Page 1 of 13 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 423
Thread: welder show and tell
  1. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    12v bimbo bucket, 16v rabbit, buy my b4 wagon please!
    05-21-2010 08:18 PM #1
    What welder do you use to make stuff, and what stuff have you made with it?
    a la show and tell...
  2. Senior Member PowerDubs's Avatar
    Jul 22nd, 2001
    NWNJ
    05-21-2010 09:13 PM #2
    If you weld, and live in jersey, and are bored.. I have all sorts of ideas for things you can build.
    I only *wish* I knew how to weld..
  3. 05-22-2010 08:16 PM #3
    I've been using a Lincoln 175, no pulse, for 11 years. Works ok
  4. Member quicka6's Avatar
    Jan 25th, 2010
    socal
    C5 A6,MK2 GTI,KJ JEEP
    05-22-2010 11:50 PM #4
    mad skills you have there bud.
    :p
  5. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    230 E. landis st coopersburg pa 18036
    a few.
    05-25-2010 09:04 AM #5
    www.nothingleavesstock.com
    NLS's full line of parts on our online store!http://nothingleavesstock.com/online...=0&sort=normal
    Email us at sales@nothingleavesstock.com 230 E. landis st. Coopersburg PA 610 282 5487
  6. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    05-25-2010 02:39 PM #6
    and what kind of welding equipment do you have over at nothing leaves stock?
  7. Banner Advertiser nothing-leaves-stock's Avatar
    May 16th, 2006
    a few.
    05-25-2010 02:43 PM #7
    miller 250 syncrowave 250 tig
    miller 110 mig
    snap on plasma cutter
    coat hanger and torch
  8. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    05-25-2010 03:44 PM #8
    Quote Originally Posted by nothing-leaves-stock View Post
    :p, that's old skool right there. Been there
    I also have the Syncrowave 250, but have a SnapOn 140Mig.
    Not showing any of my stuff after California Jay's pics :p
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  9. Member xblueinsanityx's Avatar
    Nov 19th, 2005
    north ogden
    vrt corrado, smokey mid engine corrado.... various other vehicles
    05-25-2010 04:31 PM #9
    your not a real welder till you have welded with a coat hanger and a torch
    bend it , cut it , grind it, weld it....... drive it! ..... break it........
  10. 05-25-2010 08:42 PM #10
    Quote Originally Posted by sdezego View Post
    Dont be afraid to... I may have a few more hours seat time compared to others.. I'm sure people can consider that.
  11. Member B4S's Avatar
    Apr 16th, 2003
    Marionville, Ontario, Canada
    1997 Ford Aspire, 1989 Dodge Colt GT Turbo
    05-26-2010 12:56 PM #11
    I have a lincoln 140, and the stuff I make is best put under a car where it won't be seen .
    I use it for myself, exhaust work, brackets, getting snapped off bolts out of their holes, etc.
  12. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    05-27-2010 08:23 PM #12
    miller 110 = 110v welder, or 110 amps? and if its 110v, how many input amps does it need?
  13. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    05-27-2010 08:34 PM #13
    What welding process / welder do ya'll use for light guage steel and car bodywork?
  14. Member B4S's Avatar
    Apr 16th, 2003
    05-27-2010 09:04 PM #14
    I used an old-school 110v Marquette MIG with .023" wire, then I upgraded . Worked great doing the resto work on my 82 Rabbit.
  15. Member nubVR's Avatar
    Apr 24th, 2004
    Vancouver Wa
    '00 Tropic Orange VR6BT
    05-28-2010 10:51 PM #15
    sorry for the Iphone pics..... they finally let me weld at work yesterday, so i snapped these for you guys.... Miller 350 squarewave....
  16. 06-01-2010 11:49 AM #16
    I'm using a Lincoln Precision 185. It works good, but I'm having trouble with the A/C. When trying to weld at 185A, it often cuts out and won't go past ~100A. I've used it A LOT though. It works great on DC.
    Markku Kivinen | Agtronic Motorsport
  17. Member maxcharger's Avatar
    May 28th, 2009
    nj
    1991 jetta coupe racecar 12v N/A
    06-02-2010 02:12 AM #17
    Lincoln square wave tig and i live in nj and am bored
    custom fabrication available
  18. 06-03-2010 11:32 AM #18
    Miller syncrowave 180SD tig, Weldtec air cooled torch. I am going to be building a liquid cooling system for it and use a nice micro torch with it soon.
    Millermatic 180 MIG. Best MIG I ever used for under $1000. Autset works fine and I have yet to need to max it out, and I welded up some 3/8's stuff just fine. Will also go right down to sheet metal for body work like a champ.
    Miller 375 plasma. Cuts like butter, even 1/2" plate and rusty dirty frame rails are cake.
    BLUE FTW!
    I dont have many pics at all for some reason of my welding. lol I will have to see if any are online.
  19. Junior Member
    Dec 11th, 2008
    Oroville, ca.
    1982 Rabbit Diesel
    06-10-2010 01:05 AM #19
    personally I prefer ballingwire over coathangers. As far as wilders goes my main welder is a WWII vintage shipyard welder (AC buzbox), we also have a high frequency box hooked up to it for tig welding aluminum. Other than a oxy/settling setup we have a newer Craftsman AC buzbox, and a newest welder a Hobart Handler 140 MIG welder (only set up with flux core. ). We have built things from heavy duty trailers, to small delicate repairs. One of the things we did was build a reciever for my rabbit.
    Travis
  20. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    06-25-2010 01:26 AM #20
    hitch for rabbit? trailers? pics!
  21. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    06-25-2010 06:38 PM #21
    I'm considering getting my hands on this: harbor freight gas welding outfit
    I can actually afford it, vs. a good mig
  22. Junior Member
    Dec 11th, 2008
    Oroville, ca.
