VWVortex.com - 5-Speed Swap - MK4 2.0 Auto to Manual
    Results 1 to 23 of 23
    Thread: 5-Speed Swap - MK4 2.0 Auto to Manual
    1. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 11:45 AM #1
      Well today I started my 5-Speed swap.
      Dropping Trans...
      Trans out...
      Transmission going in...
      Ran into a issue with the crank shaft. Diameter is a little bit bigger so the flywheel will not be able to bolt on.
      The way to get around this is to get a professional machinist to slightly bore out the flywheel. I'll explain more on how about doing this once I get some more info.
      My automatic trans is getting swapped into another Jetta with a bad automatic transmission.
      Will keep you guys posted...
    2. Member elRey's Avatar
      May 15th, 2001
      16vt 2.0L MK4 Jetta Wagon | B6 A4 Avant
      05-21-2010 11:59 AM #2
      Cool. went thru this myself. What flywheel are... I mean were you going to use? Are you cutting the trans/TCM wiring or swapping a manual harness in? Which ECU? reverse light wiring? Clutch switch wiring? 1.8T or 2.0L 02J tranny? swapping just the clutch pedal or smaller brake pedal also? What are you doing about the cluster?
      Just things I dealt with.
      Keep up the good job!
    3. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 12:22 PM #3
      Quote Originally Posted by elRey View Post
      I'm using a stock 2.0 Flywheel, it seems the center was a little bit smaller and I'm thinking this is because it's a automatic crank. But I took it to a machine shop and they got it taken care of.
      - I'm just keeping my wiring harness and going to cut it etc...
      - I'm keeping my stock ECU and using VAG-COM to change it over to a Manual
      - Putting a 02J in it from a 2002 Beetle, my car is a 2003 Jetta so it should be fine.
      - About the reverse and Clutch wiring this will be last to figure out.
      - I have the clutch pedal and I'm just going to trim up my brake pedal.
      Is there anything I need to watch out for? I'm doing this swap in 2 days so any advice would really help.
      I also have the shift linkage but I think it was from a 6-Speed, I'm sure it will fit right? If I get the correct bracket that goes to the trans?
      Thanks
    4. Junior Member
      May 14th, 2010
      2006/Audi/A3 & 2005/VW/GLI
      05-21-2010 12:25 PM #4
      Woah. Heck of a project you got there. Best of luck!
      2006 Audi A3 & 2005 VW Jetta GLI
    5. Member elRey's Avatar
      May 15th, 2001
      05-21-2010 12:28 PM #5
      [QUOTE=VDUB MKIV;65883543]I'm using a stock 2.0 Flywheel, it seems the center was a little bit smaller and I'm thinking this is because it's a automatic crank. But I took it to a machine shop and they got it taken care of.
      - I'm just keeping my wiring harness and going to cut it etc... [B]
    6. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 12:32 PM #6
      another thing to deal with is the shift lock/starter relay and clutch/start block relay (lack of one).
      Ok cool thanks for the heads up, I forgot about that automatic shift lock feature!
    7. Member raymondlee's Avatar
      Jun 7th, 2008
      Columbus, GA
      2009 Gli, 2000 Cabrio
      05-21-2010 12:52 PM #7
      wow that trans looks beter than my paint!!!lol
    8. Member elRey's Avatar
      May 15th, 2001
      05-21-2010 12:54 PM #8
      Also, check the size of your inner axle flanges to the output flanges on the tranny. Early 2.0L 02Js came with smaller flanges.
    9. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 01:33 PM #9
      Oh ok well it came out of a 02 and mines a 03 so it should be fine, thanks for the heads up.
      By the way the fly-wheel is in and bolted up!
    10. Member elRey's Avatar
      May 15th, 2001
      05-21-2010 01:44 PM #10
      Quote Originally Posted by VDUB MKIV View Post
      2.0L 02J vs 2.0L 01M.... is not the yrs that matter in flange size.
    11. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 02:11 PM #11
      It's a 02J not a 01M so I should be good.
    12. Member elRey's Avatar
      May 15th, 2001
      05-21-2010 02:42 PM #12
      ummm.... what tranny are you taking out?
    13. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 03:48 PM #13
      The one that I'm putting in my car.
    14. Member
      Jul 19th, 2009
      MA
      E46
      05-21-2010 03:52 PM #14
      Skeptical on whether or not this might work, atleast you're at a shop and not doing this in a garage, but I feel like your going to run into a lot of issues.
      Quote Originally Posted by Braga_Dub View Post
      When the Earths normal shift in plate tectonics causes you to scrape while parked. You are almost low enough.
    15. Member elRey's Avatar
      May 15th, 2001
      05-21-2010 04:02 PM #15
      So, you're taking out your 01M 4spd auto and putting it back in? You shouldn't have a problem then. I thought you were taking out the 01M 4spd auto and putting in a 02J 5spd manual.
    16. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 09:00 PM #16
      Quote Originally Posted by e36rjbmw View Post
      Why wouldn't it work? And yes I am getting this doing by professional VW techs.
      And yeah we are running into a few issues, but let me tell you it's a great learning experience.
    17. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 09:01 PM #17
      Yes I am taking out my 01M 4spd auto and putting in a 02J.
    18. Junior Member
      Mar 10th, 2010
      Lake Worth, Florida
      2003 GTI Uni Black
      05-21-2010 10:03 PM #18
      what would this cost for a 1.8t? i have the tiptronic or however you say it... i want a manny so badly!
    19. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-21-2010 10:29 PM #19
      Quote Originally Posted by brooksie91 View Post
      It will probably run around $2500 to $3500 including parts and labor, not cheap. But you can sell your tiptronic for probably over $900 and all the other parts along with it and maybe get around $1200 for everything so that should really help you out.
    20. Member VDUB MKIV's Avatar
      Jun 13th, 2008
      North Carolina
      1996 GTI VR6
      05-23-2010 02:56 PM #20
      Ok well here's an update, flywheel, clutch etc.. are on, transmission & axles are all bolted up.
      Got the car started and everything worked fine.
      All that's left is to do some wiring / recoding ECU and to get the shift linkage installed and bolted up.
      Should be driving my car home in a couple of days
    21. Member CerealKiler's Avatar
      May 10th, 2011
      colorado
      2.slow & VR-tea
      04-10-2012 08:13 PM #21
      I really want to do this... I just had my automatic trans rebuilt and they said it's not possibly. Stupid uneducated jerks... Anyway, what is your experience with this? Do you like it? Any issues? This isn't something an unexperienced person should do right?
      Sorry for waking such an old thread. But I figured it's been a while since you had it done and you would have had the time to really review it.
    22. Semi-n00b
      Jun 8th, 2014
      NY/Atl
      05 vw GLI w/5 speed 2.0l tranny
      07-25-2014 07:08 PM #22
      Hey I had done the same thing in my 05 Gli , my problem is I got the tranny on and got the car driving . The mechanic said I need a manual harness to get the check engine light off. So I bought one and I don't know how to install it please give me shout I need some help with my speedo & reverse
    23. Member mark6kevin's Avatar
      Jun 22nd, 2012
      NJ
      Bagged '12 GTI
      07-25-2014 07:27 PM #23
      work hard. drink harder.
      instagram: itznj
