Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 36 to 70 of 109
Thread: ** GruvenParts.com Has Plenty of Suspension Goodies !!
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-03-2011 11:44 AM #36
    Got an 02A Trans ?? Then you better have a look at these upgraded billet shift linkage parts !
    02A Billet Stainless Steel Short Shifter Bracket
    Replace the weak plastic link in your cable shift mechanism with this one made from Aerospace grade, hardened stainless steel. Reduces side/side shift throw by 35%! This part replaces OEM P/N 1J0-711-256 (1J0711256) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
    Replaces OEM P/N 1J0-711-256 (1J0711256)
    Stainless FWD/AFT Steel Shift Cable Repair Block
    GruvenParts.com is proud to release this solid stainless fwd/aft cable shift repair block for cable shift VW vehicles. This part will quickly replace the weak forward end of the factory fwd/aft shift cable P/N 1H0711265 (1HO-711-265) where it connects to the transmission linkage. There is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken fwd/aft shift cable. And if your cable is not yet broken, throw 1 of these in the glove box and be prepared for the inevitable!
    This repair block repairs the FWD/AFT cable P/N 1H0711265 (1HO-711-265) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
    Stainless SIDE/SIDE Steel Shift Cable Repair Block
    GruvenParts.com now also has solid stainless side/side cable shift repair blocks for cable shift VW vehicles. Once again, there is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken shift cable. And if your cable is not yet broken, throw 1 of these in the glove box and be prepared for the inevitable!
    Add some indestructible hardware to the factory cable shift mechanism where it needs it most! Buy these parts together and save!!
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-10-2011 09:19 AM #37
    Now You Can Choose from Jazz Blue or High Gloss Black Powdercoat Finish !!
    TT/R32 Rear Adjustable Control Arms
    Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
    We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include greaseable heim joints and bulletproof welds. Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
    We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
    Want further discounts and more great products from GruvenParts.com? Read on!
    TT/R32 Rear Adjustable Sway Bar End Linkages
    Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
    Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
  3. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-18-2011 02:48 PM #38
    Billet Dipstick Funnel
    A Billet Replacement for the Dreaded 1.8T Dipstick Funnel Has Arrived !!
    This one is made from 6061-T6 billet aluminum and neatly replaces the cheap brittle orange dipstick funnel we have all come to hate.
    This part replaces OEM P/N 06A-103-663B (06A103663B) on the following vehicles :
    MK1 Audi TT 1.8T, MKIV Golf 1.8T, MKIV Jetta 1.8T, and New Beetle 1.8T
    Be sure to check your OEM part number to verify it is 06A-103-663B as VW and Audi have made several variations of the worthless orange dipstick tube.
    Forget about ever breaking your 1.8T dipstick tube again !!
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2011 12:00 PM #39
    A4/B5 Front Adjustable Control Arms
    Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms
    BY FAR – THE BEST VALUE IN ADJUSTABLE CONTROL ARMS ON THE MARKET !
    You asked GruvenParts.com for affordable, bulletproof, and fully rebuildable Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms and we have delivered!
    Just like the GruvenParts.com popular TT/R32 rear adjustable control arms, we designed these based on years of fabricating rock crawler suspension systems for racers and weekend warriors alike. They are made from a special aircraft grade of 4130 chrominum-molybdenum alloy and then powder coated in high gloss black for maximum durability. The AMERICAN MADE racing heim joints are CAD plated, PTFE lined, and can be ordered with dust boots all around for those planning to re-enact a Grouppe B Ralley race. Finally, all parts are fully rebuildable.
    Don’t waste your hard earned money with the over-priced competitor versions. The quality and performance of the GruvenParts.com adjustable upper control arms are second to none!
    These come as a set of 4 and fit the following models :
    Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
    Audi A6/RS6 (incl. AllRoad) - 1998-2004
    VW Passat - 1998-2005
    This product replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-10-2011 08:54 AM #40
    Finally, a replacement for the orange plastic dipstick funnel !
    Our funnel is made from 6061-T6 billet aluminum and neatly replaces the cheap brittle orange dipstick funnel we have all come to hate. Choose from as machined finish or highly polished finish.
