VWVortex.com - ** GruvenParts.com Has 3.2L 24V VR6 Billet Goodies !!
    Page 2 of 5 FirstFirst 12345 LastLast
    Results 26 to 50 of 102
    Thread: ** GruvenParts.com Has 3.2L 24V VR6 Billet Goodies !!
    1. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      11-15-2010 10:49 AM #26
      Billet Audi and VW Washer Fluid Cap
      Ditch the ugly blue washer fluid cap (or half tennis ball if you’re really ghetto) with one of these slick billet aluminum 6061-T651 versions.
      Ours are CNC machined for a perfect fit and can be ordered in a variety of colors and finishes – including anodized or highly polished. Simply remove the old cap and press fit this one right into the washer tank.
      This product replaces OEM P/N 1K0-955-455 (1K0955455), 1H0-955-455 (1H0955455), and fits nearly every VW and Audi in existence. So, there’s no excuse to rock the half tennis ball anymore!
    2. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      11-30-2010 12:36 PM #28
      www.GruvenParts.com
      Quote Originally Posted by GruvenParts.com View Post
      TT/R32 Rear Adjustable Control Arms
      Got a lowered TT or R32 ? Then you already know how the camber and toe become completely out of sorts, causing poor handling and expensive tire wear the more its lowered. Don't fret, GruvenParts.com has your solution.
      We are proud to release these adjustable upper and lower rear control arms made from indestructible 4340 aircraft steel tubing. These high quality arms include greaseable heim joints and bulletproof welds. Each control arm provides up to 2 FULL INCHES of adjustment ON THE CAR (does not require removal for adjustment of both camber and toe).
      We know the economy is tough right now, so we are offering these at prices well under our competition. Buy 2 sets and save !!!
      This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces P/N 1J0-505-323L (1J0505323L) and 1J0-505-323N (1J0505323N).
      Want further discounts and more great products from GruvenParts.com? Read on!
      TT/R32 Rear Adjustable Sway Bar End Linkages
      Got a lowered TT or R32 ? Then you need to be able to adjust your rear stabilizer bar end links to ensure the linkages ride perpendicular to the swaybar and correct the less than ideal handling typical of lowered set ups. The factory set up does not provide any adjustability in the swaybar end links but GruvenParts.com has you covered!
      Our adjustable end links are made from aerospace grade 6061-T651 aluminum hex and feature 2 full inches of adjustment ON THE CAR. This makes for very quick and easy length adjustment on both the top and bottom of the linkage to completely fine tune just about any suspension set up. Our linkages utilize high quality greaseable heim joints for many years of smooth and quiet operation. While we recommend using our fully adjustable rear control arms, you can install these end links without them. The main body is show quality powder coated jazz blue to match our control arms, and like all of our parts they are made right here in Atlanta, Georgia by our FAA approved commercial jet aviation machine shop on state of the art HAAS mills and lathes. You wont find higher quality anywhere!
      This product fits Audi TT (2001-2006), Audi A3/S3, VW R32 (2004), VW Golf 4motion and 4motion Variant, VW Bora 4motion and 4motion Variant and replaces OEM linkage P/N 1J0-505-466B (1J0505466B).
      Please note : This product is sold in sets of 2 (1 for each side) and includes all required spacers and the upper bolt/lock nut. Re-use existing lower bolt.
    3. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      01-03-2011 11:48 AM #30
      The TT/R32 control arms will be back in stock 1/5/2011.
    4. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      01-10-2011 09:08 AM #31
      Now You Can Choose from Jazz Blue or High Gloss Black Powdercoat Finish !!
    5. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      01-31-2011 11:35 AM #32
      24V Billet VR6 Drive Belt Pulleys - All 24V VR6
      GruvenParts.com offers a complete set of ultra sleek lightweight 24V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 24V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys with exception of power steering pulley ARE NORMAL DRIVE (NOT UNDER-DRIVE). Our testing has determined that ONLY the power steering pulley should be under-driven (slightly). All other pulleys in the system rotate at the OEM speed. These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
      Buy them as a set and save!
      These pulleys replace the following OEM part numbers :
      Crank Pulley : 022-105-243A (022105243A)
      Tensioner Pulley: 022-145-299D (022145299D)
      Water Pump Pulley: 021-121-031A (021121031A)
      Alternator Pulley: 021-903-119A (021903119A)
      Power Steering Pulley : 038-145-255A (038145255A)
    6. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      02-10-2011 09:11 AM #33
      Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
      DOES NOT COME WITH CHEAP THIN WALL TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
      12V and 24V VR6 Coolant Pipes aka Crack Pipes
      Ours are completely tig welded by our licensed commercial jet aircraft repair facility! We were the 1st to build this part and its what started us off! If you have a billet crack pipe in your VR6, chances are it was made by http://www.GruvenParts.com. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! The 12V version replaces OEM p/n 021-121-050C (021121050C) and the 24V version replaces OEM p/n 022-121-050 (022121050).