    1982 Rabbit Diesel
    06-27-2010 02:08 AM #22
    Ill try to get some pics tomarrow. This is what I have for now:
    Ya, its a diesel.
    Well, maybe I just parked it in front of our trailer while we were camping. But seriously, ill get some pics tomarrow.
    Travis
  23. Junior Member
    Dec 11th, 2008
    Oroville, ca.
    1982 Rabbit Diesel
    06-28-2010 02:42 AM #23
    got a couple more pics for you:
    rabbit rear and hitch
    rabbit and trailer
    My grampa built that trailer years ago, the box is 3' by 5.5', and the trailer is overbuilt. (as ushal with things we built.)
    rabbit and trailer
    old westinghouse ac welder
    probably our most used welder, and its WWII vintage. vintage ac buz box
    How many of you know how to change the amperage on this welder? probably mostly just oldtimers.
    self axplanitory
    add on high freq. box
    High frequency box for tig welding aluminum. (with aformentioned buz box)
    Hobart handler 140 mig welder
    Hobart Handler 140
    boat trailer being rebuilt
    latest project: rebuilding a free boat trailer to fit my boat. (and be roadworthy )
    Thats about all for now.
    Travis
  24. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    06-28-2010 07:06 AM #24
    Quote Originally Posted by Byramtra View Post
    Ya, its a diesel.
    Travis
    can your rabbit actually tow that monster?
    props on a unique piece of equipment.
  25. 06-30-2010 12:33 PM #25
    my old rig. Airco 300 amp ac/dc welder. from the 70's and a freekin tank. My first tig welder and it payed for itself ten fold.
    Photobucket
    my new rig miller syncrowave 250 tig and miller 212 multivoltage mig. More expensive but the weld quality is second to non over the old machine.
    Photobucket
    down pipe for a vr6 turbo corrado.
    Photobucket
    short runner for the same turbo corrado.
    Photobucket
    16v and aba short runners
    Photobucket
    Photobucket
    A couple turbo manifolds.
    Photobucket
    Photobucket
  26. Junior Member
    Dec 11th, 2008
    Oroville, ca.
    1982 Rabbit Diesel
    07-03-2010 02:05 AM #26
    actually, ya, its just parked there. the tongue weght would be a problem. the biggest trailer I pulled was identicle to this one:
    http://www.truckpaper.com/listingsde...d=1611811&nh=0
    It is really stout (ie heavy), so i only took it next door back to its owner. Nice work on the tube, and aluminum, I need to work on that myself.
    Travis
  27. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    mk2 coupe,mk4 golf both 2.0hhhhhhhhh
    07-06-2010 08:29 PM #27
    cebora 250
    150 amp
    Works great on aluminum
    have problems getting pretty colors on my stainless.Tried a new glass line too
    Only like 4 months in so..
    12.2@116mph-293whp305wtq 22psi stock aba-AC-DD My Jetta
    Current Want list-sunroof delete,paint
    Fifteen52 - Urotuning
  28. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    07-06-2010 10:02 PM #28
    Quote Originally Posted by Daskoupe View Post
    cebora 250
    150 amp
    whats one of those run?
  29. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    07-06-2010 11:16 PM #29
    through Matco alot kinda.But its only 50 bucks a week lol(and a credit builder)
  30. Member J.Owen's Avatar
    May 31st, 2001
    Merica
    '05 A4, '07 Jetta, '02 Outback
    07-07-2010 09:29 AM #30
    can anyone give me some input on this welder? Ive emailed the seller but no response yet. I thought maybe somewhere here could ID it from the pictures as to a brand/ possible model.
    BlownEuros.com
    Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
  31. Member cabrlicious's Avatar
    Jan 27th, 2008
    jersey burbs
    11-18-2010 11:06 PM #31
    maybe ill take pics of the exhaust bit I did, maybe I will save my embarrassment. well, I got this far (lousy camcorder pic): MAF / Air filter bracket (installed)
  32. Member EuroKid83's Avatar
    Jan 25th, 2005
    Tacoma, WA
    11-28-2010 06:21 PM #32
    Miller Dynasty 350. Just got it, cool stuff to come...
  33. Member Angular's Avatar
    Mar 12th, 2002
    WA state
    2002 Audi S4 Avant
    12-31-2010 04:03 PM #33
    What, no Chinese welders off eBay??
    On a more serious note... beautiful welds, Jay! I hope some day I can learn to weld like that.
    He didn't post pics in this thread but Markku@Agtronic does awesome fabrication and welding too. I just love TIG welded stainless.
  34. Member yellowrocco87's Avatar
    Oct 4th, 2006
    winder, ga
    1994 Mtechnic
    01-02-2011 06:41 PM #34
    At home i have a miller Diversion 180 tig. havn't done a whole lot with it yet since my gas company sold me a contaminated bottle again
    at work we have a miller syncrowave 200 tig, Miller Millermatic 212 multivoltage mig, Miller Millermatic 135 mig, Miller Passport mig (SS wire welder), Miller Plasma Cutter.
    heres some things i have built
    First roll cage i ever built. Chromoly
    and one of me welding in one of many odd positions while building a cage
    K&H fabrication...find us on Facebook! www.facebook.com/khfabrication!
    back in the game...but RWD and skidracin
    13.24@102 all motor stock motor 12v VR6...bolt on's only
  35. Member dubnick32's Avatar
    Jan 14th, 2009
    Gurnee, IL
    Deceased MKV R, 2005 Dodge Ram 2500 Diesel 6MT, 2013 Mustang GT track pack
    02-06-2011 11:09 PM #35
    I use a Miller Dynasty DX.Photobucket
