what torch cup size are you using and what is your argon flow rate? Some welds look too hot and some look too cold. I'm sure you can spot the difference. You are also cratering at the end. It could be too hot and you are leaving the torch there too long to end the weld or maybe your argon flow is too high and the cup is too small. It may help to introduce some filler rod just before you let go of the pedal. You will have to work on the timing of this to reduce the cratering. Sign up to weldingweb.com. They do a good job critiquing welds. If you haven't found weldingtipsandtricks.com you should check it out. There is a list of common mistakes by noobs for tig welding. I thought i had it all figured out until i saw that list. haha. If you want to work on the timing a introducing rod and puddle control, weld up some aluminum plate. You can just stack rows of dimes one after another with out much cleaning or prep between welds.
bling bling platform
