VWVortex.com - welder show and tell
    Page 11 of 19 FirstFirst ... 789101112131415 ... LastLast
    Results 251 to 275 of 474
    Thread: welder show and tell
    1. 11-24-2011 07:17 PM #251
      Just Picked up an Eastwood TIG 200. Couldn't pass up the deal. (normally $899.99 on sale for $699.99 and they had one with a torn box they sold to me for $599.
      Here is the welder.
      http://www.eastwood.com/eastwood-s-a...00-welder.html
      First impression after a few hours of welding:
      I love it. Only welded 1/8" aluminum plate and tube on 115v. ( 3/32" red 2% thoriated tungsten, roughly 120-140 amps)
      I can't wait to give stainless a shot. That'll have to wait till tomorrow though.
      Now for some pics...
      and some stuff I've done with my Hobart handler 140 MIG w/ Spool gun
      Pieces left over from frame notches
      I have to find a shot of one welded up before the seam sealer... I'll dig
      Brandon A.
      BAAK2BASICS TUNING LLC
      FACESPACE US CLICK HERE
    2. 11-27-2011 11:13 PM #252
      test pipe
      Shortened my tank (need to pressure test before install)
      any advice on the aluminum welds would be appreciated, I was about to start on the FMIC end tanks on Wednesday when I ran out of gas and everything is closed until tomorrow
      the end tanks will be 14ga and I plan to weld from the inside first then the outside before welding them to the core. Welder is a lincoln 175, so I do not have frequency or pulse control, other than my foot
    3. Member J.Owen's Avatar
      May 31st, 2001
      'Murica
      '16 Jetta,'13 Pathfinder, '98 323is
      11-28-2011 10:14 AM #253
      Quote Originally Posted by diive4sho View Post
      Brandon, i'll be interested in how you like it in the long run. I was looking at that welder as it seems like a pretty good deal for a decent entry level machine.
      BlownEuros.com
      Expenses in F1 have gone down since the 1960s because teams don't need an extra pit crew to help the driver carry around his balls when he is not in the car.
    4. Member huichox4's Avatar
      Nov 8th, 2004
      83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
      11-28-2011 06:34 PM #254
      Eastwood tig200 is very Decent welder for the $$ I have one and if welding 110-115 on alum the duty cycle is not the best and you need to let it rest after a while. on SS when I did my exhaust it was surprisingly good..... I just need to practice for better welds.
      I bet it is way better on 220 but I havent used it because I have not installed the outlet on my garage for it...... and could not find the extension cord to use the 220 outlet in the Laundry room at home haha
    5. 12-01-2011 01:10 PM #255
      Ditto to what huichox4 said.
      I LOVE it for stainless.. Made a stainless downpipe and wastegate dump for a buddy's SR20 240 last night and it performaed flawlessly.
      I removed the finger switch because I like the footpedal much better.
      Only one complaint, Not only is the breaker (on/off switch) on the rear of the machine which is a PITA but it doesn't seem to wan to turn on all the time... have to snap it down a couple times before it holds and the machine turns on...maybe it's because I'm reaching behind the maching at an odd angle to do it but it bugs me.
      It gets the job done on aluminum as well, even on my 110V 15amp breaker setup. I welded AN fittings to a SAAB oilcooler for the same 240 and it came out well. Anything thicker than 1/4" in AL will probably need the 220V outlet.
      For the price of the hobart and the spoolgun I probably could have bought the Eastwood MIG AND TIG together for less. Crazy. Hindsight is 20/20 though and for quick stuff the hobart serves me well. I'm addicted to TIG now though.
      Brandon A.
    6. Member huichox4's Avatar
      Nov 8th, 2004
      12-01-2011 02:15 PM #256
      yeah I like the foot pedal much better but didnt remove the finger switch because it came really handy when we were welding some stuff in some really awkward positions inside our race car or at least tacking stuff with it is way easy.
      I havent had the issue with the switch like you mention
    7. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-01-2011 05:16 PM #257
      What kind of switch does that eastwood use? Compatible with lincoln or miller units? I'm tossing that up vs an old idealac tig-300/300 with watercooler and gasbottle for 200 more. The idealarc doesn't do squarewave, but its industrial and watercooled and does375 amps I think.
    8. Member huichox4's Avatar
      Nov 8th, 2004
      12-01-2011 05:22 PM #258
      Quote Originally Posted by Pat @ Pitt Soundworks View Post
      we were talking about the on/off switch it is a breaker style switch
      this machine is very basic and doesnot have pulse or any of the other fancy things the really expensive machines have so keep that in mind
    9. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-01-2011 06:35 PM #259
      ****. I ment to put in: for the hand control and foot pedal.
      Not having pulse doesn't matter too much for what ill be doing. In fact, I don't think I've ever used pulse.
    10. Member J.Owen's Avatar
      May 31st, 2001
      'Murica
      12-01-2011 06:47 PM #260
      good info.
      BlownEuros.com
    11. 12-09-2011 10:49 AM #261
      Some practice with the Eastwood TIG:
      Welded an O2 bung on my raceland header.
      Practice on aluminum tubing
      Had an issue where the foot pedal failed to turn the power off when I let off. Come to find out the small tab that presses the kill switch wasn't making full contact. A slight tweak with the pliers and all is good.
