Page 3 of 3 FirstFirst 1 2 3
Results 71 to 100 of 100
Thread: ** GruvenParts.com Has Billet Passat Goodies !!
  1. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-13-2012 09:55 AM #71
    These are in stock, ready to go!
    Quote Originally Posted by GruvenParts.com View Post
    AAA VR6 Billet Dipsticks
    www.GruvenParts.com is proud to release this Billet Dipstick for all AAA VR6 Corrado, Golf, Jetta, and Passat!
    The gorgeous dipstick is CNC’d from a chunk of aerospace grade aluminum and contains 2 chemically resistant O-rings for a perfect fit and seal.
    Get rid of the ugly plastic dipstick and replace with our billet version!
    This part replaces the dipstick on AAA VR6 engines found on Corrado VR6, MK3 Golf, Jetta, and Passat with OEM dipstick p/n 021115607 and OEM tube p/n 021115629E.
  2. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-13-2012 03:35 PM #72
    Bump for more billet parts !
    Billet VR6 Crack Pipes for ALL VR6 Engines Corrado thru R32!
    DOES NOT COME WITH CHEAP THIN WALL TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
    12V and 24V VR6 Coolant Pipes aka Crack Pipes
    Ours are completely tig welded by our licensed commercial jet aircraft repair facility! We were the 1st to build this part and its what started us off! If you have a billet crack pipe in your VR6, chances are it was made by http://www.GruvenParts.com. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! The 12V version replaces OEM p/n 021-121-050C (021121050C) and the 24V version replaces OEM p/n 022-121-050 (022121050).
  3. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-19-2012 10:50 AM #73
    Up for billet Passat parts
  4. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-26-2012 11:55 AM #74
    Nice day to call in sick and work on your car
    www.GruvenParts.com
  5. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-23-2012 02:37 PM #75
    MK2 / MK3 Billet Fuel Line Support Brackets
    Billet fuel line support brackets (set of 2) to replace the weak plastic clips that are probably long gone on your MK2 and MK3 VR6. Ours are CNC'd from billet aluminum to perfectly match the size and shape of your VR6 fuel lines. Mount directly to the head in place of existing plastic supports and install with supplied aerospace grade stainless fasteners. Dont leave your VR6 fuel lines loose and rubbing against hot engine components! These will take more abuse than you can dish out, guaranteed!!
    Can be chrome plated for those seeking even more engine bay bling.
    Fits all MK2 and MK3 VR6 - Jetta, GTI, Passat, and Corrado. Includes stainless bracket hardware, re-use existing 10mm nuts to bolt to head. Brackets replace OEM P/N 021-133-827 (021133827) Bracket and P/N 021-133-687A (021133687A) clip.
  6. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-16-2012 09:37 AM #76
    GruvenParts.com
  7. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-29-2012 09:38 AM #77
    MACHINED FROM 6061-T651 ALUMINUM TO EXACTLY MATCH OEM PIPE DIMENSIONS - OURS DOES NOT COME WITH CHEAP THIN WALLED TAPPED FITTINGS LIKE OTHER LESSER PIPES !!
    GruvenParts.com was the 1st to build this part and it’s what started us off! We manufacture this pipe EXACTLY to match the OEM part shape so there is NEVER a fitment issue. Be careful when considering other billet pipes which do not match the exact shape of the OEM pipe. The fitment of this part is tricky and the shape MUST BE IDENTICAL to the OEM part to ensure correct alignment between the water pump and thermo housing.
    If you have a billet crack pipe in your VR6, chances are it was made by us. Hand crafted in our Aerospace shop using O-rings from the Boeing 777, proven by many hours of track time, it's the highest quality crack pipe you can buy. It's on all of our track cars and has withstood countless hours of track abuse! Our pipe has a modular design which allows you to plug the oil cooler feed line with a ¼ NPT plug if installing an external oil cooler. Ours can also be ordered with a chrome plated drain valve for quick and clean coolant flushes. The pipe can also be ordered with a brilliant chrome finish for those seeking the ultimate engine bay bling!
    If you dont want to do this job again, buy the LIFETIME WARRANTED GruvenParts.com billet CrackPipe !
    Make sure to see our website for the complete installation DIY
    The 12V version replaces OEM p/n 021-121-050C (021121050C) found in 12V VR6 : VW Corrado, Golf, Jetta, Passat, and Eurovan.
    The 24V version replaces OEM p/n 022-121-050 (022121050) found in 24V VR6 : VW R32, Golf, Jetta, Eurovan, EOS, Audi : 3.2L V6 TT and A3
  8. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    07-09-2012 12:18 PM #79
    Everything is in stock ready to ship
    www.GruvenParts.com
  9. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-16-2012 08:17 AM #80
    Please make sure to like us out on Facebook
    http://www.facebook.com/GruvenParts
    Its a great way to keep up with all that we are developing, and request more items to be developed
    www.GruvenParts.com
  10. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    08-20-2012 10:06 AM #81
    Billet 12V VR6 Drive Belt Pulleys - All 12V VR6
    GruvenParts.com offers a complete set of ultra sleek lightweight 12V VR6 power pulleys. These include lightweight billet crank, power steering, water pump, tensioner, and alternator pulleys for your 12V VR6 engine. These pulleys are precision CNC'd from aircraft grade billet aluminum and reduce the rotating mass by a whopping 8.5 lbs! All pulleys ARE NORMAL DRIVE (NOT UNDER-DRIVE). These pulleys will not change the speed of the supercharger and will not void any supercharger warranties.
