Results 1 to 11 of 11
Thread: FS: VR6 Swap, Complete
  1. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    81 itb abf, 83 surprise
    06-19-2010 07:13 PM #1
    SOLD
    This is the most complete swap you will find.
    I parted out a running mk3 jetta last summer and kept all of the vr6 swap parts for a project. Well, that project is on a bit of a delay, and I need to clear out some space in the garage.
    This is a running swap with about 100k miles on it. It drove great when I took it out of the donor. The only reason the car was parted out was a smashed rear end, the motor was completely unharmed. The chains have not been done, but were making no noise when the motor was removed.
    I meticulously removed the wiring, and labeled EVERY connector as I took it out. This was a long and tedious process, and will save you a ton of time and guesswork when you do your swap.
    Included in the sale:
    Complete 12v OBD1 vr6 engine
    5-speed manual trans
    Shifter, cables, etc
    Complete front axles with brakes, etc
    Front subframe
    Core support
    Complete, labeled wiring harness
    ECU
    Cluster
    Pedal assembly
    Radiator
    Rear beam, brakes, etc (sans spindles)
    NO SAI, removed for more hp's
    and almost everything else from under the hood.
    I'm not trying to make money off of this, I'd really like to see it go to a good project car.
    $850 obo
    SOLD
  2. Member ekua516's Avatar
    Feb 28th, 2008
    GREENWICH CT
    1mk2/2mk3/1mkiv all jettas.....
    06-20-2010 10:21 AM #2
    damn dude...just what i was looking for but too damn far and good work labeling everything.good luck with the sell
  3. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    06-23-2010 12:19 PM #3
    up top
    MIVE
    where I am is not where I was
  4. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    07-08-2010 04:41 PM #4
    replied to PM's
    MIVE
  5. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    07-11-2010 07:16 PM #5
    up
    MIVE
  6. Member corr-audi's Avatar
    Oct 6th, 2009
    90 rado g60, bmw 325is(still own both)
    07-12-2010 08:51 AM #6
    iv been looking around and thad be nice for my corrado, and good price, im not back in US till august though
  7. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    07-12-2010 07:03 PM #7
    Quote Originally Posted by corr-audi View Post
    Who knows, it might still be around. Where do you live?
    MIVE
  8. Member corr-audi's Avatar
    Oct 6th, 2009
    07-13-2010 10:12 AM #8
    around youngstown OH area
  9. Junior Member petergiarrizzo's Avatar
    May 31st, 2010
    Brampton, ON, Canada
    1996 Golf CL
    07-14-2010 02:55 PM #9
    So for sale is a Full and complete VR6 Swap for a mk3 jetta? will this work for my golf? or will the subframe not fit? im driving a '96 golf CL (4 door, if it makes a difference, a 1.8L motor) let me know if this will be a direct fit and install. Thanks
  10. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    07-19-2010 07:56 PM #10
    Quote Originally Posted by petergiarrizzo View Post
    The subframe should bolt right up. Since you're swapping mk3 goods into a mk3 it should be very straightforward.
    MIVE
  11. Member goofydug's Avatar
    Feb 5th, 2004
    dtw
    07-20-2010 02:03 PM #11
    SOLD
    MIVE
