Page 10 of 13 FirstFirst ... 6 7 8 9 10 11 12 13 LastLast
Results 316 to 350 of 424
Thread: welder show and tell
  1. Member bmxdarcy's Avatar
    Mar 7th, 2006
    Hotel Hopper
    '96 GTI, '03 TDI, DeluxeBMX
    04-15-2012 11:03 AM #316
  2. Member nubVR's Avatar
    Apr 24th, 2004
    Vancouver Wa
    '00 Tropic Orange VR6BT
    04-15-2012 04:31 PM #317
    damn, thats nice
  3. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-08-2012 01:44 AM #318
    nobody posts anymore?
    Another industrial job. Coal plant in Oregon. We're replacing the pressed in valve seat with a pinned seat. I have to weld the pin guides to the valve casing. It's a stupid weld prep. Need to talk to corporate about this one.....
    Weld was 2.25% chrome stick welded 6g-****-me-in-the-ass-super-restricted. I welded the side against the turbine cylinder because I'm the smaller guy and can actually fit there.
    location guides are fixed to the alignment jig. Casing was heated to 450 degrees prior to welding.
    "prep". It's a nipple fitting at an angle on a round casing. You can't even really see the bottom of the prep. it's retarded.
    Like I said, super restricted 2.25% chrome stick. The only way to get to part of it was to bend the last 1.5" of the rod 90 degrees and use it that way.
    I'm not super happy with it, but considering I had to weld 50% of it upside-down, and the other 50% hugging a 450% oven, I think it turned out better than it didn't.
    It looks a lot better in person. Camera flash always makes stick welding look ****ty.
  4. 05-08-2012 12:25 PM #319
    Little reservoir 80 gal
    92 mk2 jetta VR6
    06 GTI
  5. 05-08-2012 07:01 PM #320
    MIG action 25.5 amps 480 wire speed. U welded MIG with tig gloves today, my fingers burn like a mofo holy crap. **** gets soooooo ****in hot haha
    still gotta touch up on top of the channel with TIG
    92 mk2 jetta VR6
    06 GTI
  6. 05-09-2012 07:27 PM #321
    PINHOLES are the worst enemy ! acetone=BFF this one had 0 pin holes first shot on the pressure tester, i put my fist in the air out of excitement Cause usually I get one or two on the whole tank which means more work, more work= no good
    92 mk2 jetta VR6
    06 GTI
  7. 05-12-2012 09:50 PM #322
    Last one and I stop with the whoring, :p
    92 mk2 jetta VR6
    06 GTI
  8. Member turtledub's Avatar
    May 10th, 2006
    1990 20v Corrado(soon), 2001 Outback 250k strong!
    05-13-2012 10:22 AM #324
    Anyone have any thoughts on this welder?
    http://www.tractorsupply.com/auto-ar...ackage-1048051
    Women are gentle and soft, but they hit things...
    20v AEB Corrado Build thread.
    Parting a B4 ABA Passat?
  9. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-13-2012 01:31 PM #325
    Hobart welder, good units
  10. 05-13-2012 08:24 PM #326
    not a lot of people understand 6g....
  11. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-21-2012 10:23 AM #327
    Any tips on doing anodized aluminum?
    I welded up a oil return flange last night, anodized to anodized. Ground the surface with a tiger paw, then acetone bathed and gave it enough heat to not form a puddle on 70/30 clean/penetrate to try and break up the anodizing, then went. Still came out unpleasant looking. It could be that I haven't done aluminum in almost three years.
  12. Member Eganx's Avatar
    Apr 30th, 2004
    Poulsbo WA
    built 90 jetta coupe
    05-21-2012 01:35 PM #328
    Quote Originally Posted by Pat @ Pitt Soundworks View Post
    Ya, grind that **** off. Or mix a solution of water and , soak the part for a few min, and wipe clean. The lye will eat the anodize off and leave clean aluminum. Its how I prep parts for anodizing or strip them to re-anodize. Last time I welded some AN bungs I just attacked the hex with a wire wheel, welded really nicely after that even without cleaning with acetone.
