Results 71 to 105 of 124
Thread: *** GruvenParts.com - Billet Goodies for Forced Ind Engines
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-06-2011 12:08 PM #71
    Lightweight MK4 1.8T / 2.0 Billet Drive Belt Pulleys
    GruvenParts.com offers a complete set of ultra sleek lightweight MK4 1.8T/2.0 power pulleys. These include lightweight billet crank, power steering, tensioner, and alternator pulleys for your MK4 1.8T/2.0 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by more than 5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Buy them as a set and save!
    These pulleys replace OEM part numbers :
    06A-105-243E (06A105243E) MK4 1.8T/2.0 crank pulley
    038-145-255A (038145255A) MK4 1.8T/2.0 power steering pulley
    022-903-119 (022903119) MK4 1.8T/2.0 alternator pulley
    06A-903-315E (06A903315E) MK4 1.8T/2.0 tensioner pulley
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-13-2012 09:09 AM #72
    TT/R32 Rear Adjustable Control Arms
    Click on the picture to visit our product page for up to date pricing info.
    NOW CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
    Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered.
    The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
    Choose from a zero deflection high radial load PTFE lined heim joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the heim and bushings is nearly water tight!
    OR
    A poly bushing end with a heat treated 4340 forged chromoly housing, grease fitting, zinc plated steel sleeves, and race grade greaseable black polyurethane bushings
    You decide which set up you want ! The zero deflection spherical heims are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
    All control arms feature the following :
    Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
    Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
    Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue. Please don’t adjust these with weight on the rear axle, and don’t use channel locks that could mar even a hard coat chrome plate.
    Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
    We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
    Want further discounts and more great products from GruvenParts.com? Read on!
    TT/R32 Rear Adjustable Sway Bar End Linkages
    Got a lowered TT, R32, or A3 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue or gloss black to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
    Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt
    TT/R32 OEM Headlight Leveling Adapter Bracket
    TT / R32 Headlight Leveling Adapter Bracket
    Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
  3. Member cool white98's Avatar
    Apr 23rd, 2005
    baltimore
    98 jetta aba-t/89 gti/92 yota pickup
    01-22-2012 09:36 AM #73
    i know there has been talk of the aba water outlet(crap plastic sensor flange on the side of the head) being produced. any info for us manual trans aba users? i would love to have any/all of the plastic coolant parts produced in billet!!!
    BeMoreEuro - Northeast Baltimore European Car Enthusiasts
    GTG's every first and third Tuesday in Parkville at Racers Cafe
    ---------http://autos.groups.yahoo.com/group/BeMoreEuro/---------
    ****http://forums.vwvortex.com/showthrea...e-Tuesday-GTG!****
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-25-2012 04:30 PM #74
    Could you let us know what your price point would be for an aluminum version of that?
    The main issue is the aftermarket is flooded with $9 plastic versions from China, its tough to sell a $150 version even if it is metal.
  5. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    Eight valve like WHOA.
    01-25-2012 11:18 PM #75
    Get a prototype into production and release it to the mk3 forum, I for one would be interested in buying.
    It's Timmy with mmmmMojo, i have returned
    8VALVETURBO - Sorting the kinks out.
  6. Member cool white98's Avatar
    Apr 23rd, 2005
    baltimore
    01-26-2012 06:52 AM #76
    somewhere around 100? i really have no idea what it would cost to make it. if you could still make money i bet there would be poeple willing to pay to not have to deal with that damn thing ever again!
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-30-2012 12:29 PM #77
    I dont know if a $100 metal version could happen, I think it will cost more to even make it. How many would be in at $150? Post here or email me so we can get the list started. If there is enough interest in the ABA flange, we will do it.
  8. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    01-30-2012 05:36 PM #78
    Show us what one would look like first.
  9. Member cool white98's Avatar
    Apr 23rd, 2005
    baltimore
    01-30-2012 06:32 PM #79
    better yet ,make me one ill be the guiney pig and show it off for you.
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-13-2012 02:48 PM #80
    Quote Originally Posted by AJmustDIE View Post
    It is going to look similar to ABA plastic but we'll TIG weld all the appropriate flanges in place. This part has already been scanned on the CMM and we've got the CAD model and engineering dwg made. For me to go much further, we need to make sure people want to pay $150 when $9 chineese plastic versions are out there. Believe me, I want to make the whole car from machined metal but I realize not everyone is willing to spend the extra dough.
  11. Member cool white98's Avatar
    Apr 23rd, 2005
    baltimore
    02-16-2012 06:59 AM #81
    how many would you need to sell to do a small run of theese?
  12. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-07-2012 12:11 PM #82
    10.
    Please email me if interested.
