VWVortex.com - replacing valve guides
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 32
    Thread: replacing valve guides
    1. 06-13-2010 09:33 PM #1
      so apparently i need new valve guides in the head I bought used on here, a head that was supposed to be ready to swap in. Anyways, anyone know where to buy them, and how much a machine shop would charge to replace them?
    2. 06-13-2010 10:10 PM #2
      ok i found them pretty easily on multiple sites, im not sure why I couldnt find them before. And they dont look like they are pressed in, The machine shop told me they were. Maybe I should find a different machine shop. Anyone know of any in S. Florida?
    3. Member Scotty_2.0's Avatar
      Jan 13th, 2005
      London, Ont.
      Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
      06-13-2010 10:51 PM #3
      Quote Originally Posted by 98ginster View Post
      The valve guides are pressed in. Removing them can sometimes be a PITA and may require cutting rather than a simple air hammer. Installation is usually straight forward with a specially designed driver and an air hammer.
      /// VRSociety Member #298 /// bankrupt ///
    4. 06-14-2010 03:10 PM #4
      Ok, i saw what looked like threads on the guides in the pictures for the ones for sale online, thats why I didnt think they were pressed in. Does anyone know the approximate cost to have a machine shop replace them? The machine shop I went to didnt give me a price, they just said its expensive
    5. Banned dubbinmk2's Avatar
      Jan 15th, 2008
      planet earth
      A2 86 Golf
      06-14-2010 03:22 PM #5
      wtf? hhahah it's just expensive with no price
      people are lazy
    6. Member rhussjr's Avatar
      Aug 7th, 2000
      Charlotte, NC
      1992 Jetta GLI 16V Project / 1981 Caddy 2.0 build
      06-14-2010 03:58 PM #6
      On average, most shops charge about $5-8 a guide to replace them. It is a simple process to remove them, just installing them can be tricky if the new guides do not have a lip on them.
    7. Member manfredwerner's Avatar
      Jan 29th, 2007
      staten island/brooklyn
      06-15-2010 12:54 AM #7
      yeah, never trust the texers, all parts have some surprizes...
    8. Junior Member
      May 15th, 2010
      Locust Grove, Ga
      2000 Jetta VR6
      06-15-2010 11:11 AM #8
      I had new guides and valves installed (after chain broke) in ga and i spent a little under $600.
    9. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      06-15-2010 11:33 AM #9
      If you plan to run anything but stock cams, the replacement guides need to be machined and then pressed to depth.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    10. 06-15-2010 02:00 PM #10
      yea i have a set of schrick 268's to put in. It seems like no one down here really does any work on these heads, especially for performance, so I feel kind of skeptical letting anyone work on it.
    11. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      Mk3 VRT, Mk4 VRT, Mk4 VRT, Mk4 VR, A3 VR, B6 3.6 4Motion, B5 1.8T
      06-15-2010 07:49 PM #11
      Where in South Fl are you located? There are numerous good machine shops around.
    12. 06-16-2010 01:24 PM #12
      ft lauderdale, I'd like to find a flow bench also, since I did some mild porting on the head.
    13. Member V-dubbulyuh's Avatar
      Nov 13th, 2005
      06-16-2010 05:22 PM #13
      You got PM.
    14. Member 92jetta9a's Avatar
      Apr 3rd, 2007
      Chicago Burbs
      97 GTI
      06-18-2010 06:27 PM #14
      need_a_VR6
      is there any specs on the machining? are they cam specific?
    15. Member Grabbit's Avatar
      Apr 27th, 2001
      WA
      Mk1, Mk2, Mk6, SR5 4x4
      06-18-2010 07:45 PM #15
      search some other makes forums in your area, most good machine shops don't really need to advertise, good work is word of mouth, especially true in the internet/forum era.........
    16. 06-29-2010 01:45 PM #16
      thanks for the replies. The head is at a well known shop over here in plantation, but they are asking me if I want to replace the guides, or do a ream/knurl job on them. Does the latter work for high lift cams or is that more for heads with stock internals?
    17. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      04 R32, 83 Gti, 85 Golf 2dr Diesel, 90 1Z Corrado, 91 G60, 92 SLC, 96 1Z B4, 99.5 Golf 2 dr, Eurovan
      06-29-2010 05:33 PM #17
      Quote Originally Posted by need_a_VR6 View Post
      need_a_VR6 If I am correct this only goes for high lift cams. Non agressive cams wont cause the valve retainer to bottom out into the valve guide seal. Did you run into some issues on your motors with crushed stem seals?
    18. 06-29-2010 10:58 PM #18
      im just going to tell them to do the new guides. They are telling me its going to need a valve job because the valve center will most likely change. Does this sound right? There was a 3 angle valve job already done not too long ago and would rather keep the $250 for other things.
    19. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      06-29-2010 11:36 PM #19
      it is possible that the valve center will change due to the guide going in slighly off from what they were.
    20. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      06-30-2010 09:38 AM #20
      How do you know that the head needs valve guides? The last 8v head I got on vortex was said to need valve guide and I found that the seal was bad.
    21. 06-30-2010 11:18 AM #21
      Thats what numerous people said since the valves had so much play in the guides, it was also leaking but like you said it could be just the seals
    22. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      06-30-2010 12:12 PM #22
      Quote Originally Posted by vwscream View Post
      Yes, tried using 'as is' replacement guides and wasted all 12 stem seals. Machined the lip off new guides, installed, fixed.
      For anything but STOCK rebuilds, do the guide mods.
      -Paul
    23. Member vwscream's Avatar
      Jan 27th, 2008
      Chicago Suburbs
      06-30-2010 02:56 PM #23
      I would be fine than with the autotech cams.
    24. Member dogyouare's Avatar
      Aug 9th, 2009
      Port Orange, FL
      90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
      06-30-2010 03:43 PM #24
      ok just going to say this....
      guid is pressed in...
      to remove u need to clean it so that carbon dont harm the head.
      the punch/grill out
      pressed in
      then u need to reseat the valves because it will change the how the valve sits.
      now to tell ezly if u need to change the guid.
      get the valve out little bit jiggle it to see if it moves. if it does then yes u need to get new one. if it does not move or move next to nothing then dont worry.
    25. Member notldubber's Avatar
      May 3rd, 2008
      Niagara on the Lake, Canada
      1987 vw scirocco,1991 golf 20v, Passat CC
      06-30-2010 03:56 PM #25
      I just had guides replaced aswell as had my valves polished and got the seats re-cut for 280 taxes in.