    7. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      02-21-2011 11:28 AM #35
      Speaking of 3.2L 24V VR6 motors …
      We now have full MK5 R32 lightweight pulley kits available.
      Check out the MK5 section of our site.
      www.GruvenParts.com
      Aug 26th, 2010
      NY/NJ
      07 3.6 4Mo Passat Wagon
      03-01-2011 08:45 PM #36
      Do you happen to know if an of these products for the r32 will fit my 3.6 passat
    9. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      03-21-2011 03:19 PM #37
      Just to make all the MK4 VR6 owners aware …
      www.GruvenParts.com will soon be releasing a billet aluminum version of the white plastic part which connects the intake manifold change over rod to the drive unit actuator shown in this pic (red arrow) :
      And detailed in this DIY Article section on www.GruvenParts.com
      On 12V VR6 engines (99-06 Golf, Jetta VR6), the white part is sold as part of the Drive Unit p/n 071-133-759C (071133759C) or 071-133-759D (071133759D) and on the 24V engines (R32, 02-08 Golf, Jetta, Eos, Touareg) it is sold as part of Drive Unit p/n 022-133-759 (022133759) or 022-133-759A (022133759A).
      This white plastic part continually breaks and is not readily available from VW without buying the whole plastic Drive Unit at a cost of $130-$160.
      Needless to say, we’ll put an end to that foolishness in typical GruvenParts.com fashion by milling this part from a solid chunk of 6061-T651.
      You can follow the development thread here (and feel free to chime in, too!) –
      http://forums.vwvortex.com/showthrea...-a-replacement
      Just another example of how www.GruvenParts.com is listening to your suggestions. Let us know what other parts need to be redesigned!
    10. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      03-28-2011 01:46 PM #38
      Bump for billet goodness and lots more is on the way !
      www.GruvenParts.com
      Our TT/R32 + A4/Passat Adjustable control arms are now available fully booted for extreme environments.
      A4/B5 Front Adjustable Control Arms
    11. Junior Member
      Apr 11th, 2010
      Walcott, ia
      04-04-2011 10:52 PM #39
      any idea on when we can expect this part to be ready?!?!? mine freshly broke and im in need of this part and i dont want to purchase the entire vacuum unit for just that 1 damn part!
    12. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      04-05-2011 01:25 PM #40
      It should be ready next week, DONT BUT THE WHOLE ACTUATOR FROM VW !
      Stay tuned, I will be posting more info on the aluminum version soon.
    13. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      05-12-2011 02:57 PM #41
      Im sorry for the delay on the billet version. We have design finalized Im just waiting for a 4 axis to open up at the CNC shop. We are coming to end of huge run of control arms so we should have capacity to mill the part end of week/weekend. I know you guys need it, give me a moment to get caught up. This has been a crazy month...
    14. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      05-16-2011 03:07 PM #42
      These are back in stock (in black) and ready to go !!
      www.GruvenParts.com
    15. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      05-23-2011 08:49 AM #43
      GruvenParts.com has released this billet intake drive unit arm for ALL VW/Audi VR6 engines with variable intake manifolds!
      Billet Intake Manifold Drive Unit Linkage!
      This part replaces the white plastic part that attaches to the actuator arm. The OEM part is made from injection molded nylon and becomes very brittle in the engine heat. Of course VW/Audi will not sell you *JUST* this part, you would have to buy a whole new drive unit for big bucks and get a bunch of stuff you don’t need.
      GruvenParts.com builds these the way VW should have: from a solid chunk of 6061-T651 aircraft grade aluminum on a 4 axis HAAS mill-lathe. Utilizing some tricks within the SolidWorks/MasterCam CNC software, we have tweaked the process to allow the billet part to be machined specially to accept the locking feature on the end of the intake rod. Just push fit this part onto the end of the intake rod similar to OEM plastic part fitment. There are no set screws to come loose and the fit is perfect.
      This part makes a great upgrade when installing our upgraded MKIV VR6 Intake Manifold Bushings
      Our part will also cost you about 1/3 what VW/Audi charge for their plastic drive unit (and the OEM plastic part is NOT part of their repair kit). This one is a no brainer!
      You guys asked us for it and we listened. Another great billet replacement part to rid your VW/Audi of the weak plastic parts!
      Don’t forget to check out the DIY listed on our website.
