www.GruvenParts.com offers precision CNC billet lightweight (and Non-Under-driven) crank, tensioner, and alternator pulleys for the ABA 2.0 engines. The pulley set reduces engine rotating mass by over 4 lbs to help you squeeze out every last bit of power, without the problems associated with under-driving components. Our billet tensioner comes ready to install with a 20K rpm SKF bearing to replace the cheap OEM plastic pulley. The crank pulley is a slick dual design which incorporates the power steering v-belt pulley with a light mounting flange (new shorter grade 12.9 attach bolts included). Finally, the alternator pulley is a paper light version of the OEM steel pulley to minimize parasitic losses.
This part replaces the useless rubber donut OEM P/N 035-959-209E (035959209E) that does a poor job supporting your PRICEY auxiliary water pump, and related PRICEY hoses. The OEM rubber donut allows the weight of the pump and hoses to sag, causing stress which can lead to pump and hose failure. Our billet version is the way VW should of designed it to begin with and locks the pump and hoses tight! On or off track, this part will secure the aux pump and prevent pump and hose failure.
Replaces OEM P/N 035-959-209E (035959209E) common to the following vehicles -
Corrado - all VR6
Eos - 2007 + 3.2L VR6
Eurovan - All VR6
R32 - 2004
Golf, Jetta, Jetta Wagon - 1993-2007 All VR6
Passat - 1992-2005 - All VR6 and V8
Phaeton - 2004-2007 6L V12
Touareg - 2003 on 3.2L VR6
Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include greaseable heim joints and bulletproof welds. Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
Want further discounts and more great products from GruvenParts.com? Read on!
Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
They're Back In Stock - Bigger and Better !! All Colors Now Available. Dress up your ride with our premium die cut vinyl stickers and enjoy free domestic shipping.
DOES NOT COME WITH CHEAP THIN WALL TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
12V and 24V VR6 Coolant Pipes aka Crack Pipes
Ours are completely tig welded by our licensed commercial jet aircraft repair facility! We were the 1st to build this part and its what started us off! If you have a billet crack pipe in your VR6, chances are it was made by http://www.GruvenParts.com. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! The 12V version replaces OEM p/n 021-121-050C (021121050C) and the 24V version replaces OEM p/n 022-121-050 (022121050).
Got an 02A Trans ?? Then you better have a look at these upgraded billet shift linkage parts !
02A Billet Stainless Steel Short Shifter Bracket
Replace the weak plastic link in your cable shift mechanism with this one made from Aerospace grade, hardened stainless steel. Reduces side/side shift throw by 35%! This part replaces OEM P/N 1J0-711-256 (1J0711256) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
GruvenParts.com is proud to release this solid stainless fwd/aft cable shift repair block for cable shift VW vehicles. This part will quickly replace the weak forward end of the factory fwd/aft shift cable P/N 1H0711265 (1HO-711-265) where it connects to the transmission linkage. There is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken fwd/aft shift cable. And if your cable is not yet broken, throw 1 of these in the glove box and be prepared for the inevitable!
This repair block repairs the FWD/AFT cable P/N 1H0711265 (1HO-711-265) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
Buy this part in conjunction with our billet stainless side/side cable shift reduction linkage and save!! Add some indestructible hardware to the factory cable shift mechanism where it needs it most!
GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
Buy them as a set and save!
These pulleys replace the following OEM part numbers :
Pay homage to the unique VR6 engine design with this accurate CNC keychain minature. Measuring about 2 inches in length by 1 inch width, its an instant conversation starter with the girls at the parties who are constantly wondering about your 15 degree cylinder offset. This is an Oichan original design (http://www.oichan.org) sold under his permission. Beware of the rip off versions out there which are made using water jet process and have ragged edges and poor quality. Ours are made on a 3 axis CNC 1 at a time and are literally perfect replications of the unique VR6 engine.
Available in machine polished billet aluminum or genuine 3K weave carbon fiber plate.
