Page 3 of 3 FirstFirst 1 2 3
Results 71 to 91 of 91
Thread: ** GruvenParts.com Has All Your Hybrid/Swap Engine Goodies!
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-16-2012 09:44 AM #71
    GruvenParts.com
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-29-2012 09:21 AM #72
    GruvenParts.com would like to provide a status update on the Audi 3.0L V6 variable intake linkage arms
    www.GruvenParts.com is now producing new metal versions of both the Audi A4 3.0L V6 and the VW VR6 intake manifold linkage arms, similar to the ones we currently build for Audi/VW 4.2 V8.
    Audi/VW 4.2V8 Intake Linkage Arms !
    The Audi 3.0L V6 arms will replace the plastic ones on the 2002-2006 A4/S4/A4 Quattro and 2002-2004 A6/A6 quattro with the 3.0L V6 engine (code AVK) Audi part number 06C-133-611 (06C133611) drive unit w/rotary valve which is installed onto 06C-133-201J (06C133201J) intake manifold.
    Our metal linkage arms will last forever and cost around $100 bucks, so there is no need to go to the Audi dealer and spend $500 on more plastic garbage. Here is a few pictures of our status. I hope to have these released in 1-2 weeks.
    Background info :
    See pictures below for the Audi drive unit – broken plastic OEM arms are circled in RED.
  3. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-16-2012 08:51 AM #73
    Please make sure to like us out on Facebook
    http://www.facebook.com/GruvenParts
    Its a great way to keep up with all that we are developing, and request more items to be developed
    www.GruvenParts.com
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-20-2012 07:58 AM #74
    These are in stock, ready to ship asap.
    Click the picture to order
    TT/R32 Rear Adjustable Control Arms
    Click on the picture to visit our product page for up to date pricing info.
    NOW CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
    Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
    The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
    Choose from a zero deflection high radial load PTFE lined heim joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the heim and bushings is nearly water tight!
    OR
    A poly bushing end with a heat treated 4340 forged chromoly housing, grease fitting, zinc plated steel sleeves, and race grade greaseable black polyurethane bushings
    You decide which set up you want ! The zero deflection spherical heims are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
    All control arms feature the following :
    Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
    Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
    Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue. Please don’t adjust these with weight on the rear axle, and don’t use channel locks that could mar even a hard coat chrome plate.
    Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
    We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
    Want further discounts and more great products from GruvenParts.com? Read on!
    TT/R32 Rear Adjustable Sway Bar End Linkages
    Got a lowered TT, R32, or A3 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue or gloss black to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
    Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt
    TT/R32 OEM Headlight Leveling Adapter Bracket
    TT / R32 Headlight Leveling Adapter Bracket
    Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-10-2012 09:44 AM #75
    A4, A6, Passat Stainless Slave Cylinder Bleeder Screws
    GruvenParts.com Introduces Stainless Bleeder Screws for Audi A4, A6, and VW Passat!
    Our 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw which Audi and VW provide on their clutch slave cylinder P/N 8E0-721-257F (8E0721257F) and P/N 8E0-721-257M (8E0721257M).
    How many times have you gone to bleed the brakes on your Audi A4, A6, or VW Passat only to round off the hex on the cheap plastic bleeder screw on your clutch slave cylinder? The problem is corrosive brake fluid actually melts the plastic bleeder screw and bonds it into the slave cylinder housing making it impossible to open. This problem makes it impossible to bleed your brakes properly and causes soft brake and clutch pedals. The only remedy until now has been to replace the entire slave cylinder unit, which is expensive, time consuming, and NOT FUN (to say the least!).
    GruvenParts.com has addressed this problem with our new 303 Aircraft Grade Stainless Steel Bleeder Screws. We machine these in house on state of the art HAAS CNC lathes and mills with custom screw machining capability to exactly match the OEM threads for a perfect fit. These come complete with preinstalled Viton O-rings for maximum life. The hex will never round off or become stuck in the slave cylinder body and you likely will never need to replace a slave cylinder again.
