2010 04:48 PM #117
      My 8v dyno'd today...
      373whp
      367wtq
      25psi HX35 (54mm 7blade compressor)
      Mustang dyno...
      vids/pics up soon...
    18. Member Dave926's Avatar
      Mar 30th, 2005
      Rhode Island
      09-11-2010 04:58 PM #118
      what happened to usrt quintin.
      Holy **** btw. There is still 10 psi left in that turbo, but i think at 35 psi the head will lift
    19. Former Advertiser Quintin@R.A.I.'s Avatar
      Aug 25th, 2010
      DC
      09-11-2010 05:38 PM #119
      i was only with USRT as a side gig helping out...Full time i was Asst Manager at Advance Auto then came to work here at RAI and can't do both.
    20. Member obdONE's Avatar
      Jan 28th, 2002
      Houston
      95 VRT
      09-22-2010 11:48 AM #120
      Hey all, I hope to be a member of the Holset bandwagon soon. Looking to buy the hx35 that's in the classifieds right now. hx35 with an 18cm compressor housing. going on a 12v.
      any advice for starting out?
      This is a fantastic thread, btw. Thanks so much for all the info posted up.
    21. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      09-22-2010 04:12 PM #121
      hx35 is roughly equal to a a GT30R, so go get 'em.
    22. Former Advertiser Quintin@R.A.I.'s Avatar
      Aug 25th, 2010
      DC
      09-22-2010 04:23 PM #122
      Quote Originally Posted by Pat @ Pitt Soundworks View Post
      depending on which one outta the hundreds of models you get...mine came off a bus and is roughly equal to a t3/t4 50trim
    23. Member obdONE's Avatar
      Jan 28th, 2002
      Houston
      95 VRT
      09-22-2010 04:26 PM #123
      4" inlet
      2.5" v-band out
      3" v-band hot side
      if that helps at all...
    24. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      09-22-2010 04:29 PM #124
      Quote Originally Posted by Quintin@R.A.I. View Post
      It's what, 6 lb/min difference between a 7blade and 8blade - ignoring all the vgt ones?
    25. Former Advertiser Quintin@R.A.I.'s Avatar
      Aug 25th, 2010
      DC
      09-22-2010 04:44 PM #125
      that's what they say...but see my 8blade measured 56mm inducer 82mm exducer... the 7blade measured 54mm inducer and 76.2mm exducer...so i bet the flow is about equal.
      BTW are you coming to h2o???
