Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 106 to 140 of 189
Thread: £UK Storm Rocco Project
  1. Member d-bot's Avatar
    Sep 6th, 2004
    Par 5 from the Space Needle, PNW.
    80 Storm 20vSC Syncro, 93 Corrado VR6
    02-12-2012 11:05 PM #106
    Quote Originally Posted by syracusegli View Post
    damn, i wish you were closer. i need someone to fab isht with, your pretty good
    how many hours you got in this so far?
    Move to D-town and we'll do it up! I really have no clue how many hours, but if I had to guess, but it's probably a bunch. Then again, it feels like everything has progressing smoothly.
    So a bit of a general update. The project focus has changed to be in stages. It will allow me to actually drive it an enjoy it and use the off-season to do larger parts of the project. This round is the syncro, suspension and a motor swap. Some things like the suspension, will be permanent, while others, such as the drivetrain will be temporary. At this point it needs to come together so I'm hoping to have it together for this summer. I have about two more weeks to finish up all the metal work before I seal up seams, paint and underbody coat. March, when the car is back at my place, I will probably be assembling the transmission back together, do any finish welding on removable parts for the suspension and start wiring up the OE harness back in place. April, interior, more wiring and probably by then it will be time to dump the temporary motor in (stock 1.8t).
    Today I went to the junkyard to grab a filler neck to replace my rusty filler tip one that wasn't going to work. The part from the yard was actually in good condition and I was happy to get it back and finish off the filler tube. After cutting it off and comparing it to the original , they were different. The original used a plastic trim piece around the filler while the US spec junk yard one fit right inside the stock body work.
    Plastic trim on left, original rusty one in the middle and the junk yard replacement on right.
    original with rust pores left , junk yard part right
    Being stubborn, I decided that it had to keep that plastic trim as it came with. The solution was to trim off the cancer and keep just the very edge of the original filler tube, where all the good metal was, and really the only part that was important.
    Then found a tube the same diameter in which that the plastic trim would slip over, and welded them together...
    ...and smoothed them out.
    then filled the low spots and finish blend the part. Just like stock.
    Fitted and finalized plus a bonus picture for motivation.
    tomorrow is e-brake day
  2. Member Meltkamp's Avatar
    Oct 10th, 2008
    Abilene, Tx
    1979 Scirocco 16v, 89 jetta Gli (wifes) 99 forester (wifes)
    02-12-2012 11:30 PM #107
    this is amazing! look forward to every update. keep up the good work
    Quote Originally Posted by OOOO-A3 View Post
    Because **** trunks.
    Hatch
    [IOO==o==OOI]
  3. Member scirocco*joe's Avatar
    Feb 23rd, 2002
    Roughly
    things broken
    02-13-2012 09:32 PM #108
    Quote Originally Posted by d-bot View Post
    These 5 pictures say it all.
    One motherf*cking professional thread right here with classic craftsmanship. Makes my Heron build feel like bought, not built!
    Between you and Murray, the Matts are killin' it.
    Keep up the solid work.
    Quote Originally Posted by sin bar View Post
    i don't even understand everything that's going on. i'm simply impressed.
    Philadelphia, PA
    1981 Scirocco
    2010 Sportwagen TDI
  4. Member der hare's Avatar
    Oct 27th, 2001
    Santa Monica
    02-16-2012 12:30 AM #109
    Wow. Just wow. Nice work dude
    Rando
    DCI - what part of fück off do you not understand?
    RIP Moses
  5. Member roccodingo's Avatar
    Apr 25th, 2004
    Perth, Australia
    4 x Scirocco 1, 3 x Golf 1, 1 x cabrio 1
    02-16-2012 07:19 AM #110
    Matt, filler neck plastic trim / seal thing is still available new.
    Looking good man
    If it aint a Mk1 then it's a donor....
