VWVortex.com - Sudden loss of power for 5-10 seconds on 1.8t
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 79
    Thread: Sudden loss of power for 5-10 seconds on 1.8t
    1. 06-10-2010 02:52 PM #1
      I know this thread sucks, but it's a common issue and I haven't been able to find a thread with any answer.
      Recently my 1.8t GTI has been having an occasional and sporadic total loss of power while on the freeway. Something gives out for 5-10 seconds, all power is lost, I will downshift, attempt to pull over to the side, then it will kick back in and run normally. This is the 3rd time this has happened...
      I've heard others having this problem. Is it maybe a fuel pump or boost leak issue? What should I check?
    2. n00b
      Mar 12th, 2009
      Fresno Ca
      2003 jetta GLX/1998 VW Jetta Wolfsburg Edition
      07-11-2010 03:52 PM #2
      I just recently had the same thing happen to me today on my 2003 jetta glx vr6 automatic. I see no one here has replied with a possible problem or solution. so if you come across one, please let me know. I am assuming this will happen again in the near future and would like to nip it in the bud. Thanks.
      Jul 2nd, 2002
      Orlando-ish
      2011 Hyundai Sonata GLS, 2002.5 Jetta 1.8T (gone)
      07-11-2010 03:55 PM #3
      So, does the engine completely die? i.e. RPMs go to 0 and you have to re-start. Or, is it just loss of acceleration and engine runs weird for that time? If it's still running, but badly, could be a coil pack going out.
    4. Member
      Jun 26th, 2010
      SL,UT
      00' GLX VR6 GTI (rip) 90' Golf ABA <3
      07-11-2010 03:55 PM #4
      The same thing used to happen in my vr6...the car was wrecked before i ever found out the problem...
    5. Junior Member
      Jul 20th, 2003
      2003 20th AE GTI, 2013 Passat TDI SEL
      07-29-2010 03:18 PM #5
      i've been having this same problem too. no solution discovered yet. anybody?
    6. n00b SaintMcManus215's Avatar
      Jul 29th, 2010
      Philadelphia
      2003 Volkswagen GTi 2.8L 24V VR6
      07-29-2010 05:21 PM #6
      I know when I hit 136 mph on the turnpike in my VR6, the governor kicks in and I lose all power!
      SaintMcManus215
      2003 VW GTi 2.8L 24V VR6
      AEM Cold Air
    7. Member dogdrive's Avatar
      Oct 19th, 2005
      Cali STRONG!
      2009 Volkswagen CC, 2011 Honda CR-V, 2008 Benz W211 E280, 2015 Benz W205 C300, 2016 Mazda CX-5
      07-29-2010 07:23 PM #7
      it has happened to my GTI 1.8T as well.
      I'm interested to find what's up.
    8. Banned
      Apr 25th, 2010
      Middlesex County, NJ
      mk4 jetta
      07-29-2010 07:38 PM #8
      if the engine completely loses power (rpms to 0), then you have a serious problem.
      if your engine just kinda hits a wall, but still cruises and your rpms stay up, then it could be a bad coil misfire on one of your cylinders. if it happens again, see if you check engine light is blinking. same **** happened to my 03 1.8t last week and sure enough cylinder one misfired. call a VW dealership and see if your car has gone under recall yet. theres one for coil packs and sunroof drain. just made an appt at my dealer for the new coils
    9. Member 99Golf20's Avatar
      Oct 3rd, 2004
      Bel Air MD
      99 mk4 golf 2.0
      07-29-2010 07:39 PM #9
      You know how I know you're a f@g?
      Quote Originally Posted by SaintMcManus215 View Post
    10. Member zeroboy's Avatar
      Sep 3rd, 2005
      Audi
      02' S6 Atlas grey / 02' S6 Silver
      07-30-2010 06:45 PM #10
      Same here. Normal driving, minding my own business and *CLIK* gone. All electrical/ engine gone.
      It's happened 3 or 4 times in a year. Power is back in less than 2 seconds like it never happened.
      Hang on- actually last time it happened I did get the *STOP* in my MFA display. Then, right back to normal.
      I'm pretty good with VCDS and it threw NO codes. I've removed the battery and everything is *mint*.My 1.8t has 73k on it with no problems (except one heated mirror element).
      Whatever.. .. ..
    11. 08-15-2010 05:59 PM #11
      I have a 2004 Jetta 2.0 litre. I've had the same problem for over a year. The funny thing is, it only happens when I'm under a quarter tank. I've had it checked by two mechanics, including the dealership. They were been unable to discern the problem. On the dealership's suggestion, I had the plugs changed and the battery replaced, but it didn't make a difference (total of $400 dollars for nothing). My intuition tells me it must some sort of electronic sensing problem gone awry. But there are no error codes so the mechanics have been useless. (Can't do anything with out error codes.) Without throwing more money at the problem, the only thing I can do is keep it above a quarter tank. Argh!
    12. Junior Member
      Jul 20th, 2003
      08-16-2010 04:15 PM #12
      Quote Originally Posted by MilesDavis View Post
      I had the same problem and replaced my fuel pump about a month ago, and havent had any problems since. (crossing fingers) Before I replaced my fuel pump, I noticed that I was hearing some odd noises from where the fuel pump is located (under the rear seat). When I started my car and after I parked it, I would turn off my radio and listen carefully and would hear a not-so-constant pumping noise coming from the pump. Almost as if it were sputtering at times. I also would put my hand on the cover while idling and it was equally as sputtery and it did not give off a constant/consistent hum as I would expect from a pump. After replacement, I've noticed no more acceleration hesitation issues and no weird noises. I figured it would be cheaper to just replace the part (for $160 at mjmautohaus) than to take it to the dealer to have them run around in circles trying to misdiagnose things. Good luck.