  13. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    03-10-2012 10:14 PM #83
    What about a billet coolent reserve for the 1.8t
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-19-2012 09:52 AM #84
    We can do those if enough interest and if something universal isnt already available that could work. Send me an email and if you can, send pictures in it. We will look it over.
    Thanks
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-20-2012 11:21 AM #85
    MKIV VR6 Billet Dipsticks
    GruvenParts.com has released these new Billet Dipsticks for all MKIV VR6 motors including both the 12 valve and 24 valve engines in 2.8L and 3.2L variety.
    These billet dipsticks have a CNC’d handle made from aerospace grade 6061-T651 aluminum specially machined with a chemically resistant O-ring for a perfect seal. The wire is bundled stainless permanently attached to the CNC’d handle, and also with a specially machined oil level indicator tab at the wire base.
    Now is the time to get rid of that f-ugly plastic orange OEM dipstick which is prone to breaking and causing embarrassment in your otherwise gorgeous engine bay!
    This part replaces the OEM dipstick on the following vehicles :
    Volkswagen MKIV Golf, Jetta, Touareg, and R32 with the VR6 engine codes AFP, BDF, BJS, BAA, and BMX
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-26-2012 11:32 AM #86
    Special Service Announcement from www.GruvenParts.com : DONT GO TO YOUR AUDI OR VW DEALER FOR THESE PLASTIC DRIVE LINKAGES FOR YOUR VARIABLE INTAKE MANIFOLD!
    www.GruvenParts.com is now producing new metal versions of both the Audi A4 3.0L V6 and the VW VR6 intake manifold linkage arms, similar to the ones we currently build for Audi/VW 4.2 V8.
    Audi/VW 4.2V8 Intake Linkage Arms !
    The Audi 3.0L V6 arms will replace the plastic ones on the 2002-2006 A4/S4/A4 Quattro and 2002-2004 A6/A6 quattro with the 3.0L V6 engine (code AVK) Audi part number 06C-133-611 (06C133611) drive unit w/rotary valve which is installed onto 06C-133-201J (06C133201J) intake manifold.
    See pictures below for the Audi drive unit – broken plastic OEM arms are circled in RED.
    The VW VR6 drive unit arms will replace the plastic ones on the following vehicles (yellow arrow in the picture below) :
    2.8L 12 V VR6 ENGINE - with AFP Engine Code (99-02 Golf/Jetta VR6) to replace the drive unit linkage p/n 071-133-759D (071133759D) on OEM VW rod p/n 021-133-653 (021133653)
    2.8L 24 V VR6 ENGINE - BDF Engine Code (02 - present Golf/Jetta VR6) to replace the drive unit linkage p/n 022-133-759 (022133759) on OEM VW rod p/n 022-133-653 (022133653)
    3.2L 24V VR6 Engines - 04 R32, 3.2 Touareg, 3.2 Eos, 3.2 A3, 3.2 TT to replace the drive unit linkage p/n 022-133-759A (022133759A) on rod p/n 022-133-653B (022133653B)
    We expect to have both versions available for these cars during the month of April 2012.
    ** This has been a special service announcement from www.GruvenParts.com **
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-23-2012 02:29 PM #87
    Bump for some of the best control arms in the business. Thanks for all the orders on these guys, please keep em coming!
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-16-2012 09:47 AM #88
    GruvenParts.com
  19. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-29-2012 09:32 AM #89
    Bump the best control arms in the business.
  20. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-16-2012 08:44 AM #90
    Please make sure to like us out on Facebook
    http://www.facebook.com/GruvenParts
    Its a great way to keep up with all that we are developing, and request more items to be developed
    www.GruvenParts.com
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-20-2012 08:11 AM #91
    These are in stock, ready to ship asap!
    Please click on the picture to order.
    OR
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-10-2012 09:43 AM #92
    A4, A6, Passat Stainless Slave Cylinder Bleeder Screws
    GruvenParts.com Introduces Stainless Bleeder Screws for Audi A4, A6, and VW Passat!
    Our 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw which Audi and VW provide on their clutch slave cylinder P/N 8E0-721-257F (8E0721257F) and P/N 8E0-721-257M (8E0721257M).
    How many times have you gone to bleed the brakes on your Audi A4, A6, or VW Passat only to round off the hex on the cheap plastic bleeder screw on your clutch slave cylinder? The problem is corrosive brake fluid actually melts the plastic bleeder screw and bonds it into the slave cylinder housing making it impossible to open. This problem makes it impossible to bleed your brakes properly and causes soft brake and clutch pedals. The only remedy until now has been to replace the entire slave cylinder unit, which is expensive, time consuming, and NOT FUN (to say the least!).