    Brownrocco resto thread....http://www.vwwatercooled.org.au/f55/...esto-2339.html
    Cabrio repair thread......http://www.vwwatercooled.org.au/f55/...irs-21212.html
  6. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    '50 Dodge Pilot-House, '52 DKW 125W, '76 Rabbit Ocean Bleu X2,EA Cabriolet,'77 Scirocco
    02-16-2012 08:06 AM #111
    fab porn-nomnomnom
  7. Member tobiwonkonobi's Avatar
    Nov 17th, 2002
    PVD
    mk1 coupe mk2 coupe
    02-16-2012 09:32 AM #112
    VW Fiends German Speed Society Banchwerks PVW 4/08 & 7/12
    Nothing leaves Stock Creep Customz Brokestatus Get Low Unix Performance Gengstout
  8. Member rabbito's Avatar
    Jul 26th, 2006
    Reading, PA
    "77 Bali '80 "rusty westy"
    02-16-2012 09:34 AM #113
    How did I miss this? Awesome work!
  9. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    02-17-2012 02:37 PM #114
    welds ,look awsome, what are you using to weld? mig, tig, ...?
    Old sciroccos never die....they just go faster....sometimes.......
    www.ziggituning.com
    My Project...
  10. Member d-bot's Avatar
    Sep 6th, 2004
    02-18-2012 09:41 AM #115
    Quote Originally Posted by tobiwonkonobi View Post
    Thanks thanks. Speaking of metal fab, have you talked to Jodi recently?
    Quote Originally Posted by rabbito View Post
    Too busy working on the rusty one? Haven't seen you in a while, hope you guys are doing good over there!
    Quote Originally Posted by ziggirocco View Post
    Depends on the material and what it is. The filler is stainless so that was TIG and anything done to the body is MIG. Suspension components are mild steel but will be TIG.
    I've been making some decent progress this week and checking off the to-do list. It's getting close for wrapping this part of fabrication up. Will be updating this thread tomorrow with pictures.
  11. Member d-bot's Avatar
    Sep 6th, 2004
    02-21-2012 11:28 AM #116
    Picture update, I did work. Ebrake complete, though not sure why I didn't get final pictures, welded stuff, notched the front, then did more welding in the back. Going to finish up the back sheet metal this week.
    I like pictures, so here are a lot more pictures.
    bracket for hydro brake, non-drift car edition.
    fueled by
    and all wheel welding burnouts.
    Feb 1st, 2003
    Winston-Salem, NC
    81 Rocco x 2, 87 Rocco, 98 Jetta TDI, 01 Eurovan, 05 TDI wagon, 06 GLI, 10 Jetta wolfie, 13 A4Q
    02-21-2012 12:37 PM #117
    badass.
    mmmmmmmm.....local pub taps our one and only keg today. I imagine it will be empty tonight, and I will probably call off work tomorrow.
  13. Member Neptuno's Avatar
    Jul 16th, 2003
    DE 202 Concord Pike
    82 Scirocco~Rodolfo~85 Vanagon~El Guapo~
    02-21-2012 04:56 PM #118
    dirt "D" stylings...dude Matt you guys are really rocking this one....while I hold a newborn an type!!
    Quote Originally Posted by Mtl-Marc View Post
    The engine does not need oil, it runs on awesomeness.
    For Sale 14" Steel rims:For Sale 14" Steel rims:http://forums.vwvortex.com/showthread.php?6029120-FS-Great-Shape-14-quot-rims-12-hole-4x100-Steel-rims-with-tires-caps-and-beauty-rings-120
  14. Member d-bot's Avatar
    Sep 6th, 2004
    02-25-2012 07:20 PM #119
    Quote Originally Posted by Neptuno View Post
    Another?! Didn't know! Congrats Tony!
    So close with being done with this part, and ready to be done too ... I've been putting a bunch of time in sealing up any holes in the frame and adding extra support where the body was trimmed. Almost complete with that part and next week I will be painting and sealing all this metal work up.
    Grabbed a picture of the final ebrake set-up with the bracket.
    And somewhere in there the rear suspension is complete so they came out for final welding.
    Then trimmed in and broke up the new rear trunk floor.
    After that I called in Btek Fabrication out of retirement to spin up an adapter and get the front prop shaft together.
    So he spun up all the parts as a press fit. With some heat, they slipped right together and after cooling for a second, fit snug in an instant. Then to seal the deal I asked him to finish it off and TIG weld it together. It's been too long and he needed some practice parts and figure this was a great opportunity! But enough jokes, big thanks to him as he delivered like a boss! Pictures will tell the story.
