Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 85
Thread: ** GruvenParts.com Has Audi Parts for Our Canadian Customers !
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-24-2010 10:29 PM #1
    TT/R32 Rear Adjustable Control Arms
    Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
    We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include greaseable heim joints and bulletproof welds. Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
    We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
    Want further discounts and more great products from GruvenParts.com? Read on!
    TT/R32 Rear Adjustable Sway Bar End Linkages
    Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
    Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-01-2010 02:58 PM #2
    Audi/VW 4.2V8 Intake Linkage Arms !
    GruvenParts.com 4.2L V8 Intake Manifold Linkage Arms Warranted for Life !
    Got a 4.2L V8 Audi or VW ? Then you had better check your intake manifold actuator arms (p/n 077198327A)! The OEM versions quickly break, leaving your intake manifold rod stuck, causing poor idle, drivability, loss of power, and poor fuel mileage. This is a very common problem on the 4.2L V8.
    Our intake manifold arms have an aerospace grade billet aluminum body with thread on carbon fiber composite ball end links. The composite end links are actually STRONGER than the aerospace grade aluminum body itself!
    This is how we can warranty them for life!
    Dont go to the VW/Audi dealer and pay upwards of $400 for the new actuator kit when all you need are the arms (the actuators themselves rarely fail). And DONT pay that kind of money for another set of plastic arms that will break in quick order.
    Go with GruvenParts.com and NEVER WORRY ABOUT THIS AGAIN !
    Fits the following vehicles:
    2004-2007 VW Phaeton V8
    2003+ VW Touareg V8
    2002-2004 Audi A6/Avant
    1998-2004 Audi A6/S6 Quattro
    2000+ Audi A8/S8 Quattro
    OEM P/N 077198327A (077-198-327A)
  3. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-14-2010 07:47 AM #4
    Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
    DOES NOT COME WITH CHEAP THIN WALL TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
    12V and 24V VR6 Coolant Pipes aka Crack Pipes
    Ours are completely tig welded by our licensed commercial jet aircraft repair facility! We were the 1st to build this part and its what started us off! If you have a billet crack pipe in your VR6, chances are it was made by http://www.GruvenParts.com. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! The 12V version replaces OEM p/n 021-121-050C (021121050C) and the 24V version replaces OEM p/n 022-121-050 (022121050).
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-28-2010 02:56 PM #6
    2003+ VW Touareg V8
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-19-2010 12:52 PM #7
    Genuine 3K Weave Carbon Fiber w/Adhesive Backing
    Looking for that trick custom upgrade to push your ride over the top at the shows?? Check out this R-E-A-L 3K Carbon Fiber Weave that we've put on an adhesive backing. We've also applied a clear coat to the Carbon to provide a deep gloss finish. Used for years in the aerospace industry, this genuine 3K carbon fiber with adhesive peel and stick backing adds strength and great looks to most any surface. Ships in (2) 10 inch x 20 inch .022 inch thick pieces.
    Sheets can be easily cut with sharp scissors or razors. Makes a great decorative upgrade to any surface. Sheets are fairly flexible and can be adhered to any complex contour without drastic impressions, inside/outside corners or rapidly changing surface features. High heat and low temperature applications should be avoided. Use only where typical plastic tapes would be used.
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-25-2010 09:41 AM #8
    What's in Development Currently ?
    1. Audi A4 adjustable front upper control arms - pics will be posted shortly!
    2. 02A side/side cable repair block
    3. R32/TT front adjustable swaybar end links
    4. VR6, 1.8T, 2.0 billet oil dipstick funnels
    5. Corrado stainless rear deck lid cables
    Much more ... stay tuned
    www.GruvenParts.com
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-01-2010 11:01 AM #9
    Give us suggestions on parts you want made !!
    www.GruvenParts.com
  8. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-09-2010 09:25 AM #10
    2003+ VW Touareg V8
  9. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-27-2010 05:32 PM #12
    The billet air intake linkages are back in stock, ready to ship asap!
    www.GruvenParts.com
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-30-2010 09:34 AM #13
    GruvenParts.com Die Cut Vinyl Stickers - Free for Orders over $100 !
    They're Back In Stock - Bigger and Better !! All Colors Now Available. Dress up your ride with our premium die cut vinyl stickers and enjoy free domestic shipping.
    Available in Red, Silver, White and Black.
    We ship out a freebie with any order over $100 !
  11. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-06-2010 10:35 AM #14
    The Control Arms and Sway End Links Are IN STOCK 10/5/2010
    Sorry for the slight shipping delays, but we've built stock up and are ready to go. Call or email with any questions.
    www.GruvenParts.com
  12. Member G-radoT's Avatar
    May 20th, 2006
    Wouldn't you like to know.
    2000 Audi A4 1.8T, 1990 Corrado G60 (SOLD),1993 Corrado (Sold),
    10-18-2010 03:59 AM #15
    Quote Originally Posted by GruvenParts.com View Post
    www.GruvenParts.com
    Whats the ETA on the Audi A4 front upper control arms?
    Will they fit the B5? Sneak pics avail?
  13. Member G-radoT's Avatar
    May 20th, 2006
    10-18-2010 07:20 PM #16
    Quote Originally Posted by G-radoT View Post
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-24-2010 10:36 PM #17
    A4 front adjustable control arms almost done, stay tuned for some pics.
