Results 36 to 70 of 91
Thread: ** GruvenParts.com Has All Your Hybrid/Swap Engine Goodies!
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-10-2011 08:57 AM #36
    CNC Pressed MSD Coil Pack Brackets for MK3 and MK4 VR6 !
    Use this CNC formed, powder coated Aerospace grade aluminum bracket to mount your new MSD 8224 coils on MK3 or MK4 VR6 engines. We all know how poorly the OEM Beru units hold up - so get serious about your VR6 ignition and step up to MSD! Leave the cheaply made, overpriced Beru coils for the competition!
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-21-2011 11:29 AM #38
    TT/R32 Rear Adjustable Control Arms
    Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
    We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include greaseable heim joints and bulletproof welds. Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
    We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
    Want further discounts and more great products from GruvenParts.com? Read on!
    TT/R32 Rear Adjustable Sway Bar End Linkages
    Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
    Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
  3. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-15-2011 09:19 AM #39
    MKIV VR6 Intake Manifold Bushings - 12V and 24V VR6 Engines
    These bushings replace the following OEM part numbers -
    021-133-653 (021133653) on 2.8L 12V VR6 engines - 1999-2006 Golf, Jetta, Jetta Wagon, Vanagon
    022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon
    022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos
    Another Vortex 1st - You told us about the chronic rattles common to the intake manifold change-over valve on the 12V and 24V VR6 engines and we listened. Our bushings provide the fit that VW should have used to prevent intake manifold wear.
    Our bushings are designed to provide more contact area and a tighter fit to secure the intake manifold change-over rod. Continuing to use the weak OEM bushings will result in the change-over rod vibrating (the source of the rattle), which in turn will damage the intake manifold itself. Last we checked, these intake manifolds were running close to $1,000 and are only available from VW. Dont take chances by waiting, replace the bushings with our versions BEFORE rattling occurs! There is no need to replace the rod itself, just the bushings.
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-21-2011 03:06 PM #40
    Just to make all the MK4 VR6 owners aware …
    www.GruvenParts.com will soon be releasing a billet aluminum version of the white plastic part which connects the intake manifold change over rod to the drive unit actuator shown in this pic (red arrow) :
    And detailed in this DIY Article section on www.GruvenParts.com
    On 12V VR6 engines (99-06 Golf, Jetta VR6), the white part is sold as part of the Drive Unit p/n 071-133-759C (071133759C) or 071-133-759D (071133759D) and on the 24V engines (R32, 02-08 Golf, Jetta, Eos, Touareg) it is sold as part of Drive Unit p/n 022-133-759 (022133759) or 022-133-759A (022133759A).
    This white plastic part continually breaks and is not readily available from VW without buying the whole plastic Drive Unit at a cost of $130-$160.
    Needless to say, we’ll put an end to that foolishness in typical GruvenParts.com fashion by milling this part from a solid chunk of 6061-T651.
    You can follow the development thread here (and feel free to chime in, too!) –
    http://forums.vwvortex.com/showthrea...-a-replacement
    Just another example of how www.GruvenParts.com is listening to your suggestions. Let us know what other parts need to be redesigned!
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-22-2011 10:31 AM #41
    A4 / Passat 1.8T Billet Dipstick
    www.GruvenParts.com is proud to release these gorgeous Billet Dipsticks to replace OEM part number 053-115-611C (053115611C). Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a flitting with hash marks to signify oil level min and max.
    As an added bonus, this part is made to perfectly fit our Billet Dipstick Funnels and can be ordered as a set to save! If you are ordering the billet funnel with the billet dipstick, please ensure your car uses dipstick funnel OEM P/N 053-103-663 (053103663).
    This billet dipstick replaces OEM part number 053-115-611C (053115611C) and fits the following vehicles :
    1996 - 2002 Audi A4/S4/Avant Quattro 1.8T (AEB)
    1998 – 2001 VW Passat 1.8T (AEB)
    1988 – 1992 Audi 80/90
    1982 – 1987 Audi 4000
    1987 – 1993 VW Fox
    1982 - 1985 VW Quantum 1.8L
    Don’t see your car listed here? Don’t worry! We have many more of these billet dipsticks coming for nearly all makes / models. Visit www.GruvenParts.com for the latest.
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-28-2011 01:36 PM #42
    Bump for billet goodness and lots more is on the way !
    www.GruvenParts.com
    Our TT/R32 + A4/Passat Adjustable control arms are now available fully booted for extreme environments.