    GruvenParts.com has addressed this problem with our new 303 Aircraft Grade Stainless Steel Bleeder Screws. We machine these in house on state of the art HAAS CNC lathes and mills with custom screw machining capability to exactly match the OEM threads for a perfect fit. These come complete with preinstalled Viton O-rings for maximum life. The hex will never round off or become stuck in the slave cylinder body and you likely will never need to replace a slave cylinder again.
    This 303 Aircraft Grade Stainless Steel Bleeder Screw replaces the plastic bleeder screw found in clutch slave cylinders P/N 8E0-721-257F (8E0721257F) and P/N 8E0-721-257M (8E0721257M).
    This product fits the following vehicles :
    Audi A4 1996 thru 2005 1.8, 1.8T, 2.8L including Quattro
    Audi A6 1995 thru 2005 2.7L, 2.7T, 2.8L, including Quattro and Allroad
    Volkswagen Passat 2000 thru 2005 1.8T, 2.8L including 4 Motion
  23. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-20-2012 08:22 AM #93
    In stock, ready to ship !
    Quote Originally Posted by GruvenParts.com View Post
    OR
  24. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-09-2012 09:03 AM #95
    Billet / Carbon Fiber / "VeeChain"
    Pay homage to the unique VR6 engine design with this accurate CNC keychain minature. Measuring about 2 inches in length by 1 inch width, its an instant conversation starter with the girls at the parties who are constantly wondering about your 15 degree cylinder offset. This is an Oichan original design (http://www.oichan.org) sold under his permission. Beware of the rip off versions out there which are made using water jet process and have ragged edges and poor quality. Ours are made on a 3 axis CNC 1 at a time and are literally perfect replications of the unique VR6 engine.
    Available in machine polished billet aluminum or genuine 3K weave carbon fiber plate.
  25. Member AJmustDIE's Avatar
    Dec 22nd, 2010
    Ocala, Florida
    10-15-2012 06:51 PM #97
    I always check this thread for something cool & new for the crossflow engines, alas. Nothing ever..
  26. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-03-2012 11:20 AM #98
    These arent new but they are pretty damn cool !
    MKIII 2.0 ABA Billet Lightweight Crank, Tensioner, and Alternator Pulleys – NON-UNDERDRIVE!
    www.GruvenParts.com offers precision CNC billet lightweight (and Non-Under-driven) crank, tensioner, and alternator pulleys for the ABA 2.0 engines. The pulley set reduces engine rotating mass by over 4 lbs to help you squeeze out every last bit of power, without the problems associated with under-driving components. Our billet tensioner comes ready to install with a 20K rpm bearing to replace the cheap OEM plastic pulley. The crank pulley is a slick dual design which incorporates the power steering v-belt pulley with a light mounting flange (new shorter grade 12.9 attach bolts included). Finally, the alternator pulley is a paper light version of the OEM steel pulley to minimize parasitic losses.
    Check out www.GruvenParts.com for all the billet goodies!
    These parts replace the following OEM part numbers :
    037-105-243A (037105243A) ABA crank pulley
    037-105-253 (037105253) ABA power steering pulley
    028-145-278E (028145278E) ABA serpentine tensioner pulley (also fits MK3 TDI)
    028-903-119F (028903119F) and 028-903-119AA (028903119AA)ABA alternator pulley
  27. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-10-2013 10:14 AM #100
    GruvenParts.com Billet MKIV Upper Radiator Hose 4Y!
    GruvenParts.com is about to release our BILLET MKIV VR6 12V Upper Radiator Hose 4Y to replace the junk plastic 4Y in OEM hose P/N 1J0-122-101AP (1J0122101AP) and 1J0-121-087J (1J0121087J)
    The flimsy plastic 4y section of this molded hose assembly quickly dries out and becomes super brittle. If you look at it wrong, it will snap and leave you stranded. Or worse, turn your high dollar VR6 motor into an overheated paperweight.
    Our BILLET ALUMINUM version is made from CNC'd 6061-T651 block and professionally TIG welded and leak tested. You could drive your car over this one, but we'd recommend doing that to the OEM plastic version and installing ours instead
    Ours uses an NPT fitting for the radiator reservoir return line, so if you ever wanted to delete your main coolant reservoir, you could simply install a threaded NPT plug. You could also install a coolant temp sender for those stand alone ignition installations.
    This 1 should be ready soon, please email if you would like to pre-order – Paul@GruvenParts.com
    Fits :
    All MKIV Golf/Jetta VR6 12V engines (upper radiator hose P/N 1J0-122-101AP (1J0122101AP) and 1J0-121-087J (1J0121087J)
    www.GruvenParts.com
  28. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-14-2013 01:56 PM #101
    bump for the best products for your ride
    www.GruvenParts.com
  29. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2013 09:43 AM #102
    Billet 2.4” Vortech Supercharger Pulleys !
    GruvenParts.com Billet 2.4” Supercharger Pulleys for Vortech Chargers !