    Fits perfectly right over the steering rack, and should be plenty of room for the 2.5" exhaust!
    Again, big thanks to Bryan for the help on the prop shaft parts!
    I have new hanger bearings coming on Tuesday, and after grafting in new mount locations in the tunnel, it will be time to seal this thing up!
    Stay tuned.
  15. Member syracusegli's Avatar
    Jan 21st, 2005
    syracuse, NY
    twin charged mk1 cabby
    02-25-2012 08:34 PM #120
    ive been following the thread but i just realized its RHD. where the hell did you find this car?
    Quote Originally Posted by 2mAn View Post
    go crash into a hybrid
    For all things Metal ---> www.roguemetalworks.com
  16. 02-26-2012 02:54 PM #121
    i just read through this entire thread WOW!
    this is an incredible build!!
    you've really talented
  17. Member d-bot's Avatar
    Sep 6th, 2004
    02-26-2012 06:07 PM #122
    About 4-6 years ago it was imported as a "parts car" along with a very very nice condition running sister. A fellow from VWoA owns the nice runner still as far as I know. Originally the person/company who imported this car was trying to part it out but thankfully not many items left the car. Only the euro bumpers sold. I saw it come up that summer for sale as whole or parting out and eventually disappeared from the 'tex. It changed hands one or two times until later that winter I tracked it down and purchased it in eastern PA. It's been sitting in my garage just waiting for the right time to start on it. I've been collecting parts and working on a few nice things for it that won't go on until later though.
    Quote Originally Posted by 35i 2000 View Post
    Thanks a lot, your feedback is appreciated! It's been really fun putting it together so far and making some of these ideas that have brewing for years since I picked it up, into a reality. I also have a good knowledge base backing me here for things that I have questions about, such as suspension geometry.
  18. Member
    Nov 9th, 2007
    Princeton, NJ
    02-26-2012 08:44 PM #123
    Matt,
    Nice work on the drive shaft! How will the rear parking brakes work? Do you plan to tee into the brake lines running from the master cylinder?
    1995 GLX TDI SYNCRO Build thread: http://forums.tdiclub.com/showthread.php?t=226323
    1978 MK1 Diesel 2door sunroof 121k miles
  19. Member d-bot's Avatar
    Sep 6th, 2004
    02-26-2012 09:14 PM #124
    Quote Originally Posted by ptrmzr View Post
    Matt,
    When the brake is not set it will act as a through system and the rears will work as normal. When the e-brake is applied (parking only, not a drift car!) the "feed" will close off as the cylinder is compressed, pushing only to the rear brakes. I just have to make sure to get the inlet and outlet correct when setting up the lines, but in theory this is how it will work. Cables would have been too difficult to route in this application so I went with this as an extra sense of security while parking including putting the car in gear.
  20. Member
    Nov 9th, 2007
    Princeton, NJ
    02-26-2012 09:26 PM #125
    That's pretty slick! I was lucky that my existing cables worked on my syncro project, but this should be the way all cars are set up! Where did you get the idea? Who makes the cylinder?
  21. Member ziggirocco's Avatar
    Dec 13th, 2010
    Montreal
    1987 16v scirocco
    02-26-2012 10:03 PM #126
    This is hella slick,
    beautiful work, would love to put somehting like this i, just not worth it in my applicatio. What handbrake and parts are those?
    www.ziggituning.com
    My Project...
  22. Member d-bot's Avatar
    Sep 6th, 2004
    02-26-2012 11:12 PM #127
    It's a full mk4 handle so it bolts right to the tunnel. Instead of a pull for a cable, the "pull" rod was flipped, shortened, bent and welded in order to push the Girling cylinder which has a threaded in and out for the hard lines.
  23. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    02-27-2012 12:10 PM #128
    Excellent work Matt!
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  24. 02-28-2012 02:23 PM #129
    the attention to detail with this build is staggering.
    congratulations on what you've managed so far, and keep those updates coming!!!
    do you have a date in your head of when you expect this project to be roadworthy?
