watching this one
looks great![]()
#36
SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
#38
keep your name it makes things easier to follow. I no longer own a G60 but I'm still G60ING. Maybe I should be TDIing
Thinking about a TDI swap? Review the TDI swap directory
My AHU-TDI Corrado's Conversion to European Spec AFN-VNT
#39
old update
I placed the syncro coilovers on the rear trailing arm. This is a photo of the coilovers at the highest level
If you haven't noticed the rear breaks are eurospec big break kit. That now have to go
#41
#42
#43
did you not see the pic with the 2 rears in comparsion
#45
update
most people have used the rear passat axles and cut it 10mm to fit the rear. But I only had the haldex axles from the TT. I was told that these solid axles cannot be cut short because VW heat treats them. So the machine shop made shorter shafts from me with a set of hollow front axles.
These will be my spare set. DSS will make a custom set for this application capable to hold 500AWD
#46
I have never messed with them, but I am going out on a limb to say that this sounds suspect to me. All VW axles are heat treated at the spline ends. Even if the entire axle was heat treated, I am not sure why that would prevent you from shortening. Might prevent you from being able to cut easily on a lathe, but nothing a fiber cut of wheel wouldn't be able to do. Then make a proper splice with a machined press fit insert then weld. Perhaps I am missing something.
#47
No, your arent S....I was also understood that all the OE axles can be shortened too.....
Hanz (my machinist wizard) said he just needs to see the axles/prop shaft, and stated "most likely yes".
I guess it has to do with the capabilities of the machine shop/machinist.
BUT...DSS axles arent bad either and I hear they have done a few of these awd sets.
VRT are you plus suspension? or G60? If you stated elswhere I apologize for not finding it...
#48
The hollow front sets can be done but the solid rears cannot. DDS said the same thing. They will make a new set not cut my old set.
I am + suspension
#49
rear arms are plus as well?
#50
they are passat arms. Not sure what they are considered
#52
I haven't forgotten about this project just been trying to get some of the odd parts together for conversion.
Had these made for the rear cross beam
Taken the idea from Phatvr6 build thread
#53
Have you fitted the Rallye rear pan yet? If so any pics? I'm stuck on one at the moment because the Corrado frame rails are narrower than the Golf![]()
Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
#54
No I haven't started but here is a link to a old thread that should help
http://forums.vwvortex.com/showthread.php?2086592
#55
Cool thanks. I haven't been able to find that thread since the great Zeroforum explosion
That actually shows the frame rails where I've got stuck so I might be able to figure it out now![]()
#56
I did some work on the car but forgot to take some pics. I did take a few pics of the bushings that I pressed into the rear beam
#58
LOL I'm on the slow progress train.
My car is 500KM away from me so I manage to go up to see it on the weekends when I can
#60
here in Canada we don't use turtles. We use baby seals.
I have 300k on my 2003 jetta from all the traveling I do.
#61
#62
I have my bat
#63
Corrado VS. Rice Burner
"Corrado Wins"
I get a buzz out of the combination of design and sport. Adrian Newey
#64
I have made arrangements to have the rear section cut out and the rear ralley floor wleded in. dated for Aug 1![]()
#65
#66
#67
Oh snap... I meant Oct 1![]()
#68
that was a month ago
"Corrado Wins"
#69
i'll get it right
#70