Billet fuel line support brackets (set of 2) to replace the weak plastic clips that are probably long gone on your MK2 and MK3 VR6. Ours are CNC'd from billet aluminum to perfectly match the size and shape of your VR6 fuel lines. Mount directly to the head in place of existing plastic supports and install with supplied aerospace grade stainless fasteners. Dont leave your VR6 fuel lines loose and rubbing against hot engine components! These will take more abuse than you can dish out, guaranteed!!
Can be chrome plated for those seeking even more engine bay bling.
Fits all MK2 and MK3 VR6 - Jetta, GTI, Passat, and Corrado. Includes stainless bracket hardware, re-use existing 10mm nuts to bolt to head. Brackets replace OEM P/N 021-133-827 (021133827) Bracket and P/N 021-133-687A (021133687A) clip.
GruvenParts.com is proud to release billet MK2 1.8/2.0 16V Billet Crank Pulleys !!
GruvenParts.com has designed CNC billet aluminum pulleys for the 16V 1.8L and 2.0L MK2 engines found on Scirroco, GTI, Jetta, and Passat!. Our pulleys are precision machined to a run out of less than .001 on our HAAS CNC mill-lathes. The products are completed entirely on the CNC mill, and therefore have a nearly chrome surface finish. This billet aluminum crank pulley weights just under 680 grams – over 3 times lighter than its OEM counterpart! Comes correct with exact mounting holes and provides tapped holes for OEM power steering pulley to mount up. Includes the factory timing mark as well.
Fits all Scirroco, Golf GTI, Jetta GLI, and Passat with 16v 1.8L or 2.0L engines. Replaces OEM P/N 027-105-243 (027105243)
GruvenParts.com offers a complete set of ultra sleek lightweight MK4 1.8T/2.0 power pulleys. These include lightweight billet crank, power steering, tensioner, and alternator pulleys for your MK4 1.8T/2.0 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by more than 5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon
022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos
Another Vortex 1st - You told us about the chronic rattles common to the intake manifold change-over valve on the 12V and 24V VR6 engines and we listened. Our bushings provide the fit that VW should have used to prevent intake manifold wear.
Our bushings are designed to provide more contact area and a tighter fit to secure the intake manifold change-over rod. Continuing to use the weak OEM bushings will result in the change-over rod vibrating (the source of the rattle), which in turn will damage the intake manifold itself. Last we checked, these intake manifolds were running close to $1,000 and are only available from VW. Dont take chances by waiting, replace the bushings with our versions BEFORE rattling occurs! There is no need to replace the rod itself, just the bushings.
These bushings replace the following OEM part numbers -
GruvenParts.com 4.2L V8 Intake Manifold Linkage Arms Warranted for Life !
Got a 4.2L V8 Audi or VW ? Then you had better check your intake manifold actuator arms (p/n 077198327A)! The OEM versions quickly break, leaving your intake manifold rod stuck, causing poor idle, drivability, loss of power, and poor fuel mileage. This is a very common problem on the 4.2L V8.
Our intake manifold arms have an aerospace grade billet aluminum body with thread on carbon fiber composite ball end links. The composite end links are actually STRONGER than the aerospace grade aluminum body itself!
This is how we can warranty them for life!
Dont go to the VW/Audi dealer and pay upwards of $400 for the new actuator kit when all you need are the arms (the actuators themselves rarely fail). And DONT pay that kind of money for another set of plastic arms that will break in quick order.
Go with GruvenParts.com and NEVER WORRY ABOUT THIS AGAIN !
Fits the following vehicles:
2004-2007 VW Phaeton V8
2003+ VW Touareg V8
2002-2004 Audi A6/Avant
1998-2004 Audi A6/S6 Quattro
2000+ Audi A8/S8 Quattro
GruvenParts.com builds bulletproof TIG welded Y Pipes to replace the OEM plastic in your VW coolant system!
PLEASE NOTE : This part is professionally TIG welded! There are no junk tapped threads into thin wall aluminum like the lesser versions offered by unscrupulous rip off artists. And its warranted for life!