    A4/B5 Front Adjustable Control Arms
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-05-2011 02:15 PM #43
    ABA / Corrado G60 / MK2 Billet Dipstick
    www.GruvenParts.com is proud to release these gorgeous Billet Dipsticks to replace both OEM part number 027-115-611C (027115611C) and 051-115-611B (051115611B). Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a flitting with hash marks to signify oil level min and max.
    This billet dipstick replaces both OEM part number 027-115-611C (027115611C) and 051-115-611B (051115611B) and fits the following vehicles :
    1993-1999 Jetta/Golf/Passat/Cabrio w.2.0 ABA engine
    1990-1992 Corrado G60 1.8L
    1985-1992 Jetta/Golf/Passat w/1.6L and 1.8L engines
  8. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-12-2011 01:58 PM #45
    Billet 12V VR6 Drive Belt Pulleys - All 12V VR6
    GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Buy them as a set and save!
    These pulleys replace the following OEM part numbers :
    Crank Pulley : 021-105-243 (021105243)
    Tensioner Pulley: 021-145-299 (021145299)
    Water Pump Pulley: 021-121-031A (021121031A)
    Alternator Pulley:
    Power Steering Pulley : 021-145-255 (021145255)
  9. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-16-2011 03:04 PM #46
    These are back in stock (in super gloss black) and ready to go!
    www.GruvenParts.com
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-23-2011 08:51 AM #47
    GruvenParts.com has released this billet intake drive unit arm for ALL VW/Audi VR6 engines with variable intake manifolds!
    Billet Intake Manifold Drive Unit Linkage!
    This part replaces the white plastic part that attaches to the actuator arm. The OEM part is made from injection molded nylon and becomes very brittle in the engine heat. Of course VW/Audi will not sell you *JUST* this part, you would have to buy a whole new drive unit for big bucks and get a bunch of stuff you don’t need.
    GruvenParts.com builds these the way VW should have: from a solid chunk of 6061-T651 aircraft grade aluminum on a 4 axis HAAS mill-lathe. Utilizing some tricks within the SolidWorks/MasterCam CNC software, we have tweaked the process to allow the billet part to be machined specially to accept the locking feature on the end of the intake rod. Just push fit this part onto the end of the intake rod similar to OEM plastic part fitment. There are no set screws to come loose and the fit is perfect.
    This part makes a great upgrade when installing our upgraded MKIV VR6 Intake Manifold Bushings
    Our part will also cost you about 1/3 what VW/Audi charge for their plastic drive unit (and the OEM plastic part is NOT part of their repair kit). This one is a no brainer!
    You guys asked us for it and we listened. Another great billet replacement part to rid your VW/Audi of the weak plastic parts!
    Don’t forget to check out the DIY listed on our website.
    Applications:
    2.8L 12 V VR6 ENGINE - with AFP Engine Code (99-02 Golf/Jetta VR6) to replace the drive unit linkage p/n 071-133-759D (071133759D) on OEM VW rod p/n 021-133-653 (021133653)
    2.8L 24 V VR6 ENGINE - BDF Engine Code (02 - present Golf/Jetta VR6) to replace the drive unit linkage p/n 022-133-759 (022133759) on OEM VW rod p/n 022-133-653 (022133653)
    3.2L 24V VR6 Engines - 04 R32, 3.2 Touareg, 3.2 Eos, 3.2 A3, 3.2 TT to replace the drive unit linkage p/n 022-133-759A (022133759A) on rod p/n 022-133-653B (022133653B)
  11. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-10-2011 11:19 AM #49
    Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
    MACHINED FROM 6061-T651 ALUMINUM TO EXACTLY MATCH OEM PIPE DIMENSIONS - OURS DOES NOT COME WITH CHEAP THIN WALLED TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
    12V and 24V VR6 Coolant Pipes aka Crack Pipes
    GruvenParts.com was the 1st to build this part and it’s what started us off! We manufacture this pipe EXACTLY to match the OEM part shape so there is NEVER a fitment issue. Be careful when considering other billet pipes which do not match the exact shape of the OEM pipe. The fitment of this part is tricky and the shape MUST BE IDENTICAL to the OEM part to ensure correct alignment between the water pump and thermo housing.
    If you have a billet crack pipe in your VR6, chances are it was made by us. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! Our pipe has a modular design which allows you to plug the oil cooler feed line with a ¼ NPT plug if installing an external oil cooler. Ours can also be ordered with a chrome plated drain valve for quick and clean coolant flushes. The pipe can also be ordered with a brilliant chrome finish for those seeking the ultimate engine bay bling!
    If you dont want to do this job again, buy the LIFETIME WARRANTED GruvenParts.com billet CrackPipe !
