VWVortex.com - correct turbo size for 12v vr6?
    Results 1 to 15 of 15
    Thread: correct turbo size for 12v vr6?
    1. Member vex004's Avatar
      Jun 6th, 2006
      PA
      BJS / CAEB
      05-25-2010 11:48 AM #1
      I'm new to the FI world and currently looking at purchasing a garrett t3 60-1 turbo (.70 compressor housing and 0.82 a/r). I plan on using this turbo on my 12v vr6 with low boost (~8lbs boost) for a few months until I gather some more funds and install a head spacer with larger injectors and software to match. From what I understand the .82 a/r will keep torque low which is ideal for keeping the transmission in one piece but should yield good hp. Are my statements correct and is this a turbo a good match? How will this turbo handle low boost for the time being, any power estimates, spool times? Any recommendations/input would be greatly appreciated.
      Thanks,
      Jim
    2. Member Norwegian-VR6's Avatar
      Feb 6th, 2002
      Norway
      96 Golf VRT, 09 Vw Passat 4Motion 2.0TDI Highline
      05-25-2010 12:14 PM #2
      This is a cheap and good turbo. Full spool around 3600. 0.82 will defently work very well if you plan to run over 15 psi. Under 15 psi there is alot off others that will work good.
      1996 Golf MK3 GT35R 12V 02M Lugtronic Turbo. http://forums.vwvortex.com/showthrea...er-VR6-T/page4
      2009 Passat b6 2.0TDI 4Motion Highline
    3. Member BLSport's Avatar
      Dec 24th, 2005
      Lancaster, PA
      98 VW GTI VR6T, 04 Audi A4Q 1.8T, 05 Saabaru 9-2x Aero, 80 Camaro
      05-25-2010 12:22 PM #3
      Quote Originally Posted by vex004 View Post
      What are you planning to do about fueling/software in the interim at ~8 PSI boost?
      VR6T + Pre/Post-Compressor ΔHvap Intercooling =
      Less Low, More Go
      YouTube
      Instagram
    4. Member vex004's Avatar
      Jun 6th, 2006
      PA
      BJS / CAEB
      05-25-2010 12:30 PM #4
      Quote Originally Posted by BLSport View Post
      30lb red top with c2 stage 1 obd2
    5. Member vex004's Avatar
      Jun 6th, 2006
      PA
      BJS / CAEB
      05-25-2010 12:44 PM #5
      Quote Originally Posted by Norwegian-VR6 View Post
      do you have power figures for about 8lbs? and upwards of 15lbs?
    6. Member BLSport's Avatar
      Dec 24th, 2005
      Lancaster, PA
      05-25-2010 01:01 PM #6
      That'll do it.
      The Garrett 60-1 is a nicely priced, good all-around turbo for the 12V VR6; capable enough power producer up top, but still responsive down low. The .82 A/R turbine housing should help smooth boost onset a bit and reduce drivetrain shock somewhat, and help to keep things from getting too choked up in the upper rev range.
      For your later upgrade, are you considering C2 stage 2 or 3 software, or something else? What are your ultimate power goals?
      Less Low, More Go
      YouTube
      Instagram
    7. Member dasbeast3.0's Avatar
      Aug 14th, 2007
      Grizzly bear
      05-25-2010 11:35 PM #7
      I use that exact turbo, it suits the vr nicely imo. A very capable/ well priced turbo. Couple it with a 3.38 r/p and short runner, its a sweet setup for 15psi & up. I run between 10 and 22 psi, low boost it lacks a bit (in part due to my lower gearing and short runner length)..higher boost is where it shines. Using the newest version of c2 software (42#), and EBC with adjustable duty, it improved spool up and overall performance considerably. Def a good all around turbo.
    8. Member dub_slug's Avatar
      May 12th, 2008
      Northern Colorado
      dirty jap slut
      05-25-2010 11:40 PM #8
      I liked my 60-1 but it was surging badly above 18psi. I also had the .63turbine housing so you should be fine You will really like it alot, its perfect for driveability and tons of fun
    9. Member vex004's Avatar
      Jun 6th, 2006
      PA
      BJS / CAEB
      05-27-2010 01:07 AM #9
      That'll do it.
      Looking to use C2 with 42lb injectors and lowered compression.. I suppose 400 wheel would be ideal
    10. Banned slcturbo's Avatar
      Apr 19th, 2010
      93' Corrado SLC turbo, 96' Volvo 854 R
      05-27-2010 11:15 AM #10
      What exhaust manifold/downpipe will you be using?
      If it's ATP go full T4 60 trim or 60-1. Go .69 exhaust housing for street/strip, .81 more for strip.
      For Kinetic Stuff go t3/t4 60 trim or 60-1. .82 housing.
      I was advised by multiple people that know to go full t4 P-trim wheel for ~400whp and a more "linear" spool as I want my trans to last vs. the smaller t3 housing and stage 3 wheel. Made sense to me and 2 years later all my gears still have all their teeth.
    11. Member vex004's Avatar
      Jun 6th, 2006
      PA
      BJS / CAEB
      05-30-2010 01:16 PM #11
      Quote Originally Posted by slcturbo View Post
      I will be using the atp exhaust mani and just picked up a T3-60-1, A/R .82
    12. Banned slcturbo's Avatar
      Apr 19th, 2010
      05-30-2010 02:40 PM #12
      If you want a true bolt on and were going to run an ATP mani then you should have gotten a full T4 on center turbo. ATP mani and downpipe are for a T4, not a T3.
      I would make it easy on yourself and get a Kinetic manifold and downpipe or get a T4 turbo and run the ATP stuff.
    13. Member vex004's Avatar
      Jun 6th, 2006
      PA
      BJS / CAEB
      05-31-2010 11:45 PM #13
      ..crap
      I was planning on purchasing the atp downpipe.. I'm welding up the intake piping and intercooler piping so it looks like ill be making a downpipe as well now.. What do you mean by 'on center'? I guess I should have done more research before ordering parts.
      Thanks for the valuable input!
      -Jim
    14. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      06-15-2010 06:26 PM #14
      whats the deal with on center turbos, i was told the one i have is on center but i have no idea what they were refering to.
    15. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, Mk4 VR, A3 VR, B6 3.6 4Motion, B5 1.8T
      06-15-2010 07:20 PM #15
      On-center vs. tangential... the means of attachment of the turbine flange to the manifold. The tangential is offset whereas the on-center is symmetrical.
      As advised above in other posts, for a true bolt-on no mods required such as SRI you will want on-center when used in conjunction with an ATP manifold or you WILL have clearance issues with your stock upper intake manifold/throttle body.