    This 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw found in clutch slave cylinders P/N 8E0-721-257F (8E0721257F) and P/N 8E0-721-257M (8E0721257M).
    This product fits the following vehicles :
    Audi A4 1996 thru 2005 1.8, 1.8T, 2.8L including Quattro
    Audi A6 1995 thru 2005 2.7L, 2.7T, 2.8L, including Quattro and Allroad
    Volkswagen Passat 2000 thru 2005 1.8T, 2.8L including 4 Motion
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-20-2012 08:21 AM #76
    Billet 12V VR6 Drive Belt Pulleys - All 12V VR6
    GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Buy them as a set and save!
    These pulleys replace the following OEM part numbers :
    Crank Pulley : 021-105-243 (021105243)
    Tensioner Pulley: 021-145-299 (021145299)
    Water Pump Pulley: 021-121-031A (021121031A)
    Alternator Pulley: 021-903-119 (021903119)
    Power Steering Pulley : 021-145-255 (021145255)
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-09-2012 09:28 AM #78
  8. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-03-2012 11:38 AM #80
    OR
  9. 12-13-2012 08:40 PM #81
    How about making a replacement roof gutter for an A2 jetta. Seams to be the hardest part to find, other than corrado outer door seals. know you guys can do it !
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-14-2012 04:06 PM #82
    Can you post up a picture of that or email me?
  11. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-10-2013 10:16 AM #84
    GruvenParts.com Billet MKIV Upper Radiator Hose 4Y!
    GruvenParts.com is about to release our BILLET MKIV VR6 12V Upper Radiator Hose 4Y to replace the junk plastic 4Y in OEM hose P/N 1J0-122-101AP (1J0122101AP) and 1J0-121-087J (1J0121087J)
    The flimsy plastic 4y section of this molded hose assembly quickly dries out and becomes super brittle. If you look at it wrong, it will snap and leave you stranded. Or worse, turn your high dollar VR6 motor into an overheated paperweight.
    Our BILLET ALUMINUM version is made from CNC'd 6061-T651 block and professionally TIG welded and leak tested. You could drive your car over this one, but we'd recommend doing that to the OEM plastic version and installing ours instead
    Ours uses an NPT fitting for the radiator reservoir return line, so if you ever wanted to delete your main coolant reservoir, you could simply install a threaded NPT plug. You could also install a coolant temp sender for those stand alone ignition installations.
    This 1 should be ready soon, please email if you would like to pre-order – Paul@GruvenParts.com
    Fits :
    All MKIV Golf/Jetta VR6 12V engines (upper radiator hose P/N 1J0-122-101AP (1J0122101AP) and 1J0-121-087J (1J0121087J)
    www.GruvenParts.com
  12. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-14-2013 01:56 PM #85
    bump for the best products for your ride
    www.GruvenParts.com
  13. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2013 09:35 AM #86
    Billet VW/Audi VR6/V6/V8 Oil Filter Housings !
    Precision Machined Aluminum Oil Filter Housings For VW And Audi VR6/V6/V8 Engines !
    This one was worth the wait, folks! Never, but NEVER break a flimsy plastic oil filter housing again. Or deal with the unsightly leaks created by the cheaply made (yet expensive) plastic OEM housing cracking and deflecting. We made this one the way VW and Audi should have – from A SOLID BLOCK OF ALUMINUM, by God!
    First, we start with a massive chunk of Aircraft Grade 6061-T6511 Aluminum. The section is delicately placed on one of our special CNC machining centers and precision cut to EXACTLY match the OEM plastic housing. The metal gods (well, in this case, one of our highly talented CNC programmers) has programmed elaborate steps for the very time consuming and expensive operation of profiling the special buttress threads into the housing using the exact DIN spec thread cutting tool required for a perfect seal. It simply doesn’t get better than this!
