Page 1 of 3 1 2 3 LastLast
Results 1 to 35 of 101
Thread: ** GruvenParts.com Has 3.2L 24V VR6 Billet Goodies !!
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-24-2010 10:35 PM #1
    Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
    DOES NOT COME WITH CHEAP THIN WALL TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
    12V and 24V VR6 Coolant Pipes aka Crack Pipes
    Ours are completely tig welded by our licensed commercial jet aircraft repair facility! We were the 1st to build this part and its what started us off! If you have a billet crack pipe in your VR6, chances are it was made by http://www.GruvenParts.com. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! The 12V version replaces OEM p/n 021-121-050C (021121050C) and the 24V version replaces OEM p/n 022-121-050 (022121050).
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-01-2010 02:51 PM #2
    VR6 Billet Aux Water Pump Bracket – All VR6
    This part replaces the useless rubber donut OEM P/N 035-959-209E (035959209E) that does a poor job supporting your PRICEY auxiliary water pump, and related PRICEY hoses. The OEM rubber donut allows the weight of the pump and hoses to sag, causing stress which can lead to pump and hose failure. Our billet version is the way VW should of designed it to begin with and locks the pump and hoses tight! On or off track, this part will secure the aux pump and prevent pump and hose failure.
    Replaces OEM P/N 035-959-209E (035959209E) common to the following vehicles -
    Corrado - all VR6
    Eos - 2007 + 3.2L VR6
    Eurovan - All VR6
    R32 - 2004
    Golf, Jetta, Jetta Wagon - 1993-2007 All VR6
    Passat - 1992-2005 - All VR6 and V8
    Phaeton - 2004-2007 6L V12
    Touareg - 2003 on 3.2L VR6
  3. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-07-2010 07:45 AM #3
    24V Billet VR6 Drive Belt Pulleys - All 24V VR6
    GruvenParts.com offers a complete set of ultra sleek lightweight 24V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 24V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Buy them as a set and save!
    These pulleys replace the following OEM part numbers :
    Crank Pulley : 022-105-243A (022105243A)
    Tensioner Pulley: 022-145-299D (022145299D)
    Water Pump Pulley: 021-121-031A (021121031A)
    Alternator Pulley: 021-903-119A (021903119A)
    Power Steering Pulley : 038-145-255A (038145255A)
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-11-2010 12:28 PM #4
    MKIV VR6 Intake Manifold Bushings - 12V and 24V VR6 Engines
    These bushings replace the following OEM part numbers -
    021-133-653 (021133653) on 2.8L 12V VR6 engines - 1999-2006 Golf, Jetta, Jetta Wagon, Vanagon
    022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon
    022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos
    Another Vortex 1st - You told us about the chronic rattles common to the intake manifold change-over valve on the 12V and 24V VR6 engines and we listened. Our bushings provide the fit that VW should have used to prevent intake manifold wear.
    Our bushings are designed to provide more contact area and a tighter fit to secure the intake manifold change-over rod. Continuing to use the weak OEM bushings will result in the change-over rod vibrating (the source of the rattle), which in turn will damage the intake manifold itself. Last we checked, these intake manifolds were running close to $1,000 and are only available from VW. Dont take chances by waiting, replace the bushings with our versions BEFORE rattling occurs! There is no need to replace the rod itself, just the bushings.
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-14-2010 07:45 AM #5
    TT/R32 Rear Adjustable Control Arms
    Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
    We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include greaseable heim joints and bulletproof welds. Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
    We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
    Want further discounts and more great products from GruvenParts.com? Read on!
    TT/R32 Rear Adjustable Sway Bar End Linkages
    Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
    Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
    Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-22-2010 11:58 AM #6
    MK4 Golf / Jetta / Wagon Billet Hood Pulls !
