VWVortex.com - How to break into a Mk4 golf?
    Results 1 to 19 of 19
    Thread: How to break into a Mk4 golf?
    1. 06-15-2010 09:33 PM #1
      I'm dealing with the perfect storm with this car....
      The battery is dead.
      The battery in my key also died.
      The manual door lock is not working properly. The lock turns properly, but the door won't unlock.
      My lock on the hatch has been broken for some time, it works using the unlock button inside the car, but not with the key (manually unlocking the door).
      So.... how do I get into the car? Aside from breaking a window with a hammer.
      I have replaced the battery in the key but it won't unlock the car (because the car battery is dead?)
      This is winter car so it has been sitting for about a month. I wanted to take it for a ride last Sunday and instead found myself in the eye of the storm.
      Any help would be greatly appreciated.
    2. Member LB6X's Avatar
      Jul 7th, 2009
      06-15-2010 09:39 PM #2
      AAA?
    3. Member sdavis872's Avatar
      Aug 20th, 2009
      Omaha, NE
      2003 VW Passat W8 6 speed
      06-15-2010 09:43 PM #3
      Call a lock smith.... maybe?
      \\_\__\___http://lowdownlabs.com/ ___/__/_//
      Passat W8 Sport 6 speed manual
      BC Racing Coilovers | Avant Garde M550 19x9.5 | Delinte Thunder D7 245 35 19 | COAM
      SpeedTuning USA Stage 2 | B6 S4 calipers | S5 rotors | Stop Tech Pads
    4. Member iamhollybear's Avatar
      Mar 5th, 2010
      St. Pete, FL
      00 Tropic GTI VR6
      06-15-2010 10:10 PM #4
      Quote Originally Posted by sdavis872 View Post
      this??
      it is their job to get you into your locked car right?
      VRSociety Member #32
      Female Driven
      I wonder what it must be like to be such a badass chick.
    5. Member bboy_jon's Avatar
      Jan 19th, 2010
      Columbia, MO
      2002 1.8t GTI
      06-15-2010 10:17 PM #5
      You can always break the window?
      or use a hangar or slim jim
      Have you tried manually unlocking the other doors with the key?
    6. Awaiting Email Confirmation
      Dec 29th, 2008
      Erie, Pa / Motown
      ..a Volkswagen
      06-15-2010 10:21 PM #6
      See if one of your friends has AAA, and have them say they were driving your car. They're good at what they do.
      Jul 19th, 2009
      MA
      E46
      06-15-2010 10:29 PM #7
      You can call your local police department to and they'll come and unlock it with a slim jim thing or whatever the hell its called. I don't understand how the key won't manually unlock the doors though.
      Quote Originally Posted by Braga_Dub View Post
      When the Earths normal shift in plate tectonics causes you to scrape while parked. You are almost low enough.
    8. Member Zyoid's Avatar
      Feb 25th, 2008
      Hudsonville, MI
      2012 VW Golf TDI, 2010 Mazda 3 S Sport
      06-15-2010 10:56 PM #8
      Tow it to the ghetto, or use one of these:
    9. Junior Member Nek011's Avatar
      Dec 31st, 2008
      Allentown Pa
      2000 gti vr6
      06-15-2010 11:21 PM #9
      you can try jumper cables might jut give you enough juice to unlock it
    10. Member 337forYa's Avatar
      Apr 13th, 2010
      endangered dub area
      OEM+ 337
      06-15-2010 11:24 PM #10
      pry the door open with a wedge of some sort and use a hanger... thats what AAA does but then again they do have more experience at it but ive done it befoer just takes a little patience
      Member since 04
      Post count DOES NOT get you laid
      OEM + FTW
    11. Member jtrujillo86's Avatar
      Aug 21st, 2005
      Denver, CO
      2016 Jetta 1.8T SEL, 2016.5 Mazda CX-5 Touring, 2002 Passat GLX V6 4Motion
      06-15-2010 11:37 PM #11
      Good luck...at least with the MKVs, you can't slim jim 'em.
      - Jeremy.
      Quote Originally Posted by BluMagic View Post
      It's a VW; the sensors are as sensitive as women on that time of the month . . . and the dash is as anxious to light up as a stoner.
    12. Member ECR32's Avatar
      Aug 13th, 2006
      CT
      R32T , FA civic
      06-15-2010 11:44 PM #12
      Flat head screw driver, hammer it into the lock cylinder, pull and voila
    13. Member AtomixMK3's Avatar
      Apr 6th, 2010
      Palm Springs/Redlands, CA
      1989 VW GTI 16v (W.I.P), 1998 VW Jetta 2.0 (Totalled), 2001 VW GTI 1.8t
      06-15-2010 11:46 PM #13
      Call up a locksmith. The MKVs can be done but you dont use a slim jim as they've most likely put a cover where the slim jim would normally grab a hold of you'd use specially bent entry tools. Swap batteries with someone for a few minutes and buy a remote battery they're like 3 bucks.
    14. Banned
      Oct 23rd, 2008
      Garden City, NY
      BT 20th GTI
      06-15-2010 11:48 PM #14
      Quote Originally Posted by Nek011 View Post
      retard how would that work if he cant get in the car to open the hood.
      op, coat hanger or a prayer or AAA
    15. Member Dutchmastr9's Avatar
      Sep 13th, 2004
      Boston
      2 Door bugatti coupe...er, i mean Golf Racecar
      06-15-2010 11:50 PM #15
      Quote Originally Posted by ECR32 View Post
      Unfortunately, yes it is theta easy
      You Aint About That Life | ETYolo
      Ruined Blue Golf | 42 Draft Designs
    16. Member onevrsix's Avatar
      May 27th, 2010
      Philly Area
      2013 CC, 2008 yzf-R1, 01 yzf-600r
      06-15-2010 11:55 PM #16
      everyone is saying coat hanger or plyers, but his battery is dead, He'll have to grab the handle and push it out...don't thin thats pos. I had a hard enough time getting the hanger to roll the window down when i locked my keys in my car with the car running. buddy, its looking like your gonna have to call a lock smith or pony up and smash that rear corner window. also yo could try and activate the airbags, doors automatically unlock then but that may be your most expensive option.
    17. Member psone8t's Avatar
      Oct 2nd, 2009
      SJ
      06-16-2010 12:17 AM #17
      If you dont want to use a hammer to break the window what ever you do dont wedge the door open then unlock it and pull on the handle the way the door will flex will shatter the window.. wedge it open, unlock, take wedge out then pull handle..
      VW + anything = CEL
      Buy my car $7,000
    18. 06-16-2010 12:18 AM #18
      I locked my keys in the rear hatch before(because it auto locked on me). So i took a coat hanger/steel wire and a door wedge and wedged the top corner of the door enough to stick a coat hanger inside the car and i pulled the door handle open from the inside, took me about 30 minutes but it worked. The alarms went off too
    19. Member ornithology's Avatar
      May 6th, 2009
      Vancouver, BC
      2004.5 MKIV GLI O2M
      06-16-2010 01:43 AM #19
      Lock this thread already?
