Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 36 to 70 of 204
Thread: My Generic Build Thread
  1. Member Mosbius Designs's Avatar
    Dec 2nd, 2006
    2012 Honda HRX217, 2 Golfs, and a 944.
    12-02-2010 05:20 PM #36
    You may call this generic, but you have saved a Corrado from someone who obviously was on crack. You get a
    I love all cars, I just happen to own a few pieces of german crap at the moment.
  2. Member Toffeerado's Avatar
    Aug 3rd, 2003
    Vancouver, Canada
    12-03-2010 09:41 AM #37
    Yesssssss, this a great build thread
  3. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    12-05-2010 04:48 PM #38
    Update time!
    I've been busy since I got the parts back form the blaster. Well, busy for me...
    All my suspension parts have been prepped, coated with one coat of por15, and one coat of por15 chassis black. I trimmed a set of R32 rear bushings, and pressed them into the control arms, along with an OEM set of front bushings. Then I pressed new front wheel bearings, and new hubs into my front bearing housings.
    I also spent a lot of time cleaning, Prepping, and repairing rust on my front wheel wells. I finished them off with one coat of paintable rubberized undercoating, and two coats of Krylon Fusion Satin Black. I chose the fusion because it's specifically made to stick to slick flexible plastic, so I figured it would work well over the undercoating, plus I already had it laying around.
    Seriously the pic doesn't even come close to doing it justice...
    So now I need to press the bushings into my rear beam, Prep, and coat my rear wheel wells, and install the suspension.
    After that, I have to get the rest of the glass removed. (I tried the right rear quarter window myself with the help of a friend, and it ended up exploding all over us. )
    then she's ready to head off to paint!
    My Build Thread http://forums.vwvortex.com/showthrea...c-Build-Thread
    Want a shiny new SLC Badge? PM me.
  4. Member itsski454's Avatar
    Sep 12th, 2009
    Winston-Salem, NC
    97 F150, 01 jetta glx, 94 corrado
    12-05-2010 06:38 PM #39
    looks good i still need get the bolt i snapped out
    VRSociety #44, Riches to Rags
    Some of the BEST OEM+ corrado parts out there SpoonFed Tuning
  5. Member mellbergVWfan's Avatar
    Jan 31st, 2008
    Los Angeles, CA
    81 Scirocco S
    12-27-2010 09:08 AM #40
    Stumbled here from your sig. Good to see a beat up Corrado being saved.
    Are those BBS wheels? I've never seen that style before.
  6. Member DeckManDubs's Avatar
    Sep 26th, 2004
    Mass
    Corrado SLC , TT 225QC
    02-26-2011 11:23 AM #41
    Looking good
    I'm not endorsing the purchase of a Saab, cause I'd rather gargle battery acid. It was merely the best example I could think of.
  7. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    02-26-2011 12:21 PM #42
    Quote Originally Posted by mellbergVWfan View Post
    17" BBS RX. I'm going to get them refinished, then probably sell them. I'm going to run 16's
    Might as well update while I'm here I guess. I lost a lot of momentum with the cold weather, endless snow, and the rust hole I found behind the fuel door. Body work isn't my strong suit. I hate it actually, so I'm still trying to figure out how to deal with it.
    More accurately I've been avoiding it.
    I have gotten some work done though.
    I tore down, cleaned, and completely refoamed my HVAC box. I also replaced the heater core, and blower resistor while I was in there.
    I rebuilt my shifter box with all new bushings.
    I cleaned, and rebuilt my steering rack. It wasn't leaking, but the PS pump was going out, the fluid I drained out looked like hell, and there was metal in it, so I figured it was only a matter of time for the rack. It's remounted on the K frame, and ready to go back in.
    I also made a custom set of back lit gauges. I wanted something more OEM looking than what is currently available. I scanned my stock gauges, then cleaned up, and Made some changes in photoshop. I printed them on a plastic film designed for back lit displays, then clearcoated them in a matte finish to prevent glare. Unfortunately they aren't bright enough, the light doesn't make it to the needles very well. So I'm looking for a brighter EL film to use.
    I hope to be able to post some real progress soon, things are finally starting to come together.
  8. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-13-2011 06:27 PM #43
    I got some stuff done this weekend.
    I prepped, and por15'd my swaybar, and some other miscilanious bits, which were the last things I needed to do before putting the front suspension back together.