  13. 05-21-2012 01:44 PM #329
    anodizing prevents conductivity.
  14. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-21-2012 08:13 PM #330
    I did grind the surface of the flange, and the hex. But I forgot to grind the sides of the flange. That's probably where my trouble came from.
    Sent from my HTC ThunderBolt using Tapatalk 2
  15. 05-22-2012 06:12 PM #331
    I have heard that oven cleaner will eat through the anodized finish and leave a clean surface to weld on. I would hit it with acetone still but the oven cleaner should at least take the finish off and get you down to bare aluminum.
    Brandon A.
    BAAK2BASICS TUNING LLC
    FACESPACE US CLICK HERE
  16. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-23-2012 02:50 AM #332
    Turbo Cavalier manifold, tacked for test-fit. Had some trouble getting that one 45 tack...
    Saab 9-3 pre-maf v6t tip
  17. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    05-23-2012 10:24 AM #333
    Quote Originally Posted by diive4sho View Post
    I have heard that oven cleaner will eat through the anodized finish and leave a clean surface to weld on...
    Yes, it does. Works wonders and I have used it many many times.
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
  18. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-24-2012 08:01 PM #334
    Not as good as you other guys, but I'm a fast learner.
    edit: damn that's a bad picture
  19. 05-25-2012 03:14 PM #335
    Not totally new to welding, but just picked up a Miller Diversion 180 and a couple bottles
    I now have a Hobart Handler 140 w/ 80 argon/co2, and a 330 cf (I think) argon, and an 80 argon.
    Big bottle by Jon Kensy, on Flickr
    This is what I got for now
    I am learning still, but made some decent beads
    Aluminum practice by Jon Kensy, on Flickr
  20. Member Jckl's Avatar
    Aug 29th, 2004
    IA
    99 GLX, 90 Jetta GL, 94 GL getting extras, 04 R32 parts
    05-25-2012 05:02 PM #336
    Quote Originally Posted by 5mall5nail5 View Post
    Looks like your off to a good start!
    My AWD MK3 Build:
    - Semi build thread
  21. 05-26-2012 07:55 PM #337
    Quote Originally Posted by Jckl View Post
    Thanks! I just need to remain consistent
  22. Member irishmpls_2's Avatar
    Sep 23rd, 2005
    Dulloof, Minnesota
    1992 Volvo 240 Sedan
    05-31-2012 12:29 AM #338
    I run an early 90's Thermal Dynamics TigWave 350 AC/DC.
    Tuning the welder up for some Aluminum welds...
    Electrical panel cover boxes for a pipeline company in Canada.
    Modified front primary drive plate. Was a harley, not it bolts right onto my Kawasaki. (Spline conversion)
    Handrail base plate for a museum in Madison, WI.
    Single pass metalcore in a structural application. I think this was a Miller XMT with a feeder. I dunno... I hate wirefeed welding.
    Flux core on a slide tube for ventilation.
    .035 Hardwire a blast vent door.
    Multipass 3/4" 1/16" Lincoln UltraCore, 6 passes, end termination.
    And a chinese weld, just for something to laugh at:
    And these people want to be the next world dominating super power.....
  23. Member irishmpls_2's Avatar
    Sep 23rd, 2005
    Dulloof, Minnesota
    05-31-2012 12:33 AM #339
    Here's some more industrial action for you guys. I was flown up to Minnesota to refurbish two valves at a power plant. The robotic welder **** the bed at the 90% mark on the first valve, so we had to set up the cwf and do it by hand. 26" diameter, 300 degree constant pre-heat using induction coils, sitting inside the valve. Three faces were done, the seat, the face, and the backside (locating face for another internal part). It took four 12 hour shifts to get it done. 215 amps, no foot pedal control, no hf start, and just a constant speed 0.035 stainless steel 410 on a wire feeder. The back side was done with inconel 1/8, 150a.