    Make sure to see our website for the complete installation DIY
    The 12V version replaces OEM p/n 021-121-050C (021121050C) found in 12V VR6 : VW Corrado, Golf, Jetta, Passat, and Eurovan.
    The 24V version replaces OEM p/n 022-121-050 (022121050) found in 24V VR6 : VW R32, Golf, Jetta, Eurovan, EOS, Audi : 3.2L V6 TT and A3
  12. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-16-2011 11:51 AM #50
    AAA VR6 Billet Dipsticks
    www.GruvenParts.com is proud to release this Billet Dipstick for all AAA VR6 Corrado, Golf, Jetta, and Passat!
    The gorgeous dipstick is CNC’d from a chunk of aerospace grade aluminum and contains 2 chemically resistant O-rings for a perfect fit and seal.
    Get rid of the ugly plastic dipstick and replace with our billet version!
    This part replaces the dipstick on AAA VR6 engines found on Corrado VR6, MK3 Golf, Jetta, and Passat with OEM dipstick p/n 021115607 and OEM tube p/n 021115629E.
  13. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-29-2011 02:17 PM #51
    Billet MK4 1.8T Golf/Jetta, TT Dipstick Funnel
    GruvenParts.com is proud to release these gorgeous Billet Dipsticks to replace OEM part number 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R) for the Audi TT MKI 1.8T, and VW MKIV 1.8T Golf and Jetta.
    Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a fitting with hash marks to signify oil level min and max.
    As an added bonus, this part is made to perfectly fit our 1.8T Billet Dipstick Funnels and can be ordered as a set to save! If you are ordering the billet funnel with the billet dipstick, please ensure your car uses dipstick funnel OEM P/N 06A-103-663B (06A103663B)
    This billet dipstick/funnel combo replaces OEM part number 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R) dipstick and OEM P/N 06A-103-663B (06A103663B) funnel and fits the following vehicles :
    Audi TT - MK1 w/1.8T engine
    VW Golf, Jetta, and New Beetle - MKIV 1.8T w/1.8T engine
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-06-2011 10:10 AM #52
    Audi/VW 4.2V8 Intake Linkage Arms !
    GruvenParts.com 4.2L V8 Intake Manifold Linkage Arms Warranted for Life !
    Got a 4.2L V8 Audi or VW ? Then you had better check your intake manifold actuator arms Audi/VW P/N 077-198-327A (077198327A)! The OEM plastic versions quickly break, leaving your intake manifold rod stuck which causes poor idle, drivability, loss of power, and poor fuel mileage. This is a very common problem on the Audi/VW 4.2L V8, an otherwise great engine. The dealer will only sell you a repair kit for nearly $400, and each repair kit only comes with 1 of each length linkage arm. If your vechicle has 2 broken linkage arms, you would need to buy 2 dealer repair kits (cost nearly $800)!
    Our Billet intake manifold arms are made from aerospace grade 6061-T651 aluminum with specially machined black Delrin inserts to provide a perfect fit to the actuator balls. These parts are warrantied for life!
    Dont go to the VW/Audi dealer and pay upwards of $400 for the new actuator kit when all you need are the arms (the actuators themselves rarely fail). And DONT pay that kind of money for another set of plastic arms that will break in quick order.
    Go with GruvenParts.com and NEVER WORRY ABOUT THIS AGAIN !
    Fits the following vehicles:
    2004-2007 VW Phaeton V8
    2003+ VW Touareg V8
    2002-2004 Audi A6/Avant
    1998-2004 Audi A6/S6 Quattro
    2000+ Audi A8/S8 Quattro
    Replaces OEM P/N 077198327A (077-198-327A)
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-11-2011 08:55 AM #53
    MK3 Golf/Jetta Billet Radiator Cover
    Replace your plastic MK3 Golf or Jetta radiator fan cover - OEM P/N 1HM-121-343A (1HM121343A) with this machined billet aluminum version. Our part installs in minutes to give your engine bay the attention it deserves!
    Ours is CNC'd from aerospace grade billet aluminum and sculpted to fit the contours of the MK3 Golf and Jetta engine bay perfectly.
    Available in CNC machined finish or chrome plated. Custom engraving options are available. Send us an image of your desired engraving and we will quote it - Paul@GruvenParts.com.
    Fits all 1993-1999 MK3 Golf and Jetta and replaces OEM P/N 1HM-121-343A (1HM121343A)
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-25-2011 11:30 AM #55
    Bump for more billet parts !