    We've been around VW's long enough to know that Murphy is a mother***! Therefore, we have crafted these billet MK4 Golf / Jetta / R32 / Wagon hood pulls from a solid blocks of aerospace grade 6061-T651 aluminum using 1 of our 5 axis CNC's. Its an exact replica of the OEM part, except made the way VW should of done it - from billet! Forget about the Pray and Pull theory, you're not breaking this one! Includes nut/bolt for the simple installation.
    These billet hood pulls replace VW P/N 1J5823593C (1J5 823 593C) for MK4 Jetta / Wagon and VW P/N 1J0823593C (1J0 823 593C) for MK4 Golf / R32
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-28-2010 02:22 PM #7
    Billet / Carbon Fiber / "VeeChain"
    Pay homage to the unique VR6 engine design with this accurate CNC keychain minature. Measuring about 2 inches in length by 1 inch width, its an instant conversation starter with the girls at the parties who are constantly wondering about your 15 degree cylinder offset. This is an Oichan original design (http://www.oichan.org) sold under his permission. Beware of the rip off versions out there which are made using water jet process and have ragged edges and poor quality. Ours are made on a 3 axis CNC 1 at a time and are literally perfect replications of the unique VR6 engine.
    Available in machine polished billet aluminum or genuine 3K weave carbon fiber plate.
  8. Member Voyles's Avatar
    Jun 1st, 2008
    Detroit
    MKV .:R32
    06-28-2010 07:54 PM #8
    I'm really interested in a key chain. Your link is broken.
  9. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-02-2010 01:24 PM #9
    call me, it seems to be working on our end ...
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-06-2010 05:38 PM #10
    GruvenParts//Yarrowsport MKIV Golf/Jetta Rear Stress Bar
    We are helping Yarrowsport sell their popular MKIV rear stress bar for Golf and Jetta platforms.
    Stiffen up the flexible MKIV chassis with this proven rear stress bar from Yarrowsport and sold exclusively by GruvenParts.com! This bar is machined to the factory correct dimensions and installs easily with all hardware and instructions provided.
    Fits all MK4 Golf and Jetta, R32 !
  11. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-12-2010 01:49 PM #11
    GRuvenParts.com Has NEW PARTS !!
    We are working on something for everyone, stay tuned, we have lots more in production.
    Finshed, Ready for Sale (Going onto site shortly)
    -- MK2 9A 1.8L/2.0 16V Lightweight Billet Crank Pulleys
    --Corrado G60 Billet Lightweight Alternator Pulleys
    To Be Finished Soon 1-2 weeks
    -- Audi A4/S4 Billet Adjustable Upper Control Arms
    -- R32 / TT Adjustable Front Sway Bar End Links
    -- MK2 / MK3 / New Beetle 02A Side/Side trans cable repair blocks
    -- Corrado rear deck lid billet linkages / cables - super trick !
    Stay tuned for more !!
    www.GruvenParts.com
  12. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-19-2010 12:51 PM #12
    Genuine 3K Weave Carbon Fiber w/Adhesive Backing
    Looking for that trick custom upgrade to push your ride over the top at the shows?? Check out this R-E-A-L 3K Carbon Fiber Weave that we've put on an adhesive backing. We've also applied a clear coat to the Carbon to provide a deep gloss finish. Used for years in the aerospace industry, this genuine 3K carbon fiber with adhesive peel and stick backing adds strength and great looks to most any surface. Ships in (2) 10 inch x 20 inch .022 inch thick pieces.
    Sheets can be easily cut with sharp scissors or razors. Makes a great decorative upgrade to any surface. Sheets are fairly flexible and can be adhered to any complex contour without drastic impressions, inside/outside corners or rapidly changing surface features. High heat and low temperature applications should be avoided. Use only where typical plastic tapes would be used.
  13. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-02-2010 11:04 AM #14
    GruvenParts.com Die Cut Vinyl Stickers - Free for Orders over $100 !
    They're Back In Stock - Bigger and Better !! All Colors Now Available. Dress up your ride with our premium die cut vinyl stickers and enjoy free domestic shipping.
    Available in Red, Silver, White and Black.