    This part replaces OEM part number 053-103-663 (053103663) on the following vehicles:
    Audi - 80, B5 A4 1.8T – all 4 cylinder
    VW – MK2 Golf, Jetta, Scirocco, Corrado G60 (NOT VR6), MK3 ABA’s, Eurovan T4, B3, B4, B5 Passat 1.8T and 2.0
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-21-2011 11:29 AM #42
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-07-2011 04:54 PM #43
    What other parts do you guys want ? Email, PM, or post please
    www.GruvenParts.com
  8. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-21-2011 03:27 PM #44
    Just to make all the MK4 VR6 owners aware …
    www.GruvenParts.com will soon be releasing a billet aluminum version of the white plastic part which connects the intake manifold change over rod to the drive unit actuator shown in this pic (red arrow) :
    And detailed in this DIY Article section on www.GruvenParts.com
    On 12V VR6 engines (99-06 Golf, Jetta VR6), the white part is sold as part of the Drive Unit p/n 071-133-759C (071133759C) or 071-133-759D (071133759D) and on the 24V engines (R32, 02-08 Golf, Jetta, Eos, Touareg) it is sold as part of Drive Unit p/n 022-133-759 (022133759) or 022-133-759A (022133759A).
    This white plastic part continually breaks and is not readily available from VW without buying the whole plastic Drive Unit at a cost of $130-$160.
    Needless to say, we’ll put an end to that foolishness in typical GruvenParts.com fashion by milling this part from a solid chunk of 6061-T651.
    You can follow the development thread here (and feel free to chime in, too!) –
    http://forums.vwvortex.com/showthrea...-a-replacement
    Just another example of how www.GruvenParts.com is listening to your suggestions. Let us know what other parts need to be redesigned!
  9. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-22-2011 10:18 AM #45
    ABA / Corrado G60 / MK2 Billet Dipstick
    www.GruvenParts.com is proud to release these gorgeous Billet Dipsticks to replace both OEM part number 027-115-611C (027115611C) and 051-115-611B (051115611B). Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a flitting with hash marks to signify oil level min and max.
    As an added bonus, this part is made to perfectly fit our Billet Dipstick Funnels and can be ordered as a set to save! If you are ordering the billet funnel with the billet dipstick, please ensure your car uses dipstick funnel OEM P/N 053-103-663 (053103663).
    This billet dipstick replaces both OEM part number 027-115-611C (027115611C) and 051-115-611B (051115611B) and fits the following vehicles :
    1993-1999 Jetta/Golf/Passat/Cabrio w.2.0 ABA engine
    1990-1992 Corrado G60 1.8L
    1985-1992 Jetta/Golf/Passat w/1.6L and 1.8L engines
    Don’t see your car listed here? Don’t worry! We have many more of these billet dipsticks coming for nearly all makes / models. Visit www.GruvenParts.com for the latest.
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-28-2011 01:44 PM #46
    Bump for billet goodness and lots more is on the way !
    www.GruvenParts.com
    Our TT/R32 + A4/Passat Adjustable control arms are now available fully booted for extreme environments.
  11. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-05-2011 02:11 PM #47
    bump for billet goodness !!
  12. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-12-2011 02:53 PM #49
    GruvenParts//Yarrowsport MKIV Golf/Jetta Rear Stress Bar
    We are helping Yarrowsport sell their popular MKIV rear stress bar for Golf and Jetta platforms.
    Stiffen up the flexible MKIV chassis with this proven rear stress bar from Yarrowsport and sold exclusively by GruvenParts.com! This bar is machined to the factory correct dimensions and installs easily with all hardware and instructions provided.
    Fits all MK4 Golf and Jetta, R32 !
  13. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-16-2011 01:37 PM #50
    These are back in stock (in black) and ready to go !!
    www.GruvenParts.com
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-23-2011 08:56 AM #51
    GruvenParts.com has released this billet intake drive unit arm for ALL VW/Audi VR6 engines with variable intake manifolds!
    Billet Intake Manifold Drive Unit Linkage!
    This part replaces the white plastic part that attaches to the actuator arm. The OEM part is made from injection molded nylon and becomes very brittle in the engine heat. Of course VW/Audi will not sell you *JUST* this part, you would have to buy a whole new drive unit for big bucks and get a bunch of stuff you don’t need.
    GruvenParts.com builds these the way VW should have: from a solid chunk of 6061-T651 aircraft grade aluminum on a 4 axis HAAS mill-lathe. Utilizing some tricks within the SolidWorks/MasterCam CNC software, we have tweaked the process to allow the billet part to be machined specially to accept the locking feature on the end of the intake rod. Just push fit this part onto the end of the intake rod similar to OEM plastic part fitment. There are no set screws to come loose and the fit is perfect.
    This part makes a great upgrade when installing our upgraded MKIV VR6 Intake Manifold Bushings
    Our part will also cost you about 1/3 what VW/Audi charge for their plastic drive unit (and the OEM plastic part is NOT part of their repair kit). This one is a no brainer!