    VAGKraft and Berlin Klassik are 2 local shows that you really should try to fit into your schedule, if you haven't before. they're both quality VAG events, and i'll be at both shows with pimp.
    i want to make sure that when i see the storm coming, it will be from pimp's driver seat.
  25. Member 81type53's Avatar
    Jun 2nd, 2008
    n.y.
    81 roc.79 911sc and a old man Subaru
    02-28-2012 06:34 PM #130
    So sweet. Have been lurking this. Nice fab work. Cant wait for the finished product.
    Bought it!!!!! That's why it runs you jerkies!!!!
  26. Member DubbinMkII's Avatar
    Jul 8th, 2002
    Lake Orion, MI
    81 Rocco.....
    02-28-2012 08:07 PM #131
    **** me. I wish I had the means to take on something like this. Huge props on the build. Can't wait to see her in person when she's done.
    Scrape, scrape, boom, hissssssss.........
  27. Member MickR's Avatar
    Jan 27th, 2011
    Baltimore, Meowyland
    1977 Scirocco, Protege 5, Mobylette
    02-29-2012 08:09 AM #132
    Wow, great stuff. In for more.
  28. Member d-bot's Avatar
    Sep 6th, 2004
    02-29-2012 11:21 PM #133
    Post enhanced with free VIP posting status.
  29. Member California 16v's Avatar
    Jul 20th, 2008
    Gulf Coast of Florida
    2 Sciroccos with 16v's in them, both from California : 1978 & 1988
    03-01-2012 01:16 AM #134
    you've done a great job restoring/improving this RHD mk1 Scirocco so far
    I for one look forward to seeing more progress on this project
    Pura Vida
    Surf to Surf Tomorrow
  30. Member d-bot's Avatar
    Sep 6th, 2004
    03-01-2012 09:04 PM #135
    Quote Originally Posted by MickR View Post
    Quote Originally Posted by DubbinMkII View Post
    thanks guys
    Quote Originally Posted by the_mad_bastard View Post
    I've been to June Jitterbug a few times back around 2007 year. I always enjoy the Canadian shows because they have a bit different flavor than what is usually here in the states. I'm close too, obviously and the last few years a few of us have been talking about getting to VAGcraft but for some reason never make it. This year I will try extra hard to get there, as long as the car is driving!
    Quote Originally Posted by California 16v View Post
    Not sure how much "restoration" it's getting right now, more like a drivetrain swap, but thanks!
    The final push. As usual, many photos.
    Blasted the prop and added new modded E30 hanger bearings. Coating to come.
    Then it was time to hang it all and add the tabs in the tunnel.
    Officially AWD!!!
    Out everything came and it was paint time. After some more unglamorous grinding, cutting and smoothing it was time for paint.
    etch primed, glued and tacked in the trunk floor, then seam sealed.
    weight in the rear while the glue dries. This will get sealed and painted tomorrow along with the rest of the tunnel on the interior.
    Underneath received the finish coating treatments. Will get pictures of the products I used tomorrow.
    Good to be about done with this part!
  31. Member syracusegli's Avatar
    Jan 21st, 2005
    syracuse, NY
    03-01-2012 09:17 PM #136
    freckin sweet !
  32. Member
    Feb 1st, 2003
    Winston-Salem, NC
    03-01-2012 09:26 PM #137
    what's on the bottom of your trans?
  33. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    03-01-2012 10:09 PM #138
    didn't get a chance to check aback this thread. Was going to pick down the passat...do I still need to ?
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  34. Member Meltkamp's Avatar
    Oct 10th, 2008
    Abilene, Tx
    03-01-2012 10:10 PM #139
    such an amazing build! cant wait to see this done
    Hatch
    [IOO==o==OOI]
  35. Member d-bot's Avatar
    Sep 6th, 2004
    03-01-2012 10:21 PM #140
    Quote Originally Posted by veedubtek View Post
    Beer label sticker to cover the open hole in the trans. I have a few rolls when one of my favorite local brew places went out of business, but luckily they re-opened a year later under a new name. If you ever see it, buy it.
    http://www.millkingit.com/ or I can ship you some!
    Quote Originally Posted by INA View Post
    Nope, got it sorted out. Deadlines man! Thanks anyways.