    Buy them as a set and save!
    These pulleys replace the following OEM part numbers :
    Crank Pulley : 021-105-243 (021105243)
    Tensioner Pulley: 021-145-299 (021145299)
    Water Pump Pulley: 021-121-031A (021121031A)
    Alternator Pulley: 021-903-119 (021903119)
    Power Steering Pulley : 021-145-255 (021145255)
  11. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-10-2012 09:30 AM #82
    CNC Pressed MSD Coil Pack Brackets for MK3 and MK4 VR6 !
    Use this CNC formed, powder coated Aerospace grade aluminum bracket to mount your new MSD 8224 coils on MK3 or MK4 VR6 engines. We all know how poorly the OEM Beru units hold up - so get serious about your VR6 ignition and step up to MSD! Leave the cheaply made, overpriced Beru coils for the competition!
  12. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    09-20-2012 09:07 AM #83
    GruvenParts.com builds bulletproof TIG welded Y Pipes to replace the OEM plastic in your VW coolant system!
    Billet Upper Radiator Hose Y Pipes
    PLEASE NOTE : This part is professionally TIG welded! There are no junk tapped threads into thin wall aluminum like the lesser versions offered by unscrupulous rip off artists. And its warranted for life!
    An absolute MUST HAVE for all MK3 VR6 owners and MK4 New Beetle owners. The upper radiator hose on these models is quite a pricey item from the dealer – usually about $100. The most documented cause of replacement on this hose is due to the plastic Y fitting which connects the 3 short hose pieces. The VW Y pipe cannot be bought separately, and is not suited for the high temperatures under the hood. Hell, its plastic – what did you expect?!
    Dont buy the OEM plastic part when you can buy this BILLET ALUMINUM TIG Welded replacement part for half the price!
    If you need a custom water temp sensor port welded on, please let us know. We are happy to perform customization on ANY of our products.
    Replaces the following OEM P/N :
    1H0-122-101E (1H0122101E) – MK3 Golf/Jetta VR6
    3A0-122-101E (3A0122101E) – VR6 Passat
    1C0-121-438A (1C0121438A) – New Beetle
  13. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    10-09-2012 09:36 AM #85
    02A Billet Stainless Steel Short Shifter Bracket
    Replace the weak plastic link in your cable shift mechanism with this one made from Aerospace grade, hardened stainless steel. Reduces side/side shift throw by 35%! This part replaces OEM P/N 1J0-711-256 (1J0711256) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
    Replaces OEM P/N 1J0-711-256 (1J0711256)
    Stainless FWD/AFT Steel Shift Cable Repair Block
    GruvenParts.com is proud to release this solid stainless fwd/aft cable shift repair block for cable shift VW vehicles. This part will quickly replace the weak forward end of the factory fwd/aft shift cable P/N 1H0711265 (1HO-711-265) where it connects to the transmission linkage. There is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken fwd/aft shift cable. And if your cable is not yet broken, throw 1 of these in the glove box and be prepared for the inevitable!
    This repair block repairs the FWD/AFT cable P/N 1H0711265 (1HO-711-265) common to most 02A cable shift MK3, MK4 Jettas, Golfs, TDI’s, Beetles, Passats, and Corrado VR6.
    Stainless SIDE/SIDE Steel Shift Cable Repair Block
    GruvenParts.com now also has solid stainless side/side cable shift repair blocks for cable shift VW vehicles. Once again, there is no need to source an entire shift cable mechanism (which is very hard to find, and also quite pricey) in the event of a broken shift cable. And if your cable is not yet broken, throw 1 of these in the glove box and be prepared for the inevitable!
    Add some indestructible hardware to the factory cable shift mechanism where it needs it most! Buy these parts together and save!!
  14. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    11-15-2012 09:12 AM #87
    Bump for existing and future Gruven Billet !
    www.GruvenParts.com
  15. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-10-2013 09:43 AM #89
  16. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-14-2013 02:04 PM #90
    bump for the best products for your ride
    www.GruvenParts.com
  17. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    01-31-2013 09:31 AM #91
    Billet VW/Audi VR6/V6/V8 Oil Filter Housings !
    Precision Machined Aluminum Oil Filter Housings For VW And Audi VR6/V6/V8 Engines !
    This one was worth the wait, folks! Never, but NEVER break a flimsy plastic oil filter housing again. Or deal with the unsightly leaks created by the cheaply made (yet expensive) plastic OEM housing cracking and deflecting. We made this one the way VW and Audi should have – from A SOLID BLOCK OF ALUMINUM, by God!
