#1
Not Available AnymoreI have a 99 A4 Avant 1.8TQ GIAC KO4 equipped with 5 speed manual transmission that I have recently rebuilt. Less than 1000 miles since rebuild. The body has 166K miles but the Engine has a different story. The color is Melange Metallic and has a clear CT title. This vehicle is made to be driven and be reliable. Vehicle has set the readiness code(Emissions). This A4 does not bog, hick-up or sputter like most 1.8t Audi's. No CEL, NO flashing ABS lights, nothing! Car boosts to 19-20 psi and holds 17 psi all day long. Everything works and there are no warning lights on of any kind. Below I will list what has been done and what needs to be finished and pictures in multiple posts below, over 30 pictures! KEEP SCROLLING DOWN!! . I am asking $5500 and the list below will explain why: PM me if interested. Any Questions or comments are appreciated.
Engine:
Freshly built AEB DBC (Large Port) w/ all new gaskets,head bolts, seals, etc... All OEM
Has a newer block with less than 50k painted with Por 15 engine paint( all parts have been repainted)
New OEM Timing Kit installed
New Serp belts( QTY 3)
New OEM Waterpump w/ Housing and new T.stat
034 Motorsports Intake spacer w/new hardware and gaskets
New OEM Powersteering Pump
Ice Cold A/C intact
New OEM oil pan and OEM oil pump
New OEM snub mount
ITG Panel Air Filter w/ Mod Housing
New Battery
New NGK colder plugs( Gap .028) Bolt down reliable coils
All new breather hoses and check valves
034 Motorsports Adjustable Fuel Pressure Regulator (set at 5 bar)
GIAC K04 software(chip) 235HP 265TQ ( also have stock chip) Horsepower is on stock setup( this may have more) Boosts 19-20PSI Holds 17PSI at top of RPM band
New XS Power K04 turbo with less then 1K miles
New 034 motorsports 3' test pipe w/ rear O2 sensor spacer
New OEM downpipe and OEM SS exhaust w/ less than 30K
New Forge splitter DV adjusted to 80 recirc/20 atmosphere( Sounds like a blow off valve)
New OEM N75 valve(C)
New Godspeed Front Mount intercooler
034 Fuel pressure Gauge in line with fuel feed hose
All new VAC. Hoses and anything else that engine needed was replaced
Body,Suspension, Chassis
Brand New Windshield (Installed 6/30/10)
ESC tuning bra
OEM sport suspension
New 12 pcs front control arm kit( ARMS, Sway Bar Links, Hardware))
New lower door moldings
New lower F and R bumper cover lips
New OEM Headlights w/ XENON 5000k system
New OEM Sport 17" wheels( The real thing, not reps)
Dunlop 9090 Sport tires 225-45-17 (4) 2 are new
The rest is stock and brakes are all over 75% and e-brake works great
INTERIOR
New OEM shift Knob
New armrest assembly with lid
New OEM floormats that match beltline trim
Glowshift Boost and Oil pressure Gauges"Electric sender"(can change colors)
New OEM concert radio w/CD changer controls and OEM subwoofer
Interior is in excellent shape and has hatch cargo cover
TRANSMISSION
New OEM clutch
NEW G50 Transmission Fluid
New Left and RIght transmission mounts
New RF Axle
New LF CV boot
NO wheel bearing issues
NOW FOR WHATS NEEDED
Front bumper cover has scratches( covered with BRA )
Rear wiper is deleted
Headlight washers were deleted and resevoir was removed(still have all parts)
Very slight tear in drivers seat( Replacing 6/10)
Right front fender has dent but paint intact
Remember: this vehicle is over ten yrs old. Expect cosmetic blemishes and scratches( no paint fade or rust of any kind.
OTHER THAN THAT EVERYTHING WORKS AS DESIGNED I have all orginal OEM parts that come with the purchase of this vehicle( OEM intercooler and hoses, breathers, Grills, Cat converter, OEM exhaust manifold, etc...)
UPDATE since Orginal Post Date
1) New Drivers Lower seat cover ordered(will install soon)
2) Center vent gauge bought(plan on installing Wide Band 02) Already have the gauge!
3) Reinstalled OEM Exhaust Manifold(tubular header blew the mani. to turbo gasket)
2008 VW GLI 2.0 TSI ( Revo Stage 2)
2003 Audi allroad 2.7T (Money Pit Green Unitronic Stage 2)
2007 Saturn Outlook( 8 Passenger Family Hauler)
(Too many past Audi's and VW's )
#2
#5
i'm in RI and very interested. where are you in CT? i'd like to come take a look.
#6
I'm in the NW corner of CT but the car is at my job(Audi dealer Watertown CT) more torward the center of CT. I'm working this Sat. and going out on the lake Sunday but next weekend I am free. PM if you have any questions. Thanks
#9
This car is a change in pace and insanely clean.
http://forums.vwvortex.com/showthrea......Florida-Car....