    It ain't pretty, but after you sit in an oven for an hour, welding below your sitting surface, your welds will start to look rough as well.
    After a couple days of post weld heat treating, machining will begin.
    Oh come on, you know we all LOOOVE to do buildups. lol
    (No.... we don't.)
  24. Member
    Mar 20th, 2010
    Minneapolis
    05-31-2012 09:39 AM #340
    If you ever get back up to MN LMK.
    My locost 7 build.http://forums.vwvortex.com/showthrea...lappy-locost-7
    Dear American citizens, please just bend over and accept the ass fawking from your corporate overlords.
  25. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-31-2012 10:11 AM #341
    Every March/April we go back to the plant for more work. We gonna have a sleep over?
  26. Member irishmpls_2's Avatar
    Sep 23rd, 2005
    Dulloof, Minnesota
    05-31-2012 11:47 AM #342
    Which plant do you go work at?
  27. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    05-31-2012 10:50 PM #343
    Prairie Island Nuclear. We do others, but that's the one I've been to a few times.
  28. Member irishmpls_2's Avatar
    Sep 23rd, 2005
    Dulloof, Minnesota
    05-31-2012 11:23 PM #344
    Never been inside Prairie Island. Only Monticello. Never really liked buildups and repair stuff. I prefer the start to finish fabrication over it any day of the week. I just don't have to attention span for much else anymore. Hats off to you for your patience!
  29. Member
    Mar 20th, 2010
    Minneapolis
    06-01-2012 12:47 AM #345
    I have never done much in the repair but I have dome some in shop nuke stuff. I will pass on the post welding
  30. Member Pat @ Pitt Soundworks's Avatar
    Nov 14th, 2008
    Pittsburgh
    06-01-2012 12:49 AM #346
    Yeah, it's not the most exciting of work, but I meet some cool people, and I get paid to travel around the country, so it's not too bad. It beats the fab-shop work I've done, punching out the same couple products every day.
    There's quite a bit that I do that's quite challenging - makes things interesting. That post welding was probably one of the hardest things I've done. That, or a 2" 5G weld where I was crammed in a cubby hole, and had to have someone hold my legs down while I hung off the side of some scaffolding inside a generator haha.
  31. Member irishmpls_2's Avatar
    Sep 23rd, 2005
    Dulloof, Minnesota
    06-01-2012 02:09 AM #347
    Gahhh...
    that brings back memories of climbing inside of a huge coal dust filtration tank and repairing tube sheets for filters at power plants.
    Not work I miss in the slightest.
    No thanks. I'll stick to staying home and working on car and bike projects for myself and others. Plus, I get to listen to Slayer whenever I want.
  32. Member nubVR's Avatar
    Apr 24th, 2004
    Vancouver Wa
    06-03-2012 12:54 PM #348
    Man ive been pricing new additions to my welder this morning.... Making some additions to my Millermatic 251..... I already have the 22a feeder, and a 30ft lead for my steel set up that im gonna mate up with the machine then Im gonna add a 30ft aluminum pull gun to the regular feeder. Ill pretty much be able to get any where i need to for steel or aluminum with one set up! When i get it all figured out and built ill post some pictures up!
    http://www.millerwelds.com/products/...p?model=M00218
    http://www.millerwelds.com/products/...eries_feeders/
  33. 06-05-2012 09:20 PM #349
    92 mk2 jetta VR6
    06 GTI
  34. Member Matysik's Avatar
    Oct 5th, 2008
    Greenfield, Wisco
    '08 HD (FOR SALE), '04 Silvy 4x4 with a turbo (FOR SALE), '83 4 DR. (FOR SALE), '86 5.0
    06-24-2012 01:03 PM #350
    Please strap your bottles to the wall or at least take off the regulator and put the cover on. Last thing you want is a freak accident of it falling and having a 2400 PSI torpedo ripping right through your house.
    Real name is Matysik not Matt or any other thing you guys conjure up
    Want a deal on AMSoil products? Longer fluid intervals? Message me for better than retail pricing