    Quote Originally Posted by GruvenParts.com View Post
    www.GruvenParts.com
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-06-2011 03:52 PM #57
    GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Alternator Pulley: 021-903-119 (021903119)
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-12-2011 03:50 PM #58
    2.0L BPY Engine Billet Dipsticks
    GruvenParts.com is proud to release these unbreakable Billet Aluminum Dipsticks to replace OEM part number 06F-115-611F (06F115611F) for the Audi A3, TT, Volkswagen EOS, Golf, Jetta, Passat, and Rabbit. See the complete application list below.
    We’re all well aware that the OEM’s cheap orange plastic dipstick on these engines has a small clip that breaks off the 2nd time you check your oil. The broken plastic pieces commonly fall down the oil dipstick tube resulting in contamination in the oil pan. Once broken, the OEM plastic dipstick flops around on the tube causing vacuum and oil leaks, drivability issues, and a big mess.
    GruvenParts.com has ended all that plastic silliness by releasing these high quality dipsticks machined from billet aluminum with a specially sized O-ring. The O-ring creates a tight seal against the tube and will last far longer than the cheesy orange plastic version (while looking a whole lot better!).
    This billet aluminum dipstick replaces OEM P/N 06F-115-611F (06F115611F) on OEM tube P/N 06F-103-663H (06F103663H) and fits the following vehicles :
    2006-2008 Audi A3 2.0L Sportback BPY
    2009 Audi TT 2.0L BPY
    2007-2008 Volkswagen EOS 2.0L BPY
    2008 Volkswagen Golf 2.0L BPY
    2005-2007 Volkswagen Jetta 2.0L (including GLI) BPY
    2006-2008 Volkswagen Passat 2.0T Sedan BPY
    2006-2008 Volkswagen Rabbit 2.0L GTI Turbo BPY
  19. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-20-2011 09:51 AM #59
    Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms
    BY FAR – THE BEST VALUE IN ADJUSTABLE CONTROL ARMS ON THE MARKET !
    You asked GruvenParts.com for affordable, bulletproof, and fully rebuildable Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms and we have delivered!
    Just like the GruvenParts.com popular TT/R32 rear adjustable control arms, we designed these based on years of fabricating rock crawler suspension systems for racers and weekend warriors alike. They are made from a special aircraft grade of 4130 chrominum-molybdenum alloy and then powder coated in high gloss black for maximum durability. The heim joints are CAD plated, PTFE lined for quiet operation, and can be ordered with dust boots all around for those planning to re-enact a Grouppe B Ralley race. All parts are fully rebuildable.
    Don’t waste your hard earned money with the over-priced competitor versions. The quality and performance of the GruvenParts.com adjustable upper control arms are second to none!
    These come as a set of 4 and fit the following models :
    Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
    Audi A6/RS6 (incl. AllRoad) - 1998-2004
    VW Passat - 1998-2005
    This product replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
  20. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-03-2011 10:19 AM #60
    Guys, the GB has ended on these control arms, however, we can always start another
    For 10 orders, we can offer price of $409.99, please note this INCLUDES the racing grade dust boots to protect the heims.
    If you want in on the GB, email or post up here your contact details.
    Thanks!
    www.GruvenParts.com
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-17-2011 11:33 AM #61
    DOES NOT COME WITH CHEAP THIN WALL TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
    Ours are completely tig welded by our licensed commercial jet aircraft repair facility! We were the 1st to build this part and its what started us off! If you have a billet crack pipe in your VR6, chances are it was made by http://www.GruvenParts.com. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! The 12V version replaces OEM p/n 021-121-050C (021121050C) and the 24V version replaces OEM p/n 022-121-050 (022121050).
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-27-2011 10:28 AM #62
    GruvenParts//Yarrowsport MKIV Golf/Jetta Rear Stress Bar
    We are helping Yarrowsport sell their popular MKIV rear stress bar for Golf and Jetta platforms.
    Stiffen up the flexible MKIV chassis with this proven rear stress bar from Yarrowsport and sold exclusively by GruvenParts.com! This bar is machined to the factory correct dimensions and installs easily with all hardware and instructions provided.
    Fits all MK4 Golf and Jetta, R32 !
  23. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-14-2011 12:48 PM #63
    GruvenParts.com Die Cut Vinyl Stickers - Free for Orders over $100 !
    They're Back In Stock - Bigger and Better !! All Colors Now Available. Dress up your ride with our premium die cut vinyl stickers and enjoy free domestic shipping.
    Available in Red, Silver, White and Black.
    We ship out a freebie with any order over $100 !
  24. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-06-2011 11:58 AM #64
    A4 and A6 owners with the 3.0L V6 engine, could you please check out this thread and respond -
    http://forums.vwvortex.com/showthrea...ge-Arms-FEELER
    As many of you know, GruvenParts.com specializes in machining all types of more durable engine and suspension components.