2001 Galactic Blue Wolfsburg. Clean, quick and in excellent shape. Trades considered.
http://forums.vwvortex.com/showthrea...5#post68066715
#11
Shown 034 Adj. Fuel pressure regulator. All new belts(3). Everything painted correctly.
Shown Boost gauge(prefer Blue during day and Red at night to match cluster)No malf. lights!
Yes, I took that Forge sticker off! It gave it at least 10HP more. LOL
Slight scuff marks on upper bumper cover from PO loading stuff. "Rec. re-spray for perfection"
#12
Sent another PM.
#13
Bump it up, but possibly a trade in the works!![]()
#14
Looks clean.
Check out my sig for possible trade...
Have more pics as well.
Thanks for your time.
Buy your bikes and skis here:
revolutioncycleandski.com
metalrev.com
#15
PM sent
#16
Hey guys, we might be able to work out a three-way trade. I hate the idea of doing all of the legwork and have nothing to show, but we could find a way.
Scotmbb107, you seem to be ready to trade for my car
natehack, you seem to want the Audi
And I would be quite content with the MKIV Jetta. It's not my first choice, but I can see some potential in the MKIV Jetta.
Meeting might be a mess, but it's still not out of the question. As I said in my PM, I'd find an Avant very useful and it is pretty much perfect for looking my age...but my wife has an MKIV GLI in the dark gray...and it would be pretty cool...(in a kind of lame way) to drive that look alike.
Anyway, if you guys are game...let's talk.
#17
This trading game is starting to be a mind game. So much to think about. I'm willing to drive about 5-6 hours from my location but that's about it. LOL. Every Vortexer w/ car that wants to trade makes me realize there are endless possibilities. I like the white MK3 in Florida which seems to need nothing, I like a VR6 Corrado down in Chicago because I've always wanted a Corrado, and I like the MK4 in Jersey with the VR6 and now the MK4 in Minnesota. LOL.
#18
Like I said, I'm dead-on ready to trade for your Avant. I'd love one, but if this guy wants the wagon, and you'd trade for mine...we'd all get to have something a bit different than where we started. The MKIV wouldn't be my ideal car...but potential is potential is potential...and I like potential a lot considering I've run out of things to add to mine before crossing over the line of classy taste.
I was just suggesting another possible solution.
#19
Left side with 5000k HID's on
Another front shot with lights on
Left side is straight
Right side is straight
No damage to roof and paint is great
Close up of RF fender damage. No paint missing. Dent repair said is fixable, I rec. new fender
Scuff on rear bumper cover. As mentioned, rec. respray
New breather system installed 6/25/10
#20
Anther possible trade?
I have an 00 Golf TDi- red, 2dr, black interior in pretty good condition. (probably about the same shape as the wagon)
newer trans, 20th an sus, all new suspension bushings, VR6 clutch, otherwise stock.
234k but runs like new, and is very tight.
In Buffalo, NY, I'd like a wagon for camping..
#21
Do you have any pictures of the car? And I am looking for a stock car because i want to do my own things to it. But also where do you live?
#22
No thanks. Thanks for the interest.
#24
Sent you a PM.
#25
The LIL' Guy next to it isn't included. LOL
BRA removed due to requests. Showing some Rash on cover. Rec. Respray. I do have Factory grills. Center one istalls w/o a problem. Side ones would need to be modified to fit but would be easy to do.
#26
not into champagne colored cars, but this is one of the nicest cleanest avants i have ever seen im speechless and if i had money i would buy it in a second
#27
Thank you. I hated the color at first but everyday I look at it and the more I like it. It seems to get a lot of compliments. It kind of has a classy look to it. And the belt line trim in the interior compliments it even more being almost the same color as the outside.![]()
#28
Scot, email me with your phone number. I've got the trip info together if you're ready to go. DO NOT PM the number, just email it. Had mine "used" by a web spider to send junk text message after leaving in a private PM here.
Michael
#29
Cluster with Boost gauge that changes 7 different colors
Electronic Boost controller located at knee bar and can see easily through spokes in steering wheel. Also changes 5 different colors, shows vac/boost in digital format. Peak boost, volt meter, etc...
Oil Pressure gauge in center location. Also changes 7 different colors.![]()
#30
All suspension work, sport springs, both transmission mounts and fixed baro sensor in ECU box. Now boosts 19-20 PSI. I knew this GIAC chip was capable of more. I'm starting to love this car.
#31
Then let's nail this deal down. I'll get on the road and make my way north. If those few things are out of the way, I'm all-in.
Presently, NOTHING on the Vortex I'd like to trade for more than your Avant...period! PM me, email me, call me....but let's roll it up....really.