    We also provide a proper threaded drain plug of the same size as your oil pan plug (use just 1 19mm socket for both!). Rather than some useless internal soft hex plug which easily strips, ours is a genuine Audi plug made from steel with an honest 19mm external hex. The plug comes with a contained sealing washer as well. And yes, we also provide USEABLE 36mm hex flats so you can easily remove the housing with a standard 36mm socket. Imagine that : You can simply drain the housing using its proper drain plug bolt that wont round off, and remove the housing using a proper 36mm socket that also wont round off. This could possibly make changing your oil fun again!
    This product is intended to replace VW/Audi Part Numbers 021-115-433A (021115433A) and 021-115-433B (021115433B) housings. Please check the OEM part number of your oil filter housing before ordering. You can do this easily by calling your dealer and giving them your VIN #. It will fit the following vehicles :
    VW Corrado (1992-1995 w/AAA VR6 engine)
    VW Golf and Jetta/Wagon (1993-2006 w/AAA and AFP VR6 engines)
    VW Passat (1992-1997 w/AAA VR6 engine)
    VW Touareg (2003-2007 w/3.2 and 3.6 V6 engines)
    VW Eurovan (1996-2004 w/AES V6 engine)
    Audi A8/S8 (2000-2003 w/4.2L AUX V8 engine)
    Audi Q7 (2007-2009 w/3.6L BHK V6 engine)
    Special Note At The End :
    Use oil filter part number 021-115-562 (021115562) or equivalent with our metal housing. If your parts department requires a vehicle type, tell them “1995 VW Golf GTI VR6”. This is the older, vastly superior cartridge filter with the metal end caps. VW, in their infinite cost savings wisdom, superseded it with a cheaper, cardboard end filter (021-115-562A). Please make sure to order filter 021-115-562 oil filter (or equivalent) as it is the superior filter for these engines, and will fit correctly with this housing. You can buy it from us using the drop down menu on the product page, or at any dealer or trusted auto parts store.
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-04-2013 12:48 PM #87
    Billet VW/Audi VR6/V6/V8 Oil Filter Housings - Installed !
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-02-2013 07:59 AM #88
    Billet 1.8T / 1.9TDI / 2.0 Upper Radiator Hose 4Y!
    Part is sold in machined finish but can be anodized in any color !
    GruvenParts.com is proud to announce this pre-release of our new BILLET VW/Audi 1.8T / 1.9T / 2.0 Upper Radiator Hose 4Y Pipe to replace the OEM Audi/VW plastic 4Y P/N 1J0-121-087C (1J0121087C)
    This part is found in OEM upper radiator hose P/N’s
    1J0-122-101BL (1J0122101BL),
    1J0-122-101R (1J0122101R),
    1J0-122-101A (1J0122101A),
    1J0-122-101B (1J0122101B),
    8NO-122-101A (8NO122101A),
    8N0-122-101B (8NO122101B)
    with no thermo switch.
    The flimsy plastic OEM 4Y junction located in the upper radiator hose quickly dries out and becomes super brittle. If you look at it wrong, it will snap and leave you stranded. Or worse, turn your high dollar motor into an overheated paperweight. Our BILLET ALUMINUM version is made from CNC'd 6061-T651 aircraft grade aluminum. Our version is also machined to accept ORB (o-ring boss) to Nipple as well as -AN to ORB fittings for each of the 4 ports. This will allow owners to use the factory hoses, or switch to complete -AN hoses for the holy grail of all cooling systems! Each fitting will be supplied with the appropriate viton O-ring on the ORB end. The ports will be sized as follows :
    Upper (reservoir return) : -4AN
    Lower (oil cooler outlet) : -8AN
    Left /Right Main Radiator outlets : -16AN
    Customers may choose to order this part as the main body only (with no fittings), OR, with ORB to Nipple adapters pre-installed in each port.