  15. Member G-radoT's Avatar
    May 20th, 2006
    10-25-2010 03:31 AM #18
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-28-2010 04:39 PM #19
    TT/R32 OEM Headlight Leveling Adapter Bracket
    Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-01-2010 11:51 AM #20
    Billet MK4 and Audi Dipstick Handles!
    We’re all sick of popping the hood on our stylish VW’s and Audi’s only to find an engine compartment which looks like it might have digested a construction cone somewhere along the way. Now you can finally get rid of that hideous bright orange dipstick in favor of this billet aluminum version in a variety of colors and finishes.
    Fits all 98-07 New Beetle, Golf, Jetta, Passat, 99-06 Audi A4 00-06 TT and is for use on cars with OEM dipstick P/N 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R)
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-03-2010 10:47 AM #21
    Billet Audi TT Oil Cap Ring
    Dress up your 225 TT engine with this super highly polished oil cap ring which is precision machined from 6061-T651 aluminum. This piece is machined with 7 dimples and a TT logo, and is a quarter inch thick for added bling.
    Installs quickly with 3M double tape (not included).
    This product fits all 00-06 TT with 225 HP engine cover
  19. Member G-radoT's Avatar
    May 20th, 2006
    11-03-2010 11:19 PM #22
  20. Banned
    Oct 6th, 2008
    NW, NC
    2002/Audi/TTQ & 2003/VW/VR6
    11-06-2010 05:05 PM #23
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-15-2010 09:01 AM #24
    Billet Audi TT LED Alarm Rings
    We’re proud to release these LED Alarm rings made from 6061-T651 aluminum. These come 2 to a set and are anodized in a variety of colors to provide a subtle and yet customized look for your interior.
    This product fits 00-06 TT 180 and 225 HP with 1.8T engines
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-29-2010 10:20 AM #26
    post turkey day bump !!
  23. Member G-radoT's Avatar
    May 20th, 2006
    12-01-2010 07:13 AM #27
  24. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    12-08-2010 01:27 PM #28
    bump for some billet goodies
  25. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-03-2011 11:30 AM #30
    Billet Dipstick Funnel
    Finally, a replacement for the orange plastic dipstick funnel !
    Our funnel is made from 6061-T6 billet aluminum and neatly replaces the cheap brittle orange dipstick funnel we have all come to hate. Choose from as machined finish or highly polished finish.
    This part replaces OEM part number 053-103-663 (053103663) on the following vehicles:
    Audi - 80, B5 A4 1.8T – all 4 cylinder
    VW – MK2 Golf, Jetta, Scirocco, Corrado G60 (NOT VR6), MK3 ABA’s, Eurovan T4, B3, B4, B5 Passat 1.8T and 2.0
  26. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-10-2011 09:11 AM #31
    Now You Can Choose from Jazz Blue or High Gloss Black Powdercoat Finish !!
  27. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-18-2011 02:43 PM #32
    A Billet Replacement for the Dreaded 1.8T Dipstick Funnel Has Arrived !!
    This one is made from 6061-T6 billet aluminum and neatly replaces the cheap brittle orange dipstick funnel we have all come to hate.
    This part replaces OEM P/N 06A-103-663B (06A103663B) on the following vehicles :
    MK1 Audi TT 1.8T, MKIV Golf 1.8T, MKIV Jetta 1.8T, and New Beetle 1.8T
    Be sure to check your OEM part number to verify it is 06A-103-663B as VW and Audi have made several variations of the worthless orange dipstick tube.
    Forget about ever breaking your 1.8T dipstick tube again !!
  28. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2011 11:56 AM #33
    A4/B5 Front Adjustable Control Arms
    Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms
    BY FAR – THE BEST VALUE IN ADJUSTABLE CONTROL ARMS ON THE MARKET !
    You asked GruvenParts.com for affordable, bulletproof, and fully rebuildable Audi A4/S4/RS4/A6/RS6 and VW Passat B5 Adjustable Front Upper Control Arms and we have delivered!
    Just like the GruvenParts.com popular TT/R32 rear adjustable control arms, we designed these based on years of fabricating rock crawler suspension systems for racers and weekend warriors alike. They are made from a special aircraft grade of 4130 chrominum-molybdenum alloy and then powder coated in high gloss black for maximum durability. The AMERICAN MADE racing heim joints are CAD plated, PTFE lined, and can be ordered with dust boots all around for those planning to re-enact a Grouppe B Ralley race. Finally, all parts are fully rebuildable.
    Don’t waste your hard earned money with the over-priced competitor versions. The quality and performance of the GruvenParts.com adjustable upper control arms are second to none!
    These come as a set of 4 and fit the following models :
    Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
    Audi A6/RS6 (incl. AllRoad) - 1998-2004
    VW Passat - 1998-2005
    This product replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
  29. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-10-2011 08:56 AM #34
    CNC Pressed MSD Coil Pack Brackets for MK3 and MK4 VR6 !
    Use this CNC formed, powder coated Aerospace grade aluminum bracket to mount your new MSD 8224 coils on MK3 or MK4 VR6 engines. We all know how poorly the OEM Beru units hold up - so get serious about your VR6 ignition and step up to MSD! Leave the cheaply made, overpriced Beru coils for the competition!