    Lower part of bay is now undercoated, K-frame, and control arms installed with all new bushings (R32)+ hardware.
    Koni coils are on in the front with new hubs, bearings, ball joints, sway bar links, new front calipers, and autotech rotors with Mintex pads.
    A Better angle.
    I'm pushing hard to get the car ready to go into paint in the next few weeks.
  9. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    92 Corrado 07 Mercedes e350 04 Touareg
    03-13-2011 06:58 PM #44
    This is how you rebuild a car right here. This is comin along quite nicely. The calipers look awesome, I love that color. You should spray the whole car that color. Nice work my man
  10. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-13-2011 07:31 PM #45
    Thanks! It's definitely not just a random color. That is the color the car is going to be, LE3P.
  11. Member Scotmbb107's Avatar
    Sep 5th, 2007
    CT
    2008 VW GLI TSI, 2003 Audi allroad 2.7T, 2007 Saturn Outlook
    03-13-2011 07:55 PM #46
    Unbelievable job! I agree with Cstanley19 about how a build should be done. I wish I could take the time to make everything perfect like your build. This car is going to look better than new when your done. Keep up the great work! I will be watching the build.
    2008 VW GLI 2.0 TSI ( Revo Stage 2)
    2003 Audi allroad 2.7T (Money Pit Green Unitronic Stage 2)
    2007 Saturn Outlook( 8 Passenger Family Hauler)
    (Too many past Audi's and VW's )
  12. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    03-13-2011 08:02 PM #47
    Red Mica Pearl.. very classy. I dig it. You stayin with black leather?
  13. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-13-2011 08:28 PM #48
    Quote Originally Posted by cstanley19 View Post
    Sort of...
  14. 03-13-2011 08:48 PM #49
    Awesome job man Car has come along way since I last saw it
    If you need a hand with the motor or have any questions please feel free to contact me. Anything I can do to repay you for your help
  15. 03-13-2011 08:49 PM #50
    really really digging the build man! pretty much EXACTLY what im doing to mine right now except instead of POR im powder coating all my stuff cuz its free!!
  16. Member 302W's Avatar
    Jul 24th, 2004
    NoVA
    03-13-2011 10:32 PM #51
    Top notch, anything but generic
  17. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-14-2011 08:06 AM #52
    Quote Originally Posted by blackblaze427 View Post
    Hard to argue with free powder coating! Doing the POR right is a real Pain anyway.
    Quote Originally Posted by 302W
    Maybe, but if I called it the "Super awesome build thread" people would have expected results!
  18. 03-14-2011 08:32 AM #53
    Dam doing it right
  19. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    Limassol, CYPRUS (That's in Europe,lol)
    '90 Corrado 1.8 8V G60 (previously was 1.8 16V KR), '80 MK1 Golf GTI 1.6 8V EG aka "Heron"
    03-14-2011 08:58 AM #54
    Once again, awesome work man
    What did you go with for the rear axle bushings? Poly or oem?
    Quote Originally Posted by dogger View Post
    ... (Corrado) might be the greatest collection of bad VW ideas ever put into one car.
    My Corrado (sort of) build thread / On Database
    My MK1 build thread
    SpoonFedTuning
  20. Member Toffeerado's Avatar
    Aug 3rd, 2003
    Vancouver, Canada
    03-14-2011 10:04 AM #55
    Once again, Great work!
    Quote Originally Posted by Radvr6T View Post
    A true built car is one in which the owner alone has done its work intirely!
    Not had a shop build the motor,Not had a shop paint it ,Not had a upolster do the interior,Not just supplied money for work of any kind for the vehicle!
    According to this guy no one builds cars.
  21. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    03-14-2011 11:16 AM #56
    Quote Originally Posted by RedYellowWhite View Post
    OEM. one less thing to worry about. I don't quite trust poly bushings to flex properly, and not cause problems.
  22. Member ThaCorradoKid's Avatar
    May 26th, 2004
    914-NY
    03-15-2011 03:42 PM #57
    Quote Originally Posted by NoCYet View Post
    i'm not a fan either, and they are in my car. great job on the build. nothing generic about proper.
  23. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    04-17-2011 02:37 PM #58
    Any progress? I am dying to see this thing done. I know you are metiuclous about your stuff so I know the build isn't an over nighter but you really made it tempting with the calipers...