    You guys asked us for it and we listened. Another great billet replacement part to rid your VW/Audi of the weak plastic parts!
    Don’t forget to check out the DIY listed on our website.
    Applications:
    2.8L 12 V VR6 ENGINE - with AFP Engine Code (99-02 Golf/Jetta VR6) to replace the drive unit linkage p/n 071-133-759D (071133759D) on OEM VW rod p/n 021-133-653 (021133653)
    2.8L 24 V VR6 ENGINE - BDF Engine Code (02 - present Golf/Jetta VR6) to replace the drive unit linkage p/n 022-133-759 (022133759) on OEM VW rod p/n 022-133-653 (022133653)
    3.2L 24V VR6 Engines - 04 R32, 3.2 Touareg, 3.2 Eos, 3.2 A3, 3.2 TT to replace the drive unit linkage p/n 022-133-759A (022133759A) on rod p/n 022-133-653B (022133653B)
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-10-2011 11:40 AM #53
    These are BACK IN STOCK!!
    Just like the GruvenParts.com popular TT/R32 rear adjustable control arms, we designed these based on years of fabricating rock crawler suspension systems for racers and weekend warriors alike. They are made from a special aircraft grade of 4130 chrominum-molybdenum alloy and then powder coated in high gloss black for maximum durability. The heim joints are CAD plated, PTFE lined for quiet operation, and can be ordered with dust boots all around for those planning to re-enact a Grouppe B Ralley race. All parts are fully rebuildable.
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-16-2011 11:10 AM #54
    Thanks for all orders. We are caught up, please call me direct if any questions about your order!
    www.GruvenParts.com
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-29-2011 02:56 PM #55
    Billet MK4 1.8T Golf/Jetta, TT Dipstick Funnel
    GruvenParts.com is proud to release these gorgeous Billet Dipsticks to replace OEM part number 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R) for the Audi TT MKI 1.8T, and VW MKIV 1.8T Golf and Jetta.
    Our billet dipstick is CNC’d from a solid block of 6061-T651 aluminum with a stainless steel cable permanently attached. The cable end has a fitting with hash marks to signify oil level min and max.
    As an added bonus, this part is made to perfectly fit our 1.8T Billet Dipstick Funnels and can be ordered as a set to save! If you are ordering the billet funnel with the billet dipstick, please ensure your car uses dipstick funnel OEM P/N 06A-103-663B (06A103663B)
    This billet dipstick/funnel combo replaces OEM part number 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R) dipstick and OEM P/N 06A-103-663B (06A103663B) funnel and fits the following vehicles :
    Audi TT - MK1 w/1.8T engine
    VW Golf, Jetta, and New Beetle - MKIV 1.8T w/1.8T engine
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-06-2011 10:14 AM #56
    Audi/VW 4.2V8 Intake Linkage Arms !
    GruvenParts.com 4.2L V8 Intake Manifold Linkage Arms Warranted for Life !
    Got a 4.2L V8 Audi or VW ? Then you had better check your intake manifold actuator arms Audi/VW P/N 077-198-327A (077198327A)! The OEM plastic versions quickly break, leaving your intake manifold rod stuck which causes poor idle, drivability, loss of power, and poor fuel mileage. This is a very common problem on the Audi/VW 4.2L V8, an otherwise great engine. The dealer will only sell you a repair kit for nearly $400, and each repair kit only comes with 1 of each length linkage arm. If your vechicle has 2 broken linkage arms, you would need to buy 2 dealer repair kits (cost nearly $800)!
    Our Billet intake manifold arms are made from aerospace grade 6061-T651 aluminum with specially machined black Delrin inserts to provide a perfect fit to the actuator balls. These parts are warrantied for life!
    Dont go to the VW/Audi dealer and pay upwards of $400 for the new actuator kit when all you need are the arms (the actuators themselves rarely fail). And DONT pay that kind of money for another set of plastic arms that will break in quick order.
    Go with GruvenParts.com and NEVER WORRY ABOUT THIS AGAIN !
    Fits the following vehicles:
    2004-2007 VW Phaeton V8
    2003+ VW Touareg V8
    2002-2004 Audi A6/Avant
    1998-2004 Audi A6/S6 Quattro
    2000+ Audi A8/S8 Quattro
    Replaces OEM P/N 077198327A (077-198-327A)
  19. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-11-2011 08:53 AM #57
    MK3 Golf/Jetta Billet Radiator Cover
    Replace your plastic MK3 Golf or Jetta radiator fan cover - OEM P/N 1HM-121-343A (1HM121343A) with this machined billet aluminum version. Our part installs in minutes to give your engine bay the attention it deserves!