      Pedal depressed to show what the switch looks like under the tab.
      Tab bent to fully depress switch when pedal is released. All better.
      Decided to chop some extra allroad downpipes I had lying around to make "piggie pipes". (delete the first cat out of each pipe. Chopped them after the cat, busted the cat out, smoothed out the inside, welded back together.
      I'm always up for a challenge and in trying to keep things interesting I came across this on the internet.....welding razor blades together. My attempt was, eh, ok i guess. lol
      Boredom got the best of me and I made this for my Fiance's desk at work. Made from a bunch of stainless washers, a random stainless star I found, a nickel and a masonry nail.
      crappy picture
      More scrap stainless tubing practice
      Welded an inside and outside corner joint....
      More tubing
      Be easy on me guys. I know the welds aren't the best. I'm just trying to give a review of the eastwood TIG for those who are thinking of buying it....not trying to showoff my awesome welding skills. lol
      Brandon A.
    12. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-09-2011 11:00 AM #262
      Edit: nvm
    13. Member GTijoejoe's Avatar
      Oct 6th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      12-09-2011 03:19 PM #263
      really got me in a bind between this Miller Diversion 180 and this eastwood 200.......the price just can't be ignored.....
      When welding stainless what type of cups, electrode, and CFM are you guys using? My beads always come out very dark like almost black...thanks.. perhaps we should start a thread about welding tips.
      There are so many good welders here and on EvoM... ToxicFab "Collin" over there does some very very serious work, some of the best I've ever seen on forums
      2.0T+034efi+meth = 300+whp = RIP
      FS: 2015 Honda Civic Si
    14. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-10-2011 10:57 AM #264
      Black stainless welds are insufficient gas flow/coverage, too slow travel speed, and/or too much heat.
      Sent from my HTC ThunderBolt using Tapatalk
    15. Member
      Mar 20th, 2010
      Minneapolis
      12-10-2011 10:04 PM #265
      Ok I will play too.
      Skyline exhaust I built.
    16. Member 02vwgolf's Avatar
      Oct 6th, 2009
      SE-PA
      02 vw golf, 88 Toyota Hilux, 93 4runner(sold), 97 VR jetta(sold)
      12-11-2011 12:07 PM #266
      Quote Originally Posted by TIGninja View Post
      Ok I will play too.
      Holy **** clearly someone has alot of experience behind the welder...Nice work
    17. Member bmxdarcy's Avatar
      Mar 7th, 2006
      AL
      '96 GTI, '03 TDI, '97 Chevy 3500
      12-11-2011 06:59 PM #267
      TIGninja, What do you use to cope exhaust tubing?
    18. Member
      Mar 20th, 2010
      Minneapolis
      12-11-2011 07:11 PM #268
      Quote Originally Posted by bmxdarcy View Post
      Bandsaw and a 6/48" belt sander.
    19. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-11-2011 07:41 PM #269
      don't quote posts with pictures in them
    20. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-15-2011 09:56 PM #270
      retrofit a honda s2k electric power steering rack in to my buddies 94 legend. had to do it under the car, on my side, welding the bracket while holding the rack "steady" between my legs. Hobart Handler 135 strikes again
    21. Member GTijoejoe's Avatar
      Oct 6th, 2001
      12-16-2011 09:11 PM #271
      I get to join the show and tell
      My lin135+ mig
      ... and my newly purchased Miller Diversion 180
      Welds coming soon....
    22. Member Curt_pnw's Avatar
      Nov 27th, 2005
      Edmonds, Wa
      85 Volvo 245
      12-16-2011 11:16 PM #272
      I learned how to weld TIG on aluminum with an Everlast PowerTig 250EX. This is my first try at a project using mild steel. It's so much easier.
      Not totally straight, but it's pretty.
      Brackets done. They are for hanging our aluminum stock off the ground in our shop.
      In action. Sturdy as hell. When all the lag bolts were in, we had two of the bigger guys in the shop hang from each side of one of them. Didn't even budge.
    23. Member Pat @ Pitt Soundworks's Avatar
      Nov 14th, 2008
      Stuart Fl
      12-19-2011 10:59 PM #273
      Had to build a rigging fixture at work so we can lower a couple hundred pound piece of metal we're cutting off. Forgot to picture the lifting eye. It's all crap scrap steel out of our expendable kits and shim kits. 150-175 amps with no foot control.
    24. 12-25-2011 09:09 AM #274
      has anyone ever built a dual plenum intake manifold.
      One large main plenum, and a second ram plenum connected above?
    25. 12-26-2011 06:22 PM #275
      Just got my Miller Diversion 180 a few days ago, and I spent sometime practicing yesterday and today. So far I'm pretty happy with the 180 although I have run into a few minor problems. I'm not thrilled with the small size of the pedal, it is difficult to make fine adjustments with most of your foot hanging off the end. At any rate, I'm having a ton of fun with it. I've been MIG welding for a little over 3 years now with a Millermatic 140 and while I would never give up my MIG, I'm finding TIG to be a bit more interesting and enjoyable. Here are some test beads from this morning for you to critique (1/8" carbon steel, 3/32 ceriated tungsten, 3/32 filler rod, ~105A).
      Toward the end I started to find my rhythm while listening to the subtle 'click' sound made when the filler hits the molten pool. As always, advice/criticism is welcomed.