    First, we start with a massive chunk of Aircraft Grade 6061-T6511 Aluminum. The section is delicately placed on one of our special CNC machining centers and precision cut to EXACTLY match the OEM plastic housing. The metal gods (well, in this case, one of our highly talented CNC programmers) has programmed elaborate steps for the very time consuming and expensive operation of profiling the special buttress threads into the housing using the exact DIN spec thread cutting tool required for a perfect seal. It simply doesn’t get better than this!
    We also provide a proper threaded drain plug of the same size as your oil pan plug (use just 1 19mm socket for both!). Rather than some useless internal soft hex plug which easily strips, ours is a genuine Audi plug made from steel with an honest 19mm external hex. The plug comes with a contained sealing washer as well. And yes, we also provide USEABLE 36mm hex flats so you can easily remove the housing with a standard 36mm socket. Imagine that : You can simply drain the housing using its proper drain plug bolt that wont round off, and remove the housing using a proper 36mm socket that also wont round off. This could possibly make changing your oil fun again!
    This product is intended to replace VW/Audi Part Numbers 021-115-433A (021115433A) and 021-115-433B (021115433B) housings. Please check the OEM part number of your oil filter housing before ordering. You can do this easily by calling your dealer and giving them your VIN #. It will fit the following vehicles :
    VW Corrado (1992-1995 w/AAA VR6 engine)
    VW Golf and Jetta/Wagon (1993-2006 w/AAA and AFP VR6 engines)
    VW Passat (1992-1997 w/AAA VR6 engine)
    VW Touareg (2003-2007 w/3.2 and 3.6 V6 engines)
    VW Eurovan (1996-2004 w/AES V6 engine)
    Audi A8/S8 (2000-2003 w/4.2L AUX V8 engine)
    Audi Q7 (2007-2009 w/3.6L BHK V6 engine)
    Special Note At The End :
    Use oil filter part number 021-115-562 (021115562) or equivalent with our metal housing. If your parts department requires a vehicle type, tell them “1995 VW Golf GTI VR6”. This is the older, vastly superior cartridge filter with the metal end caps. VW, in their infinite cost savings wisdom, superseded it with a cheaper, cardboard end filter (021-115-562A). Please make sure to order filter 021-115-562 oil filter (or equivalent) as it is the superior filter for these engines, and will fit correctly with this housing. You can buy it from us using the drop down menu on the product page, or at any dealer or trusted auto parts store.
  18. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-04-2013 12:49 PM #92
    Billet VW/Audi VR6/V6/V8 Oil Filter Housings - Installed !
  19. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-11-2013 08:38 AM #93
    Monday bump
  20. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    02-19-2013 09:21 AM #94
  21. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-11-2013 11:37 AM #95
  22. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    03-19-2013 03:25 PM #96
    These are in stock
  23. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    04-23-2013 08:49 AM #97
  24. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-13-2013 10:28 AM #98
  25. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    05-21-2013 11:37 AM #99
    *** NEW PRODUCT RELEASE NOTICE ***
    GruvenParts.com is Building MK2/MK3 Billet Strut Caps !!
    MK4 coming soon, too !
    Here is another one you guys wanted and we're in process of building it -
    These parts will be machined from 6061-T651 and sold in sets of 2. They will have a machined finish (the red picture is just to see it against the CAD screen background), however we can also chrome plate, anodize, or powder coat in any color (please inquire via email). We can also handle "special" orders if you want a custom design (please inquire via email).
    These billet strut caps are intended to fit over the following OEM parts :
    1H0-412-319B (1H0412319B) Stop
    357-412-319B (357412329) Stop
    1H0-412-356A (1H0412356A) Stop
    357-412-411A (357412411A) Stop
    and replace the cap found on some MK3 4 cylinder models :
    1H0-412-329 (1H)412329) Cap
    Our parts will be specially machined to accept the strut stop/cap on all MK2 and MK3 Golf, Jetta, Passat, Corrado, Cabrio, Cabriolet from 1985-1999.
    We'll also begin work on the MK4 versions as well, stay tuned!
    Please check the site under MK2 Engine and MK3 Engine sections soon, as we will update pics and add the product page soon.
  26. Banner Advertiser GruvenParts.com's Avatar
    Jul 31st, 2007
    Atlanta, GA
    Too many to list !
    06-02-2013 09:13 AM #100
    GruvenParts.com Pre-Order Page for MK2/MK3 Billet Strut Caps
    Billet MK2 / MK3 Strut Caps!
    MK2/MK3 Billet Strut Caps Pre-Order
    Please read the Pre-Order note at the end.
    GruvenParts.com is now machining billet strut caps made from 6061-T651 aircraft aluminum and sold in sets of 2. They will have a machined finish (the red picture is just to see it against the CAD screen background), however we can also chrome plate, anodize, or powder coat in any color (please inquire via email to paul@gruvenparts.com).
    Our parts are specially machined to accept the strut stop/cap on all MK2 and MK3 Golf, Jetta, Passat, Corrado, Cabrio, Cabriolet from 1985-1999.
    Pre-Order Note
    This is a Pre-Order, the parts will be completed by end of June 2013. We are filling orders now and will send these out on 1st come 1st serve basis. We will initially run 20 sets of these. If more people want them, we will machine a 2nd batch. Those who pre-order get theirs 1st.
