VWVortex.com - 2.5 gas mileage thread
    Page 2 of 4 FirstFirst 1234 LastLast
    Results 26 to 50 of 80
    Thread: 2.5 gas mileage thread
    1. Junior Member dcdude's Avatar
      Jun 17th, 2010
      South Bay, Los Angeles
      '15 Passat 1.8 TSI LE
      08-11-2010 06:12 PM #26
      Did anyone do any A/B testing before and after adding CAI and/or cat-back? I'm curious which of these has a positive or negative effect on gas mileage?
      Also- which CAI is least likely to cause a CEL on in '08?
    2. Member dr0pthehamm3r's Avatar
      Nov 30th, 2007
      SF East Bay
      "Classified" The '06 Jetta
      08-11-2010 11:02 PM #27
      hit 337mi til gas light on Chevron 91oct. 06 jetta w 5spd. stock engine.
      //FRRG - Norcal
      Follow my build: dr0pthehamm3r: The Full & Overly-detailed Story
      Instagram: dr0pthehamm3r | Twitter: IfWordsDontHurt
    3. Member Schagephonic's Avatar
      Feb 5th, 2009
      Colorado
      2013 Tiguan SE 4Motion
      08-12-2010 02:01 AM #28
      Quote Originally Posted by dcdude View Post
      CAI alone made no noticable difference for me. The AWE catback did though by adding about 10% more mpg. I'm also running a revised 87 octane C-2 chip which I can verify with my Scan Guage that the chip is shutting off fuel at hwy speeds when I lift my foot off the gas. The stock chip does not do this. So using a gentle touch of the throttle on and then off again (repeating) technique, I'm consistantly getting 34 mpg hwy cruising at 75mph. I just completed a trip in the CO mountains and averaged 36 mpg cruising at 65mph.
      Prior to my mods, I was getting between 29 and 31 mpg hwy. Also, keep in mind that your tire width, diameter (which affects weight) and rolling resistance will also make a difference too.
      I've not had any CEL's using my Neuspeed CAI.
    4. Member VWShocker's Avatar
      Mar 18th, 2010
      California
      08-12-2010 02:54 AM #29
      Quote Originally Posted by Schagephonic View Post
      You are hitting my MPG secret (the C2 chip).
      A Jetta with mods
    5. 08-16-2010 03:54 PM #30
      2006 2.5 5 SPD Jetta
      32.7 MPG @ 70 MPH HILLS, FLATS, 325 MILES
      Thinking about a cold air intake for better mpg any other suggestions?
    6. Member VWShocker's Avatar
      Mar 18th, 2010
      California
      08-16-2010 08:54 PM #31
      Quote Originally Posted by cpsvr6 View Post
      Tune is the BIGGEST helper.
      A Jetta with mods
    7. 08-17-2010 12:19 PM #32
      Quote Originally Posted by VWShocker View Post
      Tune? What do you mean?
    8. Junior Member dcdude's Avatar
      Jun 17th, 2010
      08-17-2010 12:22 PM #33
      "Tune" meaning "software" rather than timing, plugs, points and condenser, right?
      Specifically, the C2 Motorsports 2.5L Performance Software? Was anyone able to get this done locally? Was it "while you wait" fast to get? I'm concerned about the downtime and risk of shipping my only ECU anywhere.
    9. Member 07Jetta's Avatar
      Dec 23rd, 2007
      Groton, CT
      2011 Candy White 4-door GTI
      08-17-2010 01:37 PM #34
      2007 Jetta
      Cabrino CAI
      -average about 26miles per gallon
      -best to date.... 29miles per gallon and got a little over 400miles out of the tank, 406miles I thihk to be exact.
    10. Junior Member dcdude's Avatar
      Jun 17th, 2010
      08-17-2010 02:20 PM #35
      FYI- I just drove my new bone stock 5 speed CPO '08 SE back from Tucson. Just 225 pounds of me driving with 2 small bags. Here are my stats based on three partial tanks and fill ups:
      85 MPH average: 24 MPG
      75 MPH average: 27 MPG
      70 MPH average: 32 MPG (almost. 31-point-something and change!)
      Sweet spot might be 72 MPH to get 30 MPG.
    11. 08-17-2010 03:21 PM #36
      08 2dr Rabbit Tiptronic
      No mods except larger sticky tires (245's on lightweight 17's)
      Day to day driving, which is 80% stoplights, and 20% cruising 45-60mph, I average 22-24mpg
      This is taking it easy too.
      When filling up after an autocross, its about 21.
      Full on highway driving, I've gotten 35 before, but I was drafting a semi doing 60 most of the trip. Typically though, It will sit around 31-32 cruising at 75-78.
      Driving around in the summer I get worse mileage due to the AC being on constantly, during spring and fall I get 26 on my day to day with windows down.
    12. Member VWShocker's Avatar
      Mar 18th, 2010
      California
      08-17-2010 08:30 PM #37
      correct
      A Jetta with mods
    13. Member
      Aug 1st, 2002
      '74 Bug (yard), '96 Jetta 255K (yard), '02 Cabrio 104K (sold), '06 Rabbit 127K BGP, '08 Jetta 55K
      08-21-2010 12:26 AM #38
      '06 Rabbit 5 speed
      87 octane
      suburbs
      23-24 mpg fairly conservative driving
    14. Member richard_rsp's Avatar
      Mar 17th, 2010
      Valdosta, GA
      2013 VW Jetta GLI
      08-22-2010 01:11 PM #39
      Its amazing how much tire pressure affects these cars. (2010 Golf 2.5, 5-speed)
      I have the 17" Goals and normally run around 37 psi. I usually average about 25mpg around town and 30mpg on long trips.