    One such item is the Audi/VW 4.2L V8 intake links -
    Im wondering if owners of the 2002-2006 A4/S4/A4 Quattro and 2002-2004 A6/A6 quattro with the 3.0L V6 engine (code AVK) would also be interested in having us design metal linkage arms in a similar fashion.
    The Audi part number on the V6 engine is 06C-133-611 (06C133611) drive unit w/rotary valve which is installed onto 06C-133-201J (06C133201J) intake manifold.
    These intake manifolds also have plastic arms which tend to break and of course Audi is only too happy to sell you an entire drive unit at a cost of $400+ when all you really need are more durable linkage arms. See these pictures :
    So, with all that background presented, can you A4/A6 owners with the 3.0L V6 engine have a look at your intake drive unit and inspect the arms and let us know if they are broken? Can you also comment on if you would like to see GruvenParts.com release a billet aluminum version of those actuator arms with a lifetime warranty ?
    Please feel free to email us directly with your thoughts / interest in this idea. Our aim is to provide durable replacements for the parts which are prone to breaking!
    www.GruvenParts.co
    Thanks!
  25. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-13-2012 09:10 AM #65
    Click on the picture to visit our product page for up to date pricing info.
    NOW CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
    The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
    Choose from a zero deflection high radial load PTFE lined heim joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the heim and bushings is nearly water tight!
    OR
    A poly bushing end with a heat treated 4340 forged chromoly housing, grease fitting, zinc plated steel sleeves, and race grade greaseable black polyurethane bushings
    You decide which set up you want ! The zero deflection spherical heims are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
    All control arms feature the following :
    Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
    Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
    Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue. Please don’t adjust these with weight on the rear axle, and don’t use channel locks that could mar even a hard coat chrome plate.
    Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
    Got a lowered TT, R32, or A3 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue or gloss black to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    TT/R32 OEM Headlight Leveling Adapter Bracket
    TT / R32 Headlight Leveling Adapter Bracket
    Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
  26. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-13-2012 05:18 PM #66
    These parts are in stock, ready to ship!!
    OR
  27. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-19-2012 10:55 AM #67
    We also now have the billet MKIV Vr6 12V and 24V and R32/TT oil dipsticks in stock. I will have pictures coming soon. Nice to ditch the orange plastic
    www.GruvenParts.com
  28. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-20-2012 11:14 AM #68
    MKIV VR6 Billet Dipsticks
    GruvenParts.com has released these new Billet Dipsticks for all MKIV VR6 motors including both the 12 valve and 24 valve engines in 2.8L and 3.2L variety.
    These billet dipsticks have a CNC’d handle made from aerospace grade 6061-T651 aluminum specially machined with a chemically resistant O-ring for a perfect seal. The wire is bundled stainless permanently attached to the CNC’d handle, and also with a specially machined oil level indicator tab at the wire base.
    Now is the time to get rid of that f-ugly plastic orange OEM dipstick which is prone to breaking and causing embarrassment in your otherwise gorgeous engine bay!
    This part replaces the OEM dipstick on the following vehicles :
    Volkswagen MKIV Golf, Jetta, Touareg, and R32 with the VR6 engine codes AFP, BDF, BJS, BAA, and BMX
  29. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-26-2012 11:39 AM #69
    Special Service Announcement from www.GruvenParts.com : DONT GO TO YOUR AUDI OR VW DEALER FOR THESE PLASTIC DRIVE LINKAGES FOR YOUR VARIABLE INTAKE MANIFOLD!
    www.GruvenParts.com is now producing new metal versions of both the Audi A4 3.0L V6 and the VW VR6 intake manifold linkage arms, similar to the ones we currently build for Audi/VW 4.2 V8.
    The Audi 3.0L V6 arms will replace the plastic ones on the 2002-2006 A4/S4/A4 Quattro and 2002-2004 A6/A6 quattro with the 3.0L V6 engine (code AVK) Audi part number 06C-133-611 (06C133611) drive unit w/rotary valve which is installed onto 06C-133-201J (06C133201J) intake manifold.
    See pictures below for the Audi drive unit – broken plastic OEM arms are circled in RED.
    The VW VR6 drive unit arms will replace the plastic ones on the following vehicles (yellow arrow in the picture below) :
    We expect to have both versions available for these cars during the month of April 2012.
    ** This has been a special service announcement from www.GruvenParts.com **
  30. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-23-2012 02:31 PM #70
    Bump for some of the best control arms in the business. Thanks for all the orders on these guys, please keep em coming!
