Page 2 of 2 FirstFirst 1 2
Results 36 to 51 of 51
Thread: INA : Aluminum Oil filter housing & Mocal Oil Cooler Conversion Kit
  1. 11-02-2010 02:28 AM #36
    Quote Originally Posted by IMAN973 View Post
    Sam supplied me with the head flange and cast runners. I made the rest of the mani using half round extrusion and cncd valocity stacks.
    The placement of the throttle body is very common in the racing world. If i feel there is a problem i can always do what ed at ffe did and add some aluminum pipe to the plenum to change the tb orientation.
    Looks good
    Maybe you should talk Issam into taking it to production.
    As for the TB placement, it has been mentioned before it's a pretty common position for aftermarket manifolds, but there must have been a reason VW put it in the middle in the first place, and i'm guessing it has to do with equal flow to all cylinders and the use of the flaps...
    I always like to impoove on the OEM part and not change it completely.It takes away much of the guess work when something just doesn't work as it was supposed to.
  2. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    11-02-2010 10:54 AM #37
    they probably put it in the middle for fitment reasons. lol
    idk about equal flow as after seafoaming, id scope my valves sometimes and numbers 2 and 3 valves would be soaked, but numbers 1 and 4 would more often than not have nothing on them that looked even remotely helpful. idk though as I never pull the mani to do a full inspection until we just went and cleaned the valves by hand.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  3. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    12-16-2010 07:14 PM #38
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  4. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    02-23-2011 09:24 PM #39
    All PM's Replied to. Thanks for the support!
    Email | Facebook
  5. Banner Advertiser SALES@RSWORX's Avatar
    Jun 28th, 2009
    Central NJ
    01.5 Audi Avant S4, AP2 S2000, TJ on 35s
    03-02-2011 02:41 PM #40
    I think the new b7 needs this !
    Redline Speed Worx
    APR|ADV.1|AQUAMIST|BBS|SOUTH BEND CLUTCH|FERREA|HRE|KW|UNITED MOTORSPORT|MAHLE|MILLTEK|PELOQUIN|SSP|STOPTECH
    www.RedlineSpeedWorx.com
  6. Member IMAN973's Avatar
    Jun 1st, 2006
    Big Turbo Land NJ
    08 2.1L Fsi 67'd SFWD Gti, mk2 67'd VRT Jetta
    03-02-2011 03:29 PM #41
    Quote Originally Posted by Pat@RedlineSpeedWorx View Post
    Couldn't hurt
  7. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    08 FSI SFWD Drag Car
    04-13-2011 10:03 AM #42
    A birdy told me your selling it already
    Email SALES | Facebook Connect
    Performance through Design.....
  8. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    04-18-2011 01:11 AM #43
    All pms replied
  9. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    05-23-2011 12:13 AM #44
  10. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    07-26-2011 09:19 PM #45
    Hello Everyone!
    Issam is on his honeymoon and will be back shortly. All orders placed will be processed upon his return. If you're checking the status of an already placed order, please send us an email at iabed@inaengineering.com and he will get back to you as soon as he can. If anyone has any product inquiries or tech questions, as always feel free to pm me.
    Thanks
    Isaac
  11. 11-11-2011 06:00 PM #46
    Quote Originally Posted by INA View Post
    TSI kits in stock too!
    You guys are prolly the only ones that make this kit and definetly something I need. The local VW shop here in Socal already has a big order in with you guys for forged rods and pistons since the engine is coming apart to fix a leaky head gasket likely from running too hot at my last track event.
    Stock radiator handling all the cooling for both a Ko4'd engine plus a hot DSG transmission from shifting up and down with hard laps on the race track doesn't end very nicely.
    I'm gonna ask them to look into adding this into the order
    Does this still use the OEM oil filter for the TSI motor? does it also allow for use to run an oil temp and oil pressure gauge? Does it also have the parts needed to block off the factory oil heat exchanger from the radiator?
  12. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    11-11-2011 06:04 PM #47
    Quote Originally Posted by pandavw86 View Post
    You would still use the factory heat exchanger if you wish (as it is integrated with the water pump set up so unless you completely block it off , it is going to stay there).
    You will use a 719/30 Oil Filter from a 1.8T 06A motor. We supply them with the kit. If you wish to run an oil temp or oil pressure gauge we can supply a "T" fitting that you screw into your oil filter housing and from there what you do with the additional tap is up to you.
    Check your PM.
    Email | Facebook
  13. Member IMAN973's Avatar
    Jun 1st, 2006
    Big Turbo Land NJ
    11-13-2011 10:37 PM #48
  14. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    11-24-2011 02:50 PM #49
    Happy Thanksgiving
    From all of us here at INA Engineering
  15. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    12-21-2011 07:50 PM #50
    Our Christmas sales are still going on!!!
  16. Forum Sponsor Sales@INA's Avatar
    Dec 30th, 2007
    NNJ
    08-24-2012 11:55 AM #51