      Applications:
      2.8L 12 V VR6 ENGINE - with AFP Engine Code (99-02 Golf/Jetta VR6) to replace the drive unit linkage p/n 071-133-759D (071133759D) on OEM VW rod p/n 021-133-653 (021133653)
      2.8L 24 V VR6 ENGINE - BDF Engine Code (02 - present Golf/Jetta VR6) to replace the drive unit linkage p/n 022-133-759 (022133759) on OEM VW rod p/n 022-133-653 (022133653)
      3.2L 24V VR6 Engines - 04 R32, 3.2 Touareg, 3.2 Eos, 3.2 A3, 3.2 TT to replace the drive unit linkage p/n 022-133-759A (022133759A) on rod p/n 022-133-653B (022133653B)
    16. Member
      Sep 23rd, 2001
      Toronto \/ \/\/ PA
      MK4 R32
      05-24-2011 07:29 AM #44
      Time frame on R32 Adjustable front sway bar links?
    17. Member
      Sep 23rd, 2001
      Toronto \/ \/\/ PA
      MK4 R32
      05-25-2011 07:10 AM #45
      GRuvenParts.com Has NEW PARTS !!
      We are working on something for everyone, stay tuned, we have lots more in production.
      To Be Finished Soon 1-2 weeks
      -- R32 / TT Adjustable Front Sway Bar End Links
      www.GruvenParts.com
    18. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      06-05-2011 02:47 PM #46
      We do have a design ready to go on the R32 front swaybar end links but I havent found people who want them. Who all wants front adjustable swaybar end links for R32/TT ?
      Please email me directly paul@gruvenparts.com so we can finally build these!
      Thanks guys
      www.GruvenParts.com
    19. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      06-10-2011 11:57 AM #47
      MACHINED FROM 6061-T651 ALUMINUM TO EXACTLY MATCH OEM PIPE DIMENSIONS - OURS DOES NOT COME WITH CHEAP THIN WALLED TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
      GruvenParts.com was the 1st to build this part and it’s what started us off! We manufacture this pipe EXACTLY to match the OEM part shape so there is NEVER a fitment issue. Be careful when considering other billet pipes which do not match the exact shape of the OEM pipe. The fitment of this part is tricky and the shape MUST BE IDENTICAL to the OEM part to ensure correct alignment between the water pump and thermo housing.
      If you have a billet crack pipe in your VR6, chances are it was made by us. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! Our pipe has a modular design which allows you to plug the oil cooler feed line with a ¼ NPT plug if installing an external oil cooler. Ours can also be ordered with a chrome plated drain valve for quick and clean coolant flushes. The pipe can also be ordered with a brilliant chrome finish for those seeking the ultimate engine bay bling!
      If you dont want to do this job again, buy the LIFETIME WARRANTED GruvenParts.com billet CrackPipe !
      Make sure to see our website for the complete installation DIY
      The 12V version replaces OEM p/n 021-121-050C (021121050C) found in 12V VR6 : VW Corrado, Golf, Jetta, Passat, and Eurovan.
      The 24V version replaces OEM p/n 022-121-050 (022121050) found in 24V VR6 : VW R32, Golf, Jetta, Eurovan, EOS, Audi : 3.2L V6 TT and A3
    20. 06-23-2011 09:07 PM #48
      Gruven: can you confirm that this will fit MK5 R32?
    21. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      06-29-2011 09:18 AM #49
      Quote Originally Posted by 3r1k View Post
      YES!!! This fits MK5 VR engines too
      Dump the plastic stuff before it breaks.
      www.GruvenParts.com
    22. Banner Advertiser GruvenParts.com's Avatar
      Jul 31st, 2007
      Atlanta, GA
      Too many to list !
      07-06-2011 10:33 AM #50
      MKIV VR6 Intake Manifold Bushings - 12V and 24V VR6 Engines
      These bushings replace the following OEM part numbers -
      021-133-653 (021133653) on 2.8L 12V VR6 engines - 1999-2006 Golf, Jetta, Jetta Wagon, Vanagon
      022-133-653 (022133653) on 2.8L 24V VR6 engines - 2002 on Golf, Jetta, Jetta Wagon, Vanagon
      022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, Eos
      Another Vortex 1st - You told us about the chronic rattles common to the intake manifold change-over valve on the 12V and 24V VR6 engines and we listened. Our bushings provide the fit that VW should have used to prevent intake manifold wear.
      Our bushings are designed to provide more contact area and a tighter fit to secure the intake manifold change-over rod. Continuing to use the weak OEM bushings will result in the change-over rod vibrating (the source of the rattle), which in turn will damage the intake manifold itself. Last we checked, these intake manifolds were running close to $1,000 and are only available from VW. Dont take chances by waiting, replace the bushings with our versions BEFORE rattling occurs! There is no need to replace the rod itself, just the bushings.
      022-133-653B (022133653B) on 3.2L 24V VR6 engines - Touareg, R32, EOS