    13. 01-03-2011 01:56 PM #13
      My girlfriends 2.0 is having the same issue. While on the freeway yesterday @~60mph the power all of a sudden just cut out. This is an auto btw. It was as if she let off the gas. It only lasted a second or two and I didnt really think much of it untill later that night when I was driving it and the same thing happened at 60 again. I gave it a substantial amount of throttle in the process and it seemed to correct itself faster. No CEL or any fuss from the engine. Idles perfect and smoothly. I threw it in neutral right after it happened to see if the idle was kaput but it was perfect. Very weird feeling. I suspect it could be the throttle position switch(not to sure what the actual name is, I come from BMW and ford, old ones, I'm used to throttle cables) the other thing I suspect is also the fuel pump, car only has 76,000 miles and there are no other running issues. Another thing to note however is the fuel was below a quarter tank.
    14. Awaiting Email Confirmation
      Dec 29th, 2008
      Erie, Pa / Motown
      ..a Volkswagen
      01-03-2011 02:22 PM #14
      ..that being said, if youre just losing power and the cars on maybe the traction control could be activating for some reason?
    15. 01-03-2011 09:03 PM #15
      My girlfriends car doesn't have traction control
    16. 01-03-2011 09:18 PM #16
      Clean ur MAF check ur plugs, check for leaks, change fuel filter. and is your clutch bad ?
    17. Member
      Apr 22nd, 2009
      570 stokin hoes in the poconos
      1966 Ragtop, 1989 s13 driftcar 1912 Willys 6 speed quattro manual, 07 GT3, 09 LP640, S54 swapped R1
      01-03-2011 11:23 PM #17
      bounce it off the rev limiter. should fix everything.
      I spooned eastcoaststeeze in dannybarones bed
    18. Member JoeRRR's Avatar
      Feb 24th, 2007
      Pottstown, PA
      05 GTI sold, 98 GLX RIP, 12 Jetta cost cutting edition, 09 Jetta (wife's)
      01-03-2011 11:29 PM #18
      same problem... only happens when im at an 1/8th tank or less. Car will just lose power, occasionally stall, but always starts right back up.
    19. Member jetta1226's Avatar
      Jul 1st, 2007
      Canterbury, CT
      01-03-2011 11:45 PM #19
      Fuel pumps. If you still have electrical power in the car and it's acting like that I'm going to assume it's from a loss of fuel. Fuel pump or the relay/fuse for it.
      BOO WORK HOORAY BEER
    20. 01-04-2011 01:14 AM #20
      Okay so this isn't a conning problem then. I was just wondering if there was a solution to a common problem. I will have to do further investigation and see if incant find anything. Thanks
    21. Member thtninjather's Avatar
      Feb 8th, 2010
      Fort Lauderdale, FL
      2001 Jetta Wagen 2.Slow
      01-04-2011 03:17 AM #21
      have you guys ever looked for a bad ground? fuel filter? clogged injectors? those can cause some of those problems that are "unexplainable"
    22. Member
      May 21st, 2010
      Lebanon IN
      05 GTI
      01-04-2011 03:58 AM #22
      Quote Originally Posted by JBr0th3rs View Post
      Hahaha actualy did that once because I was pissed, and my crackpipe exploded and I lost all my coolant, not to mention that I looked like a compleat jack wagon to whom ever was watching, this is ill advised
    23. 01-10-2011 12:47 PM #23
      So this happened again, it only happens when the fuel is low. I am going to check fuel pressure whenever i get a chance. What should it be at for the 2.0? The normal 40-45psi? Or is it different?
    24. Member DubRubNY's Avatar
      May 9th, 2010
      NYLI
      ht02 eulB zzaJ
      01-10-2011 12:53 PM #24
      I'm pretty sure VW uses a drive by wire accelerator, check if yours is disconnected. Its near the left of the intake mani on 1.8t. I had a problem similar, turned out the clip was broken and the connection kept coming loose.
      Quote Originally Posted by zippome View Post
      so who's dick to i have to suck to get some vortex respect?
      Rape The Scene
      Buy my BBS RS' PM me for info
    25. Semi-n00b FrauleinVW's Avatar
      Apr 4th, 2011
      California
      2003 VW Jetta 2.0L
      05-16-2011 12:36 AM #25
      I've been having the exact same problem with my 2.0 liter Jetta. I will be driving around a steady 65mph on the freeway and all of the sudden the engine loses power, it starts to slow down very gradually but pushing on the accelerator has no effect. Then a couple seconds later it's fine. It only happens when I've been going at 60mph speeds, the last time it occured I was under a quarter tank, but can't remember if I've been under a quarter tank every time it happened. Just replaced the fuel filter, spark plugs, water pump and it stll happens. While working on my car discovered that the crappy braided hose for the fuel pressure regulator had split in half, replaced with much better rubber hose hoping problem would stop, but no luck. Will try replacing fuel pump, that's been my gut feeling, but I might look into replacing coil pack since I know those have been an issue.