    This Part Fits :
    VW Golf/Jetta/New Beetle with 1.8T / 1.9TDI, 2.0 1999-2012 with upper radiator hose with 4Y adapter P/N 1J0-121-087C (1J0121087C)
    Audi TT 1.8T 2000-2006 with upper radiator hose with 4Y adapter P/N 1J0-121-087C (1J0121087C)
    Applicable Engine Types :
    AEG, AVH, AZG, AWG, AWW, AVH, BEV, AWP, BEW, “CND” + BEW, ALH, ATC, AWP, AMU
    Please READ THE SPECIAL NOTES !!
    ** SPECIAL NOTE REGARDING FITTINGS **
    The fittings and ports are machined by GruvenParts.com specifically to fit the vehicle radiator hose. They match the OEM length and diameter, and thus will not cause the fitting to kink the OEM hoses. The ports adhere to the SAE specifications in all regards with the exception of length, which has been shortened. This was necessary due to the tight space constraints, which this part fits into.
    This means that customers wanting to utilize -AN hoses rather than the OEM rubber hoses will need to use -AN to ORB adapters, in which the ORB side has been shortened to fit correctly into this machined part.
    GruvenParts.com will supply ORB to nipple adapters initially. We can also make the
    -AN to ORB adapters for this part if 10 people request them. You could also take a standard -AN to ORB adapter and machine the ORB end slightly to accommodate the shorter port on this part.
    ** SPECIAL NOTE REGARDING PRE-ORDER STATUS**
    Please click here for all info : http://forums.vwvortex.com/showthrea...if-interested-!
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-06-2013 09:51 AM #89
    What other parts do you want to see made for these cars? We are always looking for new parts
    www.GruvenParts.com
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-13-2013 10:52 AM #90
    Billet 2.4” Vortech Supercharger Pulleys !
    GruvenParts.com Billet 2.4” Supercharger Pulleys for Vortech Chargers !
    Got a boost addiction? Check out these 2.4” diameter supercharger pulleys for V Series Vortech superchargers. This pulley will allow your charger to spin faster, creating more boost and more power.
    These pulleys are precision CNC’d from 6061-T6511 aluminum and are sized to precisely match the shaft output on Vortech chargers. These pulleys are 7 rib, but can be used in 6 rib applications that provide enough clearance for a 7 rib pulley (you would just have 1 empty rib). Please note the offset distance (from charger side of pulley to the centerline of the 1st rib = 0.650”). Rib spacing is 0.140” center to center (for K style serpentine belts). The overall width from end to end = 1.640”.
    These pulleys come machined to accept the standard woodruff key found on the Vortech V Series supercharger output shafts (key and bolt not included). Please calculate your maximum impeller RPM to ensure you do not overdrive the supercharger at high RPMs. This product may void any Vortech factory warranties.
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-21-2013 11:23 AM #91
    *** NEW PRODUCT RELEASE NOTICE ***
    GruvenParts.com is Building MK2/MK3 Billet Strut Caps !!
    MK4 coming soon, too !
    Here is another one you guys wanted and we're in process of building it -
    These parts will be machined from 6061-T651 and sold in sets of 2. They will have a machined finish (the red picture is just to see it against the CAD screen background), however we can also chrome plate, anodize, or powder coat in any color (please inquire via email). We can also handle "special" orders if you want a custom design (please inquire via email).
    These billet strut caps are intended to fit over the following OEM parts :
    1H0-412-319B (1H0412319B) Stop
    357-412-319B (357412329) Stop
    1H0-412-356A (1H0412356A) Stop
    357-412-411A (357412411A) Stop
    and replace the cap found on some MK3 4 cylinder models :
    1H0-412-329 (1H)412329) Cap
    Our parts will be specially machined to accept the strut stop/cap on all MK2 and MK3 Golf, Jetta, Passat, Corrado, Cabrio, Cabriolet from 1985-1999.
    We'll also begin work on the MK4 versions as well, stay tuned!
    Please check the site under MK2 Engine and MK3 Engine sections soon, as we will update pics and add the product page soon.