    Ours is CNC'd from aerospace grade billet aluminum and sculpted to fit the contours of the MK3 Golf and Jetta engine bay perfectly.
    Available in CNC machined finish or chrome plated. Custom engraving options are available. Send us an image of your desired engraving and we will quote it - Paul@GruvenParts.com.
    Fits all 1993-1999 MK3 Golf and Jetta and replaces OEM P/N 1HM-121-343A (1HM121343A)
  20. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-25-2011 11:36 AM #59
    Bump for more billet parts !
    Quote Originally Posted by GruvenParts.com View Post
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-06-2011 03:29 PM #61
    24V Billet VR6 Drive Belt Pulleys - All 24V VR6
    GruvenParts.com offers a complete set of ultra sleek lightweight 24V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 24V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Buy them as a set and save!
    These pulleys replace the following OEM part numbers :
    Crank Pulley : 022-105-243A (022105243A)
    Tensioner Pulley: 022-145-299D (022145299D)
    Water Pump Pulley: 021-121-031A (021121031A)
    Alternator Pulley: 022-903-119A (022903119A) and 038-903-119B (038903119B)
    Power Steering Pulley : 038-145-255A (038145255A)
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-20-2011 09:55 AM #62
  23. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-03-2011 10:12 AM #63
    Guys, the GB has ended on these control arms, however, we can always start another
    For 10 orders, we can offer price of $409.99, please note this INCLUDES the racing grade dust boots to protect the heims.
    If you want in on the GB, email or post up here your contact details.
    Thanks!
    www.GruvenParts.com
  24. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-17-2011 11:47 AM #64
    Bump for the best control arms on the market !
    We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include Teflon lined heim joints and bulletproof welds with optional super durable dust boots for extreme environments! Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
    Got a lowered TT, R32, or A3 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    TT/R32 OEM Headlight Leveling Adapter Bracket
    TT / R32 Headlight Leveling Adapter Bracket
    Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
  25. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-27-2011 10:04 AM #65
    In stock, ready to ship !
  26. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-14-2011 01:12 PM #66
  27. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-14-2011 01:19 PM #67
    GruvenParts.com Die Cut Vinyl Stickers - Free for Orders over $100 !
    They're Back In Stock - Bigger and Better !! All Colors Now Available. Dress up your ride with our premium die cut vinyl stickers and enjoy free domestic shipping.
    Available in Red, Silver, White and Black.
    We ship out a freebie with any order over $100 !
  28. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-06-2011 11:44 AM #68
    A4 and A6 owners with the 3.0L V6 engine, could you please check out this thread and respond -
    http://forums.vwvortex.com/showthrea...ge-Arms-FEELER
    Its regarding the variable intake manifold links. We want to build them from aluminum, but we need some interest 1st.
    Thanks!
  29. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-13-2012 09:15 AM #69
    Click on the picture to visit our product page for up to date pricing info.
    NOW CHOOSE POLY-BUSHINGS OR SPHERICAL ROD ENDS !!
    The GruvenParts adjustable control arms allow for complete rear wheel alignment and feature the following :
    Choose from a zero deflection high radial load PTFE lined heim joint with protective dust boots preinstalled over specially machined bushings. The fit of the boot over the heim and bushings is nearly water tight!
    OR
    A poly bushing end with a heat treated 4340 forged chromoly housing, grease fitting, zinc plated steel sleeves, and race grade greaseable black polyurethane bushings
    You decide which set up you want ! The zero deflection spherical heims are suited for serious track abuse while the poly bushing ends are better suited for daily drivers.
    All control arms feature the following :
    Super strong, heat treated 4340 aircraft grade chromoly rod and ¼” thick U-Joints with machined, internally lubricated (molybdenum disulfide) threads. No weak aluminum is used for these parts (aluminum threads wont hold up).
    Distinct proper wrench adjustment flats machined into the bars which allow for 2” of length adjustment while on the car. There is no knurled hand adjustment nonsense here, ours are simple to adjust.
    Thick, durable powder coat finish (and zinc plating on the poly bushing ends) in your choice of high gloss black or Bilstein jazz blue. Please don’t adjust these with weight on the rear axle, and don’t use channel locks that could mar even a hard coat chrome plate.
    Made right here in Atlanta, Georgia by our FAA approved commercial aviation machine shop working on state of the art CNC mills and lathes. You wont find many shops working at our level, and you wont find higher quality anywhere !
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue or gloss black to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
  30. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-13-2012 05:28 PM #70
    These parts are in stock, ready to ship!!
    OR
