VWVortex.com - e brake adjustment
    Results 1 to 8 of 8
    Thread: e brake adjustment
    1. Member 1.8tjettamk4's Avatar
      May 11th, 2010
      NE PA
      2001 VW Jetta 1.8t Wolfsburg Edition
      05-26-2010 09:00 PM #1
      i have a 2001 jetta 1.8t and the e brake doesn't catch until like the very top how can i adjust it to make it tighter?
    2. Member GTijoejoe's Avatar
      Oct 5th, 2001
      '06 Evo Mr, '15 CRV Touring, '16 Civic Touring
      05-26-2010 09:41 PM #2
      Most likely under the console behind the hand brake lever there is an adjuster.
      A good general adjustment is to set the hand brake @ 1-2 clicks and and tighten the equalizer adjustment until the park brakes start to drag (lift the vehicle up off the ground). This will ensure no dragging when you release the brake...
      2.0T+034efi+meth = 300+whp = RIP
      Quote Originally Posted by Ryukein View Post
      Everyone always praises function over form until the form is something that they don't like
      FS: 2015 Honda CRV Touring
      May 20th, 2009
      Cookeville TN
      02 & 03 Jetta, 92 Cabriolet, 98 Beetle
      06-05-2010 09:28 AM #3
      Not to hi-jack the thread but I have a similiar problem. My brake doesen't catch at all. The cables to the rear wheels are hooked up but I can pull them out some. How do I get to where they are connected to the brake handle? Do I have to take the console out and if so how do I do that? Is there one cable from the handle or two? The cables seem to run between the floor and the heat shield over the exhaust. BTW, my Jetta is a 2003 2.0L
    4. Member GTijoejoe's Avatar
      Oct 5th, 2001
      06-05-2010 12:58 PM #4
      There should be two cables going to your hand brake lever... I don't know exactly how to remove a MKIV, but if it is similar to a MKIII there should be some places between the seats on the side of the console which can be removed and uncover fastening hardware.. keep your eye's open, it shouldn't be that difficult.
      Keep in mind if your hand brake adjustment doesn't get them tight, than you'll need to replace your wires (they have stretched.)
      May 20th, 2009
      Cookeville TN
      06-05-2010 07:37 PM #5
      Thanks for the info. I will hopefulle be checking the cables early this week. You do pull the cables out from the bottom right? Have a good one.
    6. Member GTijoejoe's Avatar
      Oct 5th, 2001
      06-06-2010 02:56 PM #6
      out from the bottom? to remove, yet.
      May 20th, 2009
      Cookeville TN
      06-08-2010 05:55 PM #7
      I found the problem, the cables were off the adjustment part. Thanks for all the help
    8. n00b
      Jun 14th, 2010
      Ajax, ON
      2001 VW Jetta 1.8T- Wolfsburg Edition
      06-15-2010 12:29 PM #8
      How do you go about removing the e-brake housing in the center console to make adjustments?
      I attempted it last with no prior knowledge and found 2 screws on each side of the console, as well 2 screws
      under the glove box, and steering wheel (revealing the gear box).
      I cant seem to get past this. The screws I took out, loosen the housing, But I still cannot remove.
