VWVortex.com - MK4 1.8t Exhaust Manifold Gasket
    Results 1 to 11 of 11
    Thread: MK4 1.8t Exhaust Manifold Gasket
      Apr 13th, 2009
      Paramus NJ
      06-01-2010 08:54 PM #1
      Hey i was wondering if anyone had some tips of replacing my exhaust manifold gasket? a DIY would be greatly appreciated. thanks
    2. 06-01-2010 10:04 PM #2
      Since it has two completely difference gaskets, with one being extremely easy and the other being a pain in the ass, you may want to clarify.
      Road Farmin'
      Apr 13th, 2009
      Paramus NJ
      06-01-2010 11:15 PM #3
      i need the Manifold to Block gasket replaced, but i would also prefer the turbo to manifold aswell incase its not the block to manifold. thx
    4. 06-02-2010 10:10 AM #4
      I would really make sure you need a block/ex. mani gasket before replacing it, as it's a pain in the ass. Not to mention, they don't fail very often. The ex mani/turbo gasket is prone to failure and bolts loosening.
      Did you Seafoam to confirm where the leak is coming from?
      Road Farmin'
      Apr 13th, 2009
      Paramus NJ
      06-02-2010 04:58 PM #5
      i bought a manifold to block gasket and turbo to manifold gasket from the dealer like 30 mins ago. i did not seafoam my engine, i didnt think about doing that :/
    6. 06-02-2010 05:05 PM #6
      Quote Originally Posted by got dubbz View Post
      It's no fun task replacing the mani/head gasket. What made you decide to replace these gaskets?
      Road Farmin'
      Apr 13th, 2009
      Paramus NJ
      06-02-2010 05:10 PM #7
      well my car has a fart kinda sound, i thought at first it was a downpipe gasket, i replaced it and it got a little quitter, but the fart noise was still there, and its right in the region of the mani/head gasket, i cant say its from there 100% but sounds like it, idk where else it would be
    8. Member halchka99's Avatar
      Apr 18th, 2002
      Porter Ranch
      Evo IX MR |17 Porsche Macan S | 17 Mercedes C43 AMG
      06-02-2010 05:21 PM #8
      its probably your turbo to manifold gasket. check that first
      Apr 13th, 2009
      Paramus NJ
      06-02-2010 05:23 PM #9
      yea im going to do turbo to mani gasket first, test it out, if that solves the problem then thats that and im a happy man. ill be checking on here every 30 mins -1hr for advice and what not, gunna go get started on the car now, thx for all your help thus far guys.
    10. 06-02-2010 05:40 PM #10
      Even easier, you might want to just check to see if there is a bolt or two loose on the mani/turbo connection.
      Road Farmin'
    11. Member
      Apr 13th, 2009
      Paramus NJ
      06-02-2010 07:09 PM #11
      ok boys i found the issue.... my manifold is crack into two pieces. more towards the passenger side. its cracked from the top to the bottom. the crack is right on 2 or 3 bolts, didnt get a better look. i just saw a huge crack, crawled out under my car and straight up just got out. thx for the help guys.