    We ship out a freebie with any order over $100 !
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-09-2010 01:44 PM #15
    www.GruvenParts.com
    Please feel free to call or email with any questions regarding our products.
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-25-2010 09:56 AM #16
    What's in Development Currently ?
    1. Audi A4 adjustable front upper control arms - pics will be posted shortly!
    2. 02A side/side cable repair block
    3. R32/TT front adjustable swaybar end links
    4. VR6, 1.8T, 2.0 billet oil dipstick funnels
    5. Corrado stainless rear deck lid cables
    Much more ... stay tuned
    www.GruvenParts.com
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-01-2010 11:01 AM #17
    Give us suggestions on parts you want made !!
    www.GruvenParts.com
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-09-2010 09:11 AM #18
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-27-2010 05:22 PM #20
    We now offer complete VR6 crack pipe kits, everything you need to complete the job!
    We can customize your complete repair kit to include anything you want, just give us a call or email for final quote.
    www.GruvenParts.com
  19. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-30-2010 09:44 AM #21
  20. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-06-2010 10:45 AM #22
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-24-2010 11:11 PM #23
    Follow our supercharger install thread, there will be an interesting twist at the end ...
    http://forums.vwvortex.com/showthrea...r-Build-Thread
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-28-2010 04:41 PM #24
    TT/R32 OEM Headlight Leveling Adapter Bracket
    Our headlight leveling adapter bracket is neoprene covered and comes with a rubber backing plate to securely attach the OEM headlight leveling arm to the GruvenParts.com adjustable rear control arms. The bracket is fully isolated from vibration and scratches and protects the beautiful powder coated finish on our adjustable rear control arms. Includes U bracket, nuts, and rubber backing plate - ALL hardware needed to quickly and simply attach your OEM headlight leveling arm. May require slight trimming of the neoprene wrap over the U-bolt with a sharp blade.
    This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant equipped with a headlight leveling system and the GruvenParts.com rear adjustable control arms.
  23. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-01-2010 11:51 AM #25
    Billet MK4 and Audi Dipstick Handles!
    We’re all sick of popping the hood on our stylish VW’s and Audi’s only to find an engine compartment which looks like it might have digested a construction cone somewhere along the way. Now you can finally get rid of that hideous bright orange dipstick in favor of this billet aluminum version in a variety of colors and finishes.
    Fits all 98-07 New Beetle, Golf, Jetta, Passat, 99-06 Audi A4 00-06 TT and is for use on cars with OEM dipstick P/N 06A-115-611Q (06A115611Q) and 06B-115-611R (06B115611R)
  24. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-15-2010 10:49 AM #26
    Billet Audi and VW Washer Fluid Cap
    Ditch the ugly blue washer fluid cap (or half tennis ball if you’re really ghetto) with one of these slick billet aluminum 6061-T651 versions.
    Ours are CNC machined for a perfect fit and can be ordered in a variety of colors and finishes – including anodized or highly polished. Simply remove the old cap and press fit this one right into the washer tank.
    This product replaces OEM P/N 1K0-955-455 (1K0955455), 1H0-955-455 (1H0955455), and fits nearly every VW and Audi in existence. So, there’s no excuse to rock the half tennis ball anymore!
  25. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-30-2010 12:36 PM #28
    www.GruvenParts.com
    Quote Originally Posted by GruvenParts.com View Post
  26. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-03-2011 11:48 AM #30
    The TT/R32 control arms will be back in stock 1/5/2011.
  27. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-10-2011 09:08 AM #31
    Now You Can Choose from Jazz Blue or High Gloss Black Powdercoat Finish !!
  28. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2011 11:35 AM #32
  29. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-10-2011 09:11 AM #33
  30. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-21-2011 11:28 AM #35
    Speaking of 3.2L 24V VR6 motors …
    We now have full MK5 R32 lightweight pulley kits available.
    Check out the MK5 section of our site.
    www.GruvenParts.com