An absolute MUST HAVE for all MK3 VR6 owners and MK4 New Beetle owners. The upper radiator hose on these models is quite a pricey item from the dealer – usually about $100. The most documented cause of replacement on this hose is due to the plastic Y fitting which connects the 3 short hose pieces. The VW Y pipe cannot be bought separately, and is not suited for the high temperatures under the hood. Hell, its plastic – what did you expect?!
Dont buy the OEM plastic part when you can buy this BILLET ALUMINUM TIG Welded replacement part for half the price!
If you need a custom water temp sensor port welded on, please let us know. We are happy to perform customization on ANY of our products.
We've been around VW's long enough to know that Murphy is a mother***! Therefore, we have crafted these billet MK4 Golf / Jetta / R32 / Wagon hood pulls from a solid blocks of aerospace grade 6061-T651 aluminum using 1 of our 5 axis CNC's. Its an exact replica of the OEM part, except made the way VW should of done it - from billet! Forget about the Pray and Pull theory, you're not breaking this one! Includes nut/bolt for the simple installation.
These billet hood pulls replace VW P/N 1J5823593C (1J5 823 593C) for MK4 Jetta / Wagon and VW P/N 1J0823593C (1J0 823 593C) for MK4 Golf / R32
GruvenParts.com offers a complete set of ultra sleek lightweight 24V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 24V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
We’re all sick of popping the hood on our stylish VW’s and Audi’s only to find an engine compartment which looks like it might have digested a construction cone somewhere along the way. Now you can finally get rid of that hideous bright orange dipstick in favor of this billet aluminum version in a variety of colors and finishes.
Fits all 98-07 New Beetle, Golf, Jetta, Passat, 99-06 Audi A4 00-06 TT and is for use on cars with OEM dipstick P/N 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R)
Ditch the ugly blue washer fluid cap (or half tennis ball if you’re really ghetto) with one of these slick billet aluminum 6061-T651 versions.
Ours are CNC machined for a perfect fit and can be ordered in a variety of colors and finishes – including anodized or highly polished. Simply remove the old cap and press fit this one right into the washer tank.
This product replaces OEM P/N 1K0-955-455 (1K0955455), 1H0-955-455 (1H0955455), and fits nearly every VW and Audi in existence. So, there’s no excuse to rock the half tennis ball anymore!
Dress up your 225 TT engine with this super highly polished oil cap ring which is precision machined from 6061-T651 aluminum. This piece is machined with 7 dimples and a TT logo, and is a quarter inch thick for added bling.
Installs quickly with 3M double tape (not included).
This product fits all 00-06 TT with 225 HP engine cover
GruvenParts.com now also has solid stainless side/side cable shift repair blocks for cable shift VW vehicles. Once again, there is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken shift cable. And if your cable is not yet broken, throw 1 of these in the glove box and be prepared for the inevitable!
Add some indestructible hardware to the factory cable shift mechanism where it needs it most! Buy these parts together and save!!
Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms
BY FAR – THE BEST VALUE IN ADJUSTABLE CONTROL ARMS ON THE MARKET !
You asked GruvenParts.com for affordable, bulletproof, and fully rebuildable Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms and we have delivered!
Just like the GruvenParts.com popular TT/R32 rear adjustable control arms, we designed these based on years of fabricating rock crawler suspension systems for racers and weekend warriors alike. They are made from a special aircraft grade of 4130 chrominum-molybdenum alloy and then powder coated in high gloss black for maximum durability. The AMERICAN MADE racing heim joints are CAD plated, PTFE lined, and can be ordered with dust boots all around for those planning to re-enact a Grouppe B Ralley race. Finally, all parts are fully rebuildable.
Don’t waste your hard earned money with the over-priced competitor versions. The quality and performance of the GruvenParts.com adjustable upper control arms are second to none!
These come as a set of 4 and fit the following models :
Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
Audi A6/RS6 (incl. AllRoad) - 1998-2004
VW Passat - 1998-2005