  24. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    04-17-2011 05:37 PM #59
    I'm making good progress. Update is coming shortly as soon as I get the rear suspension in.
  25. Member cstanley19's Avatar
    Sep 23rd, 2006
    Las Vegas, NV
    04-17-2011 07:47 PM #60
    Nice, can't wait to see the update. I think this is going to be one of the best Corrado builds on here.
  26. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    04-18-2011 01:12 PM #61
    Thanks!
  27. Junior Member cmarkley06's Avatar
    Apr 26th, 2011
    pittsburgh, PA
    1990 VW Corrado G60
    04-28-2011 01:25 AM #62
    now this is how you rebuild a car! from the group up!
  28. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    05-08-2011 09:20 PM #63
    Update time!
    It's been a while, but I've been making steady progress.
    I spent a lot of time underneath the car, and found a crapload of hidden rust. I would see a small nick in the undercoating with a little rust colored stain around it. After removing some of the undercoating I would find a rust spot about the size of a quarter. I fixed about a dozen of these. I ground them down to bare metal, acid treated them, then applied 2 coats of POR15, and a layer of spray on undercoating.
    It's not terribly pretty, but the rust is gone, and it's the underside of the car so I can live with it.
    Next it was time to deal with this...
    Once again, bare metal, acid treatment, POR15.
    While the POR15 was out i finished the last of the parts I had blasted. Both bumper rebars, the front cross member, and the fan shroud.
    Just like everything else under the car. I noticed the metal parts of the fuel supply line were almost completely corroded away, so I picked up and installed all new lines, and a new filter.
    Then it was time to do something about the rear brake hard lines, which were as corroded as everything else on this heap. For a change my local auto parts store had everything I needed. Copper nickel line, and even the right size metric flare nuts. I picked up a cheap bubble flare kit online, and made some new brake lines that won't rust this time.
    After all that it was time to reinstall the rear beam. I pressed in the new bushings, and bolted it up with all new hardware. I ran into some trouble installing my Konis in the rear. The hardware I had was stock 10mm, and the Konis use 12mm, so I called Koni, and ordered the stuff I needed. I'm still waiting on that stuff to show up.
    I pressed the races into my new hubs, hand packed the bearings, and installed them onto new stub axles. Once again I used all new hardware. I also installed new braided stainless brake lines, new rear ABS sensors, and MKIV rear calipers.
    While I was at it, I installed an Autotech rear sway bar.
    I'm still waiting on various brackets, and clips to secure the lines, and parking brake cables to the rear beam.
    As soon as the Koni parts show up, I can get the car back down on the ground, and it's off to the body shop!
    Here are a few Before, and after pics of the rear end.
    That's it for now. Probably the last until it gets back from paint. Time for a
  29. 05-08-2011 11:37 PM #64
    Looks great!
  30. Member bpodlesnik's Avatar
    Mar 28th, 2010
    PA
    2007 TW Fit Sport
    05-09-2011 07:54 AM #65
    I love this build. Can't wait to see it back from paint. Great work dude
  31. Member RedYellowWhite's Avatar
    Apr 21st, 2008
    05-09-2011 08:36 AM #66
    Man, this build is awesome Great work. Love the attention to detail
    My MK1 build thread
    SpoonFedTuning
  32. Member NoCYet's Avatar
    Feb 10th, 2001
    Alameda, CA
    1994 Corrado
    05-09-2011 10:51 AM #67
    Thanks everyone!
    looking at the pics myself, it's actually bothering me that I didn't do the entire underside, but it's SO much work for very little payoff. The wheel wells alone took me hours apeice to clean, and prep.
  33. Member dri0514's Avatar
    Aug 21st, 2005
    Point Mugu
    1992 Corrado ATC 20V 1.8T, 2012 Durango R/T
    05-10-2011 07:14 PM #68
    All i can say wow!!!!!
  34. 06-04-2011 11:50 PM #69
    amazing. i wanna see more of your cluster mod. i aspire to build my 89 gti the way youre building your corrado.
  35. Member
    Dec 8th, 2010
    Boston/watertown ma
    89 944 turbo 93 slc corrado 09 gti and soon to be golf R
    06-08-2011 08:21 AM #70
    Any luck cleanng the block? Love to knw if those products worked fr you?