    Got a boost addiction? Check out these 2.4” diameter supercharger pulleys for V Series Vortech superchargers. This pulley will allow your charger to spin faster, creating more boost and more power.
    These pulleys are precision CNC’d from 6061-T6511 aluminum and are sized to precisely match the shaft output on Vortech chargers. These pulleys are 7 rib, but can be used in 6 rib applications that provide enough clearance for a 7 rib pulley (you would just have 1 empty rib). Please note the offset distance (from charger side of pulley to the centerline of the 1st rib = 0.650”). Rib spacing is 0.140” center to center (for K style serpentine belts). The overall width from end to end = 1.640”.
    These pulleys come machined to accept the standard woodruff key found on the Vortech V Series supercharger output shafts (key and bolt not included). Please calculate your maximum impeller RPM to ensure you do not overdrive the supercharger at high RPMs. This product may void any Vortech factory warranties.
  30. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2013 09:48 AM #103
    Billet VW/Audi VR6/V6/V8 Oil Filter Housings !
    Precision Machined Aluminum Oil Filter Housings For VW And Audi VR6/V6/V8 Engines !
    This one was worth the wait, folks! Never, but NEVER break a flimsy plastic oil filter housing again. Or deal with the unsightly leaks created by the cheaply made (yet expensive) plastic OEM housing cracking and deflecting. We made this one the way VW and Audi should have – from A SOLID BLOCK OF ALUMINUM, by God!
    First, we start with a massive chunk of Aircraft Grade 6061-T6511 Aluminum. The section is delicately placed on one of our special CNC machining centers and precision cut to EXACTLY match the OEM plastic housing. The metal gods (well, in this case, one of our highly talented CNC programmers) has programmed elaborate steps for the very time consuming and expensive operation of profiling the special buttress threads into the housing using the exact DIN spec thread cutting tool required for a perfect seal. It simply doesn’t get better than this!
    We also provide a proper threaded drain plug of the same size as your oil pan plug (use just 1 19mm socket for both!). Rather than some useless internal soft hex plug which easily strips, ours is a genuine Audi plug made from steel with an honest 19mm external hex. The plug comes with a contained sealing washer as well. And yes, we also provide USEABLE 36mm hex flats so you can easily remove the housing with a standard 36mm socket. Imagine that : You can simply drain the housing using its proper drain plug bolt that wont round off, and remove the housing using a proper 36mm socket that also wont round off. This could possibly make changing your oil fun again!
    This product is intended to replace VW/Audi Part Numbers 021-115-433A (021115433A) and 021-115-433B (021115433B) housings. Please check the OEM part number of your oil filter housing before ordering. You can do this easily by calling your dealer and giving them your VIN #. It will fit the following vehicles :
    VW Corrado (1992-1995 w/AAA VR6 engine)
    VW Golf and Jetta/Wagon (1993-2006 w/AAA and AFP VR6 engines)
    VW Passat (1992-1997 w/AAA VR6 engine)
    VW Touareg (2003-2007 w/3.2 and 3.6 V6 engines)
    VW Eurovan (1996-2004 w/AES V6 engine)
    Audi A8/S8 (2000-2003 w/4.2L AUX V8 engine)
    Audi Q7 (2007-2009 w/3.6L BHK V6 engine)
    Special Note At The End :
    Use oil filter part number 021-115-562 (021115562) or equivalent with our metal housing. If your parts department requires a vehicle type, tell them “1995 VW Golf GTI VR6”. This is the older, vastly superior cartridge filter with the metal end caps. VW, in their infinite cost savings wisdom, superseded it with a cheaper, cardboard end filter (021-115-562A). Please make sure to order filter 021-115-562 oil filter (or equivalent) as it is the superior filter for these engines, and will fit correctly with this housing. You can buy it from us using the drop down menu on the product page, or at any dealer or trusted auto parts store.
  31. Senior Member Capt.Dreadz's Avatar
    Jun 3rd, 2003
    Long Island, NY
    VRT's & 2.7T's
    02-03-2013 10:17 PM #104
    I'm ordering one tomorrow...
    Chosen Life Clothing. Streetwear for the car culture. Launch Party coming very soon!!
    Meet Long Island The place if you're looking for a euro GTG in the Long Isl./New York City area.
    FaceBook: Carlitus Christensen Sr. - Instagram: @ThatDreadLife - Twitter: @ThatDreadLife
    Kicks...Clothes...Cars...Ho's...THINGS I DO BEST!
  32. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-04-2013 12:34 PM #105
    Quote Originally Posted by Capt.Dreadz View Post
    Thanks, please help spread the word.
    Install pics - too
    Billet VW/Audi VR6/V6/V8 Oil Filter Housings - Installed !
