VWVortex.com - Does your Passat 'cruise' light in the dash do what it's supposed to? Yes? Pls answer this ?
    Results 1 to 13 of 13
    Thread: Does your Passat 'cruise' light in the dash do what it's supposed to? Yes? Pls answer this ?
      Feb 15th, 2008
      Madison, WI
      93 Rado, 97 teg, 93 prizm -- all for sale
      06-12-2010 10:10 AM #1
      My cruise doesn't work in my 98. I know this is common from a quick google search.
      I didn't get to watch it slowly die like it seems several people have. I bought it dead. What I'm wondering is there is a light in the cluster that says "cruise" or something when you switch in to "on" on the stalk. I don't mean actually setting a speed, but just powering the ability to set a speed with the on switch.
      I get nothing in the cluster and I'm wondering if my cruise just wont set... or if the device itself isn't even getting power. Just not sure where to start troubleshooting this one.
      Thanks all.
    2. Member BCinco's Avatar
      Dec 16th, 2006
      CT
      2010 GTI
      06-12-2010 02:06 PM #2
      My "Cruise" light does not work either. However, I can set the Cruise control and control the speed up and down via the stalk.
    3. Junior Member Gestalten Sie Wagen's Avatar
      Nov 10th, 2009
      Fort Riley KS
      99 B5 Wagon 1.8T
      06-12-2010 03:09 PM #3
      Same here... No cruise light on the instrument cluster, but my cruise control works fine.
    4. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      06-12-2010 04:51 PM #4
      There's no indicator at all on the B5. The B5.5 (2001.5 and up) has a green light to tell you the switch is on. It doesn't tell you if a speed is set, or anything else. Just that the switch is on.
    5. Member skennedy1023's Avatar
      Mar 4th, 2006
      Holland, MA
      1998 Passat GLS 1.8T 5 speed, 2003 Jetta GLS 1.8T
      06-12-2010 11:55 PM #5
      my cruise doesnt work either. i wanna try to fix that soon. it would be nice to have even though i wouldnt use it that much. i like to have control of the pedal but every now and then on longer trips it would be nice to move my right leg around for a minute or two. i am going to replace the switch first and see if that fixes it. if that doesnt work i am not sure what to try next.
    6. 06-13-2010 11:42 AM #6
      I have a B5, cruise control work's perfectly and their is no light indicator in the dash
    7. Member Steve in Chicago's Avatar
      Dec 13th, 2008
      Chicago, Illinois
      1999 Volkswagen Passat GLS
      06-14-2010 10:13 AM #7
      The Drive-By-Cable cars have a stand alone cruise control system consisting of the turn signal stalk controls, a control module that lives behind the glove box, vacuum vent switches on the brake and clutch pedals, a vacuum pump under the hood near the ABS pump, a vacuum diaphragm that moves the throttle plate.
      The Drive-By-Wire cars have the turn signal stalk controls and the rest of the cruise control is incorporated into the DBW system and controlled by the ECM.
      Here is some good info on the earlier DBC systems... http://www.passatworld.com/forums/sh...d.php?t=279901
    8. Member 4ePikanini's Avatar
      Aug 29th, 2007
      South Africa, East London
      2005 Touareg R5
      06-14-2010 10:48 AM #8
      I have an early B5 (not 5.5) and my light lights up on the tachometer next to the fog light indicator when I switch the stalk to the "ON" position.
      I am in South Africa though.
      it is a 1.8T
      The cluster
      the stalk
      my install - http://www.passatworld.com/forums/sh...d.php?t=311804
      Karma's Law - For every action there is a multiplied reaction!
      1993 Mitsu Pajero GLS 3.0 V6 LWB - SOLD
      2000 VW Passat 1.8T - SOLD
      2001 Gen3 Pajero Di-D LWB
    9. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      06-14-2010 11:12 AM #9
      Quote Originally Posted by fourie_marius View Post
      Yes, the light is enabled on cars sold outside the United States. Users who have swapped in a european instrument cluster report the indicator working. I guess the Germans figured all the little lights would confuse us poor 'mericans.
    10. Member 4ePikanini's Avatar
      Aug 29th, 2007
      2005 Touareg R5
      06-14-2010 12:16 PM #10
      Quote Originally Posted by scotts13 View Post
      I suppose you guys get all the "bongs" as Jeremy Clarkson calls them. Those "bongs" confuse the hell outta us!
    11. Member scotts13's Avatar
      Feb 15th, 2007
      Lehigh County, Pa.
      2004 GLS 1.8T
      06-14-2010 02:37 PM #11
      Yeah. The strident "OMG, you're almost out of washer fluid!" warning makes me jump every time. I wonder how many people crash their cars, taking their eyes off the road to see if the chime is for "low washer fluid" or "engine being destroyed"?
    12. Member Steve in Chicago's Avatar
      Dec 13th, 2008
      Chicago, Illinois
      06-14-2010 07:26 PM #12
      You also have the DBW (or E-gas) throttle system. What year is your car and what engine code is your 1.8?
    13. Member 4ePikanini's Avatar
      Aug 29th, 2007
      2005 Touareg R5
      06-15-2010 04:05 AM #13
      Quote Originally Posted by Steve in Chicago View Post
      2000 model
      APU engine code.