      I got my oil changed about a month ago and have noticed a decline in my gas mileage. (like averaging 18mpg in town and highway of 25mpg)
      Checked my tire pressure yesterday before I left on a trip and noticed that all four tires had been reduced to about 29.5 psi. (Thanks local VW service dept. obviously they dont realize that with 17" goals, that it is supposed to be at 34 psi!)
      Anyway, now they are back to 37 and I got 34.9 mpg on my trip yesterday (55-65 mph)
      Keep them tires pumped up, especially with the larger, wider tires!
    15. Member thygreyt's Avatar
      Jun 7th, 2009
      fort lauderdale, FL
      1k-m-cbta-02q-PTE5858
      08-23-2010 12:03 AM #40
      i am gettin consistent numbers... 25 city and 28 at hwy (80mph)
    16. 08-23-2010 11:11 PM #41
      I have noticed this as well. Tire pressure makes a significant difference with this car.
    17. Member Schagephonic's Avatar
      Feb 5th, 2009
      Colorado
      09-01-2010 10:48 AM #42
      Want an instant 10% more MPG? Try to find non-ethenol "enriched" fuel. I found some in Ft. Collins, CO and filled my near-empty tank, reset my Scan-Guage, drove to Denver. Normally I get about 32.5 mpg on this highway run as there's a slight elevation gain. This time I achieved 36.2 mpg. I'll continue to seek out more of these gas stations and do more monitoring of the data.
    18. Junior Member
      Jan 2nd, 2010
      1999 1.8T Beetle, 2009 2.5 Rabbit/Golf
      09-02-2010 03:37 PM #43
      I was getting about 24mpg on average with the recommended oil. I switched to 0w-40 and now I get about 25 or 26mpg. Also, I noticed running 91oct or better improves my mpg.
    19. 09-03-2010 09:22 PM #44
      Here's mine
      Pure stock
      87 Octane gasoline
      Best MPG = 46.4 MPG from San Diego to Sacramento
      Longest range = 596 miles/tank
      That was all back when I was doing >90% highway. Now with 50/50 mix driving and shorter trips, it's quite a bit less now. I was hoping to get my lifetime average up to 40 MPG, but that's not going to happen given my current driving situation.
    20. Member
      Aug 1st, 2002
      09-04-2010 01:26 PM #45
      26 per gallon last fill up around town. I'm not really sacrificing many mpg compared to my 2.0L Jetta with racks (28 winter, 30 summer around town).
    21. Member jtrujillo86's Avatar
      Aug 21st, 2005
      Denver, CO
      2016 Jetta 1.8T SEL, 2016.5 Mazda CX-5 Touring, 2002 Passat GLX V6 4Motion
      09-04-2010 05:51 PM #46
      I haven't been too impressed with the 2.5's city MPG. For the last two years in grad school, all I really ever drove were city miles to and from school. Every tank would amount to about 23 miles per gallon. Now, I'm working about 35 minutes away from my house and have a 65 MPH highway drive every day. I'm consistently seeing between 32 and 33 MPG
      - Jeremy.
      EDIT: And all this is on 87 octane. If I use 85 I see about a one mile per gallon drop in both the city and highway.
      Quote Originally Posted by BluMagic View Post
      It's a VW; the sensors are as sensitive as women on that time of the month . . . and the dash is as anxious to light up as a stoner.
    22. Junior Member dcdude's Avatar
      Jun 17th, 2010
      09-05-2010 11:14 AM #47
      My last two city tanks were 20 and 21 MPG. Granted, I still have my foot in it from time to time (hey- it's my new car) but I try to drive and shift between 2,000 and 3,000. My commute is only 7 miles each way, which can't be good, but I wonder if something's wrong? Checked tire pressure recently. I do haul around 2 car seats and a stroller, but that can't be 100 pounds of crap.
      I like the idea of experimenting with 91 octane, but I wonder if it will pay for itself?
      Also considering 0W-40. There is strong suspicion that Porsche specs it to cheat up their CAFE numbers.
    23. Member jtrujillo86's Avatar
      Aug 21st, 2005
      Denver, CO
      09-05-2010 11:21 AM #48
      I live near Drake and Timberline in Fort Collins, so I'd be interested to hear at which station you found this. Also, ethanol has lower energy content than gasoline, so it's less efficient. I don't doubt you'd see a sizable increase in MPG by using non-enriched gasoline.
      - Jeremy.
    24. Junior Member NickVW's's Avatar
      Mar 30th, 2009
      Chicopee MA
      07 Wolfsburg
      09-07-2010 01:52 PM #49
      My 07 Jetta 2.5 manual
      Average 375-425 a tank winter-summer 87 octane 90% highway
      Highway and city mpg don't vary much for my driving
      Best ever was 33 mpg
      My Fiance's 08 Rabbit 2.5 auto
      Average 325-375 a tank all year round 75% city driving 87 octane
      We took a trip to Florida in the rabbit and averaged somehow 36 mpg on cruise control doing 80 mph on 87 octane
      I think they put pixie dust or something in southern gas
    25. Member VWShocker's Avatar
      Mar 18th, 2010
      California
      09-08-2010 12:48 AM #50
      I used a whole tank full of gas the other day searching for non-ethanol petrol. No luck except that I was able to score some 101 octane.
      Gonna try it out before the big day.
      A Jetta with mods
